HRG3216P-2002-D-T5
HRG3216P-2002-D-T5
    SUSUMU
    电阻器 20KΩ ±0.5% 1W ±25ppm/℃ 1206
HRG3216P-2002-D-T5 数据手册
High power thin film chip resistors (short side terminal) ■HRG series AEC-Q200 Compliant Features ・ Wider bottom terminal enabling higher power capability (short side terminal) ・ Significantly larger power handling capability than existing same size resistors Thin film surface mount resistors Size: 3216, Power rating: 1.0W, Resistance range: 10 ~ 100KΩ ・ Precision resistance tolerance: ±0.1%, very small TCR: ±25ppm/°C ・ Thin film structure enabling low noise and anti-sulfur Applications ・ Power source related devises ・ DC motors, inverters HRG series ・ Robotics, Industrial control system ◆Part numbering system HRG 3216 P - 1001 - B - T5 Packaging quantity: T1(1,000pcs), T5(5,000pcs) Series code Size: HRG3216 Resistance tolerance Temperature coefficient of resistance Nominal resistance value (E-24, E-96: all 4 digit) ◆Electrical Specification Temperature coefficient of resistance Power ratings Type Resistance range(Ω) Resistance tolerance (ppm/°C) ±0.1% (B) ±25(P) Resistance value series Operating temperature 200V E-24, E-96 -55℃ ~ 155℃ 47≦R≦100k ±50(Q) Packaging quantity ±0.5% (D) 1.0W HRG3216 Maximum voltage 47≦R≦100k 10≦R≦100k T1 T5 ◆Dimensions L a a Type W t b 29 b HRG3216 Size (inch) 1206 L W a b t 3.20±0.20 1.60±0.20 0.50±0.25 1.10±0.20 0.45±0.10 (unit:mm) ◆Reliability specification Standard ≦47Ω ≧47Ω Test items Condition (test methods (JIS C5201-1) Life (biased) 70℃, rated voltage,* 1 90min on 30min off, 1000hours High temperature high humidity 85℃, 85%RH, 1/10 of rated power, 90min on 30min off, 1000hours ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) Temperature shock -55℃ (30min) ∼ 125℃ (30min) 1000cycles ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) High temperature exposure 155℃, no bias, 1000hours ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) Resistance to soldering heat 260±5℃, 10 seconds (reflow) ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) Rated voltage is given by E= R x P E= rated voltage (V), R=nominal resistance value(Ω), P=rated power(W) If rated voltage exceeds maximum voltage /element, maximum voltage/element is the rated voltage. ◆Reliability test data ○High temperature high humidity (biased) 0.12 0.08 0.06 0.12 0.10 Load Life @ 70℃ at Rated Power 1.0W n = 4 0.04 0.02 0.00 -0.02 -0.04 -0.06 HRG3216:10kΩ -0.08 Resistance drift(%) Resistance drift(%) 0.10 -0.10 -0.12 0.08 0.06 0.02 0.00 -0.02 -0.04 -0.06 Test duration(h) 0.12 0.10 Thermal Shock -55℃ - +125℃ n = 25 0.02 0.00 -0.02 -0.04 -0.06 HRG3216:10kΩ -0.08 Resistance drift(%) Resistance drift(%) 10           100          1000       10000 ○High temperature exposure 0.04 0.08 0.06 High Temperature Exposure at 155℃ with no power n = 25 0.04 0.02 0.00 -0.02 -0.04 -0.06 HRG3216:10kΩ -0.08 -0.10 -0.10 -0.12 HRG3216:10kΩ -0.08 -0.12 10           100          1000       10000 0.12 0.06 0.1W n = 25 -0.10 ○Temperature shock 0.08 Temperature Humidity Bias 0.04 Test duration(h) 0.10 HRG series ○Biased life test 10           100          1000       10000 Test duration(h) -0.12 10           100          1000       10000 Test duration(h) Ratio to rated power (%) ◆Derating Curve 100 50 0 -55     Thin film surface mount resistors *1 ±(0.5%+0.05Ω) ±(0.25%+0.01Ω) 0     50 70  100     155 Ambient temperature (℃) 30
HRG3216P-2002-D-T5
物料型号:HRG系列
器件简介: - HRG系列是高功率薄膜芯片电阻器,符合AEC-Q200标准。 - 特点包括更宽的底部终端以实现更高的功率能力,显著大于同等尺寸现有电阻器的功率处理能力。 - 尺寸为3216,功率等级为1.0W,电阻范围为10至100KΩ。 - 精度电阻公差为±0.1%,非常小的温度系数为±25ppm/°C。 - 薄膜结构实现低噪音和抗硫特性。
引脚分配:短侧端子设计,提供更高的功率能力。
参数特性: - 功率等级:1.0W - 电阻范围:10 ~ 100KΩ - 电阻公差:±0.1%(B级),±0.5%(D级) - 最大电压:200V - 工作温度范围:-55°C至155°C
功能详解: - 适用于电源相关设备、直流电机、逆变器、机器人技术、工业控制系统等。
应用信息: - 适用于电源相关设备、直流电机、逆变器、机器人技术、工业控制系统。
封装信息: - 尺寸:1206(3.20±0.20mm x 1.60±0.20mm) - 封装类型:HRG3216 - 包装数量:T1(1,000pcs),T5(5,000pcs)
可靠性规范: - 包括偏置寿命测试、高温高湿测试、温度冲击测试、高温暴露测试和耐焊热测试。
额定电压计算公式:E = R x P,其中E是额定电压(V),R是标称电阻值(Ω),P是额定功率(W)。
HRG3216P-2002-D-T5 价格&库存
很抱歉,暂时无法提供与“HRG3216P-2002-D-T5”相匹配的价格&库存,您可以联系我们找货
HRG3216P-2002-D-T5
