B12B-ZR-SM4-TF(LF)(SN) 数据手册
Emboss Tape
ZH CONNECTOR
1.5mm pitch/Disconnectable Crimp style connectors
Specifications –––––––––––––––––––
The ZH connector is very small with a
mounting height of 5.6 mm and a thickness
of only 3.5 mm. Contact retention lances on
the housing make insertion easier, while the
dimple at the center of the contact ensures
reliable contact with the post.
• Compact, low profile design
• Housing lances
• Reliable contact construction
• Distortion resistant construction
• Compatible with the ZR insulation
displacement connectors
• Current rating: 1.0 A AC, DC (AWG #26)
• Voltage rating: 50 V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 20 mΩ max.
After environmental tests/ 30 mΩ max.
• Insulation resistance: 500 MΩ min.
• Withstanding voltage: 500 VAC/minute
• Applicable wire: AWG #32 to #26
• Applicable PC board thickness: 0.6 to 1.2 mm, 1.6 mm
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
PC board layout and Assembly layout
〈Through-hole type (viewed from soldering side) 〉
Side entry type
3.5
1.5min
1.5 ±0.05
2.2min
1.5min
7.1
4.6min
1.5 ±0.05
2.7
(3.4)
5.6
φ0.7±0.03
3.7
Top entry type
2.7
(3.4)
φ0.7±0.03
4.6
Note: 1. Tolerances are non-cumulative: ±0.05 mm for all centers.
2. Hole dimension differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should
be larger. The dimensions above should serve as a guideline. Contact JST for details.
〈SMT type (viewed from component side) 〉
SM4 type
Top entry type
1.3 ±0.1
3.7
1.5 ±0.1
1.5 ±0.05
0.6
SM2 type
Side entry type
2
(6.4)
1.5 × (N-1)+ 0.9
2.3 ±0.1
0.9±0.05
2 min
0.7 min
1.4
±0.1
(7.4)
1.4 ±0.1
0.7 min
3.7
Note: 1. N...Number of circuits
2. Tolerances are non-cumulative: ±0.05 mm for all centers.
3. The dimensions above should serve as a guideline. Contact JST for details.
1
1.1 ±0.1
1.5 ±0.05
1.9 ±0.1
Side entry type
2.5max
3.7
φ1.1+0.1
4.3
1.5 ±0.05
0.7min
ZH CONNECTOR
Contact
4
Model No.
0.5
1
1.4
SZH-002T-P0.5
SZH-003T-P0.5
1.1
Applicable wire
AWG#
Insulation O.D. (mm)
mm2
2.2
Q'ty/
reel
0.08 ∼0.13
28∼26
0.8∼1.1
13,000
0.032∼0.08
32∼28
0.5∼0.9
16,000
1.5
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
0.3
RoHS compliance
Contact
Applicator
Dies
Crimp applicator with dies
MKS-L
MK/SZH-002-05
APLMK SZH002-05
Crimping
machine Crimp applicator
SZH-002T-P0.5
AP-K2N
Contact
SZH-003T-P0.5
Applicator
Dies
MKS-L
MK/SZH-003-05
APLMK SZH003-05
*MKS-SC
SC/SZH-003-05
APLSC SZH003-05
Crimping
AP-K2N
Note: *Strip-crimp applicator.
Housing
B
Circuit No.1
ZHR-2
ZHR-3
ZHR-4
ZHR-5
ZHR-6
ZHR-6(3.0)
ZHR-7
ZHR-8
ZHR-9
ZHR-10
ZHR-11
ZHR-12
ZHR-13
2
3.4
3
A
1.5
4
0.3
1.5
5
6
6
6
5
3
2
1
4.2
7
8
9
0.3
10
11
12
13
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
Dimensions (mm)
A
B
Model No.
Circuits
Q'ty/
bag
1.5
4.5
1,000
3.0
6.0
1,000
4.5
7.5
1,000
6.0
9.0
1,000
7.5
10.5
1,000
15.0
18.0
1,000
9.0
12.0
1,000
10.5
13.5
1,000
12.0
15.0
1,000
13.5
16.5
1,000
15.0
18.0
1,000
16.5
19.5
1,000
18.0
21.0
1,000
Material
PA 66, UL94V-0, natural (white)
ZHR-2-oo(blank)…natural (white)
K…black R…red E…blue M…green L…lemon yellow
LE…light blue DO…dark orange H…gray
RoHS compliance
Note: 1. ZHR-6(3.0) is 6 circuits 3.0 mm pitch plugged up.
As for this housing, only circuit No.1 is marked.
2. ZHR-6(3.0) is not UL/CSA approved.
Through-hole type shrouded header
Circuits Top entry
type
B
3.5
2
B
3
3.5
4
2.2
4.5
φ0.5
Circuit
No.1
1.5
1.5
A
2.7
Note) 3.4
A 1.5
2.7
Note) 3.4
4.5
5
Circuit
No.1
2.2
6
7
8
9
10
11
12
13
Side entry type
B2B-ZR
B3B-ZR
B4B-ZR
B5B-ZR
B6B-ZR
B7B-ZR
B8B-ZR
B9B-ZR
B10B-ZR
B11B-ZR
B12B-ZR
B13B-ZR
Side entry
type
Note)
Note)
Top entry type
S2B-ZR
S3B-ZR
S4B-ZR
S5B-ZR
S6B-ZR
S7B-ZR
S8B-ZR
S9B-ZR
S10B-ZR
S11B-ZR
S12B-ZR
S13B-ZR
B2B-ZR-3.4
B3B-ZR-3.4
B4B-ZR-3.4
B5B-ZR-3.4
B6B-ZR-3.4
B7B-ZR-3.4
B8B-ZR-3.4
B9B-ZR-3.4
B10B-ZR-3.4
B11B-ZR-3.4
B12B-ZR-3.4
B13B-ZR-3.4
Q'ty/box
Top entry Side entry Side entry
type
type type-3.4
Side entry type
A
B
S2B-ZR-3.4
S3B-ZR-3.4
S4B-ZR-3.4
S5B-ZR-3.4
S6B-ZR-3.4
S7B-ZR-3.4
S8B-ZR-3.4
S9B-ZR-3.4
S10B-ZR-3.4
S11B-ZR-3.4
S12B-ZR-3.4
S13B-ZR-3.4
1.5
4.5 2,000 2,000 2,000
3.0
6.0 2,000 2,000 1,000
4.5
7.5 2,000 2,000 2,000
6.0
9.0 2,000 1,000 1,000
7.5 10.5 2,000 1,000 1,000
9.0 12.0 1,000 1,000 1,000
10.5 13.5 1,000 1,000 1,000
12.0 15.0 1,000 1,000 1,000
13.5 16.5 1,000 1,000 1,000
15.0 18.0 1,000
500
500
16.5 19.5 1,000
500
500
18.0 21.0
500
500
500
Material and Finish
Pin: Brass, copper-undercoated, tin-plated (reflow treatment)
Wafer: Glass-filled PA 66, UL94V-0, natural (ivory)
4.6
1.5
1.5
2.7
Note) 3.4
2.4
JST
φ0.5
A
3.7
B
Circuit No.1
Dimensions (mm)
Model No.
Top entry type
1.4
RoHS compliance This product displays (LF)(SN) on a label.
Note: Headers with 3.4 mm long solder tails, suited for the 1.6 mm thick PC
board.
ex. B2B-ZR-3.4-oo(blank)…natural (ivory)
K…black R…red E…blue M…green Y…Yellow
2
ZH CONNECTOR
SMT type shrouded header
SM2 type
SM2 type
Side entry type
Model No.
Side entry type
Circuits
S2B-ZR-SM2-TF
S3B-ZR-SM2-TF
S4B-ZR-SM2-TF
S5B-ZR-SM2-TF
S6B-ZR-SM2-TF
S7B-ZR-SM2-TF
S8B-ZR-SM2-TF
S9B-ZR-SM2-TF
S10B-ZR-SM2-TF
S11B-ZR-SM2-TF
S12B-ZR-SM2-TF
S13B-ZR-SM2-TF
2
3
4
5
B
Circuit No.1
5
1.5
A
1.5
1.5
1
6
7
8
3.7
9
10
HJST
1.5
11
12
φ1
13
Dimensions (mm)
A
B
Q’ty/
reel
1.5
4.5
1,000
3.0
6.0
1,000
4.5
7.5
1,000
6.0
9.0
1,000
7.5
10.5
1,000
9.0
12.0
1,000
10.5
13.5
1,000
12.0
15.0
1,000
13.5
16.5
1,000
15.0
18.0
1,000
16.5
19.5
1,000
18.0
21.0
1,000
0.9
Material and Finish
Wafer: Glass-filled PA 46, UL94V-0, natural (ivory)
SM4 type
SM4 type (with solder tabs)
Top entry type
Model No.
2
B
A
Dimensions (mm)
Circuits
3
2.25
1.5
4
5
5
6
3.7
7
HJST
1.5
8
9
10
Circuit No.1
11
12
13
Q'ty/reel
type
type
Top entry type
Side entry type
A
B
B2B-ZR-SM4-TF
B3B-ZR-SM4-TF
B4B-ZR-SM4-TF
B5B-ZR-SM4-TF
B6B-ZR-SM4-TF
B7B-ZR-SM4-TF
B8B-ZR-SM4-TF
B9B-ZR-SM4-TF
B10B-ZR-SM4-TF
B11B-ZR-SM4-TF
B12B-ZR-SM4-TF
B13B-ZR-SM4-TF
S2B-ZR-SM4A-TF
S3B-ZR-SM4A-TF
S4B-ZR-SM4A-TF
S5B-ZR-SM4A-TF
S6B-ZR-SM4A-TF
S7B-ZR-SM4A-TF
S8B-ZR-SM4A-TF
S9B-ZR-SM4A-TF
S10B-ZR-SM4A-TF
S11B-ZR-SM4A-TF
S12B-ZR-SM4A-TF
S13B-ZR-SM4A-TF
1.5
6.0
1,000
1,000
3.0
7.5
1,000
1,000
4.5
9.0
1,000
1,000
6.0
10.5
1,000
1,000
7.5
12.0
1,000
1,000
9.0
13.5
1,000
1,000
10.5
15.0
1,000
1,000
12.0
16.5
1,000
1,000
13.5
18.0
1,000
1,000
15.0
19.5
1,000
1,000
16.5
21.0
1,000
1,000
18.0
22.5
1,000
1,000
Material and Finish
Side entry type
Wafer: PA 6T, UL94V-0, natural (ivory)
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
B
A
5
2.25
1
3.7
1.5
Circuit No.1
1.5
Note: 1. PA 9T is used for some colored products.
2. The products listed above are supplied on embossed-tape.
3. Contact JST for the top entry type headers with suction cap.
HJST
ex.
3
S2B-ZR-SM4A-oo-TF(blank)…natural (ivory)
LE…light blue DO…dark orange DH…dark gray
