GPC4216L100-12V
GPC4216L100-12V
    INGHAI(赢海)
    Lead wire
    频率3kHz 电压-额定12V
GPC4216L100-12V 数据手册
規 格 承 認 書 PECIFICATION FOR APPROVAL 客 戶 CUSTOMER 項 目 ITEM 型 號 : : 压电无源蜂鸣器(外部驱动) TYPE : GPC4216L100-12V3000 铜片 线长可定制 描述 DESCRIPTION : Φ42.0 x H16 mm 3000Hz 12V >=95DB at 10cm L=100 mm 客戶料號 CUSTOMER NO. : 規 格 書 號 SPECIFICATION NO.: 版 本 EDITION NO. 日 期 DATE : V1.0 : 2016-2-23 客戶承認 CUSTOMER CONFIRM AND SIGN 檢查 審核 承認 TESTED BY CHECKED BY APPROVED BY 東莞市赢海電子有限公司 DONGUAN INGHAI ELECTRONICS CO.,LTD 製作 審查 確認 ISSUED BY CHECKED BY APPROVED BY 周明 李林 地址:廣東省東莞市長安鎮上沙第五工业区新春 1 路新春科技园 電話 / TEL:0769-83060958 傳真 / FAX: 0769-81608993 網址:HTTP://WWW.INGHAI.COM 1/3 DONGGUAN INGHAI ELECTRONICS CO.,LTD Model NO: GPC4216L100-12V3000 A: DIMEMSIONS Unit:mm Tolerance:±0.5 黑 红 B: SPECIFICATIONS Model NO GPC4216L100 Rated Voltage 12 VP-P Operating Voltage 3-30VP-P Max.Rated Current Max.5mA Capacitance at 1000Hz (Pf) 38000±30% Sound Pressure level(dB/min) at 10cm Min.95dB at Rated Voltage Resonant Frequency 3000±300Hz Operating Temperature -20 ℃~+60 ℃ Storage Temperature -30 ℃~+70 ℃ Case material and color ABS / Black Measuring condition Part shall be measured under a condition (Temperature: 5~35℃, Humidity: 45%~85%R.H., Atmospheric pressure: 860 ~1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H. Atmospheric pressure: 860 ~1060hPa) is regulated to measure. 2/3 C: Reliability Test After any following tests the part shall meet specifications without any degradation in appearance and performance except SPL. SPL shall not deviate more than -10 dB from the initial value 1. 2. 3. 4. 5. 6. 7. Ordinary Temperature Life Test The part shall be subjected to 96 hours at 25±10℃. Input rated voltage Resonant frequency, 1/2 duty Square wave. High Temperature Test The part shall be capable of with standing a storage temperature of +70℃ for 96 hours. Low Temperature Test The part shall be capable of with standing a storage temperature of -30℃ for 96 hours. Humidity Test Temperature:+40℃±3℃ Relative Humidity:90%~95% Duration: 48 hours and expose to room temperature for 6 hours Temperature Shock Test Temperature:60℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle) Total cycle: 10 cycles Drop Test Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick, three sides, six plain.) Vibration Test Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes Note: As this product is not protected from foreign material entering, please make sure that any foreign materials (e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it. 3/3
GPC4216L100-12V 价格&库存
很抱歉,暂时无法提供与“GPC4216L100-12V”相匹配的价格&库存,您可以联系我们找货
GPC4216L100-12V
  • 1+4.35120
  • 10+3.49860
  • 30+3.07720
库存:50
GPC4216L100-12V
  • 1+4.79520
  • 10+3.85560
  • 30+3.39120
  • 100+2.78046
  • 500+2.52396
  • 1000+2.38032
库存:486
