承
认
书
SPECIFICATION FOR APPROVAL
客户名称:Customer
货
SMD2520 石英晶体谐振器
名:Description
客户料号:
Part No
物料编号:
Code No
S2225000201080C3
频
率:Frequency
25.000MHZ
日
期:Date
2023-04-18
备
注:RoHS compliance with Directive (EU) 2015/863
制作(Prepare by)
检查(Check by)
批准(Approve by)
江丹娜
甘瑛
张刚
客户批准
Approve by customer
批准日期
Approval date
Add:广东省深圳市华发北路桑达工业区桑达雅苑 7P
7 P Sangda Yayuan Huafa North Road, Futian District, Shenzhen, Guangdong
Tel:
86-755-83048260
86-755-83048290
Fax: 86-755-83048280
www.jghcorp.com
ShenZhen JingGuangHua Electronics Co.,Ltd.
1、 Specifications
1
规格型号 Holder Type
2
标称频率 Nominal Frequency
25.000MHz
3
振动模式 Mode of Oscillation
Fundamental
4
调整频差 Frequency Tolerance at 25℃
±10ppm
5
温度频差 Temperature Frequency Stability
±30ppm
6
工作温度 Operating Temperature Range
-40~85℃
7
贮存温度 Storage Temperature Range
-40~125℃
8
负载电容 Load Capacitance
9
静电容
Shunt capacitance
≤5 pF
10
等效电阻 Equivalent Series Resistance
100 Ω Max
11
激励功率 Drive Level
100uW Max
12
绝缘阻抗 Insulation Resistance
13
年老化率 Aging
14
测试仪器 Test machine
SMD2520
20pF
500MΩ/100V±15VDC
±3ppm/First year
250B
2.Frequency stability over temperature range (AT cut)
Temperature
Range
Frequency Stability
±3PPM
±5PPM
±7.5PPM
±10PPM
±30PPM
±50PPM
-40℃~+85℃
-40℃~+125℃
0℃~+50℃
-10℃~+60℃
-20℃~+70℃
-30℃~+70℃
www.jghcorp.com
±20PPM
±70PPM
3. Dimensions (unit:mm)
4.Recommended Reflow profile
www.jghcorp.com
5、Reliability specifications
NO
Item
Condition
Free drop from 75 cm height on a hard
1.
Drop Test
wooden board for 3 times. (Board is
thickness more than 30 mm.)
2.
Mechanical
Shock
Half sine wave, 1000G, 0.5mS, three times for
all 3 directions
Vibration
Frequency change:
≤5ppm
Rr as specification
Frequency change:
≤5ppm
Rr as specification
Frequency range:10~55hz
3.
Standard
Amplitude:1.52mm
Frequency change:
≤5ppm
Sweep time:1mintutes
perpendicular axes each test time:2Hrs
Rr as specification
Temperature:245℃±5℃
4.
Solderability
Immersing depth:0.5mm minimum
Immersion time:5±1sec.
90% exhibit tin ok
Flux:Rosin resin methyl alcohol solvent(1:4)
5.
6.
7.
8.
Resistance to
Test temperature:260℃±5℃
soldering heat
Test time :10±1sec.
High Temp
&Humidity
Low temperature
storage
High temperature
storage
Frequency change:
≤10ppm
Rr as specification
Frequency change:
85±3℃& RH85%, 500±12 hours
≤10ppm
Rr as specification
Frequency change:
-40±3℃, 500±12 hours
≤10ppm
Rr as specification
Frequency change:
+85±3℃,500±12 hours
≤10ppm
Rr as specification
Frequency change:
9.
Temperature cycling
-40±3℃/10min~+85±3℃/10min, 100cycles
≤10ppm
Rr as specification
www.jghcorp.com
6、Packaging standard
www.jghcorp.com
7.Inner carton
A n tistatic bag
S ea l
R eel
L able
L able
R eel
7-1.MARKING
(1)Marking Labels are affixed to reel, inner carton and outer carton.
(2) Each label contains the following information.
(a) Manufacture’s name or symbol
(b) Parts name or type
(c) Frequency
(d) Quantity
(e) Reel number
(f) Manufacturer’s code (EIAJ code)
7-2. QUANTITY
3000pcs/reel (max.5reels in outer carton)
7-3. STORAGE ENVIRONMENT
Storage the reel at normal temperature and humidity
Open the packing just before using
Do not expose the sun
Do not storage with some erosive chemicals
Nothing is allowed to put on the reel or carton to prevent mechanical damage
7-4. HANDLING
Handle with care to prevent the damage of tape, reel and products.
www.jghcorp.com
很抱歉,暂时无法提供与“S2225000201080C3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.60040
- 100+0.56240
- 300+0.52440
- 500+0.48640
- 2000+0.46740
- 5000+0.45600
