KHC250E335Z32N0T00
KHC250E335Z32N0T00
    NCC(贵弥功)
    贴片电容(MLCC) 1210 3.3µF -20~+80% 25V Y5U
KHC250E335Z32N0T00 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS / RoHS Compliant (High Reliability) ?FEATURES 1. Small size and large capacitance, high ripple current. 2. Temperature characteristic is Y5U in EIA code. 3. Superior humidity characteristic and long life. 4. Excellent noise absorption. ?APPLICATIONS 1. Smoothing circuit of small size DC-DC converter. 2. On-board power supply. 3. Noise suppressor for various kinds of equipments. 4. By-pass or decoupling circuits. ?CONSTRUCTION Ceramic Dielectric Termination Tin Plating (21, 31, 32, 43size : For flow or reflow soldering) (55, 76size : For reflow soldering only) Silver (THC Series only) (All sizes : For reflow soldering only) Internal Electrode ?RATINGS 1. 2. 3. 4. 5. 6. Category Temperature Range Rated Voltage Range Rated Capacitance Range Rated Capacitance Tolerance Temperature Characteristics Rated Ripple Current -55 to +125C 25, 50, 100, 200Vdc 0.047 to 47MF M (P20%) , Z (P80 20%) E (JIS) Y5U (EIA) See No.5 on the following table ?SPECIFICATIONS No. Items Specification Test Condition 1 Withstand Voltage No abnormality. 250% of rated voltage shall be applied for 5 seconds. 2 Insulation Resistance 1000/CR(MO) or 10000(MO) whichever is less. Rated voltage shall be applied for 60P5 seconds at temperature 20P2C. 3 Rated Capacitance Within specified tolerance. Temperature Frequency Voltage : 20P2C : 1P0.1kHz : 1P0.2Vrms 4 Dissipation Factor 5.0% maximum. Temperature Frequency Voltage : 20P2C : 1P0.1kHz : 1P0.2Vrms 5 Rated Ripple Current Size code 21 31 32 43 55 76 Arms 0.2 0.3 0.5 1.0 2.0 3.0 (1/4) 10kHzK1MHz (sine curve) Ripple voltage Vp shall be less than the rated voltage. CAT. No. E1002P MULTILAYER CERAMIC CHIP CAPACITORS / ?SPECIFICATIONS No. 6 Items Adhesion Specification Test Condition No visible damage. Substrate 5N (0.51kgf) for 10P1 seconds Capacitor 7 Bend strength of the face plating Appearance : No visible damage. DC/C : P15% The substrate shall be bend by 1mm at a rate of 1mm/s for 5 seconds. Press Press bar Capacitor Substrate 1.0mm 45P2mm 8 Solderability Min. 75% of surface of the termination shall be covered with new solder 9 Resistance to Soldering Heat Appearance : No visible damage. DC/C : P15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. 10 Temperature Cycle Appearance : No visible damage. DC/C : P15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. 45P2mm Solder Solder Temperature Dipping Time Support Pb Free Eutectic 245P5C 235P5C 2P0.5sec. Solder Temperature : 260P5C Dipping Time : 2P0.5 seconds Step 1 2 3 4 Temperature (C) Min. Category temperature P3 Room temperature Max. Category temperature P3 Room temperature (min.) 30P3 3 max. 30P3 3 max. THC series : 5 cycles TMC series : 100 cycles 11 Humidity Load Life Appearance : No abnormality. DC/C : P20% D.F. : 7% maximum I.R. : 50/CR(MO) or 1000(MO) whichever is less. Temperature : 40P2C Humidity : 90 to 95%RH Voltage : Rated voltage Time : 500P24 0 hours 12 Endurance Appearance : No abnormality. DC/C : P20% D.F. : 7% maximum I.R. : 100/CR(MO) or 1000(MO) whichever is less. Temperature : 85P2C Voltage : 200% of rated voltage. hours Time : 1000P48 0 Temperature : 125P3C Voltage : Rated voltage Time : 1000P48 0 hours *CR : Rated Capacitance(MF) (2/4) CAT. No. E1002P MULTILAYER CERAMIC CHIP CAPACITORS ?STANDARD RATINGS Dimensions(mm) Rated Capacitance (mF) L 0.33 0.47 0.68 1.0 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 2.2 3.3 4.7 6.8 10 15 22 0.047 0.068 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 2.2 3.3 4.7 6.8 0.047 0.068 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 2.2 25 50 100 200 W Tmax. a 2.0P0.2 1.25P0.2 1.25 0.3P0.2 0.2 3.2P0.2 1.6P0.2 1.6 0.5P0.3 0.3 3.2P0.2 2.5P0.2 2.0 0.6P0.3 0.5 4.5P0.3 3.2P0.2 2.2 0.6P0.3 1.0 0.8P0.5 2.0 0.8P0.5 3.0 5.7P0.4 5.0P0.4 7.5P0.5 6.3P0.5 3.0 2.2 3.0 3.0 2.0P0.2 1.25P0.2 1.25 0.3P0.2 0.2 3.2P0.2 1.6P0.2 1.6 0.5P0.3 0.3 3.2P0.2 2.5P0.2 0.6P0.3 0.5 0.6P0.3 1.0 4.5P0.3 3.2P0.2 5.7P0.4 5.0P0.4 2.0 2.5 2.2 3.0 2.2 0.8P0.5 2.0 7.5P0.5 6.3P0.5 3.0 2.5 0.8P0.5 3.0 2.0P0.2 1.25P0.2 1.25 0.3P0.2 0.2 3.2P0.2 1.6P0.2 1.6 0.5P0.3 0.3 3.2P0.2 2.5P0.2 0.6P0.3 0.5 2.0 2.5 4.5P0.3 3.2P0.2 2.2 5.7P0.4 5.0P0.4 7.5P0.5 6.3P0.5 3.0 2.2 3.0 3.0 3.2P0.2 1.6P0.2 1.6 3.2P0.2 2.5P0.2 4.5P0.3 3.2P0.2 5.7P0.4 5.0P0.4 7.5P0.5 6.3P0.5 2.0 2.5 2.2 3.0 2.2 3.0 2.5 3.0 0.6P0.3 1.0 0.8P0.5 2.0 0.8P0.5 3.0 0.5P0.3 0.3 0.6P0.3 0.5 0.6P0.3 1.0 0.8P0.5 2.0 0.8P0.5 3.0 ?PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 Maximum ripple current (Arms) 9 10 11 12 13 14 15 Part Number Previous Part Number KHC250E334M21N0T00 KHC250E474M21N0T00 KHC250E684M21N0T00 KHC250E105M31N0T00 KHC250E155M31N0T00 KHC250E225M31N0T00 KHC250E335M32N0T00 KHC250E475M32N0T00 KHC250E685M43N0T00 KHC250E106M43N0T00 KHC250E156M43N0T00 KHC250E226M55N0T00 KHC250E336M55N0T00 KHC250E476M76N0T00 KHC500E104M21N0T00 KHC500E154M21N0T00 KHC500E224M21N0T00 KHC500E334M31N0T00 KHC500E474M31N0T00 KHC500E684M31N0T00 KHC500E105M32N0T00 KHC500E155M32N0T00 KHC500E225M32N0T00 KHC500E335M43N0T00 KHC500E475M43N0T00 KHC500E685M55N0T00 KHC500E106M55N0T00 KHC500E156M55N0T00 KHC500E226M76N0T00 KHC101E473M21N0T00 KHC101E683M21N0T00 KHC101E104M31N0T00 KHC101E154M31N0T00 KHC101E224M31N0T00 KHC101E334M32N0T00 KHC101E474M32N0T00 KHC101E684M32N0T00 KHC101E105M43N0T00 KHC101E155M43N0T00 KHC101E225M43N0T00 KHC101E335M55N0T00 KHC101E475M55N0T00 KHC101E685M76N0T00 KHC201E473M31N0T00 KHC201E683M31N0T00 KHC201E104M32N0T00 KHC201E154M32N0T00 KHC201E224M32N0T00 KHC201E334M43N0T00 KHC201E474M43N0T00 KHC201E684M55N0T00 KHC201E105M55N0T00 KHC201E155M76N0T00 KHC201E225M76N0T00 THCS20E1E334MTF THCS20E1E474MTF THCS20E1E684MTF THCS30E1E105MTF THCS30E1E155MTF THCS30E1E225MTF THCS40E1E335MTF THCS40E1E475MTF THCS50E1E685MTF THCS50E1E106MTF THCS50E1E156MTF THCS60E1E226MTF THCS60E1E336MTF THCS70E1E476MTF THCS20E1H104MTF THCS20E1H154MTF THCS20E1H224MTF THCS30E1H334MTF THCS30E1H474MTF THCS30E1H684MTF THCS40E1H105MTF THCS40E1H155MTF THCS40E1H225MTF THCS50E1H335MTF THCS50E1H475MTF THCS60E1H685MTF THCS60E1H106MTF THCS60E1H156MTF THCS70E1H226MTF THCS20E2A473MTF THCS20E2A683MTF THCS30E2A104MTF THCS30E2A154MTF THCS30E2A224MTF THCS40E2A334MTF THCS40E2A474MTF THCS40E2A684MTF THCS50E2A105MTF THCS50E2A155MTF THCS50E2A225MTF THCS60E2A335MTF THCS60E2A475MTF THCS70E2A685MTF THCS30E2D473MTF THCS30E2D683MTF THCS40E2D104MTF THCS40E2D154MTF THCS40E2D224MTF THCS50E2D334MTF THCS50E2D474MTF THCS60E2D684MTF THCS60E2D105MTF THCS70E2D155MTF THCS70E2D225MTF (Just for your reference) ?DIMENSIONS 16 17 18 T K HC 1 0 1 E 4 7 5 M 5 5 N 0 T 0 0 Supplement code Taping code Terminal code Size code Capacitance tolerance code Nominal Capacitance code Temperature characteristics code Rated voltage code Series code Category (3/4) L W Rated voltage (Vdc) a CAT. No. E1002P MULTILAYER CERAMIC CHIP CAPACITORS ?STANDARD RATINGS Dimensions(mm) Rated voltage Rated Capacitance (Vdc) (mF) L 0.68 1 1.5 2.2 3.3 4.7 6.8 10 0.33 0.47 0.68 1.0 1.5 2.2 3.3 4.7 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 0.033 0.047 0.068 0.1 0.15 0.22 0.33 0.47 25 50 100 200 W Tmax. a 3.2P0.2 1.6P0.2 1.6 0.4P0.2 0.3 3.2P0.2 2.5P0.2 2.2 0.5P0.2 0.5 4.5P0.3 3.2P0.2 0.5P0.3 1.0 0.4P0.2 0.3 0.5P0.2 0.5 0.5P0.3 1.0 2.5 3.0 3.2P0.2 1.6P0.2 3.2P0.2 2.5P0.2 1.6 2.2 2.5 4.5P0.3 3.2P0.2 2.5 3.0 3.2P0.2 1.6P0.2 1.6 0.4P0.2 0.3 3.2P0.2 2.5P0.2 2.2 0.5P0.2 0.5 4.5P0.3 3.2P0.2 0.5P0.3 1.0 0.4P0.2 0.3 0.5P0.2 0.5 0.5P0.3 1.0 2.5 3.0 3.2P0.2 1.6P0.2 3.2P0.2 2.5P0.2 1.6 2.2 2.5 4.5P0.3 3.2P0.2 2.5 3.0 ?PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 Maximum ripple current (Arms) 10 11 12 13 14 15 Part Number Previous Part Number KMC250E684M31N0T00 KMC250E105M31N0T00 KMC250E155M31N0T00 KMC250E225M32N0T00 KMC250E335M32N0T00 KMC250E475M43N0T00 KMC250E685M43N0T00 KMC250E106M43N0T00 KMC500E334M31N0T00 KMC500E474M31N0T00 KMC500E684M32N0T00 KMC500E105M32N0T00 KMC500E155M32N0T00 KMC500E225M43N0T00 KMC500E335M43N0T00 KMC500E475M43N0T00 KMC101E104M31N0T00 KMC101E154M31N0T00 KMC101E224M32N0T00 KMC101E334M32N0T00 KMC101E474M32N0T00 KMC101E684M43N0T00 KMC101E105M43N0T00 KMC101E155M43N0T00 KMC201E333M31N0T00 KMC201E473M31N0T00 KMC201E683M32N0T00 KMC201E104M32N0T00 KMC201E154M32N0T00 KMC201E224M43N0T00 KMC201E334M43N0T00 KMC201E474M43N0T00 TMCS30E1E684MTF TMCS30E1E105MTF TMCS30E1E155MTF TMCS40E1E225MTF TMCS40E1E335MTF TMCS50E1E475MTF TMCS50E1E685MTF TMCS50E1E106MTF TMCS30E1H334MTF TMCS30E1H474MTF TMCS40E1H684MTF TMCS40E1H105MTF TMCS40E1H155MTF TMCS50E1H225MTF TMCS50E1H335MTF TMCS50E1H475MTF TMCS30E2A104MTF TMCS30E2A154MTF TMCS40E2A224MTF TMCS40E2A334MTF TMCS40E2A474MTF TMCS50E2A684MTF TMCS50E2A105MTF TMCS50E2A155MTF TMCS30E2D333MTF TMCS30E2D473MTF TMCS40E2D683MTF TMCS40E2D104MTF TMCS40E2D154MTF TMCS50E2D224MTF TMCS50E2D334MTF TMCS50E2D474MTF (Just for your reference) ?DIMENSIONS 16 17 18 T K MC 2 0 1 E 1 0 4 M 3 2 N 0 T 0 0 (4/4) L W Supplement code Taping code Terminal code Size code Capacitance tolerance code Nominal Capacitance code Temperature characteristics code Rated voltage code Series code Category a CAT. No. E1002P
KHC250E335Z32N0T00
物料型号:CHEMI-CON NIPPON多层陶瓷片式电容器
器件简介: - 小型化且具有较大的电容和高纹波电流。 - 温度特性为EIA代码中的Y5U。 - 出色的湿度特性和长寿命。 - 优秀的噪声吸收能力。
应用信息: 1. 小型DC-DC转换器的平滑电路。 2. 板载电源。 3. 各种设备的噪声抑制器。 4. 旁路或去耦电路。
引脚分配:文档中未提供具体的引脚分配信息。
参数特性: - 类别温度范围:-55至+125°C。 - 额定电压范围:25, 50, 100, 200Vdc。 - 额定电容范围:0.047至47μF。 - 额定电容公差:M(±20%), Z(±5%)。 - 温度特性:E(JIS)Y5U(EIA)。 - 额定纹波电流:见下表5。
功能详解:文档提供了详细的规格说明,包括耐电压、绝缘电阻、额定电容、耗散因数、额定纹波电流、粘附性、端面镀层的弯曲强度、可焊性、耐焊热性、温度循环、湿度负荷寿命和耐久性等测试条件和规格。
封装信息:提供了不同尺寸和额定电压的电容器的标准额定值,包括最大纹波电流和部件编号。
KHC250E335Z32N0T00 价格&库存
很抱歉,暂时无法提供与“KHC250E335Z32N0T00”相匹配的价格&库存,您可以联系我们找货
