AS03JTE1003
AS03JTE1003
    VIKING(光颉)
    电阻器 100KΩ ±5% 1/10W ±100ppm/℃ 0603
AS03JTE1003 数据手册
Data Sheet Customer: Product: Anti-Sulfurated Thick Film Chip Resistor - AS Series (Chip) Size: 0201/0402/0603/0805/1206/1210/2010/2512 Issued Date: 26-Feb-21 Edition: REV.C1 VIKING TECH CORPORATION VIKING TECH CORPORATION KAOHSIUNG BRANCH VIKING ELECTRONICS (WUXI) CO., LTD. ( ) No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) Prepared by (Sales) 26-Feb-21 26-Feb-21 26-Feb-21 26-Feb-21 Susan Huang J.C. Liu J.C. Liu Accepted by (Customer) AS Series (Chip) Anti-Sulfurated Thick Film Chip Resistor Scope This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. Features Special construction to prevent sulfuration in a sulfur containing environment Construction Applications High-end Computer L Industrial Equipment Automatic Equipment Controller D1 Medical Equipment W     T    D2  Alumina Substrate  Bottom Electrode  Top Electrode High-end Multimedia Electronics Outdoor Electronic Applications   Edge Electrode  Barrier Layer  External Electrode  Resistor Layer  Primary Overcoat  Secondary Overcoat Dimensions D1 D2 (mm) T (mm) (mm) (mm) Weight (g) (1000pcs) 0.60±0.03 0.30±0.03 0.23±0.03 0.15±0.05 0.15±0.05 0.150 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 AS03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 AS05 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 AS06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 AS10 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 AS0A 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 AS12 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 Type Size (Inch) L W (mm) AS01 0201 AS02 www.viking.com.tw For detail questions, contact sales@viking.com.tw 1 Edition: REV.C1 Revision: 26-Feb-2021 AS Series (Chip) Anti-Sulfurated Thick Film Chip Resistor Part Numbering AS 06 F Product Type Dimensions Resistance Tolerance 01: 0201 02: 0402 03: 0603 05: 0805 06: 1206 10: 1210 0A: 2010 12: 2512 T D: ±0.5% F: ±1% J: ±5% E 1002 TCR (PPM/°C) Packaging Code T: 7”Taping Reel V:10”Taping Reel W:13”Taping Reel Power Resistance Rating E: ±100 F: ±200 - : No Specified : Standard 3: 1/12W X: 1/10W W: 1/8W V: 1/4W O: 1/3W U: 1/2W Q: 3/4W T: 1W R0R0: 0Ω 0010: 1Ω 1000: 100Ω 1002: 10KΩ 2201: 2.2KΩ 1003: 100KΩ 1004: 1MΩ Derating Curve Recommend Land Pattern Derating Curve C B A Power ratio (%) . 100 AS02 AS03 AS05 AS06 AS10 AS0A AS12 80 60 40 AS01 20 0 Type A (mm) B (mm) C (mm) AS01 0.30 0.25 0.30 AS02 0.50 0.45 0.60 AS03 0.90 0.60 0.90 AS05 1.20 0.70 1.30 AS06 2.00 0.90 1.60 AS10 2.00 0.90 2.80 AS0A 3.80 0.90 2.80 AS12 4.90 1.60 3.50 0 20 40 60 80 100 120 140 160 Ambient Temperature ( ℃ ) Soldering Condition (IPC/JEDEC J-STD-020) www.viking.com.tw For detail questions, contact sales@viking.com.tw 2 Edition: REV.C1 Revision: 26-Feb-2021 AS Series (Chip) Anti-Sulfurated Thick Film Chip Resistor Standard Electrical Specifications Power Rating at 70C Jumper Rated Current Item Type 1/20W AS01 (0201) Jumper: 1A Operating Temp. Range Max. Operating Voltage Max. Overload Voltage -55 ~ +125C 25V 50V 1/16W AS02 (0402) 50V Resistance Range ±0.5% ±1% (E24,E96) (E24,E96) 1Ω - 10MΩ - 100V Jumper: 1A 75V 100V Jumper: 1A 1/8W AS05 (0805) 150V 300V Jumper: 2A 1/4W AS06 (1206) -55 ~ +155C 200V 200V 400V Jumper: 2.5A 200V 400V 250V 500V Jumper: 3.5A 1W AS12 (2512) ±200 ±100 ±200 - 1Ω - 9.76Ω 10Ω - 1MΩ 1.02MΩ - 10MΩ ±200 ±100 ±200 0Ω (
AS03JTE1003
物料型号:Viking AS系列芯片电阻,提供多种尺寸,包括0201、0402、0603、0805、1206、1210、2010和2512。
器件简介:该系列电阻采用钌基材料制成,具有特殊的结构设计,可在含硫环境中防止硫化。
引脚分配:文档中描述了电阻的结构,包括铝基板、边缘电极、电阻层、底层电极、阻挡层、主覆盖层、顶层电极和外部电极。
参数特性: - 尺寸:提供了不同尺寸的长(L)、宽(W)、厚(T)以及相关的直径(D1、D2)。 - 重量:列出了每1000片的重量。 - 功率额定值:不同尺寸的电阻有不同的功率额定值,如1/20W、1/16W、1/10W等。 - 电阻范围:提供了不同尺寸电阻的电阻值范围。 - 温度系数(TCR):列出了不同电阻的TCR值。
功能详解:适用于高端计算机、工业设备、自动设备控制器、医疗设备、高端多媒体电子、户外电子应用等。
应用信息:文档中提到了电阻的应用领域,包括高端计算机、工业设备、自动设备控制器、医疗设备等。
封装信息:提供了不同尺寸的封装信息,包括封装类型、包装数量、胶带宽度、卷径等。
AS03JTE1003 价格&库存
很抱歉,暂时无法提供与“AS03JTE1003”相匹配的价格&库存,您可以联系我们找货
