RC0402FR-0751R1P
RC0402FR-0751R1P
    YAGEO(国巨)
    贴片电阻 0402 51.1Ω ±1% 1/16W ±200ppm/℃
RC0402FR-0751R1P 数据手册
DATA SHEET LEAD FREE CHIP RESISTORS RC_P series ±0.5%, ±1%, ±5% Product specification – September 5, 2018 V.0 Sizes 0201/0402/0603/0805/ 1206/1210/1218/2010/2512 Product specification Chip Resistor Surface Mount SCOPE This specification describes RC series chip resistors with made by thick film process. APPLICATIONS  All general purpose application RC_P SERIES 2 8 0201 to 2512 ORDERING INFORMATION - GLOBAL PART NUMBER Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER RC XXXX X X X XX XXXX P (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0201/0402/0603/0805/1206/1210/1218/2010/2512 FEATURES  Total lead free without RoHS exemption  Halogen Free Epoxy  Reducing environmentally hazardous wastes  High component and equipment reliability (2) TOLERANCE  Saving of PCB space (4) TEMPERATURE COEFFICIENT OF RESISTANCE D = ± 0.5% F = ± 1.0% J = ± 5.0% ( for jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel - = Based on spec. (5) TAPING REEL 07 = 7 inch dia. Reel 13 =13 inch dia. Reel (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point. Example: 97R6 = 97.6Ω 9K76 = 9760Ω 1M = 1,000,000Ω (7) DEFAULT CODE Letter P is lead free (without RoHS exemption) ORDERING EXAMPLE The ordering code for a RC0402 0.0625W chip resistor value 100KΩ with ±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is: RC0402JR-07100KP. www.yageo.com Sep. 05, 2018 V.1 Product specification Chip Resistor Surface Mount RC_P SERIES 3 8 0201 to 2512 MARKING RC0201 / RC0402 No Marking Fig. 1 RC0603 03 Fig. 2 E24 series: 3 digits, 5% First two digits for significant figure and 3rd digit for number of zeros Value = 10 KΩ RC0805 / RC1206 / RC1210 / RC1218 / RC2010 / RC2512 00 Fig. 3 Value = 10 KΩ E24/E96 series: 4 digits, 1%, 0.5% First three digits for significant figure and 4th digit for number of zeros Note For further marking information, please see special data sheet "Chip resistors marking". CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added, as shown in Fig.4. Outlines For dimensions, please refer to Table 1 Fig. 4 Chip resistor outlines www.yageo.com Sep. 05, 2018 V.1 Product specification Chip Resistor Surface Mount SERIES RC_P 4 8 0201 to 2512 DIMENSION Table 1 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) RC0201 0.60±0.03 0.30±0.03 0.23±0.03 0.10±0.05 0.15±0.05 RC0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 RC0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 RC0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 RC1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC1210 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC1218 3.10±0.10 4.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC2010 5.00±0.10 2.50±0.15 0.55±0.10 0.45±0.15 0.50±0.20 RC2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.50±0.20 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS RESISTANCE RANGE TYPE Fig. 4 Chip resistor outlines RC0201 Operating Max. Temperature Working Range Voltage -55 °C to +125 °C RC0402 1Ω≤R≤10Ω: -100~+500ppm/℃ 10Ω
RC0402FR-0751R1P
物料型号:YAGEO RC_P系列,尺寸从0201到2512。
器件简介:RC系列贴片电阻采用厚膜工艺制造,无铅且无需RoHS豁免,使用无卤环氧树脂封装,具有高可靠性和节省PCB空间的特点。
引脚分配:文档中未明确指出引脚分配,但通常贴片电阻为两个端点用于连接。
参数特性: - 公差:±0.5%,±1%,±5% - 包装类型:纸带卷装(R)和压花卷装(K) - 温度系数:根据规格书有不同的温度系数 - 电阻值:由2到4位数字表示,R/K/M表示小数点位置
功能详解: - 适用于所有通用应用 - 电阻体由贵金属嵌入玻璃中,覆盖第二层玻璃以防止环境影响 - 激光修调至额定电阻值 - 覆盖保护性环氧涂层 - 两端加上外部终端(Ni屏障上的亚光锡)
应用信息:适用于所有通用目的的应用场景。
封装信息:详细尺寸信息见表1,包括长度、宽度、高度、内引线长度和外引线长度。
电气特性:包括工作温度范围、最大工作电压、过载电压、最大介质电压和电阻温度系数等,具体数值见表2。
测试和要求:包括电阻温度系数、寿命/耐久性、高温暴露、耐湿性、湿度、冲击、热冲击、短时间过载、过载、板弯曲/弯曲和焊接性等测试条件、程序和要求。
RC0402FR-0751R1P 价格&库存
很抱歉,暂时无法提供与“RC0402FR-0751R1P”相匹配的价格&库存,您可以联系我们找货
RC0402FR-0751R1P
  • 1+0.830381+0.10372
  • 10+0.1999110+0.02497
  • 50+0.1269250+0.01586
  • 100+0.10601100+0.01324
  • 500+0.07277500+0.00909
  • 1000+0.062751000+0.00784
  • 5000+0.046005000+0.00575
库存:37491
