Silicon Epitaxial Planar Switching Diode
Features
PINNING
• SOD-123 package
• Fast switching
• These diodes are also available in other case style
including the DO-35 case with the type designation
1N4148, the MiniMELF case with the type
designation LL4148 and the MicroMELF case with
the type designation MCL4148.
PIN
1
2
DESCRIPTION
Cathode
Anode
2
1
Top View
Marking Code: " "
Simplified outline SOD-123 and symbol
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Value
Unit
Peak Reverse Voltage
VRM
100
V
Reverse Voltage
VR
75
V
Average Rectified Forward Current
IF(AV)
150
mA
Non-repetitive Peak Forward Surge Current at t = 1 μs
IFSM
2
A
Power Dissipation
Ptot
400
mW
Thermal Resistance from Junction to Ambient Air
RθJA
312
Tj
150
O
Tstg
- 65 to + 150
O
Junction Temperature
Storage Temperature Range
C/W
O
C
C
Characteristics at Ta = 25 OC
Parameter
Reverse Breakdown Voltage
at IR = 1 µA
Symbol
Min.
Max.
Unit
V(BR)R
75
V
0.715
0.855
1
1.25
1
25
50
30
µA
nA
µA
µA
Forward Voltage
at IF = 1 mA
at IF = 10 mA
at IF = 50 mA
at IF = 150 mA
VF
Peak Reverse Current
at VR = 75 V
at VR = 20 V
at VR = 75 V, TJ = 150 OC
at VR = 25 V, TJ = 150 OC
IR
Total Capacitance
at VR = 0 V, f = 1 MHz
CT
2
pF
Reverse Recovery Time
at Irr = 0.1 X IR, IF = IR = 10 mA, RL = 100 Ω
trr
4
ns
1 of 3
Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
V
Forward characteristics
3
I F ( m A)
5K
102
Vo
2nF
60
VRF =2V
10
Rectification Efficiency Measurement Circuit
10
Tj=100 C
Tj=25 C
1
10-2
10-1
2
VF (V)
Amissible power dissipation
vs. ambient temperature
1000
Leakage current vs. junction temperature
10
4
5
2
103
5
600
I R (nA)
P tot (mW)
800
400
2
10 2
5
2
10
200
5
VR=20V
2
200
100
Tj ( C)
Reverse capacitance vs. reverse voltage
Amissible repetitive peak forward current vs. pulse duration
100
Tj=25 C
f=1MHz
1.1
5
4
3
2
10
I FRM (A)
Ctot (VR)
Ctot (0 V)
1.0
0.9
0.8
V=0
5
4
3
2
0.1
0.2
1
0.5
5
4
3
2
0.7
4
6
VR (V)
200
100
Tamb ( C)
8
10
0.1
-5
10
2
5
-4 2
10
5
-3 2
10
5
10-2
2
5
-1 2
10
5
tp (s)
2 of 3
1
2
5
10
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123
3 of 3
很抱歉,暂时无法提供与“1N4148W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.11990
- 200+0.04015
- 1500+0.02508
- 3000+0.01991
- 国内价格
- 20+0.08890
- 100+0.05510
- 800+0.03630
- 3000+0.02600
- 6000+0.02480
- 30000+0.02280
- 国内价格
- 3000+0.02620
- 9000+0.02540
- 237000+0.02470
- 国内价格
- 50+0.07097
- 500+0.06392
- 5000+0.05922
- 10000+0.05687
- 30000+0.05452
- 50000+0.05311
- 国内价格
- 50+0.04850
- 500+0.03845
- 3000+0.03219
- 6000+0.02884
- 24000+0.02592
- 51000+0.02441
