DATA SHEET
SURFACE MOUNT MULTILAYER
CERAMIC CAPACITORS
Automotive grade
NP0/X7R/X7S
6.3 V TO 2000 V
Product Specification – June 4, 2025 V.23
0.2 pF to 680nF
Product specification
Surface-Mount Ceramic Multilayer Capacitors
Automotive grade NPO/X7R/X7S 6.3 V to 2000 V
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes
Automotive grade chip capacitors
with lead-free terminations and
used for automotive equipments.
All part numbers are identified by the series, size, tolerance, TC material,
packing style, voltage, process code, termination and capacitance value.
APPLICATIONS
All general purpose applications
under normal operation and
usage conditions for automotive
equipments.
FEATURES
AEC-Q200 qualified
MSL class: MSL 1
AC series soldering is
compliant with J-STD-020D
High component and
equipment reliability
The capacitors are 100%
performed by automatic optical
inspection prior to taping.
GLOBAL PART NUMBER
AC
XXXX X X XXX X
(1)
(2) (3) (4)
B
(5)
X XXX
(6) (7)
(1) SIZE – INCH BASED (METRIC)
0201 (0603) / 0402 (1005) / 0603 (1608) / 0805 (2012) / 1206 (3216)/ 1210 (3225) /
1812 (4532) / 2220 (5750)
(2) TOLERANCE
NPO(< 10 pF)
NPO(≥ 10 pF)
X7R/X7S
B = ± 0.1 pF
F = ± 1%
J = ± 5%
C = ± 0.25 pF
G = ± 2%
K = ± 10%
D = ± 0.5 pF
J = ± 5%
M = ± 20%
Note: Capacitance tolerance ±5% doesn’t available for full X7R range,
please contact local sale before order.
(3) PACKING STYLE (SEE TABLE. 12 FOR DETAIL)
R = Paper/PE taping reel; Reel 7 inch
K = Blister taping reel; Reel 7 inch
P = Paper/PE taping reel; Reel 13 inch
F = Blister taping reel; Reel 13 inch
(4) TC MATERIAL
NPO
X7R
X7S
(5) RATED VOLTAGE
5 = 6.3 V
6 = 10 V
7 = 16 V
8 = 25 V
9 = 50 V
0 = 100 V
A = 200 V
Y = 250 V
B = 500 V
Z = 630 V
C = 1000 V
D = 2000 V
6) PROCESS
N = NPO
B = X7R/X7S
(7) CAPACITANCE VALUE
2 significant digits+number of zeros
The 3rd digit signifies the multiplying factor, and letter R is decimal point
Example: 121 = 12 x 101 = 120 pF
www.yageo.com
Jun. 4, 2025 V.23
CONSTRUCTION
The capacitor consists of a
rectangular block of ceramic
dielectric in which a number of
interleaved metal electrodes are
contained. This structure gives rise
to a high capacitance per unit
volume.
The inner electrodes are
connected to the two end
terminations and finally covered
with a layer of plated tin (Matte
Sn). The terminations are leadfree. A cross section of the
structure is shown in Fig.1.
Detailed Cross Section
Dielectric Material
Barrier Layer
(Ni)
Termination Finish
(100% Matte Sn)
Dielectric
Material
End Termination/
External Electrode
(Cu)
Inner Electrodes
(Ni)
End Termination/
External Electrode
(Cu)
Barrier Layer
(Ni)
Termination Finish
(100% Matte Sn)
Inner Electrodes
(Ni)
Fig. 1 Surface mounted multilayer ceramic capacitor construction
DIMENSION
OUTLINES
Table 1 For outlines see fig. 2
TYPE
L1 (mm)
0201
0402
0603
0805
1206
L2 / L3 (mm)
min.
max.
L4 (mm)
min.
W (mm)
T (MM)
0.6± 0.03
0.3± 0.03
0.3± 0.03
0.10
0.20
0.20
1.0± 0.05
0.5 ± 0.05
0.5± 0.05
0.15
0.35
0.30
1.6± 0.10
0.8± 0.10
0.8± 0.10
0.20
0.50
0.60
2.0± 0.10
1.25± 0.10
0.25
0.75
0.70
For dimension see Table 1
0.6± 0.10
0.85± 0.10
1.25± 0.20
0.6± 0.10
0.85± 0.10
1.00± 0.10
1.15± 0.10
1.25± 0.20
1.6± 0.20
2.0± 0.20
1.25± 0.20
3.2± 0.15
1.6± 0.15
3.2± 0.30
1.6± 0.20
3.2± 0.30
1.6± 0.30
1.6± 0.30
3.2± 0.20
2.5± 0.20
0.85± 0.10
3.2± 0.30
2.5± 0.20
Fig. 2 Surface mounted multilayer
ceramic capacitor dimension
0.25
0.75
1.50
0.25
0.85
1.50
0.25
0.75
2.20
0.25
0.75
2.20
0.25
0.75
3.40
1.25± 0.20
1210
1808
3.2± 0.40
2.5± 0.30
4.5± 0.40
2.0± 0.30
1812
4.5± 0.40
3.2± 0.30
2220
5.7± 0.40
5.0± 0.30
1.6± 0.20
2.0± 0.20
(1)
1.6± 0.20
(2)
2.0± 0.20
2.5± 0.20
2.5± 0.30
1.25± 0.20
0.85± 0.10
1.25± 0.20
1.60± 0.20
2.0± 0.20
1.25 ± 0.20
1.6 ± 0.20
NOTE
(1)(2) NPO, 1210, 630V ~1000V, 4.7nF ~22nF
www.yageo.com
Jun. 4, 2025 V.23
CAPACITANCE RANGE & THICKNESS FOR NP0
Table 2 Sizes from 0201 to 0805
CAP.
0201
0402
0603
0805
25 V / 50 V 25 V / 50 V 25 V / 50 V
100 V
200 V / 250 V
50 V
100 V 200 V / 250 V
500 V
630 V
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
39 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
47 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
56 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
68 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
82 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
100 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.2 pF
0.3± 0.03
0.47 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.56 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.68 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.82 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.0 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.2 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.5 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.8 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
2.2 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
2.7 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
3.3 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
3.9 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
4.7 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
5.6 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
6.8 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
8.2 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
10 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
12 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
15 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
18 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
22 pF
0.3± 0.03
0.5± 0.05
0.8± 0.1
27 pF
0.3± 0.03
0.5± 0.05
33 pF
0.3± 0.03
NOTE
1. Values in shaded cells indicate thickness class in mm
2. Capacitance value of non E-12 series is on request
www.yageo.com
Jun. 4, 2025 V.23
Table 3 Sizes from 0402 to 0805 (continued)
0402
0603
25 V / 50 V
25 V / 50 V
120 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
150 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
180 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
220 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
270 pF
0.5± 0.05
0.8± 0.1
330 pF
0.5± 0.05
390 pF
CAP.
0805
100 V 200 V / 250 V
50 V
100 V 200 V / 250 V
500 V
630 V
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
470 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
560 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
680 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
820 pF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
1.0 nF
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
1.2 nF
0.8± 0.1
0.8± 0.1
0.85± 0.1
0.85± 0.1
1.5 nF
0.8± 0.1
0.8± 0.1
0.85± 0.1
0.85± 0.1
1.8 nF
0.8± 0.1
0.8± 0.1
0.85± 0.1
0.85± 0.1
2.2 nF
0.8± 0.1
0.8± 0.1
1.25± 0.2
1.25± 0.2
2.7 nF
0.8± 0.1
1.25± 0.2
1.25± 0.2
3.3 nF
0.8± 0.1
1.25± 0.2
1.25± 0.2
3.9 nF
0.8± 0.1
1.25± 0.2
1.25± 0.2
4.7 nF
0.8± 0.1
1.25± 0.2
1.25± 0.2
5.6 nF
0.8± 0.1
1.25± 0.2
1.25± 0.2
6.8 nF
0.8± 0.1
1.25± 0.2
1.25± 0.2
8.2 nF
0.8± 0.1
1.25± 0.2
1.25± 0.2
10 nF
0.8± 0.1
1.25± 0.2
1.25± 0.2
NOTE
www.yageo.com
Jun. 4, 2025 V.23
Table 4 Sizes from 1206 to 1210
CAP.
1206
1210
50 V
100 V
200 V /
250 V
10 pF
12 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2
15 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
18 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
22 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
27 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
33 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
39 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
47 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2
56 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
68 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
500 V
630 V
1000 V
2000 V
50 V
100 V
200 V /
250 V
500 V
82 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
100 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
120 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
150 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
180 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
220 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
270 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1 1.25± 0.2
330 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1 1.25± 0.2
390 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1 1.25± 0.2
470 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1 1.25± 0.2
560 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1 1.25± 0.2
680 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1 1.25± 0.2
820 pF
0.6± 0.1
0.6± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2
1.0 nF
0.6± 0.1
1.2 nF
0.6± 0.1
0.6± 0.1 0.85± 0.1
1.25± 0.2
1.5 nF
0.6± 0.1
0.6± 0.1 0.85± 0.1
1.25± 0.2
1.8 nF
0.6± 0.1
0.6± 0.1
1.25± 0.2
2.2 nF
0.6± 0.1
0.6± 0.1
1.25± 0.2
2.7 nF
0.6± 0.1
0.6± 0.1
1.25± 0.2
630 V* 1000 V*
3.3 nF
1.25± 0.2
3.9 nF
1.25± 0.2
4.7 nF
1.25± 0.2
1.60± 0.2
2.0± 0.2
5.6 nF
1.25± 0.2
1.60± 0.2
2.0± 0.2
6.8 nF
1.25± 0.2
1.60± 0.2
2.0± 0.2
8.2 nF
1.60± 0.2
1.60± 0.2
2.0± 0.2
10 nF
1.60± 0.2
1.60± 0.2
2.5± 0.3
15 nF
1.60± 0.2
2.5± 0.3
22 nF
2.0± 0.2
2.5± 0.3
33 nF
2.5± 0.3
47 nF
NOTE
3. * : L: 3.2± 0.40 W: 2.5± 0.30
www.yageo.com
Jun. 4, 2025 V.23
CAPACITANCE RANGE & THICKNESS FOR X7R/X7S
Table 5
CAP.
Sizes from 0201 to 0603
0201
25V
0603
0402
50 V
10V
10V
16 V
25 V
50 V
100 V
100 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
150 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
220 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
330 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
470 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
680 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
1.0 nF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
1.5 nF 0.3± 0.03
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
2.2 nF 0.3± 0.03
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
3.3 nF 0.3± 0.03
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
4.7 nF 0.3± 0.03
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
6.8 nF 0.3± 0.03
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
10 nF 0.3± 0.03
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
15 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
22 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
33 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
47 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
68 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
100 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
150 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
330 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
470 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
680 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
(X7S)
220 nF
16 V
(X7S)
25 V
(X7S)
(X7S)
(X7S)
(X7S)
50 V
100 V
0.8± 0.1
0.8± 0.1
NOTE
2. Capacitance value of non E-6 series is on request
www.yageo.com
Jun. 4, 2025 V.23
Table 6
Size 0805
0805
CAP.
10 V
16 V
25 V
50 V
100 V
200 V / 250 V
500 V
1.0 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.5 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
2.2 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
3.3 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
4.7 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
6.8 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
10 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
15 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
22 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
33 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
47 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
68 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
100 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
150 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
220 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
330 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
470 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
680 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.85± 0.1
1.25± 0.2
0.85± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
NOTE
www.yageo.com
Jun. 4, 2025 V.23
Table 7
Size 1206
1206
CAP.
6.3 V
10V
16V
25V
50 V
100 V
220 pF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
330 pF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
470 pF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
680 pF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
2.2 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
4.7 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
10 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
22 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
33 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.60± 0.2
47 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.60± 0.2
68 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.60± 0.2
100 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.60± 0.2
150 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
220 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
330 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.60± 0.2
1.60± 0.2
470 nF
1.00± 0.1
1.00± 0.1
1.00± 0.1
1.00± 0.1
1.60± 0.2
1.60± 0.2
680 nF
1.15± 0.1
1.15± 0.1
1.15± 0.1
1.60± 0.2
1.60± 0.2
1.60± 0.2
Table 8
200 V / 250 V
500 V
630 V
1000 V
Size 1210
1812
1210
CAP.
6.3V
10 V
16 V
25 V
50V
100 V
200 V / 250 V
50V
100V
100 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
150 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
220 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
330 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
2.0± 0.2
470 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
2.0± 0.2
1.60± 0.2
1.60± 0.2
680 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
2.0± 0.2
1.60± 0.2
1.60± 0.2
NOTE
www.yageo.com
Jun. 4, 2025 V.23
ELECTRICAL CHARACTERISTICS
NP0/X7R DIELECTRIC CAPACITORS; NI/SIN TERMINATIONS
Unless otherwise specified, all test and measurements shall be made under standard atmospheric conditions for
testing as given in 5.3 of IEC 60068-1:
Temperature: 15
Relative humidity: 25% to 75%
C to 35
C
Air pressure: 86 kPa to 106 kPa
Before the measurements are made, the capacitor shall be stored at the measuring temperature for a time
sufficient to allow the entire capacitor to reach this temperature.
The period as prescribed for recovery at the end of a test is normally sufficient for this purpose.
Table 9
VALUE
DESCRIPTION
Capacitance range
0.2 pF to 680 nF
Dissipation factor (D.F.)
NPO
C < 30 pF
≤ 1 / ( 400 + 20C )
C ≥ 30 pF
X7R/X7S
≤ 0.1 %
0201
≤10V
0402
0603
0805
1206
1210
100pF to 100nF
100pF to 680nF
1nF to 680nF
220pF to 680nF
100nF to 680nF
1812
≤ 5%
150nF to 220nF
16V
≤ 10%
100pF to 22nF
100pF to 220nF
1nF to 470nF
27nF to 100nF
330nF to 680nF
680nF
100pF to 39nF
1nF to 180nF
220pF to 680nF
100nF to 680nF
≤ 3.5%
≤ 5%
150nF to 220nF
25V
≤ 10%
100pF to 470pF
100pF to 10nF
220pF to 680nF
100nF to 680nF
≤ 2.5%
12nF to 27nF
47nF to 220nF
220nF
≤ 3.5%
560pF to 10nF
33nF to 100nF
330nF to 680nF
330nF to 680nF
≤ 5%
150nF to 220nF
50V
100pF to 470pF FF 100pF to 10nF
560pF to 1nF
≤ 10%
100pF to 39nF
1nF to 180nF
47nF to 220nF
220nF to 470nF
12nF to 100nF
100V
220pF to 1.5nF
100pF to 10nF
220pF to 470nF
100nF to 680nF
≤ 2.5%
≤ 3.5%
560nF to 680nF
680nF
1nF to 100nF
220pF to 470nF
100nF to 270nF
12nF to 100nF
470nF to 680nF
≤ 5%
470nF to 680nF
≤ 2.5%
560nF to 680nF
330nF to 680nF
≤ 5%
200V/250V
1nF to 22nF
220pF to 100nF
100nF
≤ 2.5%
500V
1nF to 4.7nF
220pF to 10nF
≤ 2.5%
630V
220pF to 10nF
≤ 2.5%
1KV
220pF to 1nF
≤ 2.5%
Insulation resistance after 1 minute at Ur (DC)
NPO (general)
X7R (general)
0603/25V/330nF to 470nF
0603/10V to 25V/560nF to 680nF
0402/10V/>100nF
0402/16V/>100nF
X7S (general)
0402/10V to 25V/>100nF
Operating temperature range:
NP0/X7R/X7S
I.R. ≥ 100 GΩ or I.R. × C ≥ 1000 Ω.F. whichever is less
1206/630V >1nF, 1210/630V & 1KV >1nF
I.R. ≥ 10 GΩ or I.R. × C ≥ 500 Ω.F. whichever is less
I.R. X C ≥ 100 Ω.F.
I.R. X C ≥ 100 Ω.F.
I.R. X C ≥ 50 Ω.F.
I.R. X C ≥ 50 Ω.F.
I.R. ≥ 1 GΩ or I.R. × C ≥ 100 Ω.F. whichever is less
I.R. X C ≥ 50 Ω.F.
–55 °C to +125 °C
www.yageo.com
Jun. 4, 2025 V.23
SOLDERING RECOMMENDATION
Table 10
SOLDERING
SIZE
METHOD
0201
Reflow
O
Wave
0402
0603
0805
1206
≥ 1210
O
O
O
O
O
O
O
O
SOLDERING CONDITIONS
The lead free MLCCs are able to stand the reflow soldering conditions as below:
Temperature: above 220 °C
Endurance: 95 to 120 seconds
Cycles: 3 times
The test of "soldering heat resistance" is carried out in accordance with the schedule of "MIL-STD-202G-method 210F", "The robust
construction of chip capacitors allows them to be completely immersed in a solder bath of 260 °C for 10 seconds". Therefore, it is possible
to mount MLCCs on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Capacitors are tested
for solderability at 245 °C during 2 seconds. The test condition for no leaching is 260°C for 30 seconds.
TESTS AND REQUIREMENTS
Table 11 Test procedures and requirements
NO
AEC-Q200 TEST
TEST METHOD
Preconditioning, Class II only :
150 +0/–10 °C for 1 hour, then keep for
24 ± 1 hours at room temperature
4
Temperature Cycling
1000 cycles with following detail:
15 minutes at lower category temperature
15 minutes at upper category temperature
Measurement at least 24 hours after test conclusion.
5
Destructive Physical Analysis
2. Test condition:
85 °C, 85% R.H. connected with 100 KΩ resistor, applied
1.5V/Ur (no more than 630V) for 1,000 hours.
Biased Humidity
No visual damage
∆C/C
NPO: Within ± 2.5% or 0.25 pF,
whichever is greater
X7R/X7S: ± 10%
D.F. meet initial specified value
IR meet initial specified value
Electrical test not required.
1. Preconditioning, class 2 only:
150 +0/-10 °C /1 hour, then keep for
24 ± 1 hour at room temp
7
REQUIREMENTS
3. Recovery:
NPO: 6 to 24 hours
X7R/X7S: 24 ± 4 hours
4. Final measure: C. D. I.R.
5. Measurement at least 24 hours after test conclusion
No visual damage after
recovery
∆C/C
NPO: Within ± 2% or 1 pF,
X7R/X7S: ± 15%
D.F.
NPO: ≤ 2 x specified value.
X7R/X7S:
(1) ≤ 16V: ≤ 7% or specified
value whichever is greater
(2) ≥ 25V: ≤ 5% or specified
I.R.
The insulation resistance shall
greater than 10% of initial spec.
8
High Temperature
No visual damage
www.yageo.com
Jun. 4, 2025 V.23
NO
AEC-Q200 TEST
Operational Life
TEST METHOD
REQUIREMENTS
∆C/C
Temperature: 125 °C
X7R/X7S: ± 15%
Specified stress voltage applied for 1,000 hours:
D.F.
Applied 2.0 x Ur for 6.3V to 100V *
High voltage series follows with below
stress condition:
Applied 1.5 x Ur for 200V, 250V series
Applied 1.3 x Ur for 500V, 630V series
Applied 1.2 x Ur for 1KV, 2KV, 3KV series
Note: If the capacitance value is less than the minimum value
X7R/X7S:
IR
NPO: ≥ 4,000 MΩ or IR x Cr ≥
permitted, then after the other measurements have been
40Ω.F. whichever is less
made the capacitor shall be preconditioned according to “IEC
X7R/X7S: ≥ 1,000 MΩ or
60384 and then the requirement shall be met.
IRx Cr ≥ 50Ω.F.
* Note : Applied 1.5 x Ur for 6.3V to 100V
0402/X7S/10V~25V/>100nF
whichever is less *
* IRx Cr ≥ 5Ω.F.
0402/X7R/50V/>10nF
0603/X7R/25V/>220nF; 0603/X7R/50V/220nF
0402/10V-16V/>100nF
* IRx Cr ≥ 10Ω.F.
0603/X7R/100V/≥100nF
0603/25V/>220nF
0805/X7R/100V/≥ 470nF
9
External Visual
Any applicable method using × 10 magnification
10
Physical Dimension
Verify physical dimensions to the applicable device specification. In accordance with specification
13
Mechanical Shock
Three shocks in each direction shall be applied along the three
∆C/C
mutually perpendicular axes of the test specimen
NPO: Within ± 0.5% or 0.5 pF,
(18 shocks)
Peak value: 100 g’s
X7R/X7S: ± 10%
Duration: 6 ms
Velocity change: 12.3 ft/s
Waveform: Half-sin
D.F.
Within initial specified value
IR
5 g’s for 20 minutes, 12 cycles each of 3 orientations.
∆C/C
Test from 10-2000 Hz.
NP0: Within ± 0.5% or 0.5 pF,
14
Vibration
X7R/X7S: ± 10%
D.F: meet initial specified value
www.yageo.com
Jun. 4, 2025 V.23
NO
AEC-Q200 TEST
TEST METHOD
REQUIREMENTS
Preconditioning, class II only : 150 +0/–10 °C for 1 hour, then
Dissolution of the end face
keep for 24 ± 1 hours at room temperature
plating shall not exceed 25% of
Follow MIL-STD-202 method 210 condition k, time above 217
the length of the edge
deg-C , 60s to 150s.
concerned
∆C/C
15
Resistance to Soldering Heat
NPO: Within ± 1% or 0.5 pF,
whichever is greater.
X7R/X7S: ± 10%
D.F. within initial specified value
IR within initial specified value
Per AEC-Q200-002
A component passes a voltage
level if all components stressed
at that voltage level pass.
YNM0053-1
6 kV
DC
FAIL
PASS
2 kV
DC
FAIL
17
ESD
12 kV
AD
PASS
FAIL
1 kV
DC
FAIL
500 V
DC
FAIL
< 500 V
DC
4 kV
DC
PASS
1 kV
DC
FAIL
2 kV
DC
PASS
8 kV
DC
PASS
4 kV
DC
FAIL
6 kV
DC
16 kV
AD
PASS
FAIL
8 kV
DC
PASS
12 kV
AD
PASS
25 kV
AD
FAIL
500 V
DC
PASS
16 kV
AD
25 kV
AD
Note: Classify the components according to the highest ESD voltage level survived during ESD testing.
Fig. 4 Passive component HBM ESD test flow diagram
(DC = Direct Contact Discharge, AD = Air Discharge)
1. J-STD-002 Method B1, coating durability category 2. Preheat
The solder should cover over
at 155°C for 4 hours. After preheating, immerse the capacitor
95% of the critical area of each
in a solution of ethanol and rosin. Immerse in eutectic solder
termination.
solution for 5+0/-0.5 seconds at 245± 5°C.
18
Solderability
2. J-STD-002 Method D, Coating Durability Category 2.
3. Should be placed into steam aging. After preheating, immerse
the capacitor in a solution of Ethanol and rosin. Immerse in
eutectic solder solution for 30 seconds at 260± 5°C.
www.yageo.com
Jun. 4, 2025 V.23
Within specified tolerance
Capacitance
NPO:
f = 1 MHz for C ≤ 1nF, measuring at voltage 1 Vrms at 25 °C
f = 1± 0.1 KHz for C > 1nF,
measuring at voltage 1± 0.2 Vrms at 25 °C
X7R/X7S:
At 25 °C, 24 hours after annealing
f = 1± 0.1 KHz, measuring at voltage 1± 0.2 Vrms at 25 °C
on Table 9
Dissipation
Factor (D.F.)
NPO:
measuring at voltage 1± 0.2 Vrms at 25°C
X7R/X7S:
Insulation
Resistance
(I.R.)
At Ur (DC) for 1 minute
Capacitance shall be measured by the steps shown in the
following table.
The capacitance change should be measured after 5 min at
each specified temperature stage.
19
Step
a
b
c
d
e
Electrical
Characterization
Temperature
coefficient
Temperature(°C)
25± 2
Lower temperature± 3°C
25± 2
Upper Temperature± 2°C
25± 2
on Table 9
∆C/C
NPO: ± 30ppm /°C
X7R: ± 15%
X7S: ± 22%
(1) NPO
Temperature Coefficient shall be calculated from the formula
as below
Temp, Coefficient = C2 - C1 106 [ppm/°C]
C1 xΔT
C1: Capacitance at step c
C2: Capacitance at 125°C
∆T: 100°C (=125°C -25°C)
(2) X7R/X7S
Capacitance Change shall be calculated from the formula as
below
∆C =
C2 - C1
x 100%
C1
C2: Capacitance at step b or d
Voltage
Proof
1. Specified stress voltage applied for 1~5 seconds
2. Ur ≤ 100 V: series applied 2.5 Ur
3. 100 V < Ur ≤ 200 V series applied (1.5 Ur + 100)
4. 200 V < Ur ≤ 500 V series applied (1.3 Ur + 100)
5. Ur > 500 V: 1.3 Ur
6. Ur ≥ 1000 V: 1.2 Ur
Charge/Discharge current is less than 50 mA
No breakdown or flashover
www.yageo.com
Jun. 4, 2025 V.23
Part mounted on a 100mm × 40mm FR4 PCB board, which is
1.6± 0.2 mm thick and has a layer-thickness 35µm± 10 µm.
Part should be mounted using the following soldering reflow
profile.
Conditions:
No visual damage
∆C/C
X7R/X7S: ± 10%
NPO:
Bending 3 mm at a rate of 1 mm/s, radius jig 340 mm
X7R/X7S:
Bending 2 mm at a rate of 1 mm/s, radius jig 340 mm
21
Board Flex
Test Substrate:
b
C
4.5
Y NSC 147
40
a
100
unit: mm
22
Terminal Strength
With the component mounted on a PCB obtained with the
device to be tested, apply a 17.7N (1.8Kg) force to the side of
a device being tested.
This force shall be applied for 60+1 seconds.
Also the force shall be applied gradually as not to apply a
shock to the component being tested.
* Apply 2N force for 0402 size.
* Apply 1N force for 0201 size.
Magnification of 20X or greater
may be employed for
inspection of the mechanical
integrity of the device body,
terminals and body/terminal
junction.
Before, during and after the
test, the device shall comply
with all electrical requirements
stated in this specification.
www.yageo.com
Jun. 4, 2025 V.23
THICKNESS CLASSES AND PACKING QUANTITY
Table 12
SIZE CODE
THICKNESS
CLASSIFICATION
PACKING CODE
7 INCH
13 INCH
QUANTITY PER REEL
TAPE WIDTH
Ø 180 MM / 7 INCH
Paper
Blister
Ø 330 MM / 13 INCH
Paper
Blister
0201
0.3 ± 0.03 mm
R
P
8 mm
15,000
50,000
0402
0.5 ± 0.05 mm
R
P
8 mm
10,000
50,000
0603
0.8 ± 0.1 mm
R
P
8 mm
4,000
15,000
0.6 ± 0.1 mm
R
P
8 mm
4,000
20,000
0.85 ± 0.1 mm
R
P
8 mm
4,000
15,000
1.25 ± 0.2 mm
K
F
8 mm
3,000
10,000
0.6 ± 0.1 mm
R
P
8 mm
4,000
20,000
0.85 ± 0.1 mm
R
P
8 mm
4,000
15,000
1.0/1.15 ± 0.1 mm
K
F
8 mm
3,000
10,000
1.25 ± 0.2 mm
K
F
8 mm
3,000
10,000
1.60 ± 0.2 mm
K
F
8 mm
2,000
8,000
0.85 ± 0.1 mm
K
F
8 mm
4,000
10,000
1.15 ± 0.1 mm
K
F
8 mm
3,000
10,000
1.25 ± 0.2 mm
K
F
8 mm
3,000
10,000
2.0 ± 0.2 mm
K
8 mm
2,000
2.5 ± 0.2 mm
K
8 mm
1,000
0.6 / 0.85± 0.1 mm
K
12 mm
2,000
1.15± 0.1 mm
K
12 mm
1,000
1.25± 0.2 mm
K
12 mm
1,000
1.6 ± 0.2 mm
K
12 mm
2,000
0805
1206
1210
1812
www.yageo.com
Jun. 4, 2025 V.23
PAPER/PE TAPE SPECIFICATION
Fig. 5 Paper/PE tape
Table 13 Dimensions of paper/PE tape for relevant chip size; see Fig.5
SIZE
Unit: mm
SYMBOL
CODE A0
B0
W
E
F
P0 (1)
P1
P2
Ø D0
K0
T
0.38 ± 0.05
(0.47/ 0.55)± 0.10
0201
0.39 ± 0.06 0.70 ± 0.06 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.55 ± 0.03
0402
0.70 ± 0.15 1.21 ± 0.12 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.50 +0.1 /-0 (0.75/ 0.60)± 0.10
0603
1.05 ± 0.14 1.86 ± 0.13 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05/0.95/ 0.75)± 0.10 (1.15/ 1.05/ 0.85)± 0.10
0805
1.50 ± 0.15 2.26 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05/0.95/ 0.75)± 0.10 (1.15/ 1.05/ 0.85)± 0.10
1206
1.90 ± 0.15 3.50 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (0.95/ 0.75)± 0.10
(0.85/ 0.70)± 0.10
(1.05/ 0.85)± 0.10
NOTE
1. P0 pitch tolerance over any 10 pitches is 0.2 mm
www.yageo.com
Jun. 4, 2025 V.23
BLISTER TAPE SPECIFICATION
P0
D0
K0
P2
E
F
cover tape
W
B0
A0
T2
SCM015
D1
P1
K0: so chosen that the orientation of the component
cannot change
For W = 8 mm: T2 = 3.5 mm max.
For W = 12 mm: T2 = 6.5 mm max.
direction of unreeling
Fig. 6 Blister tape
Table 14 Dimensions of blister tape for relevant chip size; see Fig.6
SYMBOL
SIZE
A0
B0
CODE
Unit: mm
K0
W
Min. Max. Min. Max. Min. Max.
E
F
Ø D0
Ø D1
Min.
P0 (2)
P1
P2
T2
Min. Max.
0805
1.29 1.65 2.09 2.60 1.25 1.62 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.30 1.67
1206
1.65 2.12 3.30 3.75 1.22 2.15 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.27 2.20
1210
2.55 3.02 3.31 3.88 0.97 2.92 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.02 2.97
1808
2.05 2.55 4.80 5.45 1.30 2.45 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.35 2.50
1812
3.35 3.75 4.70 5.33 0.70 2.40 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 8.0 ± 0.10 2.0 ± 0.05 0.75 2.45
NOTE
1. Typical capacitor displacement in pocket
2. P0 pitch tolerance over any 10 pitches is ±0.2 mm
www.yageo.com
Jun. 4, 2025 V.23
REEL SPECIFICATION
W2
C
N
A
HBK039
W1
Fig. 7 Reel
Table15 Reel dimensions; see Fig.7
TAPE WIDTH
SYMBOL
Unit: mm
A
N
C
W1
W2max.
8 (Ø 178 mm/7")
178 ± 1.0
60 ± 1.0
13 +0.50/-0.20
9.4 ± 1.5
14.4
8 (Ø 330 mm/13")
330 ± 1.0
100 ± 1.0
13 +0.50/-0.20
9.0 ± 0.2
14.4
12 (Ø 178 mm/7")
178 ± 1.0
60 ± 1.0
13 +0.50/-0.20
13.4 ± 1.5
18.4
P ROPERTIES OF REEL
Material: polystyrene
Surface resistance: 100 °C).
Therefore, it is advised to use the smallest possible size and follow the dimensional recommendations given in
Tables 8, 9 and 10 for reflow and wave soldering. More detailed information is available on request.
Solid line: Typical process (terminal temperature)
Dotted lines: Process limits - bottom process limit (terminal temperature) & upper process limit
(top surface temperature).
Fig. 8 Infrared soldering, forced gas convection reflow soldering - Temperature/time profile for SnPb solders
www.yageo.com
Jun. 4, 2025 V.23
300
YNM0016
10 s max.
T
(C)
260 C
255 C
245 C
250
220 C
200
180 C
Preheating
ca. 45~90 s > 220 C
150 C
150
Typical
Ramp down rate < 6 C/s
100
Ramp up rate < 3 C/s
50
100
150
200
250
300
350
400
t (s)
Fig. 9 Infrared soldering, forced gas convection reflow soldering - Temperature/time profile for lead-free SnAgCu solders
300
T
10 s max., max. contact time 5 s per wave
(C)
235 C to 260 C (SnPb)
250 C to 260 C (SnAgCu)
250
cooling
first wave
200
YNM0017
second wave
Preheating
ca. 2 C/s
T < 150 C
ca. 3.5 C/s typical
150
ca. 5 C/s
130 C
120 C
100 C
100
Typical
50
100
150
200
t (s)
250
Fig. 10 Double wave soldering for SnPb and lead-free SnAgCu solder - Temperature/time profile (terminal temperature)
www.yageo.com
Jun. 4, 2025 V.23
D
C
preferred direction during wave soldering
FOOTPRINT DIMENSIONS
G
B
A
F
solder land /
solder paste
pattern
solder resist
pattern
occupied area
MBG628-1
Fig. 11 Discrete capacitors recommended dimensions of footprint
Table 17 Reflow soldering; for footprint dimensions see Fig.11
Unit: mm
SIZE
CODE
A
B
C
D
F
G
0201
0.8 ± 0.20
0.25 ± 0.05
0.28 ± 0.07
0.3 ± 0.10
0402
1.5 ± 0.15
0.5 ± 0.15
0.5 ± 0.15
0.5 ± 0.15
1.75 ± 0.15
0.95 ± 0.15
0603
2.3 ± 0.15
0.7 ± 0.15
0.8 ± 0.15
0.9 ± 0.15
2.7 ± 0.15
1.5 ± 0.15
0805
2.8 ± 0.25
0.9 ± 0.25
0.95 ± 0.25
1.4 ± 0.25
3.2 ± 0.25
2.1 ± 0.25
1206
4.0 ± 0.25
2.0 ± 0.25
1.0 ± 0.25
1.8 ± 0.25
4.4 ± 0.25
2.5 ± 0.25
1210
4.0 ± 0.25
2.0 ± 0.25
1.0 ± 0.25
2.7 ± 0.25
4.4 ± 0.25
3.4 ± 0.25
1808
5.4 ± 0.25
3.3 ± 0.25
1.05 ± 0.25
2.3 ± 0.25
5.8 ± 0.25
2.9 ± 0.25
1812
5.4 ± 0.25
3.3 ± 0.25
1.05 ± 0.25
3.5 ± 0.25
5.8 ± 0.25
4.1 ± 0.25
2220
6.6 ± 0.25
4.5 ± 0.25
1.05 ± 0.25
5.3 ± 0.25
7.0 ± 0.25
5.9 ± 0.25
Processing remarks
IR or hot plate soldering
Ceramic substrate only
www.yageo.com
Jun. 4, 2025 V.23
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 23
Jun. 4, 2025
- Add NPO, 1210, 630V to 1000V, 15nF
Version 22
Jan. 14, 2025
- Revise AEC-Q200 test condition to version E.
Version 21
May 21, 2024
- Add 1206/NPO/630V/1.2nF to 10nF;
- Add 1210/NPO/630V/4.7nF to 33nF;
- Add 1210/NPO/1000V/4.7nF to 22nF;
Version 20
Jan. 20, 2024
Version 19
Jul. 08, 2022
Version 18
Apr. 16, 2022
- Add 0402/X7R/100pF to 150pF/10V to 50V;
- Add 0603/X7R/100pF to 680pF/10V to 100V;
- Add 1206/X7R/220pF to 10nF/6.3V to 250V;
- Add 0805/NPO/500V 10pF to 470pF
- Add 0805/NPO/630V 10pF to 180pF
- Add 1210/NPO/50V~500V/47pF to 820pF
- Add 0402/X7S/10V~16V/150nF~220nF
Version 17
Jan. 14, 2022
- Add 1206/NPO/2000V/10pF to 47pF
Version 16
Nov. 17, 2021
- Add 1206/X7R/500V to 1000V/220pF to 1nF
Version 15
Oct. 12, 2021
Version 14
Aug. 09, 2021
Version 13
Jun. 08, 2021
Version 12
Feb. 26, 2021
Version 11
Jun. 29, 2018
Version 10
May. 2, 2018
- Add 0603/NPO/25V/50V/2.7nF to 10nF
- I.R. for NPO change to " I.R. ≥ 100 GΩ or I.R.
C ≥ 1000Ω.F.
whichever is less"
- Add 1206/NPO/1kV/10pF to 220pF
1206/X7R/1kV/1nF
- Move out "Array" and "High Cap" to individual specification
Add 0603 NPO 50V/100V 1.2nF to 2.2nF
0402 X7R 50V 15nF to 100nF
0603 X7R 25V 330nF to 680nF
0603 X7R 50V 150nF to 220nF
0603 X7R 100V 68nF to 100nF
- Add 0201/ X7R/ 50V / 100 pF to 1nF
0603/ X7R/ 16V / 680nF to 1µF
0603/ X7R/ 25V / 150nF / 220nF/ 1µF
1210/ X7R/ 50V / 4.7µF
- Add 0201 NPO 25V/ 50V, 0.2pF to 33pF, Add 0402 NPO 50V 270pF to
1nF, Add 0805 X7R 25V 2.2uF
- Add 0603 NPO 100V 820pF to 1nF,
- Add 0805 NPO 50V to 100V, 1.2nF to 10nF,
- Add 0805 X7R 16V 2.2uF, 50V 680nF to 1uF,
- Add 1206 X7R 100V 330nF to 2.2uF, 250V 33nF to 100nF
Version 9
Mar. 22, 2018
- Add 0402 X7R 100nF 25~50V
Version 8
Nov. 22, 2017
- Add X7R/0201/25V/100pF~10nF
Version 7
Jul. 7, 2017
- Add X7R/0805/330nF to 470nF/50V, X7R/1206/10uF/6.3V
Version 6
Mar. 31, 2017
- Add NPO/0603/1nF/50V, X7R/0603/1uF/10V, X7R/0603/470nF/16V,
X7R/0603/220nF/25V
Version 5
Nov. 15, 2016
- Add Soldering Condition
Version 4
Jun. 14, 2016
- Add X7R/0805/2.2uF/10V and NPO/1206/1.2nF to 1.5nF/250V
Version 3
Jul. 21, 2015
- Tests and Requirements update
Version 2
Jul. 17, 2014
Version 1
Apr. 19, 2013
- Capacitance range update
Version 0
Dec. 25, 2012
- New
www.yageo.com
Jun. 4, 2025 V.23
LEGAL DISCLAIMER
YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any
errors, inaccuracies or incompleteness contained in any product related information, including but not limited
to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or
improvements to product related information at any time and without notice.
YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any
particular purpose or the continuing production of any of its products. To the maximum extent permitted by
law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii)
any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all
implied warranties, including warranties of fitness for a particular purp ose, non-infringement and
merchantability.
YAGEO products are designed for general purpose applications under normal operation and usage conditions.
Please contact YAGEO for the applications listed below which require especially high reliability for the
prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace
equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster
prevention equipment, crime prevention equipment, Electric heating apparatus, bu rning equipment, Highly
public information network equipment, data-processing equipment , Medical devices, Military equipment, Power
generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and
Undersea equipment, or for any other application or use in which the failure of YAGEO products could result
in personal injury or death, or serious property damage.
Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights
for revising this content without further notification, as long as products are unchanged. Any product change
will be announced by PCN.
www.yageo.com
Jun. 4, 2025 V.23
