UPTF0805-10W-P-1472BT
    VENKEL
    14.7KΩ ±0.1%
UPTF0805-10W-P-1472BT 数据手册
UPTF SERIES ULTRA PRECISION THIN FILM RESISTORS FEATURES: • TCR as low as ±2ppm • Excellent characteristics at higher frequencies • Tolerance as low as ±0.01% PART NUMBER STRUCTURE UPTF 0805 - 10W Series Size 0402 0603 0805 1206 1210 2010 2512 Power Rating 16W = 0.063W 10W = 0.10W 8W = 0.125W 5W = 0.20W 4W = 0.25W 2W = 0.50W - P - TCR 2 = ±2ppm/˚C 3 = ±3ppm/˚C P = ±5ppm/˚C N = ±10ppm/˚C E = ±25ppm/˚C 1001 A T ☐ Resistance Code 1001 = 1kΩ 39R9 = 39.9Ω 49R9 = 49.9Ω Tolerance U = ±0.01% A =±0.05% B = ±0.1% C = ±0.25% D = ±0.50% Packaging T = Tape & Reel Optional Reel Identifier Leave blank for standard quantity. Add "-1K" if 1000 piece reel is required Example P/N: UPTF0805-10W-P-1001AT Standard Termination is 100% matte Tin over Nickel. DIMENSIONS Unit: inches (mm) L W ι ι 1 ι 2 L W T ι1 ι2 0402 0.040 ± 0.002 (1.0 ± 0.05) 0.020 ± 0.002 (0.5 ± 0.05) 0.014 ± 0.002 (0.35 ± 0.05) 0.008 ± 0.004 (0.2 ± 0.10) 0.008 ± 0.004 (0.2 ± 0.10) 0603 0.063 ± 0.008 (1.6 ± 0.20) 0.031 ± 0.008 (0.8 ± 0.2) 0.017 ± 0.004 (0.45 ± 0.10) 0.010 ± 0.006 (0.25 ± 0.15) 0.010 ± 0.006 (0.25 ± 0.15) 0805 0.079 ± 0.008 (2.0 ± 0.20) 0.050 ± 0.008 (1.25 ± 0.20) 0.021 ± 0.004 (0.55 ± 0.10) 0.016 ± 0.008 (0.4 ± 0.20) 0.012 ± 0.008 (0.3 ± 0.20) 1206 0.126 ± 0.008 (3.2 ± 0.20) 0.063 ± 0.008 (1.6 ± 0.20) 0.021 ± 0.004 (0.55 ± 0.10) 0.018 ± 0.008 (0.45 ± 0.20) 0.012 ± 0.008 (0.3 ± 0.20) 1210 0.126 ± 0.008 (3.2 ± 0.20) 0.098 ± 0.006 (2.50 ± 0.15) 0.021 ± 0.004 (0.55 ± 0.10) 0.018 ± 0.008 (0.45 ± 0.20) 0.012 ± 0.008 (0.3 ± 0.20) 2010 0.197 ± 0.008 (5.0 ± 0.20) 0.098 ± 0.006 (2.50 ± 0.15) 0.021 ± 0.004 (0.55 ± 0.10) 0.236 ± 0.012 (0.60 ± 0.30) 0.02 ± 0.010 (0.50 ± 0.25) 2512 0.248 ± 0.008 (6.30 ± 0.20) 0.122 ± 0.006 (3.10 ± 0.15) 0.021 ± 0.004 (0.55 ± 0.10) 0.236 ± 0.012 (0.60 ± 0.30) 0.02 ± 0.010 (0.50 ± 0.25) 1 T ι SIZE (INCHES) 2 STRUCTURE 3 5 4 1 6 87 1 Ceramic Substrate 5 Nickel Plating 2 Backside Electrode 6 Tin Plating 3 Top Electrode 7 Resistive layer 4 Edge Electrode 8 Overcoat 2 1 Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 07/2020-A 1 UPTF SERIES ULTRA PRECISION THIN FILM RESISTORS ELECTRICAL SPECIFICATION & RANGE Tolerance 0.01% (U) 0.05% (A) 0.10% (B) 0.25% (C) 0.50% (D) SIZE 0402 0603 0805 1206 1210 2010 2512 Power Rating at 70°C (W) 0.063W (1/16W) 0.063W (1/16W) 0.10W (1/10W) 0.125W (1/8W) 0.20W (1/5W) 0.25W (1/4W) 0.50W (1/2W) Max. Working Voltage 25V 50V 100V 150V 150V 150V 150V Max. Overload Voltage 50V 100V 200V 300V 300V 300V 300V Operating Temp. Range -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C TCR Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range ±2ppm (2) 49.9Ω - 4.99KΩ 24.9Ω - 15KΩ 24.9Ω - 30KΩ 24.9Ω - 49.9KΩ 24.9Ω - 49.9KΩ 24.9Ω - 100KΩ 24.9Ω - 100KΩ ±3ppm (3) 49.9Ω - 4.99KΩ 24.9Ω - 15KΩ 24.9Ω - 30KΩ 24.9Ω - 49.9KΩ 24.9Ω - 49.9KΩ 24.9Ω - 100KΩ 24.9Ω - 100KΩ ±5ppm (P) 49.9Ω - 20KΩ 24.9Ω - 60KΩ 24.9Ω - 150KΩ 24.9Ω - 300KΩ 24.9Ω - 300KΩ 24.9Ω - 300KΩ 24.9Ω - 300KΩ ±10ppm (N) 49.9Ω - 20KΩ 24.9Ω - 100KΩ 24.9Ω - 200KΩ 24.9Ω - 499KΩ 24.9Ω - 499KΩ 24.9Ω - 499KΩ 24.9Ω - 499KΩ ±2ppm (2) 49.9Ω - 20KΩ 24.9Ω - 15KΩ 24.9Ω - 30KΩ 24.9Ω - 49.9KΩ 24.9Ω - 49.9KΩ 24.9Ω - 100KΩ 24.9Ω - 100KΩ ±3ppm (3) 49.9Ω - 4.99KΩ 24.9Ω - 15KΩ 24.9Ω - 30KΩ 24.9Ω - 49.9KΩ 24.9Ω - 49.9KΩ 24.9Ω - 100KΩ 24.9Ω - 100KΩ ±5ppm (P) 49.9Ω - 4.99KΩ 24.9Ω - 60KΩ 2.49Ω - 150KΩ 24.9 - 300KΩ 24.9Ω - 300KΩ 24.9Ω - 300KΩ 24.9Ω - 300KΩ ±10ppm (N) 49.9Ω - 20KΩ 4.7Ω - 332KΩ 4.7Ω - 1MΩ 4.7Ω - 1.5MΩ 4.7Ω - 1MΩ 4.7Ω - 1MΩ 4.7Ω - 1MΩ ±25ppm (E) 49.9Ω - 20KΩ 4.7Ω - 511KΩ 4.7Ω - 1MΩ 4.7Ω - 1.5MΩ 4.7 -1MΩ 4.7Ω - 1MΩ 4.7Ω - 1MΩ ±2ppm (2) 49.9Ω - 4.99KΩ 24.9Ω - 15KΩ 24.9Ω - 30KΩ 24.9Ω - 49.9KΩ 24.9Ω - 49.9KΩ 24.9Ω - 100KΩ 24.9Ω - 100KΩ ±3ppm (3) 49.9Ω - 4.99KΩ 24.9Ω - 15KΩ 24.9Ω - 30KΩ 24.9Ω - 49.9KΩ 24.9Ω - 49.9KΩ 24.9Ω - 100KΩ 24.9Ω - 100KΩ ±5ppm (P) 49.9Ω - 20KΩ 24.9Ω - 60KΩ 24.9Ω - 150KΩ 24.9 - 300KΩ 24.9Ω - 300KΩ 24.9Ω - 300KΩ 24.9Ω - 300KΩ ±10ppm (N) 49.9Ω - 100KΩ 4.7Ω - 511KΩ 4.7Ω - 1MΩ 4.7Ω - 1.5MΩ 4.7Ω - 1MΩ 4.7Ω - 1MΩ 4.7Ω - 1MΩ 24.9Ω - 300KΩ ±5ppm (P) 49.9Ω - 20KΩ 24.9Ω - 60KΩ 24.9Ω - 150KΩ 24.9 - 300KΩ 24.9Ω - 300KΩ 24.9Ω - 300KΩ ±10ppm (N) 49.9Ω - 100KΩ 4.7Ω - 511KΩ 4.7Ω - 1MΩ 4.7Ω - 1.5MΩ 4.7Ω - 1MΩ 4.7Ω - 1MΩ 4.7Ω - 1MΩ ±5ppm (P) 49.9Ω - 20KΩ 24.9Ω - 60KΩ 24.9Ω - 150KΩ 24.9 - 300KΩ 24.9Ω - 300KΩ 24.9Ω - 300KΩ 24.9Ω - 300KΩ ±10ppm (N) 49.9Ω - 100KΩ 4.7Ω - 511KΩ 4.7Ω - 1MΩ 4.7Ω - 1.5MΩ 4.7Ω - 1MΩ 4.7Ω - 1MΩ 4.7Ω - 1MΩ NOTE: Overload Voltage=2.5*√(P*R). MARKING CODE E-24 values for 0603 size maybe marked with the standard 3 digit marking code. E-96 values for 0805 size and larger, will be marked with standard 4 digit marking code. E-24 values for 0603 size and larger, will be marked with standard 3 digit marking code. 0603 - E-96 values will be marked with a standard 3 digit alpha numeric code Please see 0603 marking codes PDF. Note: 0402 cannot be marked. DERATING CURVE Rated power (%) 120 100 80 60 40 20 0 -50 -55 -25 0 25 50 75 70 100 125 150 175 Ambient temperature (˚C) Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 07/2020-A 2 UPTF SERIES ULTRA PRECISION THIN FILM RESISTORS REEL SPECIFICATIONS F Label Unit: mm (inch) H M C E C E F G H M 13.0 ± 0.2 (0.51 ± 0.008) 60.0 ± 1.0 (2.36 ± 0.03) 11.4 ± 1.0 (0.45 ± 0.04) 9.0 ± .3 (0.35 ± 0.012) 1.5 ± .3 (0.06 ± 0.012) 180 ± 2.0 (7.09 ± 0.08) Minimum of 30 empty pockets at the beginning of reel, 65 minimum empty pockets at the end. G TAPE SPECIFICATIONS T G B A W F T J Dø Embossed H Paper E Units: mm (inches). TAPE Paper SIZE A B W E F T G H J DØ 0402 1.16 ±0.10 0.70 ±0.10 8.0 ±0.10 1.75 ±0.05 3.50 ±0.05 0.40 ±0.03 2.00 ±0.05 4.00 ±0.10 2.00 ±0.05 1.55 ±0.05 0603 1.90 ±0.10 1.10 ±0.05 8.0 ±0.10 1.75 ±0.05 3.50 ±0.05 0.60 ±0.03 4.00 ±0.10 4.00 ±0.10 2.00 ±0.05 1.55 ±0.05 0805 2.37 ±0.20 1.60 ±0.05 8.0 ±0.10 1.75 ±0.05 3.50 ±0.05 0.75 ±0.05 4.00 ±0.10 4.00 ±0.10 2.00 ±0.05 1.55 ±0.05 1206 3.55 ±0.05 2.00 ±0.05 8.0 ±0.10 1.75 ±0.05 3.50 ±0.05 0.75 ±0.05 4.00 ±0.10 4.00 ±0.10 2.00 ±0.05 1.55 ±0.05 1210 3.40 ±0.05 2.75 ±0.05 8.0 ±0.10 1.75 ±0.05 3.50 ±0.05 0.75 ±0.05 4.00 ±0.10 4.00 ±0.05 2.00 ±0.05 1.60 ±0.10 2010 5.45 ±0.10 2.85 ±0.10 12.00 ±0.10 1.75 ±0.10 5.50 ±0.05 1.00 +0.20, -0 4.00 ±0.10 4.00 ±0.05 2.00 ±0.05 1.50 +0.1, -0 2512 6.65 ±0.10 3.40 ±0.10 12.00 ±0.10 1.75 ±0.10 5.50 ±0.05 1.00 +.02.0, -0 4.00 ±0.10 4.00 ±0.05 2.00 ±0.05 1.50 +0.1, -0 Embossed PEEL BACK FORCE AND DIRECTION DIAGRAM Direction of pull Top cover tape Carrier tape Peel back force and direction of peel back angle should follow EIA481-1-A. Peel back force should be between 0.1N – 1.3N and peel back angle of 165˚ – 180˚. 165 ~ 180˚ Direction of unreeling Bottom cover tape Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 07/2020-A 3 UPTF SERIES ULTRA PRECISION THIN FILM RESISTORS ENVIRONMENTAL CHARACTERISTICS REQUIREMENT TEST Tol. ≤0.05% Temperature Coefficient of Resistance (T.C.R.) Short Time Overload TEST METHOD Tol. >0.05% MIL-STD-202 Method 304 +25/-55/+125/+25°C As Spec. ΔR±0.05% ΔR±0.2% JIS-C-5201-1 4.13 RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds ΔR±0.2% for high power rating Insulation Resistance MIL-STD-202 Method 302 Apply 100VDC for 1 minute >9999MΩ ΔR±0.05% ΔR±0.2% ΔR±0.5% for high power rating MIL-STD-202 Method 108A 70±2°C RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” Endurance 0201:>7kΩ→ ΔR±0.5% ≤7kΩ→ ΔR±0.2% Damp Heat with Load Bending Strength Solderability Resistance to Soldering Heat ΔR±0.05% ΔR±0.3% ΔR±0.5% for high power rating ΔR±0.05% JIS-C-5201-1 4.33 Bending amplitude 3mm for 10 seconds 2010 / 2512 sizes: 2mm Other sizes: 3mm ΔR±0.1% MIL-STD-202 Method 208H 245±5°C for 3 seconds 95% min. coverage ΔR±0.05% MIL-STD-202 Method 210E 260±5°C for 10 seconds ΔR±0.1% Dielectric Withstanding Voltage Low Temperature Operation MIL-STD-202 Method 103B 40±2°C 90~95% R.H. RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” MIL-STD-202 Method 301 Max. Overload Voltage for 1 minute By Type ΔR±0.05% ΔR±0.2% JIS-C-5201-1 4.36 1 hour, -65°C, followed by 45 minutes of RCWV ΔR±0.5% for high power rating High Temperature Exposure MIL-STD-202 Method 108 at +155°C for 1000 hrs ΔR±0.5% RCWV (Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. Storage Temperature: 15~28°C; Humidity: < 80%RH Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 07/2020-A 4
- 温度系数(TCR)低至±2ppm - 高频特性优异 - 容差低至±0.01% - 符合RoHS和REACH标准,无卤素冲突矿物
物料型号结构为UPTF,提供0402、0603、0805、1206、1210、2010和2512等尺寸,功率等级从0.063W至16W不等,TCR值从±2ppm至±25ppm,容差从±0.01%至±0.50%。
封装信息包括尺寸、长度、宽度、厚度等,标准端子为100%亚光锡覆盖镍。
电气规格和范围详细列出了不同尺寸的最大功率、最大工作电压、最大过载电压和工作温度范围。
标记代码说明了0603尺寸的E-24值可能使用标准的3位数字标记代码,而0805尺寸及以上的E-96值将使用标准的4位数字标记代码。
环境特性包括电阻的温度系数、短时间过载、绝缘电阻、耐久性、湿热带负载、弯曲强度、焊接性和耐焊接热、介质耐压、低温运行和高温暴露等测试要求和方法。
此外,还提供了卷轴规格和胶带规格的详细信息。
UPTF0805-10W-P-1472BT 价格&库存
很抱歉,暂时无法提供与“UPTF0805-10W-P-1472BT”相匹配的价格&库存,您可以联系我们找货
