規 格 承 認 書
PECIFICATION FOR APPROVAL
客 戶
CUSTOMER
項 目
ITEM
: 贴片式电磁有源蜂鸣器(内部驱动)
型 號
TYPE
: GSD128065YB-3V2400
DESCRIPTION : L12.8 X W12.8X H6.5 mm 2400Hz 3V ≥85dB 正发音 PPS 材质
客戶料號
CUSTOMER NO. :
規 格 書 號
SPECIFICATION NO.:
版 本
EDITION NO.
日 期
DATE
V1.0
201
客戶承認
CUSTOMER CONFIRM AND SIGN
檢查
審核
承認
TESTED BY
CHECKED BY
APPROVED BY
東莞市赢海電子有限公司
DONGUAN INGHAI ELECTRONICS CO.,LTD
製作
審查
確認
ISSUED BY
CHECKED BY
APPROVED BY
周明
刘承成
1/6
地址:广东省东莞市虎门镇怀德社区怀雅路雅瑶工业区
電話 / TEL:0769-83060958
傳真 / FAX: 0769-81608993
網址:HTTP://WWW.INGHAI.COM
A. SCOPE
This specification applies SMD piezoelectric buzzer, GSD128065YB-3V2400
B. SPECIFICATION
No.
Item
Unit
Specification
Condition
1
Oscillation Frequency
KHz
2.4 ± 0.3
2
Operating Voltage
VDC
2~ 5
3
Rated Voltage
VDC
3
4
Current Consumption
mA
MAX. 30
at Rated Voltage
5
Sound Pressure Level
dB
MIN. 85
at 10cm at Rated Voltage
6
Tone/Pulse Rate
7
Operating Temperature
-20 ~ +70
8
Storage Temperature
-30 ~ +80
9
Dimension
mm
12.8 x 12.8 x H6.5
10
Weight (MAX)
gram
2.0
11
Housing Material
PPS
12
Leading Pin
Tin Plated Brass(Sn)
13
Environmental
Protection Regulation
RoHS
Constant
See appearance drawing
C. APPEARANCE DRAWING
2/6
Potting
D.TESTING METHOD
Standard Measurement conditions
Temperature:25±2℃ Humidity:45-65%
Acoustic Characteristics:
The oscillation frequency, current consumption and sound pressure are
measured by the measuring instruments shown below
In the measuring test, buzzer is placed as follows:
3/6
E. VOLTAGE / CURRENT / SOUND PRESSURE CHARACTERISTICS
F. Soldering Condition
(1)Recommendable reflow soldering condition is as follows
(Reflow soldering is twice)
Note:It is requested that reflow soldering should be executed
after heat of product goes down to normal.
Heat resistant line
4/6
(Used when heat resistant reliability test is performed)
(2)Manual soldering
Manual soldering temperature 350 ºC within 5 sec.
G: Reliability Test
After any following tests the part shall meet specifications without any degradation in
appearance and performance except SPL. SPL shall not deviate more than -10 dB
from the initial value
1.
2.
3.
4.
5.
6.
7.
Ordinary Temperature Life Test
The part shall be subjected to 96 hours at 25±10℃. Input rated voltage
Resonant frequency, 1/2 duty Square wave.
High Temperature Test
The part shall be capable of with standing a storage temperature of +85℃ for 96 hours.
Low Temperature Test
The part shall be capable of with standing a storage temperature of -30℃ for 96 hours.
Humidity Test
Temperature:+40℃±3℃ Relative Humidity:90%~95% Duration: 48 hours
and expose to room temperature for 6 hours
Temperature Shock Test
Temperature:70℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle)
Total cycle: 10 cycles
Drop Test
Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick,
three sides, six plain.)
Vibration Test
Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes
Measuring condition
Part shall be measured under a condition (Temperature: 5~35℃, Humidity: 45%~85%R.H., Atmospheric
pressure: 860 ~1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H.
Atmospheric pressure: 860 ~1060hPa) is regulated to measure.
Note:
As this product is not protected from foreign material entering, please make sure that any foreign
5/6
materials (e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in
your production processes. The functional degradation (e.g. SPL down) may occur if foreign
material enter it.
H. PACKING STANDARD
6/6
1 Reel : 300PCS
Carton Box
(10 Inner Box)
Inner Box
(1Layer Reel)
Inner Box
330mmx330mmx30mm
1x300PCS=300PCS
Carton Box
350mmx350mmx370mm
10x300PCS=3,000PCS
7/6
很抱歉,暂时无法提供与“GSD128065YB-3V2400”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.75000
- 10+5.58360
- 30+4.93560
- 100+4.21200
- 国内价格
- 1+3.78001
- 10+3.64001
- 100+3.30400
- 500+3.13600
- 国内价格
- 1+15.06730
- 50+8.98820
- 200+6.29180
- 450+4.49410
- 900+4.26940
- 4500+3.95480
