規 格 承 認 書
PECIFICATION FOR APPROVAL
客 戶
CUSTOMER
項 目
ITEM
型 號
驻极体电容咪头(ECM)
TYPE
: GMI6027-2C48DB
DESCRIPTION :
φ6.0 x 2.7 MM 焊点 1033 -48 dB 2V ≤2.2KΩ S/N: ≥58 dB
客戶料號
CUSTOMER NO. :
規 格 書 號
SPECIFICATION NO.:
版 本
EDITION NO.
日 期
DATE
V1.0
2020-1-9
客戶承認
CUSTOMER CONFIRM AND SIGN
檢查
審核
承認
TESTED BY
CHECKED BY
APPROVED BY
東莞市赢海電子有限公司
DONGUAN INGHAI ELECTRONICS CO.,LTD
製作
審查
確認
ISSUED BY
CHECKED BY
APPROVED BY
周明
地址:廣東省東莞市
電話 / TEL:0769-83060958
傳真 / FAX: 0769-81608993
網址:HTTP://WWW.INGHAI.COM
1/5
A. SCOPE
This specification applies electret condenser microphone, GMI6027-2C48DB
B. SPECIFICATION
■Test condition: RL=2.2KΩ
No.
Item
1
Directivity
2
Sensitivity
3
Standard operating voltage
VS=2.0V TEMP=25℃±2℃
Symbol
Unit
Specification
Related humidity=65±5%
Condition
Omnidirectional
S
dB
-48±3
Vs
V
2.0
Zout
KΩ
≤2.2
0dB=1V/Pa 1KHz
4
Output impedance
5
Frequency
Hz
100-10000
6
Max operating voltage
V.
10
7
Sensitivity reduction
△S-Vs
dB
-3
8
Max. current consumption
IDSS
mA
≤0.5
9
Signal to noise ration
S/N
dBA
≥58
10
Max. Sound Pressure Level
S.P.L
dB
110
11
Operation temp.
-20 ~+60
12
Storage temp.
-30 ~+70
13
Dimension
mm
φ6.0 x 2.7
See appearance drawing
14
Terminal
Terminal
Vs=1.5VDC to 3VDC
2/5
C. TYPICAL FREQUENCY RESPONSE CURVE
Relative Response (dB)
全指向性
+20
+10
-10
+8
-3
+3
+3
-3
-3
-6
5000
10000
-20
-30
100
200
500
1000
2000
20000
Frequency (Hz)
D. APPEARANCE DRAWING
3/5
E. MEASUREMENT CIRCUIT
Measurement Circuit
Vs:Source Voltage2.0V
RL:Load Resistance2.2KΩ
C1=10pF C2=33pF
F. 可靠性试验
Reliability Test
经过以下所有试验在 20℃的条件下放置 3 小时后,麦克风的灵敏度与试验前比较变化在 3dB 以
内
After any following tests, the sensitivity of the microphone to be within ±3dB of initial sensitivity
after 3hours of conditioning at 20℃
5-1 振动试验
Vibration
5-2 高温试验
Dry Heat
5-3 低温试验
Dry Cold
5-4 高温高湿试验
Damp Heat
5-5 温度循环试验
Temperature cycles
5-6 跌落试验
Packing drop test
5-7 温度冲击试验
Temperature impact test
5-8 静电冲击试验
Electrostatic shock test
周波数 1/Frequency1:10Hz~55Hz
振幅/Amplitude:1.52mm
变化/Change of Frequency:1 octave/min
3 方向,各 2 小时/hours in each of 3 axes
+80±5℃ for 96 hours
-40±5℃ for 96 hours
90%~95%RH,+70±5℃ for 96 hours
-20℃
25℃
70℃
(2h) (1h) (2h) (1h) (2h)×10 cycles
Height:1m
顺序:三个面各跌 10 次
Procedure:10 times from each of 3 axises
-20℃
70℃
30min 30s
30min ×10 cycles
6000V(contact), 8000V(air) ×10 axises
4/5
备注 Note
6-1 工作温度范围
Operation Temperature
6-2 储存温度范围
Storage Temperature
-20℃~70℃
-40℃~80℃
G. 焊接条件
Soldering Condition
7-1 焊接使用 90W 的烙铁。
The soldering copper of a type of 90W shall be applied
焊接条件
Soldering Condition.
7-2 电烙铁表面温度 320±10℃
The temperature of the working surface of the soldering copper shall be 320±10℃
7-3 焊接时把麦克风嵌入散热能力强的金属块内。
ECM shall be soldered fixed on the metal block(heat sink)which has the higher radiation effects said
heat sink
Shall contact with of ECM.
7-4 焊接时间控制在 2~3 秒内。
time for each terminal shall be 2~3 sec.
7-5 焊接后不能出现针孔。
The pinhole after soldering shall be avoided.
7-6 静电容易破坏麦克风必须采取措施避免(电烙铁接地,戴静电环等。)
ECM may easily destroyed by the static electricity and the countermeasure for eliminating the static
electricity (the ground for soldering copper, for worktable and for human body) shall be executed.
7-7 散热板形状
Shape of heat sink
5/5
很抱歉,暂时无法提供与“GMI6027-2C48db”相匹配的价格&库存,您可以联系我们找货
