RGV3216P-4303-B-T1
RGV3216P-4303-B-T1
    SUSUMU
    贴片电阻 1206 430KΩ ±0.1% 1/4W ±25ppm/℃
RGV3216P-4303-B-T1 数据手册
Metal thin film chip resistors (high voltage operation) ■RGV series AEC-Q200 Compliant Features ・High voltage operation is possible because the limiting element voltage is hjgh. (RGV3225 1000V) ・Long term stability with inorganic Passivation. Thin film surface mount resistors ・Resistance tolerance : ±0.1% , TCR : ±25 ppm/℃ ・Thin film structure enabling low noise and anti-sulfur Applications ・Automotive electronics RGT series ・Industrial measurement instrumentation, Industrial machies. ・High voltage circuit and equipment. ◆Part numbering system RGV 3216 P - 2004 - B - T5 T1(1,000pcs) T5(5,000pcs) Series code Resistance tolerance Size:RGV3216, RGV3225 Nominal resistance value(all 4 digit) Temperature coefficient of resistance ◆Electrical Specification Type RGV3216 Power ratings Temperature coefficient of resistance (ppm/℃) Resistance range(Ω) Resistance tolerance ±0.1%(B) ±25(P) 1/4W ±0.5%(D) Maximum voltage Resistance value series Operating temperature E-24, E-96 -55℃∼ 155℃ Packaging quantity 700V 120KΩ≦R≦3MΩ ±50(Q) RGV3225 ±25(P) 1/3W 120KΩ≦R≦4.3MΩ T1 T5 1000V ±50(Q) ◆Dimensions L Type Size (inch) L W a b t RGV3216 1206 3.20±0.20 1.60±0.25 0.50±0.25 0.50±0.20 0.40+0.15/-0.1 RGV3225 1210 3.20±0.20 2.50±0.25 0.50±0.25 0.50±0.20 0.40+0.15/-0.1 W a t b 19 (unit:mm) ◆Reliability specification 規 格 Test items Condition( IEC60115-1/JIS C5201-1) ※1 Standard 85℃, rated voltage , 90min. ON/ 30min. OFF, 1000hours ±0.05%+0.05Ω High temperature high humidity 85℃、85%RH, 1/10 of rated power, 90min. ON/ 30min. OFF, 1000hours ±0.1%+0.05Ω Temperature shock -55℃ (30min) ∼ 125℃(30min) 1000 cycles ±0.1%+0.01Ω High temperature exposure 155℃, no baias, not mounted, 1000h ±0.1%+0.01Ω Resistance to soldering heat 260±5℃, 10seconds (reflow) Thin film surface mount resistors Life (baised) ±0.05%+0.01Ω *1 Rated voltage is given by E= RxP E= rated voltage (V), R=nominal resistance value(Ω), P=rated power(W) If rated voltage exceeds maximum voltage /element, maximum voltage/element is the rated voltage. RGV series Ratio to rated power (%) ◆Derating Curve 100 50 0 -55 0 50 85 100 155 Ambient temperature (℃) 20
RGV3216P-4303-B-T1 价格&库存
很抱歉,暂时无法提供与“RGV3216P-4303-B-T1”相匹配的价格&库存,您可以联系我们找货
RGV3216P-4303-B-T1
  • 1+3.344691+0.43408
  • 10+2.7567110+0.35777
  • 25+2.5615625+0.33245
  • 50+2.4188350+0.31392
  • 100+2.28579100+0.29666
  • 250+2.12710250+0.27606
  • 500+2.01945500+0.26209
库存:1073
RGV3216P-4303-B-T1
  • 1000+2.086761000+0.27083
  • 3000+1.941443000+0.25197
库存:1073
RGV3216P-4303-B-T1
库存:1073
