CSRL / CSNL Series — Metal Foil Current Sensing Resistors
Features
• 2512 size
• TCR down to ±50 ppm/°C
• 2W of power
• Current handling to 63 amps
• Low inductance – typically less than 0.1nH • Non-standard resistance values available
• Resistances down to 0.0005 (1/2 milliΩ)
• RoHS compliant / lead-free available
Electrical Specifications
Type / Code
Package Type
Power Rating
(Watts) @ 70°C
Dielectric
Withstanding Voltage
Resistance
Temperature Coefficient
Ohmic Range and Tolerance
1%
5%
CSRL 2
2512
2W
200V
±50 ppm/°C
0.001Ω, 0.002Ω
0.001Ω, 0.002Ω
CSNL 2
2512
2W
200V
±50 ppm/°C
0.001Ω – 0.007Ω
0.001Ω – 0.007Ω
Performance Characteristics
Test
Test Specification
Typical
Moisture Resistance
±0.5%
≤0.5%
Load Life
±0.5%
≤0.5%
Leach Resistance
90 seconds min
>90 seconds
Resistance to Soldering Heat
±0.5%
≤0.25%
Solderability
min 95% coverage
≥95%
Temperature Cycling
±0.5%
≤0.5%
Thermal Shock
±0.5%
≤0.5%
Short Time Overload
±0.5%
≤0.5%
Insulation Resistance
1MΩ minimum
≥1MΩ
How to Order
CSRL
2
0.01
1%
R
SEI Type
Code
Nominal Resistance
Tolerance
Packaging
Type
Description
Code
Size
Tolerance
CSRL
Standard
2
2512
1%
CSNL
Narrow Terminations
Toll Free: (888) SEI-SEIS
(888) 734-7347
SEI Type Pkg Qty
All
2,000
Description
Code
7" - Paper Tape
R
5%
www.seielect.com
33
email: marketing@seielect.com
Rev 03/07
Mechanical Specifications
Type / Code
L
Body Length
W
Body Width
H
Body Height
a
Top Termination
b
Bottom Termination
Units
CSRL 2 (2mΩ)
6.50 ± 0.33
3.20 ± 0..33
0.70 ± 0.15
1.90 ± 0.15
1.90 ± 0.15
mm
CSRL 2 (1mΩ)
6.50 ± 0.33
3.20 ± 0.33
0.80 ± 0.15
2.50 ± 2.50
2.50 ± 0.15
mm
CSNL 2 (0.5mΩ)
6.35 ± 0.25
3.18 ± 0.25
1.40 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (0.75mΩ)
6.35 ± 0.25
3.18 ± 0.25
1.00 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (1mΩ)
6.35 ± 0.25
3.18 ± 0.25
0.80 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (1.5mΩ)
6.35 ± 0.25
3.18 ± 0.25
0.65 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (2mΩ)
6.35 ± 0.25
3.18 ± 0.25
0.50 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (2.5mΩ)
6.35 ± 0.25
3.18 ± 0.25
1.00 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (3mΩ)
6.35 ± 0.25
3.18 ± 0.25
0.70 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (3.5mΩ)
6.35 ± 0.25
3.18 ± 0.25
0.71 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (4mΩ)
6.35 ± 0.25
3.18 ± 0.25
0.60 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (4.5mΩ)
6.35 ± 0.25
3.18 ± 0.25
0.58 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (5mΩ)
6.35 ± 0.25
3.18 ± 0.25
0.50 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (5.5mΩ)
6.35 ± 0.25
3.18 ± 0.25
0.47 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (6mΩ)
6.35 ± 0.25
3.18 ± 0.25
0.50 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (6.5mΩ)
6.35 ± 0.25
3.18 ± 0.25
0.47 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
CSNL 2 (7mΩ)
6.35 ± 0.25
3.18 ± 0.25
0.45 ± 0.20
1.30 ± 0.30
1.30 ± 0.30
mm
Solder Pad Dimensions
Type / Code
L
Total Length
W
Total Width
D
Pad Depth
Units
CSRL 2
8.00
4.00
3.35
mm
CSNL 2
8.00
4.00
2.00
mm
(888) 734-7347
www.seielect.com
34
Rev 03/07
很抱歉,暂时无法提供与“CSRL2512FT1L00”相匹配的价格&库存,您可以联系我们找货
