RT0805WRB0747RL
RT0805WRB0747RL
    YAGEO(国巨)
    贴片电阻 0805 47Ω ±0.05% 1/8W ±10ppm/℃
RT0805WRB0747RL 数据手册
Product specification – May 25, 2004 V.1 Supersedes Date of Nov. 11, 2003 DATA SHEET CHIP RESISTORS RT Series (Pb Free) 1%; 0.5%; 0.25%; 0.1% 2 Chip Resistor Surface Mount RT 9 (Pb Free) SERIES SCOPE This specification describes RT series chip resistors with lead-free terminations made by thin film process. ORDERING INFORMATION Part number is identified by the series, size, tolerance, packing style, temperature coefficient, special type and resistance value. RT XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) MARKING RT0805/RT1206/RT1210/RT2010/RT2512 (1) SIZE 0201 = 0.024×0.012 0402 = 0.040×0.020 0603 = 0.063×0.033 0805 = 0.083×0.051 1206 = 0.122×0.063 1210 = 0.122×0.102 2010 = 0.197×0.098 2512 = 0.250×0.126 Either resistance in E-24 or E-96: 4 digits First three digits for significant figure and 4th digit for number of zeros ynsc004 Fig. 1 Value=10KΩ RT0603 E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros ynsc015 Fig. 2 Value=12KΩ (2) TOLERANCE L = ±0.01% (on request) W = ±0.05% (on request) B= ±0.1% C= ±0.25% D= ±0.5% F = ±1% (3) PACKAGING TYPE R = Paper taping reel K = Embossed Plastic Tape Reel (4) TEMPERATURE CHARACTERISTIC OF RESISTANCE B = ±10 ppm/°C (on request) C = ±15 ppm/°C (on request) D = ±25 ppm/°C E = ±50 ppm/°C (5) SPECIAL TYPE 07 = 7 inch dia. Reel 13 = 13 inch dia. Reel (6) RESISTANCE VALUE 5R6, 56R, 560R, 5K6, 56K, 1M (7) RESISTOR TERMINATIONS L = Lead free terminations (pure Tin) E-96 series: 3 digits for 0603±1% EIA-96 marking method. See Table 1 + ynsc002 Fig. 3 Value=12.4KΩ RT0201/ RT0402/ RESISTANCE VALUE IS NOT IN E-24 / E96 SERIES No value marking ynsc007 Fig. 4 EIA - 96 MARKING RULE Table 1 shows the first two digits of the three-digit EIA-96 part-marking scheme. Code Value Code Value Code Value Code Value Code Value Code Value Code Value Code Value 01 02 03 04 05 06 07 08 09 10 11 12 100 102 105 107 110 113 115 118 121 124 127 130 13 14 15 16 17 18 19 20 21 22 23 24 133 137 140 143 147 150 154 158 162 165 169 174 25 26 27 28 29 30 31 32 33 34 35 36 178 182 187 191 196 200 205 210 215 221 226 232 37 38 39 40 41 42 43 44 45 46 47 48 237 243 249 255 261 267 274 280 287 294 301 309 49 50 51 52 53 54 55 56 57 58 59 60 316 324 332 340 348 357 365 374 383 392 402 412 61 62 63 64 55 66 67 68 69 70 71 72 422 432 442 453 464 475 487 499 511 523 536 549 73 74 75 76 77 78 79 80 81 82 83 84 562 576 590 604 619 634 649 665 681 698 715 732 85 86 87 88 89 90 91 92 93 94 95 96 750 768 787 806 825 845 866 887 909 931 953 976 The third character is a letter multiplier: X=10 -1 , Y=10 -2 , A=10 0, B=10 1, C=10 2, D=10 3, E=10 4, F=10 5 www.yageo.com May 25, 2004 V.1 3 Chip Resistor Surface Mount RT SERIES 9 (Pb Free) CONSTRUCTION The resistors are constructed out of protective coat a high-grade ceramic body. Internal handbook, 4 columns resistive layer metal electrodes are added at each end and connected by a resistive inner electrode H material. The composition of the end termination resistive material is adjusted to give ceramic substrate MBE940_d I2 the approximate required resistance and laser cutting of this resistive Fig. 5 Chip resistor construction layer that achieves tolerance trims the value. The resistive layer is covered with a protective coat and printed with the resistance value. Finally, the two external terminations (pure Tin) are added. See fig.5 DIMENSION Table 2 For dimension see Table 2 protective coat I1 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) RT0201 0.6±0.10 0.30±0.05 0.25±0.05 0.15±0.10 0.15±0.10 RT0402 1.00±0.10 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 RT0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 W RT0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 RT1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 MBE940_a RT1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.20 0.50±0.20 L RT2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.20 0.50±0.20 Fig. 6 Chip resistor dimension RT2512 6.35±0.10 3.20±0.15 0.55±0.10 0.60±0.20 0.50±0.20 POWER RATING RATED POWER AT 70°C: RATED VOLTAGE: Pmax halfpage handbook, (%Prated ) 100 MLB206_a The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) 50 Where 0 −55 0 50 70 85 100 125 Precision Standard 155 Tamb (°C) Powr Fig. 7 Maximum dissipation (Pmax) in percentage of rated power as a function of the operating ambient temperature (Tamb) V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (X) www.yageo.com May 25, 2004 V.1 4 Chip Resistor Surface Mount RT 9 (Pb Free) SERIES ELECTRICAL CHARACTERISTICS Table 3 CHARACTERISTICS RT0201 OPERATION MODE Precision Standard Power POWER RATING @ 70°C OPERATING TEMPERATURE RANGE RESISTANCE RANGE IN E-24/E-96 (E-192; special value on Request) 1/64W 1/20W 1/16W RT0402 RT0603 RT0805 Precision Standard Power Precision Standard Power Precision Standard Power 1/64W 1/16W 1/10W 1/32W 1/10W 1/8W 1/20W 1/8W 1/5W –10°C to +85°C for precision type; –55°C to +125°C for standard; –55°C to +155°C for power type 33Ω~22KΩ (
RT0805WRB0747RL
物料型号:文档描述的是国巨(YAGEO)的RT系列贴片电阻,这些电阻采用无铅端子,由薄膜工艺制成。
器件简介:RT系列贴片电阻具有多种尺寸和精度,包括1%、0.5%、0.25%和0.1%的容差。电阻值可以是E-24或E-96系列,部分尺寸如RT0603、RT0805等,还有特殊的尺寸如RT0201和RT0402。
引脚分配:文档中没有明确提到引脚分配,因为这是关于电阻器的文档,电阻器通常被视为两个端点的组件。
参数特性:电阻器的参数包括尺寸、公差、包装类型、温度系数和特殊类型。电阻值的表示方法根据E-24或E-96系列有所不同,还提供了无铅端子的选项。
功能详解:文档详细描述了电阻器的构造,包括由高等级陶瓷体、内部金属电极、电阻材料层和保护涂层组成。电阻层通过激光切割来调整电阻值,并在外部加上纯锡端子。
应用信息:虽然文档没有直接提到具体的应用场景,但贴片电阻广泛应用于电子电路中,用于限制电流、分压、匹配阻抗等。
封装信息:提供了不同尺寸的电阻器的详细尺寸数据,包括长度、宽度、高度和内引脚间距。还提供了不同尺寸电阻器的卷带封装信息,包括卷带宽度、卷轴直径等。
RT0805WRB0747RL 价格&库存
很抱歉,暂时无法提供与“RT0805WRB0747RL”相匹配的价格&库存,您可以联系我们找货
