CR
SERIES
GENERAL PURPOSE THICK FILM RESISTORS
FEATURES:
• TCR as low as ±100ppm
• Available Sizes 01005 to 2512
• Stable over temperature range
• Good power dissipation capabilities (Rated power
is conservatively rated)
• 100% matte Tin over Nickel with wrap around termination
for excellent solderability
• Some values available for conductive epoxy application (suitable for MRI applications)
PART NUMBER STRUCTURE
CR
1206
Series
Size
01005
0201
0402
0603
0805
1206
1210
2010
2512
8W
Power Rating
32W = 0.031W
20W = 0.05W
16W = 0.063W
10W = 0.10W
8W = 0.125W
4W = 0.25W
2W = 0.50W
W = 0.75W
1W = 1W
2W =2W
103
J
T
Resistance
Tolerance
D = ± 0.5%
F = ± 1%
J = ± 5%
Terminaton
Leave blank for
standard termination.
Packaging
T = Tape & Reel
Optional Reel Identifier
Leave blank if standard Reel
size.
3 DIGIT
(J TOL.)
2R2=2.2Ω
103=10KΩ
4 DIGIT
(D & F
TOL.)
10R2=10.2Ω
1002=10KΩ
Jumper
3 zeros
P = Palladium Silver
Termination (PdAg)
No tolerance specified
for the zero ohm
Note: 1% E24 values may be
marked with a 3 digit code.
Add "-13" if 13" Reel is
required
Leave blank for zero
ohm value
Example P/N: CR1206-8W-103JT
Standard temination finish is 100% matte Tin (Sn) over Nickel.
DIMENSIONS
Unit: inches (mm)
SIZE
L
W
T
C1
C2
01005
0.016 ± 0.0008
(0.4 ± 0.02)
0.008 ± 0.0008
(0.2 ± 0.02)
0.005 ± 0.0008
(0.13 ± 0.02)
0.003 ± 0.001
(0.08 ± 0.03)
0.003 ± 0.001
(0.08 ± 0.03)
0201
0.024 ± 0.002
(0.6 ± 0.05)
0.012 ± 0.001
(0.3 ± 0.02)
0.010 ± 0.002
(0.25 ± 0.05)
0.020 ± 0.008
(0.50 ± 0.20)
0.006 ± 0.002
(0.15 ± 0.05)
0402
0.040 ± 0.002
(1.0 ± 0.05)
0.020 ± 0.002
(0.5 ± 0.05)
0.014 ± 0.002
(0.35 ± .05)
0.008 ± 0.004
(0.2 ± 0.1)
0.008 ± 0.004
(0.2 ± 0.1)
0603
0.063 ± 0.004
(1.6 ± 0.1)
0.031 ± 0.004
(0.8 ± 0.1)
0.018 ± 0.004
(0.45 ± 0.1)
0.012 ± 0.006
(0.30 ± 0.15)
0.012 ± 0.006
(0.30 ± 0.15)
0805
0.079 ± 0.006
(2.0 ± 0.15)
0.050 ± 0.006
(1.25 ± 0.15)
0.018 ± 0.006
(0.45 ± 0.15)
0.014 ± 0.006
(0.35 ± 0.15)
0.014 ± 0.006
(0.35 ± 0.15)
1206
0.126 ± 0.006
(3.2 ± 0.15)
0.063 ± 0.006
(1.6 ± 0.15)
0.022 ± 0.006
(0.56 ± 0.15)
0.020 ± 0.008
(0.50 ± 0.20)
0.020 ± 0.008
(0.50 ± 0.20)
1210
0.126 ± 0.006
(3.2 ± 0.15)
0.098 ± 0.006
(2.50 ± 0.15)
0.022 ± 0.006
(0.56 ± 0.15)
0.020 ± 0.008
(0.50 ± 0.20)
0.020 ± 0.008
(0.50 ± 0.20)
2010
0.197 ± 0.006
(5.0 ± 0.15)
0.098 ± 0.006
(2.50 ± 0.15)
0.022 ± 0.006
(0.56 ± 0.15)
0.026 ± 0.008
(0.65 ± 0.25)
0.024 ± 0.008
(0.60 ± 0.20)
2512 (1W)
0.248 ± 0.006
(6.3 ± 0.15)
0.126 ± 0.006
(3.2 ± 0.15)
0.022 ± 0.006
(0.56 ± 0.15)
0.026 ± 0.008
(0.65 ± 0.25)
0.024 ± 0.008
(0.60 ± 0.20)
2512 (2W)
0.248 ± 0.006
(6.3 ± 0.15)
0.126 ± 0.006
(3.2 ± 0.15)
0.024 ± 0.008
(0.60 ± 0.20)
0.024 ± 0.008
(0.60 ± 0.20)
0.020 ± 0.008
(0.50 ± 0.20)
STRUCTURE
3
1
Alumina Substrate
6
Tin Plating
2
Backside Electrode
7
Primary Coating
3
Topside Electrode
8
Secondary Layer
4
Edge Electrode
9
Resistive layer
5
Nickel Plating
10
Marking
5
4
1
7
8
6
9
2
1
Email: sales@venkel.com
Phone: 512.794.0081 |
Toll Free: 800.950.8365 |
Web: www.venkel.com
Rev: 9/2021
1
CR
SERIES
ELECTRICAL SPECIFICATIONS & RANGE
Zero Ohm
(Jumper)
Zero Ohm
(Jumper)
Tolerance
±0.5% (D)
±1% (F)
±5% (J)
Zero Ohm
(Jumper)
Zero Ohm
(Jumper)
Tolerance
±0.5% (D)
SIZE
01005
0201
Power Rating
at 70°C (W)
0.03W
(1/32W)
0.05W
(1/20W)
Max. Working Voltage
√—PR or 15V
whichever is less
√—PR or 25V
whichever is less
0603
0.10W
(1/10W)
0.063W
(1/16W)
√—PR or 50V
whichever is less
0805
0.10W
(1/10W)
√—PR or 75V
whichever is less
0.10W
(1/10W)
0.125W
(1/8W)
√—PR or 150V
whichever is less
*Max. Overload Voltage
30V
50V
100V
150V
300V
Operating Temp. Range
-55°C to +125°C
-55°C to +125°C
-55°C to +155°C
-55°C to +155°C
-55°C to +155°C
Current Rating
0.5A
0.5A
1A
1A
2A
Resistance
50 mΩ (max)
50 mΩ (max)
50 mΩ (max)
50 mΩ (max)
50 mΩ (max)
TCR
Resistance Range
Resistance Range
Resistance Range
Resistance Range
Resistance Range
±100ppm
10Ω - 1MΩ
10Ω - 1MΩ
10Ω - 1MΩ
±200ppm
1.02MΩ - 10MΩ
1.02MΩ - 10MΩ
1.02MΩ - 10MΩ
±100ppm
10Ω - 10MΩ
10Ω - 1MΩ
10Ω - 10MΩ
10Ω - 10MΩ
1Ω - 9.76Ω;
1.02MΩ - 10MΩ
1Ω - 9.76Ω;
10.2MΩ - 21.5MΩ
1Ω - 9.76Ω;
10.2MΩ - 21.5MΩ
±200ppm
10Ω - 10MΩ
1Ω - 9.76Ω;
10.2MΩ - 20MΩ
±250ppm
100Ω - 1MΩ
±300ppm
10Ω - 99Ω
±100ppm
±200ppm
1Ω - 10MΩ
1Ω - 10MΩ
1Ω - 10MΩ
1Ω - 10MΩ
1Ω - 10MΩ
±250ppm
100Ω - 1MΩ
±300ppm
10Ω - 99Ω
±350ppm
10MΩ - 22MΩ
10MΩ - 22MΩ
SIZE
1206
Power Rating
at 70°C (W)
0.125W (1/8W) 0.25W (1/4W)
√—PR or 200V whichever
is less
√—PR or 200V
whichever is less
√—PR or 200V
whichever is less
√—PR or 200V
whichever is less
400V
400V
400V
500V
-55°C to +155°C
-55°C to +155°C
-55°C to +155°C
-55°C to +155°C
Current Rating
2A
2.5A
3.5A
4A
1210
0.25W (1/4W)
2010
0.50W (1/2W) 0.50W (1/2W) 0.75W (3/4W)
2512
1.0W
1.0W
2.0W
Resistance
50 mΩ (max)
50 mΩ (max)
50 mΩ (max)
50 mΩ (max)
TCR
Resistance Range
Resistance Range
Resistance Range
Resistance Range
±100ppm
10Ω - 1MΩ
±200ppm
1.02MΩ - 10MΩ
±100ppm
10Ω - 10MΩ
10Ω - 1MΩ
±200ppm
1Ω - 9.76Ω;
10.2MΩ - 21.5MΩ
1Ω - 9.76Ω;
1.02MΩ - 20MΩ
±250ppm
±1% (F)
±5% (J)
0402
0.063W
(1/16W)
±300ppm
±100ppm
±200ppm
1Ω - 10MΩ
10Ω - 1MΩ
1Ω - 9.76Ω
10Ω - 1MΩ
20.5MΩ 21.5MΩ
10Ω - 1MΩ
±250ppm
±300ppm
20.5MΩ - 21.5MΩ
±350ppm
10MΩ - 22MΩ
10Ω - 1MΩ
20.5MΩ - 21.5MΩ
1Ω - 9.76Ω;
1.02MΩ - 20MΩ
10Ω - 1MΩ
20.5MΩ 21.5MΩ
1Ω - 9.76Ω;
1Ω - 9.76Ω;
1Ω - 9.76Ω
1.02MΩ - 20MΩ 1.02MΩ - 20MΩ
20.5MΩ - 22MΩ 20.5MΩ - 22MΩ
10Ω - 1MΩ
10Ω - 1MΩ
10Ω - 1MΩ
1Ω - 9.76Ω
10Ω - 1MΩ
1Ω - 9.76Ω;
1Ω - 9.76Ω;
1Ω - 9.76Ω;
1Ω - 9.76Ω
1Ω - 9.76Ω
1.02MΩ - 20MΩ
1Ω - 9.76Ω
1.1MΩ - 20MΩ
1Ω - 9.76Ω
* Note: Max OverLoad Voltage = 2.5 * ( P x R )1/2 or Max. overload voltage listed above, whichever is lower.
Web: www.venkel.com
Rev: 9/2021
2
CR
SERIES
MARKING CODE
• 1 % E-24 values for 0603 size and larger are typically marked with the
standard 3 digit marking code.
• 1% E-96 values for 0805 size and larger may or may not be marked with the
standard 4 digit marking code.
• 5% E-24 values for 0603 size and larger, will be marked with standard 3 digit
marking code.
• 0603 -1% E-96 values will be marked with a standard 3 digit alpha numeric
code (Please see page 5 for alpha numeric codes).
• 01005, 0201 and 0402 cannot be marked.
• 5% E-24 values for 1210~2512, may be marked with 4 digit marking code.
• E-192 values will not typically be marked.
DERATING CURVE
Rated power (%)
120
100
80
60
40
-55
-25
50
75
70
100
125
150
175
Ambient temperature (˚C)
01005 & 0201 size
0402 to 2512 Size
Web: www.venkel.com
Rev: 9/2021
3
CR
SERIES
TAPE & REEL SPECIFICATIONS
REEL
F
Label
H
Unit: mm (inch)
M C
E
C
E
F
G
H
M
13.0 ± 0.2
(0.51 ±
0.008)
60.0 ± 1.0
(2.36 ± 0.03)
11.4 ± 1.0
(0.45 ± 0.04)
9.0 ± .3
(0.35 ±
0.012)
1.5 ± .3
(0.06 ±
0.012)
180 ± 2.0
(7.09 ± 0.08)
Minimum of 30 empty pockets at the beginning of reel, 65 minimum empty pockets at the end.
G
TAPE
T
G
B
A
W
F
T
J
Dø
TAPE
Paper
H
Embossed
E
Paper
All dimensions in mm.
SIZE
A
B
W
E
F
T
G
H
J
DØ
01005
0.45
± 0.03
0.25
± 0.03
8.0
± 0.2
1.75
± 0.1
3.5
± 0.05
0.40
± 0.10
2.0
± 0.05
4.0
± 0.1
2.0
± 0.05
1.5
+ 0.1-0
0201
0.7
± 0.08
0.4
± 0.08
8.0
± 0.2
1.75
± 0.1
3.5
± 0.05
0.42
± 0.20
2.0
± 0.05
4.0
± 0.1
2.0
± 0.05
1.5
+ 0.1-0
0402
1.15
± 0.1
0.65
± 0.1
8.0
± 0.2
1.75
± 0.1
3.5
± 0.05
0.45
± 0.10
2.0
± 0.05
4.0
± 0.1
2.0
± 0.05
1.5
+ 0.1-0
0603
1.9
± 0.1
1.1
± 0.1
8.0
± 0.2
1.75
± 0.1
3.5
± 0.05
0.70
± 0.10
4.0
± 0.1
4.0
± 0.1
2.0
± 0.05
1.5
+ 0.1-0
0805
2.4
± 0.1
1.65
± 0.1
8.0
± 0.2
1.75
± 0.1
3.5
± 0.05
0.85
± 0.10
4.0
± 0.1
4.0
± 0.1
2.0
± 0.05
1.5
+ 0.1-0
1206
3.5
± 0.1
1.9
± 0.1
8.0
± 0.2
1.75
± 0.1
3.5
± 0.05
0.85
± 0.10
4.0
± 0.1
4.0
± 0.1
2.0
± 0.05
1.5
+ 0.1-0
1210
3.5
± 0.1
2.8
± 0.1
8.0
± 0.2
1.75
± 0.1
3.5
± 0.05
0.85
± 0.10
4.0
± 0.1
4.0
± 0.1
2.0
± 0.05
1.5
+ 0.1-0
2010
5.4
± 0.2
2.9
± 0.2
12.0
± 0.1
1.75
± 0.1
5.5
± 0.5
1.2
4.0
± 0.1
4.0
± 0.1
2.0
± 0.05
1.5
+ 0.1-0
2512
6.9
± 0.2
3.6
± 0.2
12.0
± 0.1
1.75
± 0.1
5.5
± 0.5
1.2
8.0
± 0.1
4.0
± 0.1
2.0
± 0.05
1.5
+ 0.1-0
Embossed
PEEL BACK FORCE & DIRECTION DIAGRAM
Direction of pull
Top cover tape
Carrier tape
Peel back force and direction of peel back angle should
follow EIA481-1-A. Peel back force should be between
0.1N – 1.3N and peel back angle of 165˚ – 180˚.
165 ~ 180˚
Direction of unreeling
Bottom cover tape
Web: www.venkel.com
Rev: 9/2021
4
CR
SERIES
MARKING CODES FOR 0603, 1% RESISTORS
As the chart shows, a Two-Digit Number Code is assigned to each standard Resistance Value per E96 guidelines (Decade
value listings). This is followed by an Alpha Code System which is a multiplier for the value table. Each letter, from
"A” — "Z”, represents a specific multiplier.
STANDARD RESISTANCE VALUES FOR THE 10 TO 100 DECADE
(also usable in decade multiples or sub-multiples)
MARKING CODES FOR RESISTANCE VALUES
E96
E96
E96
E96
E96
E96
DECADE
CODE
DECADE
CODE
DECADE
CODE
DECADE
CODE
DECADE
CODE
DECADE
CODE
100
01
147
17
215
33
316
49
464
65
681
81
102
02
150
18
221
34
324
50
475
66
698
82
105
03
154
19
226
35
332
51
487
67
715
83
107
04
158
36
340
52
499
68
732
84
110
05
162
21
237
37
348
53
511
69
750
85
113
06
165
22
243
38
357
54
523
70
768
86
115
07
169
23
249
39
365
55
536
71
787
87
118
08
174
24
255
40
374
56
549
72
806
88
121
09
178
25
261
41
383
57
562
73
825
89
124
10
182
26
267
42
392
58
576
74
845
90
127
11
187
27
274
43
402
59
590
75
866
91
130
12
191
28
280
44
412
60
604
76
887
92
133
13
196
29
287
45
422
61
619
77
909
93
137
14
200
30
294
46
432
62
634
78
931
94
140
15
205
31
301
47
442
63
649
79
953
95
143
16
210
32
309
48
453
64
665
80
976
96
LETTER
MULTIPLIER
CROSS
REFERENCE
A – 100
B – 101
C – 102
D – 103
E – 104
F – 105
G – 106
H – 107
X – 10-1
Y – 10-2
Z – 10-3
( Letter multipliers
may also come in
lower case.)
By combining a specific two-digit code and a letter multiplier, you have a series of Numeric/Alpha digits
that give you the complete E96 Resistance Value Codes for parts marking.
0603, ±1%
Chip Marking
01A
25C
93D
EXAMPLE:
Explanation
01 means 100 and A = 1
25 means 178 and C = 100
93 means 909 and D = 1000
Value:
100 x 1.0 = 100 Ohm
178 x 100 = 17.8K Ohm
909 x 1000 = 909K Ohm
Web: www.venkel.com
Rev: 9/2021
5
CR
SERIES
ENVIRONMENTAL CHARACTERISTICS
REQUIREMENT
ITEM
±1% and Below
±5%
Temperature Coefficient of
Resistance (T.C.R.)
Short Time Overload
TEST METHOD
Jumper
JIS-C-5201-1 4.8
IEC-60115-1 4.8
-55˚C~+12˚C, 25˚C is the reference temperature
As Spec.
±(1.0%+0.05Ω)
±(2.0%+0.05Ω)
CR0402-16W-113JT-13 价格&库存
很抱歉,暂时无法提供与“CR0402-16W-113JT-13”相匹配的价格&库存,您可以联系我们找货
