600F0R2BT250XT
600F0R2BT250XT
    ATC
    ±0.1pF
600F0R2BT250XT 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600F Ultra-Low ESR, High Q, NPO Capacitors FEATURES • • • • • Lowest ESR in Class Highest Working Voltage in Class - 250 V Standard EIA Size: 0805 Laser Marking (Optional) High Self-Resonance Frequencies 600 SERIES OVERVIEW APPLICATIONS Case Size EIA Case Size 600 L 0402 600 S 0603 600 F 0805 PACKAGING OPTIONS • Cellular Base Stations • Broadband Wireless Services • Satellite Communications • Subscriber-based Wireless Devices • WiFi (802.11) • Public Safety Radio Tape & Reel CIRCUIT APPLICATIONS Vertical Orientation Tape & Reel LEAD-FREE COMPATIBLE COMPONENT ENVIRONMENTAL CHARACTERISTICS • Filter Networks • High Q Frequency Sources • Matching Networks • Tuning, Coupling, Bypass and DC Blocking ELECTRICAL SPECIFICATIONS Temperature Coefficient (TCC) 0 ± 30 PPM/ºC Capacitance Range 0.1 pF to 240 pF Operating Temperature -55ºC to +125ºC* Quality Factor Greater than 2,000 @ 1 MHz Insulation Resistance (IR) Series Themal Shock 5 Cycles, -55ºC to 125ºC Moisture Resistance Mil-STD-202, Method 106 Life Test 2000 hours at 125ºC at 2X WVDC Solderability Solder Coverage > 90% of end termination Terminal Strength 4 lbs. typ., 2 lb. min. Military Approval DSCC Drawing Number 05001 105 Megohms min. @ 25ºC at rated WVDC 104 Megohms min. @ 125ºC at rated WVDC Working Voltage (WVDC) 200 V Dielectric Withstanding Voltage (DWV) 250% of rated WVDC for 5 seconds Aging Effects None Piezoelectric Effects None The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 070621 – rf microwave products – 503 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600F Ultra-Low ESR, High Q, NPO Capacitors CAPACITANCE VALUES Value (pF) 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.5 1.6 1.8 2.0 2.2 2.4 2.7 3.0 Cap Code 0R1 0R2 0R3 0R4 0R5 0R6 0R7 0R8 0R9 1R0 1R1 1R2 1R3 1R5 1R6 1R8 2R0 2R2 2R4 2R7 3R0 Marking Tolerances A9 H9 M9 d9 f9 m9 n9 t9 y9 A0 B0 C0 D0 E0 F0 G0 H0 J0 K0 L0 M0 A, B A, B A, B, C A, B, C A, B, C A, B, C A, B, C A, B, C A, B, C A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D Value (pF) 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 15 18 20 22 24 27 Cap Code 3R3 3R6 3R9 4R3 4R7 5R1 5R6 6R2 6R8 7R5 8R2 9R1 100 110 120 150 180 200 220 240 270 Marking Tolerances N0 P0 Q0 R0 S0 T0 U0 V0 W0 X0 Y0 Z0 A1 B1 C1 E1 G1 H1 J1 K1 L1 A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D A, B, C, D B, C, J, K B, C, J, K B, C, J, K B, C, J, K F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M Value (pF) 30 33 36 39 43 47 51 56 62 68 75 82 91 100 110 120 150 180 200 220 240 Cap Code 300 330 360 390 430 470 510 560 620 680 750 820 910 101 111 121 151 181 201 221 241 Marking Tolerances M1 N1 P1 Q1 R1 S1 T1 U1 V1 W1 X1 Y1 Z1 A2 B2 C2 E2 G2 H2 J2 K2 F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M F, G, J, K, M HOW TO ORDER 600 F 100 J T 250 X** T Series Packaging Case Size T = Tape and Reel, 500 pcs T4K = Tape and Reel, 4000 pcs TV = Vertical Tape and Reel, 500 pcs See mechanical dimensions below Capacitance Code Laser Marking (Optional) EIA Capacitance Code in pF. Third digit = number of zeros or after “R” significant figures Voltage Rating Capacitance Tolerance Code Code Tol. A B C Termination Style Code D ±0.05 pF ±0.1 pF ±0.25 pF ±0.5 pF F G J K M ±1% ±2% ±5% ±10% ±20% The above part number refers to a 600F Series (case size F) 10 pF capacitor, J tolerance (±5%), 250 WVDC, with T termination (Tin Plated over Nickel Barrier, RoHS Compliant), Laser Marking and Tape and Reel packaging. T = Tin Plated over Nickel Barrier (RoHS Compliant) TN = Tin Plated Non-Magnetic Barrier W = Tin/Lead Solder Nickel Barrier **Laser Marking is optional 504 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 022521 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600F Ultra-Low ESR, High Q, NPO Capacitors 600F Series Data Sheet Condition Description Capacitors horizontally mounted on 23.3 -mil thick Rogers R0435® softboard 52-mils wide 1/2 oz. Cu traces FSR = lowest frequency at which S11 response, referenced at capacitor edge, crosses real axis on Smith Chart. FPR = lowest frequency at which there is a notch in S21 magnitude response. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 010621 – rf microwave products – 505 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600F Ultra-Low ESR, High Q, NPO Capacitors OUTLINE DIMENSIONS Y L (0805) W L: .079 ± .008 (2.01 ± 0.20) W: .049 ± .008 (1.24 ± 0.20) T: .051 max (1.30 max) Y: .020 ± 0.01 (0.51 ± 0.25) inches (mm) T L SUGGESTED MOUNTING PAD DIMENSIONS W L T B A B Case Size L, S, and F Case Size A Min. B Min. C Min. D Min. 0402 (1005) .0275 (0.70) .0354 (0.90) .0157 (0.40) .0866 (2.20) 0603 (1608) .0393 (1.00) .0433 (1.10) .0236 (0.60) .110 (2.80) 0805 (2012) .0590 (1.50) .0512 (1.30) .0236 (0.60) .1259 (3.20) inches (mm) C D DESIGN KITS Item # Description Cap. Value Range (pF) DK0032T 600F Series Ultra-low ESR, High Q Microwave Capacitors 16 different values, 15 pcs. min. per value 0.1 to 2.0 DK0033T 600F Series Ultra-low ESR, High Q Microwave Capacitors 16 different values, 15 pcs. min. per value 0.1 to 10 Kit 34T DK0034T 600F Series Ultra-low ESR, High Q Microwave Capacitors 16 different values, 15 pcs. min. per value 10 to 27 Kit 35T DK0035T 600F Series Ultra-low ESR, High Q Microwave Capacitors 7 different values, 15 pcs. min. per value 100 to 240 Kit # Kit 32T Kit 33T RoHS Compliant Cap. Value (pF) 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8,0.9, 1.0, 1.1, 1.2, 1.5...............................................±0.1% Price $100.00 1.6, 1.8, 2.0......................................................±0.25% 1.0, 1.2, 1.5, 1.8, 2.0. 2.2, 2.4, 2.7, 3.0, 3.3.....±0.1% 3.9, 4.7, 5.6, 6.8, 8.2........................................±0.25% $100.00 10.....................................................................±5% 10, 12, 15, 18, 20, 22, 24, 27............................±5% $100.00 100, 120, 150, 180, 200, 220, 240...................±5 $55.00 For Online Kit Orders, Catalog & Application Notes, Visit: www.avx.com 506 Tol. (pF) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products –
600F0R2BT250XT
物料型号:600F系列,由Kyocera和AVX生产。
器件简介:这是一系列射频/微波多层陶瓷电容器(MLC),具有超低等效串联电阻(ESR)、高Q值和NPO(负温度系数)特性。
引脚分配:文档中没有提供具体的引脚分配信息,但通常这类电容器是表面贴装的,有两端引脚。
参数特性: - 最低的ESR在同类产品中 - 最高的工作电压在同类产品中 - 250V - 标准EIA尺寸:0805 - 激光打标(可选) - 高自谐振频率
功能详解: - 应用在移动通信基站、用户无线设备、宽带无线服务、Wi-Fi、卫星通信、公共安全无线电等领域。 - 电路应用包括滤波网络、匹配网络、高Q频率源、调谐、耦合、旁路和直流阻断。
应用信息: - 适用于射频/微波电路,特别是在需要高Q值和低ESR的应用中。
封装信息: - 提供标准EIA尺寸:0402、0603、0805。 - 提供激光打标选项。 - 符合RoHS标准。
环境特性: - 热冲击:5周期,-55°C至125°C - 耐湿性:符合Mil-STD-202,方法106 - 寿命测试:在125°C下2000小时,2倍额定直流工作电压 - 可焊性:焊料覆盖超过终端的90% - 终端强度:典型值4磅,最小值2磅 - 军用认证:DSCC图纸编号05001
电气规格: - 温度系数(TCC):0至30ppm/°C - 电容范围:0.1 pF至240pF - 工作温度:-55°C至+125°C - 品质因数:在1 MHz时大于2000 - 绝缘电阻(IR):在25°C下最小105兆欧,额定直流工作电压 - 在125°C下最小10兆欧,额定直流工作电压 - 工作电压(WVDC):200V - 介质耐压(DWV):额定直流工作电压的250%,持续5秒 - 老化效应:无 - 压电效应:无
电容值表提供了不同电容值的编码、标记和公差。
订购指南说明了如何根据系列、尺寸、电容编码、公差编码等来订购产品。
封装尺寸和建议的安装垫尺寸也提供在文档中。
设计套件提供了不同电容值范围的电容,以便于设计和测试。
600F0R2BT250XT 价格&库存
很抱歉,暂时无法提供与“600F0R2BT250XT”相匹配的价格&库存,您可以联系我们找货
