HMR06JL7--300M
HMR06JL7--300M
    VIKING(光颉)
    贴片电阻 1206 300mΩ ±5% 1/4W ±500ppm/℃
HMR06JL7--300M 数据手册
Data Sheet Customer: Product: High Ohmic Chip Resistor - HMR Series Size: 0805/1206 Issued Date: 10-Mar-21 Edition: REV.A5 VIKING TECH CORPORATION 光頡科技股份有限公司 VIKING TECH CORPORATION KAOHSIUNG BRANCH 光頡科技股份有限公司高雄分公司 VIKING ELECTRONICS (WUXI) CO., LTD. 光頡電子(無錫)有限公司 No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) 10-Mar-21 10-Mar-21 10-Mar-21 Susan Huang J.C. Liu J.C. Liu Prepared by (Sales) Accepted by (Customer) 【HMR Series】 High Ohmic Chip Resistor High Ohmic Chip Resistor ■Scope -This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. ■Features -Extended resistance range(110MΩ ~ 1GΩ ) -Surface mount package -Highly reliable multilayer electrode construction ■Construction ■Applications -Voltage dividers and hybrids -X-Ray equipment -Low signal detection or amplification circuits -High input impedance quartz amplifiers -Testing devices  Alumina Substrate  Bottom Electrode  Top Electrode  Edge Electrode  Barrier Layer  External Electrode  Resistor Layer  Primary Overcoat  Secondary Overcoat ■Dimensions Type Size (Inch) HMR05 HMR06 D1 D2 (mm) T (mm) (mm) (mm) Weight (g) (1000pcs) 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 L W (mm) 0805 1206 ■Part Numbering HMR 05 J Product Type Dimensions Resistance Tolerance J: ±5% 05: 0805 06: 1206 www.viking.com.tw L Function Code L: Standard 7 --200M Packaging Code 7: 7” Reel 5Kpcs A: 10” Reel 10Kpcs D: 13” Reel 20Kpcs F: Bulk Resistance For detail questions, contact:sales@viking.com.tw 1 - - 200M: 200MΩ - - - -1G: 1GΩ “-“ to fill up 6 spaces Edition: REV.A5 Revision: 10-Mar-2021 【HMR Series】 High Ohmic Chip Resistor Derating Curve ■Derating Curve ■Recommend Land Pattern . 100 B Power ratio (%) C A Type A (mm) B (mm) C (mm) HMR05 1.20 0.70 1.30 HMR06 2.00 0.90 1.60 80 60 40 20 0 0 20 40 60 80 100 120 140 160 Ambient Temperature ( ℃ ) ■Soldering Condition (IPC/JEDEC J-STD-020) ■Standard Electrical Specifications Item Type HMR05 (0805) Power Rating at 70C Operating Temp. Range 1/8W Max. Operating Voltage Max. Overload Voltage 150V 300V Resistance Range ±5% TCR (PPM/C) 110MΩ ~ 500MΩ ±500 510MΩ ~ 1GΩ ±1000 110MΩ ~ 500MΩ ±500 510MΩ ~ 1GΩ ±1000 -55 ~ +125C HMR06 (1206) 1/4W 200V 400V Operating Voltage=√(P*R) or Max. Operating Voltage listed above, whichever is lower. Overload Voltage=2.5*√(P*R) or Max. Overload Voltage listed above, whichever is lower. ■ Viking is capable of manufacturing the optional spec based on customer’s requirement. www.viking.com.tw For detail questions, contact:sales@viking.com.tw 2 Edition: REV.A5 Revision: 10-Mar-2021 【HMR Series】 High Ohmic Chip Resistor ■Environmental Characteristics Requirement Item Temperature Coefficient of Resistance (T.C.R.) Test Method 5% JIS-C-5201-1 4.8 IEC-60115-1 4.8 As Spec. Short Time Overload (2.0%+0.05Ω) Insulation Resistance 10G At 25C/-55C and 25C/+125C, 25C is the reference temperature JIS-C-5201-1 4.13 IEC-60115-1 4.13 RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds JIS-C-5201-1 4.6 IEC-60115-1 4.6 Max. Overload Voltage for 1 minute Endurance Damp Heat with Load Dry Heat JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 (3.0%+0.10Ω) 702C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.24 IEC-60115-1 4.24 (3.0%+0.10Ω) 402C, 90~95% R.H., RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 (1.5%+0.10Ω) at +125 C for 1000 hrs JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending Strength (1.0%+0.05Ω) Bending once for 60 seconds 0805, 1206 sizes: 3mm Solderability JIS-C-5201-1 4.17 IEC-60115-1 4.17 95% min. coverage 2455C for 3 seconds Resistance to Soldering Heat JIS-C-5201-1 4.18 IEC-60115-1 4.18 (1.0%+0.05Ω) 2605C for 10 seconds Voltage Proof JIS-C-5201-1 4.7 IEC-60115-1 4.7 No breakdown or flashover 1.42 times Max. Operating Voltage for 1 minute Leaching Individual leaching area ≦5% JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 Total leaching area ≦ 10% 2605C for 30 seconds JIS-C-5201-1 4.19 IEC-60115-1 4.19 Rapid Change of Temperature (1.0%+0.05Ω) -55C to +125C, 5 cycles RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. ■ Storage Temperature: 15~28°C; Humidity < 80%RH www.viking.com.tw For detail questions, contact:sales@viking.com.tw 3 Edition: REV.A5 Revision: 10-Mar-2021 【HMR Series】 High Ohmic Chip Resistor ▓Packaging Reel Specifications & Packaging Quantity Tape Width Reel Diameter ΦA (mm) 5K 8mm 7 inch 178.5±1.5 10K 8mm 10 inch 254±1.0 20K 8mm 13 inch 330±1.0 Packaging Quantity Type HMR05 Paper HMR06 ΦB (mm) ΦC (mm) W (mm) T (mm) 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 60 +1/-0 Paper Tape Specifications Bottom Tape Top Tape ψ D0 E A F W B T A (mm) Type B (mm) W (mm) P1 Resistor Paper Tape E (mm) F (mm) P2 P0 (mm) P0 Direction of unreeling P1 (mm) ΦD0 (mm) P2 (mm) T (mm) HMR05 1.60±0.10 2.40±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 HMR06 1.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 ■Marking 5% for 0805/1206: 3 digits marking in E24 st Example: 101=100Ω 102=1KΩ (1 and 2 E24 code 10 11 www.viking.com.tw 12 13 15 16 nd 18 rd are E24 code and 3 code is multiplier) 20 22 24 27 30 33 36 39 43 For detail questions, contact:sales@viking.com.tw 4 47 51 56 62 68 75 82 91 Edition: REV.A5 Revision: 10-Mar-2021 【HMR Series】 High Ohmic Chip Resistor REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version A2 Jun 03, 2014 - - Environmental Characteristics updated Version A3 Jul 15, 2016 - - Remove Material Description Modify Storage Temperature Version A4 May 20, 2019 - - Modify TCR Test description Version A5 Mar 10, 2021 - - Modify Soldering Condition (IPC/JEDEC J-STD-020) - Modify Bending Test description www.viking.com.tw For detail questions, contact:sales@viking.com.tw 5 Edition: REV.A5 Revision: 10-Mar-2021
HMR06JL7--300M 价格&库存
很抱歉,暂时无法提供与“HMR06JL7--300M”相匹配的价格&库存,您可以联系我们找货
