GMD0955YB-12V2700
GMD0955YB-12V2700
    INGHAI(赢海)
    插件,D9xL5.5mm
    电磁有源一体蜂鸣器(内含驱动电路)
GMD0955YB-12V2700 数据手册
規 格 承 認 書 PECIFICATION FOR APPROVAL 客 戶 CUSTOMER 項 目 ITEM 型 號 : : 电磁有源一体蜂鸣器(内含驱动电路) TYPE : GMD0955YB-12V2700 描述 DESCRIPTION : φ9.0 x 5.5 mm 2700Hz DC12V ≥80dB 客戶料號 CUSTOMER NO. : 規 格 書 號 PBT 耐高温材质 P=5 mm SPECIFICATION NO.: 版 本 EDITION NO. 日 期 DATE : V1.1 : 2014-6-18 客戶承認 CUSTOMER CONFIRM AND SIGN 檢查 審核 TESTED BY CHECKED BY 承認 APPROVED BY 東莞市赢海電子有限公司 DONGUAN INGHAI ELECTRONICS CO.,LTD 製作 審查 ISSUED BY CHECKED BY 周明 刘承成 確認 APPROVED BY 1/4 地址:廣東省東莞市長安鎮上沙管理區北橫路 8 號 電話 / TEL:0769-83060958 傳真 / FAX: 0769-81608993 網址:HTTP://WWW.INGHAI.COM DONGGUAN INGHAI ELECTRONICS CO.,LTD Model NO: GMD0955YB-12V2700 A: DIMEMSIONS Unit:mm Tolerance:±0.5 B: SPECIFICATIONS Model NO GMD0955YB Rated Voltage 12VDC Operating Voltage 8.0~15.0VDC Max.Rated Current Max.30mA Sound Pressure level(dB)at10cm Min.80dB 2/4 Resonant Frequency 2700±300Hz Operating Temperature -20 ℃~+75 ℃ Storage Temperature -30 ℃~+85 ℃ Case material and color PBT / Black Measuring condition Part shall be measured under a condition (Temperature: 5~ 35℃, Humidity: 45% ~ 85%R.H., Atmospheric pressure: 860 ~ 1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H. Atmospheric pressure: 860 ~1060hPa) is regulated to measure. 3/4 C: Acoustic Characteristics The oscillation frequency, current consumption and sound pressure are measured by the measuring instruments shown below D: In the measuring test, buzzer is placed as follows: E: Typical Frequency Response Curve 4/4 F: Reliability Test After any following tests the part shall meet specifications without any degradation in appearance and performance except SPL. SPL shall not deviate more than -10 dB from the initial value 1. Ordinary Temperature Life Test The part shall be subjected to 96 hours at 25±10℃. Input rated voltage 2. 3. 4. 5. 6. 7. Resonant frequency, 1/2 duty Square wave. High Temperature Test The part shall be capable of with standing a storage temperature of +85℃ for 96 hours. Low Temperature Test The part shall be capable of with standing a storage temperature of -30℃ for 96 hours. Humidity Test Temperature:+40℃±3℃ Relative Humidity:90%~95% Duration: 48 hours and expose to room temperature for 6 hours Temperature Shock Test Temperature:75℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle) Total cycle: 10 cycles Drop Test Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick, three sides, six plain.) Vibration Test Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes Note: As this product is not protected from foreign material entering, please make sure that any foreign materials (e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it. 5/4
GMD0955YB-12V2700
1. 物料型号:GMD0955YB-12V2700。 2. 器件简介:这是一个电磁有源一体蜂鸣器,内含驱动电路,尺寸为9.0x5.5 mm,工作频率为2700Hz,工作电压为DC12V,声压级≥80dB,使用PBT耐高温材质,音膜直径P=5mm。 3. 引脚分配:文档中未明确提供引脚分配的信息。 4. 参数特性: - 额定电压:12VDC。 - 工作电压范围:8.0~15.0VDC。 - 最大额定电流:最大30mA。 - 10cm处的声压级:最小80dB。 - 谐振频率:2700±300Hz。 - 工作温度:-20°C~+75°C。 - 存储温度:-30°C~+85°C。 - 外壳材料和颜色:PBT/黑色。 5. 功能详解:文档中提供了测量条件、声学特性、典型频率响应曲线和可靠性测试等信息。 6. 应用信息:文档中未明确提供应用信息,但根据器件的参数特性,适用于需要电磁蜂鸣器的场合。 7. 封装信息:封装尺寸为9.0x5.5 mm,材料为PBT,颜色为黑色。
GMD0955YB-12V2700 价格&库存
很抱歉,暂时无法提供与“GMD0955YB-12V2700”相匹配的价格&库存,您可以联系我们找货
GMD0955YB-12V2700
  • 1+1.92851
  • 30+1.85601
  • 100+1.71101
  • 500+1.56601
  • 1000+1.49351
GMD0955YB-12V2700
  • 1+2.79720
  • 10+2.19240
  • 30+1.93320
  • 100+1.62000
  • 500+1.47960
库存:994
