HPCR0402-R-2003FT
HPCR0402-R-2003FT
    VENKEL
    电阻器 200KΩ ±1% 1/8W ±100ppm/℃ 0402
HPCR0402-R-2003FT 数据手册
HPCR SERIES HIGH POWER RESISTORS FEATURES: • Available Sizes 0402 to 1210 • Values from 1Ω to 1MΩ, plus 0Ω Jumper • TCR as low as ±100PPM • Good power dissipation capabilities • 100% matte Tin over Nickel with wrap around termination for excellent solderability PART NUMBER STRUCTURE HPCR 1210 Series Size 0402 0603 0805 1206 1210 - W - Power Rating R = 1/8W (0.125W) T = 1/4W ( 0.25W) U = 1/3W (0.33W) V = 1/2W (0.50W) W = 3/4W (0.75) - 103 J T Resistance Value Tolerance F = ± 1% J = ± 5% Packaging T = Tape & Reel 3 DIGIT (J TOL.) 2R2=2.2Ω 103=10KΩ 4 DIGIT (F TOL.) 10R2=10.2Ω 1002=10KΩ ☐ Optional Reel Identifier Leave blank for standard quantity. Add “-13” if 13” Reel is required Example P/N: HPCR1210-W-103JT Standard Termination is 100% matte Tin over Nickel. DIMENSIONS Unit: inches (mm) L W C2 C1 T C1 SIZE L W T C1 C2 0402 0.040 ± 0.002 (1.0 ± 0.05) 0.020 ± 0.002 (0.5 ± 0.05) 0.014 ± 0.002 (0.35 ± .05) 0.008 ± 0.004 (0.2 ± 0.1) 0.008 ± 0.004 (0.2 ± 0.1) 0603 0.063 ± 0.004 (1.6 ± 0.1) 0.031 ± 0.004 (0.8 ± 0.1) 0.018 ± 0.004 (0.45 ± 0.1) 0.012 ± 0.007 (0.30 ± 0.20) 0.012 ± 0.007 (0.30 ± 0.20) 0805 0.079 ± 0.006 (2.0 ± 0.10) 0.050 ± 0.003 (1.25 ± 0.10) 0.019 ± 0.003 (0.50 ± 0.10) 0.014 ± 0.007 (0.35 ± 0.20) 0.015 ± 0.007 (0.40 ± 0.20) 1206 0.122 ± 0.003 (3.10 ± 0.10) 0.061 ± 0.003 (1.55 ± 0.10) 0.021 ± 0.003 (0.55 ± 0.10) 0.020 ± 0.009 (0.50 ± 0.25) 0.020 ± 0.008 (0.50 ± 0.20) 1210 0.122 ± 0.003 (3.10 ± 0.10) 0.10 ± 0.006 (2.60 ± 0.15) 0.021 ± 0.003 (0.55 ± 0.10) 0.020 ± 0.009 (0.50 ± 0.25 0.020 ± 0.008 (0.50 ± 0.20) C2 STRUCTURE 3 8 4 1 6 7 9 5 1 Alumina Substrate 6 Primary Coating 2 Backside Electrode 7 Protective Coating 3 Top Electrode 8 Barrier Layer (Ni) 4 Edge Electrode 9 Termination 100% matte Tin 5 Resistive layer 10 Marking 2 1 Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 03/2021-A 1 HPCR SERIES HIGH POWER RESISTORS ELECTRICAL SPECIFICATION & RANGE SIZE 0402 0603 0805 1206 1210 Power Rating at 70°C (W) 0.125W (1/8W) 0.25W (1/4W) 0.33W (1/3W) 0.50W (1/2W) 0.75W (3/4W) Max. Working Voltage — √ PR or 50V whichever is less — √ PR or 75V whichever is less — √ PR or 150V whichever is less — √ PR or 200V whichever is less — √ PR or 200V whichever is less Operating Temp. Range -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C Zero Ohm (Jumper) Current Rating 1.5A 2A 2.5A 3.5A 4.5A Zero Ohm (Jumper) Resistance 20 mΩ (max) 20 mΩ (max) 20 mΩ (max) 20 mΩ (max) 20 mΩ (max) Tolerance TCR Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range ±100ppm 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ ±200ppm 1Ω - 9.76Ω 1Ω - 9.76Ω 1Ω - 9.76Ω 1Ω - 9.76Ω 1Ω - 9.76Ω ±100ppm 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ ±200ppm 1Ω - 9.76Ω 1Ω - 9.76Ω 1Ω - 9.76Ω 1Ω - 9.76Ω 1Ω - 9.76Ω ±1 (F) ±5% (J) NOTE: Overload Voltage=2.5*√(P*R). MARKING CODE • 1% E-24 values for 0603 size and larger are typically marked with the standard 3 digit marking code. • 1% E-96 values for 0805 size and larger, will be marked with standard 4 digit marking code. • 5% E-24 values for 0603 size and larger, will be marked with standard 3 digit marking code. • 0603 - 1% E-96 values will be marked with a standard 3 digit alpha numeric code (Please see alpha numeric marking codes for resistors). • 0402 size cannot be marked DERATING CURVE Rated power (%) 120 100 80 60 40 20 0 -50 -55 -25 0 25 50 75 100 70 Ambient temperature (˚C) Email: sales@venkel.com | 125 150 175 Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 03/2021-A 2 HPCR SERIES HIGH POWER RESISTORS REEL SPECIFICATIONS F Label Unit: mm (inch) H M C E C E F G H M 13.0 ± 0.2 (0.51 ± 0.008) 60.0 ± 1.0 (2.36 ± 0.03) 11.4 ± 1.0 (0.45 ± 0.04) 9.0 ± .3 (0.35 ± 0.012) 1.5 ± .3 (0.06 ± 0.012) 180 ± 2.0 (7.09 ± 0.08) Minimum of 30 empty pockets at the beginning of reel, 65 minimum empty pockets at the end. G TAPE SPECIFICATIONS T G B A F W T J Dø Embossed H Paper E Units: mm (inches). TAPE Paper SIZE (in) A B W E F T G H J Dø 0402 1.15 ±0.10 0.65 ±0.10 8.0 ±0.20 1.75 ±0.10 3.50 ±0.05 0.45 ±0.10 2.00 ±0.05 4.00 ±0.10 2.00 ±0.05 1.50 ±0.10 0603 1.90 ±0.10 1.10 ±0.10 8.0 ±0.20 1.75 ±0.10 3.50 ±0.05 0.70 ±0.10 4.00 ±0.10 4.00 ±0.10 2.00 ±0.05 1.50 ±0.10 0805 2.40 ±0.10 1.65 ±0.10 8.0 ±0.20 1.75 ±0.10 3.50 ±0.05 0.85 ±0.10 4.00 ±0.10 4.00 ±0.10 2.00 ±0.05 1.50 ±0.10 1206 3.50 ±0.10 1.90 ±0.10 8.0 ±0.20 1.75 ±0.10 3.50 ±0.05 0.85 ±0.10 4.00 ±0.10 4.00 ±0.10 2.00 ±0.05 1.50 ±0.10 1210 3.50 ±0.10 2.80 ±0.10 8.0 ±0.20 1.75 ±0.10 3.50 ±0.05 0.85 ±0.10 4.00 ±0.10 4.00 ±0.05 2.00 ±0.05 1.50 ±0.10 PEEL BACK FORCE AND DIRECTION DIAGRAM Direction of pull Top cover tape Carrier tape Peel back force and direction of peel back angle should follow EIA481-1-A. Peel back force should be between 0.1N – 1.3N and peel back angle of 165˚ – 180˚. 165 ~ 180˚ Direction of unreeling Bottom cover tape Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 03/2021-A 3 HPCR SERIES HIGH POWER RESISTORS ENVIRONMENTAL CHARACTERISTICS REQUIREMENT TEST ±1% and below ±5% Temperature Coefficient of Resistance (T.C.R.) Short Time Overload TEST METHOD Jumper JIS-C-5201-1 4.8 IEC-60115-1 4.8 At 25°C/-55°C and 25°C/+125°C, 25°C is the reference temperature As Spec. ±(1.0%+0.05Ω) Insulation Resistance ±(2.0%+0.05Ω)
HPCR0402-R-2003FT
物料型号:HPCR系列高功率电阻
器件简介:HPCR系列提供从0402到1210的尺寸,阻值范围从1Ω到1MΩ,包括0Ω跳线。具有低至±100PPM的温度系数,符合RoHS和REACH标准,无卤素冲突矿物,具有良好的散热能力和优秀的焊接性。
引脚分配:文档中未明确提供引脚分配信息,但通常这类电阻为表面贴装元件,具有两端引脚。
参数特性: - 尺寸:0402至1210 - 功率:从1/8W(0.125W)至3/4W(0.75W) - 公差:±1%(F)和±5%(J) - 最大工作电压:根据尺寸不同,从V PR或50V(取较小值)至V PR或200V(取较小值) - 工作温度范围:-55°C至+155°C - 零欧姆(跳线)电流额定值:从1.5A至4.5A
功能详解:HPCR系列电阻设计用于高功率应用,具有优异的热性能和电气稳定性。
应用信息:适用于需要高功率和高稳定性电阻的场合,如电源管理、电机驱动等。
封装信息:提供多种尺寸的封装选项,包括0402、0603、0805、1206和1210,以及相应的封装尺寸和标记代码。
制造商信息:VENKEL LTD,提供了联系方式和官方网站。
HPCR0402-R-2003FT 价格&库存
很抱歉,暂时无法提供与“HPCR0402-R-2003FT”相匹配的价格&库存,您可以联系我们找货
