BM07B-NSHSS-TBT(LF)(SN)
    JST
    SMD,P=1mm
    线对板针座 1x7P 立贴 间距:1mm
BM07B-NSHSS-TBT(LF)(SN) 数据手册
NSH CONNECTOR 1.0mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– 1.0mm pitch secure lock type connector. This low insertion force type connector realizes easier mating operation. The basic concept of the contact part of this connector is equivalent to the performance proven SHL connector. • Secure locking structure • Contact lock structure • Prevention of contact deformation • Clear engagement click sounds • Current rating: 1.0 A AC, DC (AWG #28) • Voltage rating: 50 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 30 mΩ max. After environmental tests/ 50 mΩ max. • Insulation resistance: 100 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable wire: Conductor size/ AWG #32 to #28 Insulation O.D./ 0.4 to 0.8 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 PC board layout and Assembly layout Top entry type Side entry type 1 ± 0.1 0.6 ± 0.1 (4.5) 5.7 ±0.1 (7.8) 5.6 ±0.1 3.9 ±0.1 2.8 ±0.1 0.6 ±0.1 2.8 ±0.1 0.3 ±0.1 Connector outline (7.65) 0.8 7.4 ±0.1 Connector outline Circuit No.1 1 ±0.05 0.6 ±0.05 0.55 0.3 ±0.1 (4.4) A ±0.05 1±0.1 1 ±0.05 0.6 ±0.05 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. The dimensions above should serve as a guideline. Contact JST for details. Circuit No.1 A ±0.05 Contact Applicable wire mm2 AWG# Model No. SSHL- 003T- P0.2 0.032∼0.08 Q´ty/ reel 0.4∼0.8 41,000 Material and Finish 4.75 Phosphor bronze, tin-plated (reflow treatment) 2 0.5 32∼28 Insulation O.D. (mm) 0.8 2.35 0.8 0.4 RoHS compliance Contact Crimping machine Crimp applicator SSHL-003T-P0.2 AP-K2N Applicator Dies Crimp applicator with dies MKS-L-10-3 MK/SSH/L-003-02 APLMK SSH/L003-02 *MKS-SC SC/SSH/L-003-02 APLSC SSH/L003-02 Note: *Strip-crimp applicator Contact JST for applicable wires in case that it is not usable due to wire size. 1 NSH CONNECTOR Housing 4.2 Circuit No.1 mark Circuits Model No. 2 NSHR-02V-S NSHR-03V-S NSHR-04V-S NSHR-05V-S NSHR-06V-S NSHR-07V-S NSHR-08V-S NSHR-09V-S NSHR-10V-S NSHR-11V-S NSHR-12V-S NSHR-13V-S NSHR-14V-S NSHR-15V-S 3 6.2 4 5 6 7 8 A 9 B 10 11 12 13 14 15 4.2 Dimensions (mm) A B Q'ty/ bag *2.0 *5.0 3,000 2.0 5.0 3,000 3.0 6.0 2,500 4.0 7.0 2,000 5.0 8.0 1,500 6.0 9.0 1,500 7.0 10.0 1,500 8.0 11.0 1,000 9.0 12.0 1,000 10.0 13.0 1,000 11.0 14.0 1,000 12.0 15.0 1,000 13.0 16.0 1,000 14.0 17.0 1,000 Material Circuit No.1 mark PBT, UL94V-0, natural 6.2 RoHS compliance Note: 2 circuits product is that the second pin of 3 circuits product is plugged up. (Between circuits 2.0mm pitch) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 1 ex. A B 4.2 NSHR-02V-SS...natural Z...ivory TR...tomato red E...blue MG...moss green DH...dark gray LE...light blue K...black DPK...dark pink 6.2 Circuit No.1 mark 1 A B Circuit No.1 mark 6.2 4.2 1 A B 2 NSH CONNECTOR Shrouded header Side entry type Top entry type B B B A Circuit No.1 mark 4.4 A 0.55 Circuit No.1 mark 4.4 4.4 Circuit No.1 mark 4.4 1 0.55 0.8 0.8 6 6 6 1 B A Circuit No.1 mark A 6 Circuit No.1 mark B A Circuit No.1 mark B A 4.4 0.55 4.4 1 0.8 6 6 1 Circuit No.1 mark B Circuit No.1 mark B A 4.4 A 4.4 1 0.55 0.8 6 6 1 Top entry type Side entry type Circuits Model No. 2 BM02B-NSHSS-TBT BM03B-NSHSS-TBT BM04B-NSHSS-TBT BM05B-NSHSS-TBT BM06B-NSHSS-TBT BM07B-NSHSS-TBT BM08B-NSHSS-TBT BM09B-NSHSS-TBT BM10B-NSHSS-TBT BM11B-NSHSS-TBT BM12B-NSHSS-TBT BM13B-NSHSS-TBT BM14B-NSHSS-TBT BM15B-NSHSS-TBT 3 4 5 6 7 8 9 10 11 12 13 14 15 Dimensions (mm) A B Q'ty/ reel Circuits Model No. SM02B-NSHSS-TB SM03B-NSHSS-TB SM04B-NSHSS-TB SM05B-NSHSS-TB SM06B-NSHSS-TB SM07B-NSHSS-TB SM08B-NSHSS-TB SM09B-NSHSS-TB SM10B-NSHSS-TB SM11B-NSHSS-TB SM12B-NSHSS-TB SM13B-NSHSS-TB SM14B-NSHSS-TB SM15B-NSHSS-TB *2.0 *5.0 1,000 2 2.0 5.0 1,000 3 3.0 6.0 1,000 4 4.0 7.0 1,000 5 5.0 8.0 1,000 6 6.0 9.0 1,000 7 7.0 10.0 1,000 8 8.0 11.0 1,000 9 9.0 12.0 1,000 10 10.0 13.0 1,000 11 11.0 14.0 1,000 12 12.0 15.0 1,000 13 13.0 16.0 1,000 14 14.0 17.0 1,000 15 Dimensions (mm) A B *5.0 1,500 2.0 5.0 1,500 3.0 6.0 1,500 4.0 7.0 1,500 5.0 8.0 1,500 6.0 9.0 1,500 7.0 10.0 1,500 8.0 11.0 1,500 9.0 12.0 1,500 10.0 13.0 1,500 11.0 14.0 1,500 12.0 15.0 1,500 13.0 16.0 1,500 14.0 17.0 1,500 Material and Finish Material and Finish Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Polyamide, UL94V-0, natural Reinforcement: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS compliance This product displays (LF)(SN) on a label. Note: 1. The products listed above are supplied on embossed-tape/without suction tape. 2. 2 circuits product is that the second pin of 3 circuits product is plugged up. (Between circuits 2.0mm pitch) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 3 *2.0 Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Polyamide, UL94V-0, natural Reinforcement: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS compliance This product displays (LF)(SN) on a label. Note: 1. The products listed above are supplied on embossed-tape/with suction tape. 2. 2 circuits product is that the second pin of 3 circuits product is plugged up. (Between circuits 2.0mm pitch) ex. Q'ty/ reel BM02B-NSHSS-TBT SM02B-NSHSS-TBS...natural Z...ivory TR...tomato red E...blue MG...moss green DH...dark gray LE...light blue K...black DPK...dark pink
BM07B-NSHSS-TBT(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“BM07B-NSHSS-TBT(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
    • 1+3.790641+0.49042
    • 10+2.9172210+0.37742
    • 50+2.3582350+0.30510
    • 100+1.99140100+0.25764
    • 500+1.91279500+0.24747
    • 1000+1.860391000+0.24069
    • 2000+1.834182000+0.23730
    库存:487
      • 1+2.738171+0.35426
      • 50+2.7132850+0.35104
      • 100+2.19884100+0.28448
      • 300+1.85034300+0.23939
      • 500+1.78396500+0.23081
      • 1000+1.734181000+0.22437
      • 4000+1.692694000+0.21900
      库存:163
        • 1+2.882291+0.37290
        • 50+2.8560850+0.36951
        • 100+2.31456100+0.29945
        • 300+1.94773300+0.25199
        • 500+1.87785500+0.24295
        • 1000+1.825451000+0.23617
        库存:163
          • 1+5.10840
          • 10+4.12560
          • 30+3.63960
          库存:7
          • 10+7.32180
          • 100+5.47600
          • 500+4.24540
          • 1000+3.07640
          • 2000+2.92260
          • 10000+2.70730
          库存:2000
