2SC4617R
2SC4617R
    CBI(创基)
    SOT-523-3
    VCEO=50V V(BR)CEO=50V fT =180MHz
2SC4617R 数据手册
Plastic-Encapsulate Transistors TRANSISTOR (NPN) SOT-523 FEATURES Low Cob:Cob=2.0pF(Typ) z z Complement to 2SA1774 1. BASE 2. EMITTER 3. COLLECTOR MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter Value Unit VCBO Collector-Base Voltage 60 V VCEO Collector-Emitter Voltage 50 V VEBO Emitter-Base Voltage 7 V IC Collector Current -Continuous 150 mA PC Collector Power Dissipation 150 mW TJ Junction Temperature 150 ℃ Tstg Storage Temperature -55-150 ℃ ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Test conditions Min Typ Max Unit Collector-base breakdown voltage V(BR)CBO IC=50uA, IE=0 60 V Collector-emitter breakdown voltage V(BR)CEO IC=1mA, IB=0 50 V Emitter-base breakdown voltage V(BR)EBO IE=50uA, IC=0 7 V Collector cut-off current ICBO VCB=60V, IE=0 0.1 μA Emitter cut-off current IEBO VEB=7V, IC=0 0.1 μA DC current gain hFE VCE=6V, IC=1mA Collector-emitter saturation voltage Transition frequency Collector output capacitance VCE(sat) fT Cob 120 560 IC=50mA, IB=5mA 0.4 VCE=12V, IC=2mA, f=100MHz 180 MHz VCB=12V, IE=0, f=1MHz 3.5 CLASSIFICATION OF hFE Rank Range Marking Q R S 120-270 180-390 270-560 BQ BR BS 1 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. V pF Typical Characteristics IC —— 2SC4617 hFE VCE —— IC 1000 200 COMMON EMITTER Ta=25 ℃ COMMON EMITTER VCE=6V 1/0.9/0.8mA Ta=100 ℃ 160 (mA) 0.7mA 300 COLLECTOR CURRENT DC CURRENT GAIN IC 0.5mA 120 Ta=25 ℃ hFE 0.6mA 0.4mA 0.3mA 80 0.2mA 100 30 40 IB=0.1mA 10 0.1 0 0 4 8 12 16 COLLECTOR-EMITTER VOLTAGE VCEsat —— 20 VCE 24 3 1 0.3 (V) 10 COLLECTOR CURREMT Ic IC 1000 —— IC 100 30 200 (mA) VBE 100 VCE=6V COMMON EMITTER IC/IB=10 (mA) 300 IC 10 COLLCETOR CURRENT COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (mV) 30 100 Ta=100 ℃ 30 Ta=25 ℃ Ta=100 ℃ 3 Ta=25 ℃ 1 0.3 10 0.1 0.3 1 10 3 COLLECTOR CURRENT Cob/Cib —— 100 30 Ic 0.1 0.0 200 0.2 (mA) 0.4 0.6 BASE-EMMITER VOLTAGE VCB/VEB Pc 100 —— 0.8 VBE 1.0 (V) Ta 200 f=1MHz IE=0 / IC=0 o COLLECTOR POWER DISSIPATION Pc (mW) Ta=25 C CAPACITANCE C (pF) 30 Cib 10 Cob 3 1 0.1 150 100 50 0 0.3 1 3 REVERSE VOLTAGE 10 V 30 0 100 (V) 25 50 75 AMBIENT TEMPERATURE 100 Ta 2 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. 125 (℃ ) 150 PACKAGE OUTLINE Plastic surface mounted package; 3 leads SOT-523 3 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
2SC4617R 价格&库存
很抱歉,暂时无法提供与“2SC4617R”相匹配的价格&库存,您可以联系我们找货
2SC4617R
    • 20+0.11086
    库存:20
