CSRV0204FTDV3303
CSRV0204FTDV3303
    VIKING(光颉)
    MELF_D1.4X3.5MM_SM
    贴片电阻 MELF_D1.4X3.5MM_SM 330KΩ ±1% 1/4W ±50ppm/℃
CSRV0204FTDV3303 数据手册
Data Sheet Customer: Product: Metal Film Precision MELF Resistor-CSRV Series Size: 0102/0204/0207 Issued Date: 10-Mar-21 Edition: REV.B8 VIKING TECH CORPORATION 光頡科技股份有限公司 VIKING TECH CORPORATION KAOHSIUNG BRANCH 光頡科技股份有限公司高雄分公司 VIKING ELECTRONICS (WUXI) CO., LTD. 光頡電子(無錫)有限公司 No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) 10-Mar-21 10-Mar-21 10-Mar-21 Susan Huang J.C. Liu J.C. Liu Prepared by (Sales) Accepted by (Customer) 【CSRV Series】 Metal Film Precision MELF Resistor ■Features -AEC-Q200 Compliance -Thin film technology -Excellent overall stability -Sn termination on Ni barrier layer -Tight tolerance down to ±0.1% -Extremely low TCR down to ±5 PPM/°C -High power rating up to 1 Watts -SMD enabled structure -Lead-free and RoHS compliant ■Applications -Automotive(non-safety parts) -Industrial -Telecommunication -Medical Equipment -Measurement/Testing Equipment TECHNICAL SPECIFICATIONS DESCRIPTION CSRV0102 CSRV0204 CSRV0207 Resistance range 1Ω-1MΩ; 0Ω 0.1Ω-3.4MΩ; 0Ω 0.1Ω-3.4MΩ; 0Ω ±5%;±1%;±0.5%;±0.25%;±0.1% Resistance tolerance ±100ppm/℃; ±50ppm/℃; ±25ppm/℃; ±15ppm/℃ Temperature coefficient Operation mode Standard Power rating P70 1/8W 1/5W Operating voltage Umax. 150V 200V ±100ppm/℃; ±50ppm/℃; ±25ppm/℃; ±15ppm/℃; ±10ppm/℃; ±5ppm/℃ High power Standard High power Standard High power 0.3W 1/4W 2/5W 1/2W 1W 200V 200V 200V 300V 350V -55℃~155℃ Operating temperature range Max. resistance change at P70 for resistance range, ΔR/R max., after 1000 h ≦0.5% ≦0.5% ≦0.5% ■Construction & Dimension www.viking.com.tw  Insulation Coating  Electrode Cap  Trimming Line  Resistor Layer  Ceramic Rod  Marking Type L (mm) L1 min. (mm) ΦD (mm) ΦD1 (mm) K (mm) Weight 1,000EA (g) CSRV0102 2.20±0.10 1.1 1.10±0.10 D +0/-0.15 0.45±0.05 7.7 CSRV0204 3.50±0.2 1.7 1.40±0.15 D +0/-0.2 0.8±0.1 18.7 CSRV0207 5.90±0.2 2.9 2.20±0.20 D +0/-0.2 1.3±0.1 80.9 For detail questions, contact:sales@viking.com.tw 1 Edition: REV.B8 Revision: 10-Mar-2021 【CSRV Series】 Metal Film Precision MELF Resistor ■Part Numbering Part Number:CSRV0204DTDV1001 Part Number:CSRV0204JT-VR0R0 C S R V 0 2 0 4 D T D V 1 0 0 1 C S R V 0 2 0 4 J T - V R 0 R 0 Product Type CSRV Dimensions (L×ΦD) 0102: 2.2x1.1 0204: 3.5x1.4 0207: 5.9x2.2 Resistance Tolerance B: ±0.1% C: ±0.25% D: ±0.5% F: ±1% J: ±5% or Jumper ■Recommend Land Pattern Packaging Code TCR (PPM/°C) T: Taping Reel S: ±5 B: ±10 N: ±15 C: ±25 D: ±50 E: ±100 -: Jumper Power Rating T: 1W U: 1/2W V: 1/4W G: 2/5W P: 1/5W W: 1/8W L: 0.3W Resistance 0010: 1Ω 0100: 10Ω 2201: 2200Ω 1001: 1KΩ 1004: 1MΩ R050: 0.05Ω 22R1: 22.1Ω R0R0: 0Ω ■Derating Curve Derating Curve 100 A Type A (mm) B (mm) C (mm) CSRV0102 1.0 0.8 1.5 CSRV0204 1.6 1.2 1.6 CSRV0207 3.0 1.7 2.4 Power ratio (%) B . C 80 Except for 5ppm 60 5ppm 40 20 0 0 20 40 60 80 100 120 140 160 Ambient Temperature ( ℃ ) ■Soldering Condition (IPC/JEDEC J-STD-020) www.viking.com.tw For detail questions, contact:sales@viking.com.tw 2 Edition: REV.B8 Revision: 10-Mar-2021 【CSRV Series】 Metal Film Precision MELF Resistor ■Standard Electrical Specifications Item Type 0102 Power Rating at 70°C 1/8W Operating Max. Max. Temp. Operating Overload Range Voltage Voltage -55 ~ +155C 150V 300V Resistance Range ±0.1% ±0.25% ±0.5% 100Ω-56KΩ 49.9Ω100Ω-82KΩ 200KΩ - TCR (PPM/°C) ±1% 49.9Ω390KΩ 1Ω-1MΩ 200V 400V - ±15 - ±25 ±50 1Ω-1MΩ -55 ~ +125C ±5% 10Ω-332KΩ ±100 - ±5 49.9Ω-20KΩ 0204 1/4W 10Ω-300KΩ -55 ~ +155C 200V 10Ω-1MΩ 400V 10Ω-1MΩ 1Ω-1MΩ 0207 1/2W -55 ~ +155C 300V 600V 0.2Ω-3.4MΩ ±50 0.1Ω-1MΩ ±100 ±25 - 10Ω-1MΩ 10Ω-1MΩ ±15 1Ω-3.4MΩ 10Ω-332KΩ 600V 1Ω-3.4MΩ ±5 49.9Ω-20KΩ 10Ω-300KΩ 300V ±10 10Ω-3.4MΩ - -55 ~ +125C - 1Ω-1MΩ - - ±10 ±15 10Ω-3.4MΩ 1Ω-3.4MΩ ±25 1Ω-3.4MΩ 0.2Ω-3.4MΩ 0.1Ω-1MΩ ±50 ±100 ■High Power Rating Electrical Specifications Item Type Power Rating at 70°C Operating Max. Max. Temp. Operating Overload Range Voltage Voltage Resistance Range ±0.1% ±0.25% ±0.5% ±1% ±5% 100Ω-56KΩ 1/5W -55 ~ +155C 0102 49.9Ω200KΩ 100Ω-82KΩ 200V 400V - 49.9Ω390KΩ -55 ~ +125C 200V 400V 2/5W -55 ~ +155C 200V 400V 350V 700V 1W -55 ~ +155C 350V 700V 10Ω-1MΩ - 10Ω-3.4MΩ 1Ω - 1MΩ 1Ω – 3.4MΩ 10Ω-332KΩ 1Ω-1MΩ ±10 ±15 1Ω-3.4MΩ ±25 0.2Ω-3.4MΩ ±50 0.1Ω-1MΩ ±100 - 10Ω-1MΩ 10Ω-1MΩ ±100 ±5 ±5 49.9Ω-20KΩ 10Ω-300KΩ 0207 ±25 - -55 ~ +125C - 1Ω-1MΩ 10Ω-332KΩ 10Ω-1MΩ ±15 ±50 49.9Ω-20KΩ 10Ω-300KΩ 0204 - 1Ω-1MΩ 0.3W TCR (PPM/°C) - ±10 ±15 10Ω-3.4MΩ 1Ω-3.4MΩ ±25 1Ω-3.4MΩ 0.2Ω-3.4MΩ ±50 0.1Ω-1MΩ ±100 Operating Voltage=√(P*R) or Max. Operating Voltage listed above, whichever is lower. Overload Voltage=2.5*√(P*R) or Max. Overload Voltage listed above, whichever is lower. RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. ■ Viking is capable of manufacturing the optional spec based on customer’s requirement. www.viking.com.tw For detail questions, contact:sales@viking.com.tw 3 Edition: REV.B8 Revision: 10-Mar-2021 【CSRV Series】 Metal Film Precision MELF Resistor ■Jumper Specifications Item Power Rating Operating Temp.Range Resistance Rated Current Type 1/8W CSRV0102 1/5W 2A -55 ~ +155C 0.3W 1/4W CSRV0204 -55 ~ +155C 2/5W 0Ω(
CSRV0204FTDV3303 价格&库存
很抱歉,暂时无法提供与“CSRV0204FTDV3303”相匹配的价格&库存,您可以联系我们找货
