CRS0402-16W-9101FT
CRS0402-16W-9101FT
    VENKEL
    厚膜电阻 9.1KΩ ±1% 62.5MW
CRS0402-16W-9101FT 数据手册
CRS SERIES ANTI-SULFURATION RESISTORS FEATURES: • Confirmed test data with no failures up to 9,000 hours • TCR as low as ±100ppm • Moisture Sensitivity Level: 1 • Specially designed termination prevents an open mode due to the formation of Silver Sulfide (Ag2S) PART NUMBER STRUCTURE CRS 1206 Series Size 0201 0402 0603 0805 1206 1210 2010 2512 - 4W - Power Rating 20W = 0.05W 16W = 0.063W 10W = 0.10W 8W = 0.125W 4W = 0.25W 2W = 0.50W W = 0.75W X = 1.0W 103 J T Resistance Code Tolerance D = ±0.5% F = ± 1% J = ±5% Packaging T = Tape & Reel 3 DIGIT (J TOL.) e.g. 2R2=2.2Ω 103=10KΩ 4 DIGIT (F TOL.) e.g. 10R2=10.2Ω 1002=10KΩ Example P/N: CRS1206-4W-103JT Standard termination finish is 100% matte Tin (Sn) over Nickel. DIMENSIONS Unit: inches (mm) L W C C T C C Size (inches) L W T C 0201 0.024 ± 0.002 (0.6 ± 0.05) 0.012 ± 0.001 (0.3 ± 0.02) 0.010 ± 0.002 (0.25 ± 0.05) 0.006 ± 0.002 (0.15 ± 0.05) 0402 0.040 ± 0.002 (1.0 ± 0.05) 0.020 ± 0.002 (0.5 ± 0.05) 0.014 ± 0.002 (0.35 ± 0.05) 0.008 ± 0.004 (0.2 ± 0.01) 0603 0.063 ± 0.008 (1.6 ± 0.2) 0.031 ± 0.008 (0.8 ± 0.2) 0.014 ± 0.004 (0.45 ± 0.10) 0.010 ± 0.006 (0.25 ± 0.15) 0805 0.079 ± 0.008 (2.0 ± 0.2) 0.050 ± 0.008 (1.25 ± 0.20) 0.018 ± 0.006 (0.45 ± 0.15) 0.016 ± 0.008 (0.4 ± 0.20) 1206 0.126 ± 0.008 (3.2 ± 0.2) 0.063 ± 0.008 (1.6 ± 0.2) 0.022 ± 0.006 (0.57 ± 0.15) 0.018 ± 0.008 (0.45 ± 0.2) 1210 0.126 ± 0.008 (3.2 ± 0.2) 0.098 ± 0.006 (2.50 ± 0.15) 0.022 ± 0.006 (0.56 ± 0.15) 0.018 ± 0.008 (0.45 ± 0.20) 2010 0.197 ± 0.006 (5.0 ± 0.15 0.098 ± 0.006 (2.50 ± 0.15 0.022 ± 0.005 (0.55 ± 0.12) 0.024 ± 0.01 (0.60 ± 0.25) 2512 0.248 ± 0.006 (6.3 ± 0.15) 0.122 ± 0.006 (3.1 ± 0.15) 0.022 ± 0.005 (0.55 ± 0.12) 0.024 ± 0.01 (0.60 ± 0.25) STRUCTURE 5 6 7 4 1 Alumina Substrate 6 Protective Overcoat II 2 Bottom Electrode (Ag) 7 Side Electrode (resin Ag) 3 8 1 3 Topside Electrode (Ag-Pd) 8 Internal Electrode (Ni) 4 Resistance Element (RuO2) 9 External Electrode (Sn) 2 5 Protective Overcoat I 9 Email: sales@venkel.com | Phone: 512.794.0081 | Toll Free: 800.950.8365 | Web: www.venkel.com Rev: 01/2021-A 1 CRS SERIES ANTI-SULFURATION RESISTORS ELECTRICAL SPECIFICATION & RANGE SIZE 0201 0402 0603 0805 1206 1210 2010 2512 Power Rating at 70°C (W) 0.05W (1/20W) 0.063W (1/16W) 0.10W (1/10W) 0.125W (1/8W) 0.25W (1/4W) 0.33W (1/3W) 0.75W (3/4W) 1.0W (1W) 1A 1A 1A 2A 2A 2.5A 3.5A 4A 50 mΩ (max) 50 mΩ (max) 50 mΩ (max) 50 mΩ (max) 50 mΩ (max) 50 mΩ (max) 50 mΩ (max) 50 mΩ (max) Max. Working Voltage √—PR or 25V whichever is less √—PR or 50V whichever is less √—PR or 50V whichever is less √—PR or 150V whichever is less √—PR or 200V whichever is less √—PR or 200V whichever is less √—PR or 200V whichever is less √—PR or 250V whichever is less Operating Temp. Range -55°C to +125°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C -55°C to +155°C TCR Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range Resistance Range ±100ppm - 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ ±200ppm - 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ ±100ppm - 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ ±200ppm 1Ω - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ ±100ppm - 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ 10Ω - 1MΩ ±200ppm 1Ω - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ 0Ω, 1Ω - 9.76Ω, 1.02M - 10MΩ Zero ohm (Jumper) Current Rating Zero ohm (Jumper) Resistance Tolerance ±0.5% (D) ±1% (F) ±5% (J) NOTES: (1) Overload Voltage = 2.5*√(P*R). (2) Zero Ohm Jumper is
CRS0402-16W-9101FT 价格&库存
很抱歉,暂时无法提供与“CRS0402-16W-9101FT”相匹配的价格&库存,您可以联系我们找货
