ZHR-2-R
ZHR-2-R
    JST
    P=1.5mm
    1X2P 1.5MM
ZHR-2-R 数据手册
Emboss Tape ZH CONNECTOR 1.5mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– The ZH connector is very small with a mounting height of 5.6 mm and a thickness of only 3.5 mm. Contact retention lances on the housing make insertion easier, while the dimple at the center of the contact ensures reliable contact with the post. • Compact, low profile design • Housing lances • Reliable contact construction • Distortion resistant construction • Compatible with the ZR insulation displacement connectors • Current rating: 1.0 A AC, DC (AWG #26) • Voltage rating: 50 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 20 mΩ max. After environmental tests/ 30 mΩ max. • Insulation resistance: 500 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable wire: AWG #32 to #26 • Applicable PC board thickness: 0.6 to 1.2 mm, 1.6 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 PC board layout and Assembly layout 〈Through-hole type (viewed from soldering side) 〉 Side entry type 3.5 1.5min 1.5 ±0.05 2.2min 1.5min 7.1 4.6min 1.5 ±0.05 2.7 (3.4) 5.6 φ0.7±0.03 3.7 Top entry type 2.7 (3.4) φ0.7±0.03 4.6 Note: 1. Tolerances are non-cumulative: ±0.05 mm for all centers. 2. Hole dimension differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. 〈SMT type (viewed from component side) 〉 SM4 type Top entry type 1.3 ±0.1 3.7 1.5 ±0.1 1.5 ±0.05 0.6 SM2 type Side entry type 2 (6.4) 1.5 × (N-1)+ 0.9 2.3 ±0.1 0.9±0.05 2 min 0.7 min 1.4 ±0.1 (7.4) 1.4 ±0.1 0.7 min 3.7 Note: 1. N...Number of circuits 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. The dimensions above should serve as a guideline. Contact JST for details. 1 1.1 ±0.1 1.5 ±0.05 1.9 ±0.1 Side entry type 2.5max 3.7 φ1.1+0.1 0 (7.4) 4.3 1.5 ±0.05 0.7min ZH CONNECTOR Contact 4 Model No. 0.5 1 1.4 SZH-002T-P0.5 SZH-003T-P0.5 1.1 Applicable wire AWG# Insulation O.D. (mm) mm2 2.2 Q'ty/ reel 0.08 ∼0.13 28∼26 0.8∼1.1 13,000 0.032∼0.08 32∼28 0.5∼0.9 16,000 1.5 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 0.3 RoHS compliance Contact Applicator Dies Crimp applicator with dies MKS-L MK/SZH-002-05 APLMK SZH002-05   ―   ― ― Crimping machine Crimp applicator SZH-002T-P0.5 AP-K2N Contact SZH-003T-P0.5 Applicator Dies Crimp applicator with dies MKS-L MK/SZH-003-05 APLMK SZH003-05 *MKS-SC SC/SZH-003-05 APLSC SZH003-05 Crimping machine Crimp applicator AP-K2N Note: *Strip-crimp applicator. Housing B Circuit No.1 ZHR-2 ZHR-3 ZHR-4 ZHR-5 ZHR-6 ZHR-6(3.0) ZHR-7 ZHR-8 ZHR-9 ZHR-10 ZHR-11 ZHR-12 ZHR-13 2 3.4 3 A 1.5 4 0.3 1.5 5 6 6 6 5 3 2 1 4.2 7 8 9 0.3 10 11 12 13 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. Dimensions (mm) A B Model No. Circuits Q'ty/ bag 1.5 4.5 1,000 3.0 6.0 1,000 4.5 7.5 1,000 6.0 9.0 1,000 7.5 10.5 1,000 15.0 18.0 1,000 9.0 12.0 1,000 10.5 13.5 1,000 12.0 15.0 1,000 13.5 16.5 1,000 15.0 18.0 1,000 16.5 19.5 1,000 18.0 21.0 1,000 Material PA 66, UL94V-0, natural (white) ZHR-2-oo(blank)…natural (white) K…black R…red E…blue M…green L…lemon yellow LE…light blue DO…dark orange H…gray RoHS compliance Note: 1. ZHR-6(3.0) is 6 circuits 3.0 mm pitch plugged up. As for this housing, only circuit No.1 is marked. 2. ZHR-6(3.0) is not UL/CSA approved. Through-hole type shrouded header Circuits Top entry type B 3.5 2 B 3 3.5 4 2.2 4.5 φ0.5 Circuit No.1 1.5 1.5 A 2.7 Note) 3.4 A 1.5 2.7 Note) 3.4 4.5 5 Circuit No.1 2.2 6 7 8 9 10 11 12 13 Side entry type B2B-ZR B3B-ZR B4B-ZR B5B-ZR B6B-ZR B7B-ZR B8B-ZR B9B-ZR B10B-ZR B11B-ZR B12B-ZR B13B-ZR Side entry type Note) Note) Top entry type S2B-ZR S3B-ZR S4B-ZR S5B-ZR S6B-ZR S7B-ZR S8B-ZR S9B-ZR S10B-ZR S11B-ZR S12B-ZR S13B-ZR B2B-ZR-3.4 B3B-ZR-3.4 B4B-ZR-3.4 B5B-ZR-3.4 B6B-ZR-3.4 B7B-ZR-3.4 B8B-ZR-3.4 B9B-ZR-3.4 B10B-ZR-3.4 B11B-ZR-3.4 B12B-ZR-3.4 B13B-ZR-3.4 Q'ty/box Top entry Side entry Side entry type type type-3.4 Side entry type A B S2B-ZR-3.4 S3B-ZR-3.4 S4B-ZR-3.4 S5B-ZR-3.4 S6B-ZR-3.4 S7B-ZR-3.4 S8B-ZR-3.4 S9B-ZR-3.4 S10B-ZR-3.4 S11B-ZR-3.4 S12B-ZR-3.4 S13B-ZR-3.4 1.5 4.5 2,000 2,000 2,000 3.0 6.0 2,000 2,000 1,000 4.5 7.5 2,000 2,000 2,000 6.0 9.0 2,000 1,000 1,000 7.5 10.5 2,000 1,000 1,000 9.0 12.0 1,000 1,000 1,000 10.5 13.5 1,000 1,000 1,000 12.0 15.0 1,000 1,000 1,000 13.5 16.5 1,000 1,000 1,000 15.0 18.0 1,000 500 500 16.5 19.5 1,000 500 500 18.0 21.0 500 500 500 Material and Finish Pin: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (ivory) 4.6 1.5 1.5 2.7 Note) 3.4 2.4 JST φ0.5 A 3.7 B Circuit No.1 Dimensions (mm) Model No. Top entry type 1.4 RoHS compliance This product displays (LF)(SN) on a label. Note: Headers with 3.4 mm long solder tails, suited for the 1.6 mm thick PC board. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-ZR-3.4-oo(blank)…natural (ivory) K…black R…red E…blue M…green Y…Yellow 2 ZH CONNECTOR SMT type shrouded header SM2 type SM2 type Side entry type Model No. Side entry type Circuits S2B-ZR-SM2-TF S3B-ZR-SM2-TF S4B-ZR-SM2-TF S5B-ZR-SM2-TF S6B-ZR-SM2-TF S7B-ZR-SM2-TF S8B-ZR-SM2-TF S9B-ZR-SM2-TF S10B-ZR-SM2-TF S11B-ZR-SM2-TF S12B-ZR-SM2-TF S13B-ZR-SM2-TF 2 3 4 5 B Circuit No.1 5 1.5 A 1.5 1.5 1 6 7 8 3.7 9 10 HJST 1.5 11 12 φ1 13 Dimensions (mm) A B Q’ty/ reel 1.5 4.5 1,000 3.0 6.0 1,000 4.5 7.5 1,000 6.0 9.0 1,000 7.5 10.5 1,000 9.0 12.0 1,000 10.5 13.5 1,000 12.0 15.0 1,000 13.5 16.5 1,000 15.0 18.0 1,000 16.5 19.5 1,000 18.0 21.0 1,000 0.9 Material and Finish Pin: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 46, UL94V-0, natural (ivory) RoHS compliance This product displays (LF)(SN) on a label. SM4 type SM4 type (with solder tabs) Top entry type Model No. 2 B A Dimensions (mm) Circuits 3 2.25 1.5 4 5 5 6 3.7 7 HJST 1.5 8 9 10 Circuit No.1 11 12 13 Q'ty/reel Top entry Side entry type type Top entry type Side entry type A B B2B-ZR-SM4-TF B3B-ZR-SM4-TF B4B-ZR-SM4-TF B5B-ZR-SM4-TF B6B-ZR-SM4-TF B7B-ZR-SM4-TF B8B-ZR-SM4-TF B9B-ZR-SM4-TF B10B-ZR-SM4-TF B11B-ZR-SM4-TF B12B-ZR-SM4-TF B13B-ZR-SM4-TF S2B-ZR-SM4A-TF S3B-ZR-SM4A-TF S4B-ZR-SM4A-TF S5B-ZR-SM4A-TF S6B-ZR-SM4A-TF S7B-ZR-SM4A-TF S8B-ZR-SM4A-TF S9B-ZR-SM4A-TF S10B-ZR-SM4A-TF S11B-ZR-SM4A-TF S12B-ZR-SM4A-TF S13B-ZR-SM4A-TF 1.5 6.0 1,000 1,000 3.0 7.5 1,000 1,000 4.5 9.0 1,000 1,000 6.0 10.5 1,000 1,000 7.5 12.0 1,000 1,000 9.0 13.5 1,000 1,000 10.5 15.0 1,000 1,000 12.0 16.5 1,000 1,000 13.5 18.0 1,000 1,000 15.0 19.5 1,000 1,000 16.5 21.0 1,000 1,000 18.0 22.5 1,000 1,000 Material and Finish Side entry type Pin: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 6T, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) B A 5 2.25 1 3.7 1.5 Circuit No.1 1.5 RoHS compliance This product displays (LF)(SN) on a label. Note: 1. PA 9T is used for some colored products. 2. The products listed above are supplied on embossed-tape. 3. Contact JST for the top entry type headers with suction cap. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. HJST ex. 3 S2B-ZR-SM4A-oo-TF(blank)…natural (ivory) K…black R…red E…blue M…green L…lemon yellow LE…light blue DO…dark orange DH…dark gray
ZHR-2-R
物料型号:ZH CONNECTOR有多种型号,例如SZH-002T-P0.5、SZH-003T-P0.5等,适用于不同的电线规格和应用场景。
器件简介:ZH CONNECTOR是一种小型化的1.5mm间距、可断开的压接式连接器,具有5.6mm的安装高度和3.5mm的厚度。
引脚分配:文档中提供了详细的引脚分配信息,包括直插型和表面贴装型(SMT)的布局,以及不同类型(如顶入型和侧入型)的引脚分配
参数特性:包括电流额定值1.0A AC/DC(AWG #26)、电压额定值50V AC/DC、温度范围-25˚C至+85˚C、接触电阻初始值/20 mΩ最大,环境测试后/30 mΩ最大、绝缘电阻500 MΩ最小、耐压500 VAC/分钟。
功能详解:ZH CONNECTOR具有紧凑、低轮廓设计,接触保持凸耳使插入更容易,接触中心的凹点确保与柱子的可靠接触。
应用信息:适用于电线AWG #32至#26,PCB板厚度0.6至1.2mm,1.6mm。
封装信息:提供了不同型号的ZH CONNECTOR的尺寸和包装数量信息,例如ZHR-2至ZHR-13型号的尺寸和每袋/每卷的数量。
ZHR-2-R 价格&库存
很抱歉,暂时无法提供与“ZHR-2-R”相匹配的价格&库存,您可以联系我们找货
