1N4148WS
Silicon Epitaxial Planar Switching Diode
Features
• SOD-323 package
PINNING
DESCRIPTION
PIN
• Fast switching
• These diodes are also available in other case style
including the DO-35 case with the type designation
1N4148, the MiniMELF case with the type
designation LL4148 and the MicroMELF case with
the type designation MCL4148.
1
Cathode
2
Anode
2
1
W2
T4
Top View
Marking Code: "W2"
T4
Simplified outline SOD-323 and symbol
MARKING:T4
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Value
Unit
Peak Reverse Voltage
VRM
100
V
Reverse Voltage
VR
75
V
Average Rectified Forward Current
IF(AV)
150
mA
Surge Forward Current (t < 1 s, Tj = 25 OC)
IFSM
350
mA
Power Dissipation
Ptot
200
mW
Thermal Resistance from Junction to Ambient Air
RθJA
625
Tj
150
O
Tstg
- 65 to + 150
O
Junction Temperature
Storage Temperature Range
C/W
O
C
C
Characteristics at Ta = 25 OC
Parameter
Forward Voltage
at IF = 1 mA
at IF = 10 mA
at IF = 50 mA
at IF = 150 mA
Peak Reverse Current
at VR = 75 V
at VR = 20 V
at VR = 75 V, TJ = 150 OC
at VR = 25 V, TJ = 150 OC
Symbol
VF
IR
Min.
Max.
Unit
0.715
0.855
1
1.25
V
1
25
50
30
µA
nA
µA
µA
Total Capacitance
at VR = 0 V, f = 1 MHz
CT
2
pF
Reverse Recovery Time
at Irr = 0.1 X IR, IF = IR = 10 mA, RL = 100 Ω
trr
4
ns
Page 1 of 3
2/23/2012
Dynamic forward resistance
vs. forward current
Forward characteristics
4
3
10
2
2
3
10
5
10
Tj=25 C
f=1kHz
10
Tj=100 C
Tj=25 C
rF (
I F ( m A)
5
10
1
2
2
10
5
2
10
-2
10
5
2
10-1
1
2
-2
10
10-1
1
VF (V)
102
10
I F (mA)
Reverse capacitance vs. reverse voltage
Amissible repetitive peak forward current vs. pulse duration
Tj=25 C
f=1MHz
1.1
100
5
4
3
2
10
I FRM (A)
Ctot (VR)
Ctot (0 V)
1.0
0.9
0.8
2
4
6
VR (V)
Page 2 of 3
1
V=0
0.1
0.2
0.5
5
4
3
2
0.7
4
3
2
8
10
0.1
-5
10 2
5
-4
10 2
5 10-3 2
5
-2 2
10
5
-1
10 2
5
1
tp (s)
2/23/2012
2
5
10
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
Page 3 of 3
SOD-323
2/23/2012
很抱歉,暂时无法提供与“1N4148WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.11660
- 200+0.03905
- 1500+0.02431
- 3000+0.01936
- 国内价格
- 50+0.05411
- 500+0.04310
- 3000+0.03435
- 6000+0.03068
- 24000+0.02744
- 51000+0.02582
- 国内价格
- 20+0.02945
- 200+0.02755
- 500+0.02565
- 1000+0.02375
- 3000+0.02280
- 6000+0.02147
- 国内价格
- 3000+0.02870
- 9000+0.02790
- 216000+0.02700
- 国内价格
- 20+0.08620
- 100+0.05360
- 800+0.03540
- 3000+0.02530
- 6000+0.02400
- 30000+0.02220
