SD103AW
SD103AW
    CBI(创基)
    SOD-123
    肖特基二极管 SOD123 VR=40V Io=350mA IR=5μA
SD103AW 数据手册
Surface Mount Schottky Barrier Diodes Features PINNING • Low Forward Voltage PIN DESCRIPTION 1 Cathode 2 Anode 2 1 S4 Top View Marking Code: S4 Simplified outline SOD-123 and symbol Absolute Maximum Ratings (Ta = 25 C) O Parameter Peak Repetitive Reverse Voltage Reverse Voltage Symbol SD103AW SD103BW SD103CW SD103AW SD103BW SD103CW Value Unit 40 30 20 40 30 20 VRRM VR V V Average Forward Rectified Current IF(AV) 350 mA Non-Repetitive Peak Forward Surge Current at t = 1 s IFSM 2 A Power Dissipation Ptot 400 mW Tj, Tstg - 65 to + 125 Operating and Storage Temperature Range C O Characteristics at Ta = 25 C O Symbol Min. Typ. Max. 40 30 20 - - - - 5 5 5 VF - - 0.37 0.6 V Total Capacitance at VR = 0 V, f = 1 MHz CT - 50 - pF Reverse Recovery Time at IF = IR = 200 mA, Irr = 0.1 IR, RL = 100 Ω trr - 10 - ns Parameter Reverse Breakdown Voltage at IR = 10 µA Reverse Leakage Current at VR = 30 V at VR = 20 V at VR = 10 V Forward Voltage at IF = 20 mA at IF = 200 mA SD103AW SD103BW SD103CW SD103AW SD103BW SD103CW V (BR)R IR 1 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. Unit V µA 2 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. ACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123 3 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
SD103AW 价格&库存
很抱歉,暂时无法提供与“SD103AW”相匹配的价格&库存,您可以联系我们找货
SD103AW
  • 15+0.04582
库存:15
SD103AW
  • 3000+0.03740
  • 9000+0.03630
  • 165000+0.03520
库存:9000
SD103AW
  • 1+0.26400
  • 200+0.08778
  • 1500+0.05489
  • 3000+0.04356
库存:14
SD103AW
  • 20+0.19410
  • 100+0.12060
  • 800+0.07980
  • 3000+0.05690
  • 6000+0.05420
  • 30000+0.05000
库存:14
SD103AW
    • 20+0.05951
    • 200+0.04731
    • 600+0.04050
    • 3000+0.03608
    • 9000+0.03262
    • 21000+0.03068
    库存:697
