BAV199
BAV199
    CBI(创基)
    SOT-23
    开关二极管 1对串联 85V 160mA SOT-23
BAV199 数据手册
Silicon Epitaxial Planar Diode Low leakage switching double diode For low leakage current applications 3 Feature • Very low leakage current • Medium speed switching times • Series pair configuration 1 2 Marking Code: PX SOT-23 Plastic Package Absolute Maximum Ratings (Ta = 25 C) O Parameter Symbol Value Unit VRRM 85 V VR 85 V IF 160 140 mA IFRM 500 mA IFSM 4 1 0.5 A PD 250 Thermal Resistance Junction to Ambient Air RθJA 500 Operating and Storage Temperature Range Tj, Tstg - 65 to + 150 Peak Repetitive Reverse Voltage Continuous Reverse Voltage Continuous Forward Current Single Diode Double Diode Repetitive Peak Forward Current Non-Repetitive Peak Forward Surge Current at t = 1 µs at t = 1 ms at t = 1 s Power Dissipation mW C/W O C O Electrical Characteristics (Ta = 25 C) O Parameter Reverse Breakdown Voltage at IR = 100 µA Symbol Min. Typ. Max. Unit V(BR)R 85 - - V - - 0.9 1 1.1 1.25 Forward Voltage at IF = 1 mA at IF = 10 mA at IF = 50 mA at IF = 150 mA VF Reverse Current at VR = 75 V at VR = 75 V, Tj = 150 OC IR IR - - 5 80 nA Total Capacitance at VR = 0, f = 1 MHz CT - 2 - pF Reverse Recovery Time at IF = IR = 10 mA, Irr = 0.1 X IR, RL = 100 Ω trr - - 3 µs 1 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. V 2 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. PACKAGE OUTLINE Plastic surface mounted package; 3 leads SOT-23 3 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
BAV199
物料型号为“Silicon Epitaxial Planar Diode”,是一种低漏电切换双二极管,适用于低漏电电流应用。
器件简介包括极低的漏电电流和中等速度切换时间,以及系列对配置。
引脚分配为SOT-23塑料封装,具有3个引脚。
参数特性包括: - 峰值重复反向电压(VRRM):85V - 连续反向电压(VR):85V - 连续正向电流(IF):单二极管160mA,双二极管140mA - 重复峰值正向电流(IFRM):500mA - 非重复峰值正向浪涌电流(IFSM):在1秒、1毫秒时分别为4A、1A、0.5A - 功率耗散(P0):250mW - 热阻(RBJA):500°C/W - 工作和存储温度范围(T, Tstg):-65至+150°C
功能详解包括电气特性,如反向击穿电压、正向电压、反向电流、总电容和反向恢复时间。
应用信息未在文档中明确说明,但根据其特性,可能适用于需要低漏电和中等速度切换的应用。
封装信息为SOT-23塑料表面贴装封装,具有3个引脚。
BAV199 价格&库存
很抱歉,暂时无法提供与“BAV199”相匹配的价格&库存,您可以联系我们找货
BAV199
  • 1+0.15950
  • 200+0.05324
  • 1500+0.03333
  • 3000+0.02640
库存:4
BAV199
    • 50+0.11373
    • 500+0.09040
    • 3000+0.07150
    • 6000+0.06372
    • 24000+0.05692
    • 51000+0.05336
    库存:6145
    BAV199
      • 20+0.11800
      • 100+0.07310
      • 800+0.04830
      • 3000+0.03450
      • 6000+0.03280
      • 30000+0.03040
      库存:32
      BAV199
      • 50+0.09208
      • 500+0.08228
      • 5000+0.07575
      • 10000+0.07249
      • 30000+0.06922
      • 50000+0.06726
