SM/SMH Series
Stackpole Electronics, Inc.
Surface Mount Wirewound Resistor
Features:
Resistive Product Solutions
High temperature molded encapsulation
Flex termination for absorbing thermal expansion
All welded construction
Non-inductive winding available (contact Stackpole with
requirements)
RoHS compliant, lead-free and halogen-free
Electrical Specifications
Type/Code
Power Rating
@ 70ºC
Maximum
Working
Voltage
Dielectric
Withstanding
Voltage
Resistance
Temperature
Coefficient
SM2615
1W
25V
>500V
±75 ppm/ºC
±100 ppm/ºC
±20 ppm/ºC
SM4124
2W
50V
>500V
±75 ppm/ºC
±100 ppm/ºC
±20 ppm/ºC
SM4527
2W
60V
>500V
SM4527…-LP
SMH4527
2W
3W
60V
60V
>500V
>500V
SM6227
3W
100V
>500V
SM8035
4W
100V
Ohmic Range (Ω) and Tolerance
0.1%
5 - 10
10.1 - 400
5 - 10
3 - 10
10.1 - 1K
5 - 10
3 -10
10.1 - 1K
±75 ppm/ºC
±100 ppm/ºC
±20 ppm/ºC
±75 ppm/ºC
±75 ppm/ºC
±75 ppm/ºC
±100 ppm/ºC
±20 ppm/ºC
10.1 - 3K
±75 ppm/ºC
±100 ppm/ºC
±20 ppm/ºC
>500V
0.5%
3 - 10
10.1 - 5K
1%
1 - 10
10.2 - 400
5%
0.01 - 0.098
0.1 - 10
11 - 400
0.05 - 0.098
0.01 - 0.098
0.1 - 10
10.2 - 1K
11 - 1K
0.05 - 0.098
0.01 - 0.098
0.1 - 10
10.2 - 1K
11 - 1K
0.01 - 0.05
0.01 - 0.05
0.05 - 0.098
1 - 10
10.2 - 3K
11 - 3K
0.05 - 0.098
1 - 10
10.2 - 5K
11 - 5K
Performance Characteristics
Test
Moisture Resistance
Thermal Shock
Load Life @ 70ºC - 1,000 hours
Resistance to Soldering Heat
Terminal Strength
Dielectric Withstanding Voltage
Short Time Overload
Test Specification
±1%
±0.5%
±1%
±1%
±0.5%
±0.001% / V
±0.2%
Operating Temperature Range: -55ºC to +275ºC
-55ºC
Power Derating Curve:
70ºC
Percent Rated Power (%)
100
80
60
40
275°C
-40
80
120
160
200
240
280
320
Ambient Temperature (ºC)
Rev Date: 10/25/2018
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
SM/SMH Series
Mechanical Specifications
A
B
C
D
E
F
Body
Total
Body
Body
Termination
Termination
Length
Length
Height
Width
Width
Length
SM2615
0.260 ± 0.015
6.60 ± 0.38
0.280 ± 0.032
7.11 ± 0.81
0.140 ± 0.015
3.56 ± 0.38
0.150 ± 0.015
3.81 ± 0.38
0.100 ± 0.015
2.54 ± 0.38
SM4124
0.410 ± 0.015
10.41 ± 0.38
0.430 ± 0.032
10.92 ± 0.81
0.180 ± 0.015
4.57 ± 0.38
0.240 ± 0.015
6.10 ± 0.38
SM4527
0.455 ± 0.015
11.56 ± 0.38
0.475 ± 0.032
12.07 ± 0.81
0.215 ± 0.015
5.46 ± 0.38
SM4527…-LP
0.455 ± 0.015
11.56 ± 0.38
0.475 ± 0.032
12.07 ± 0.81
SMH4527
0.455 ± 0.015
11.56 ± 0.38
SM6227
SM8035
Type/Code
W
H
L
Unit
0.090 ± 0.015
2.29 ± 0.38
0.138
3.51
0.130
3.30
0.350
8.89
inches
mm
0.122 ± 0.015
3.10 ± 0.38
0.090 ± 0.015
2.29 ± 0.38
0.181
4.60
0.157
3.99
0.583
14.81
inches
mm
0.270 ± 0.015
6.86 ± 0.38
0.122 ± 0.015
3.10 ± 0.38
0.105 ± 0.015
2.67 ± 0.38
0.169
4.29
0.157
3.99
0.587
14.91
inches
mm
0.150 ± 0.015
3.81 ± 0.38
0.270 ± 0.015
6.86 ± 0.38
0.122 ± 0.015
3.10 ± 0.38
0.105 ± 0.015
2.67 ± 0.38
0.169
4.29
0.157
3.99
0.587
14.91
inches
mm
0.475 ± 0.032
12.07 ± 0.81
0.150 ± 0.015
3.81 ± 0.38
0.270 ± 0.015
6.86 ± 0.38
0.122 ± 0.015
3.10 ± 0.38
0.105 ± 0.015
2.67 ± 0.38
0.169
4.29
0.157
3.99
0.587
14.91
inches
mm
0.625 ± 0.015
15.88 ± 0.38
0.645 ± 0.032
16.38 ± 0.81
0.250 ± 0.015
6.35 ± 0.38
0.275 ± 0.015
6.99 ± 0.38
0.122 ± 0.015
3.10 ± 0.38
0.130 ± 0.015
3.30 ± 0.38
0.236
5.99
0.157
3.99
0.850
21.59
inches
mm
0.800 ± 0.015
20.32 ± 0.38
0.825 ± 0.032
20.96 ± 0.81
0.362 ± 0.015
9.19 ± 0.38
0.350 ± 0.015
8.89 ± 0.38
0.122 ± 0.015
3.10 ± 0.38
0.122 ± 0.015
3.10 ± 0.38
0.340
8.64
0.157
3.99
0.950
24.13
inches
mm
SM Series Hot Spot Temperature
2
www.seielect.com
SM/SMH Series
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
SM
Surface Mount - General Purpose and
Precision Wirewound Resistor
SMD
YES
100% Matte Sn
Jan-06
06/01
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the
eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the
electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and
products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of
Dodd-Frank Act regarding Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free
and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually
strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our
environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms
of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
S
M
4
1
2
4
F
T
1
K
L
P
Product Series
Code Description
SM
Standard
SMH High Power
NSM Non-inductive
Power Rating
Size
Power
2615
1W
4124
2W
4527
2W
(H)4527 3W
6227
3W
8035
4W
Tolerance
Code
Tol
B
0.1%
D
0.5%
F
1%
J
5%
Code
T
Packaging
Size
Quantity
2615
1,500
4527(-LP), H4527 1,200
13" Reel
4527
900
Plastic Tape
4124
800
6227
750
8035
350
Description
3
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
"L" used as multiplier
of 10-3 for any value
under 0.1 ohm.
0.01 ohm = 10L0
0.1 ohm = R100
1 Kohm = 1K00
Code
(blank)
-LP
Special
Description
Standard
Low Profile
www.seielect.com
很抱歉,暂时无法提供与“SM4527FT5L00”相匹配的价格&库存,您可以联系我们找货
