附件 6
版本号:FH-2017-001
一、概述
● 电容器及介质种类:
※ 高频类: 此类介质材料的电容器为Ⅰ类电容器,包括通用型高频 COG、COH 电容器和温度补
偿型高频 HG、LG、PH、RH、SH、TH、UJ、SL 电容器。其中 COG、COH 电容器电性能最稳定,
几乎不随温度、电压和时间的变化而变化,适用于低损耗,稳定性要求高的高频电路,HG、LG、
PH、RH、SH、TH、UJ、SL 电容器容量随温度变化而相应变化,适用于低损耗、温度补偿型电路
中。
※ X7R、X5R、X7S、X6S:此类介质材料的电容器为Ⅱ类电容器,具有较高的介电常数,容量比Ⅰ
类电容器高,具有较稳定的温度特性,适用于容量范围广,稳定性要求不高的电路中,如隔直、耦合、
旁路、鉴频等电路中。
※Y5V:此类介质材料的电容器为Ⅱ类电容器,是所有电容器中介电常数最大的电容器,但其容量稳
定性较差,对温度、电压等条件较敏感,适用于要求大容量,温度变化不大的电路中。
※Z5U:此类介质材料的电容器为Ⅱ类电容器,其温度特性介于 X7R 和 Y5V 之间,容量稳定性较差,
对温度、电压等条件较敏感,适用于要求大容量,使用温度范围接近于室温的旁路,耦合等,低直流
偏压的电路中。
SUMMARY
●Types of Dielectric Material and Capacitor
※HIGH FREQUENCY TYPE: The capacitor of this kind dielectric material is considered as ClassⅠ
capacitor, including high frequency COG、COH capacitor and temperature compensating capacitor such as
HG, LG, PH, RH,SH, TH, UJ, SL. The electrical properties of COG、COH capacitor are the most stable one
and change invariablly with temperature, voltage and time. They are suited for applications where low-losses
and high-stability are required, HG,LG,PH,RH,SH,TH,UJ,SL capacitor’s capacitance changes with
temperature.They are suited for applications where low-losses and temperature compensating circuits.
※ X7R、X5R、X7S、X6S: X7R、X5R、X7S、X6S material is a kind of material has high dielectric
constant. The capacitor made of this kind material is considered as Class Ⅱ capacitor whose capacitance
is higher than that of class Ⅰ. These capacitors are classified as having a semi-stable temperature
characteristic and used over a wide temperature range, such in these kinds of circuits, DC-blocking,
decoupling, bypassing, frequency discriminating etc.
※Y5V: The capacitor made of this kind of material is the highest dielectric constant of all ceramic
capacitors. They are used over a moderate temperature range in application where high capacitance is
required because of its unstable temperature coefficient, but where moderate losses and capacitance changes
can be tolerated. Its capacitance and dissipation factors are sensible to measuring conditions, such as
temperature and voltage, etc.
※Z5U: The capacitor made of this kind of material is considered as ClassⅡ capacitor, whose temperature
characteristic is between that of X7R and Y5V. The capacitance of this kind of capacitor is unstable and
sensible to temperature and voltage. Ideally suited for bypassing and decoupling application circuits
operating with low DC bias in the environment approaches to room temperature.
第
1 页
共
14 页
二、尺寸及结构
DIMENSIONS AND STRUCTURE
※ 尺寸 DIMENSIONS
L
L
W
W
T
WB
WB
型号 Type
尺寸
英制表示 公制表示
British
Metric
expression expression
介质种类
Dielectric
W
T
WB
0.2±0.02
0.2±0.02
0.1±0.03
All
0.3±0.03
0.3±0.03
0.15±0.10
C<220nF
0.3±0.05
0.3±0.05
0.15±0.10
C≥220nF
1.00±0.05 0.50±0.05 0.50±0.05
0.25±0.10
C≤0.47uF
1.00±0.15 0.50±0.10 0.50±0.10
0.25±0.10 0.47uF<C≤1uF
L
0402
所有介质
0.4±0.02
All Dielectric
0201
0603
0.6±0.03
所有介质
All Dielectric 0.6±0.05
0402
0603
0805
1005
1608
2012
第
(mm)
特别说明
Special
Instructions
1005
Y5V/Z5U
Dimensions
除 Y5V/Z5U
1.00±0.15 0.50±0.15 0.50±0.15
外
1.00±0.20 0.50±0.20 0.50±0.20
0.25±0.10
C<1uF
0.25±0.10
1uF≤C<10uF
0.25±0.10
C≥10uF
所有材料 1.60±0.10 0.80±0.10 0.80±0.10
All Dielectric 1.60±0.20 0.80±0.20 0.80±0.20
0.30±0.10
C<10uF
0.30±0.10
C≥10uF
2.00±0.20 1.25±0.20 0.70±0.10
0.50±0.20
C≤0.22uF
2.00±0.20 1.25±0.20 0.80±0.10
0.50±0.20
2.00±0.20 1.25±0.20 1.25±0.20
0.50±0.20 2.2uF<C≤10uF
Y5V/Z5U
2 页
0.22uF<C≤
共
14 页
2.2uF
型号 Type
尺寸
2012
WB
除 Y5V/Z5U 2.00±0.20 1.25±0.20 0.80±0.20
外
0.50±0.20
C<1uF
0.50±0.20
C≥1uF
3.20±0.30 1.60±0.30 0.80±0.20
0.60±0.30
C≤10uF
3.20±0.30 1.60±0.30 1.60±0.30
0.60±0.30
C>10uF
0.60±0.30
C≤1uF
除 Y5V/Z5U 3.20±0.30 1.60±0.30 1.00±0.20
外
3.20±0.30 1.60±0.30 1.25±0.20
0.60±0.30
1uF<C≤2.2uF
0.60±0.30
C≥4.7uF
≤2.80
0.60±0.30
All
4.50±0.40 2.00±0.20
≤2.20
0.60±0.30
All
4.50±0.40 3.20±0.30
≤3.50
0.60±0.30
All
5.70±0.40 5.00±0.40
≤3.50
0.60±0.30
All
5.70±0.50 6.30±0.50
≤6.20
0.60±0.30
All
7.60±0.50 3.20±0.30
≤8.10
0.60±0.30
All
7.60±0.50 9.00±0.50
≤8.10
0.60±0.30
All
Y5V/Z5U
1206
3216
1210
3225
1808
4520
1812
4532
2220
5750
2225
5763
3012
7632
3035
7690
(mm)
特别说明
Special
Instructions
介质种类
Dielectric
英制表示 公制表示
British
Metric
0805
Dimensions
L
W
T
所有介质
3.20±0.30 2.50±0.30
All Dielectric
所有介质
All Dielectric
所有介质
All Dielectric
所有介质
All Dielectric
所有介质
All Dielectric
所有介质
All Dielectric
所有介质
All Dielectric
0.60±0.30 2.2uF<C<4.7uF
备注:可根据客户的特殊要求设计符合客户需求的产品。
Note:We can design according to customer special requirements。
序号
NO
※ 结构 STRUCTURE
W
L
①
②
T
③
①
②
③
第
3 页
④
④
⑤
⑤
名称
Name
陶瓷介质
Ceramic dielectric
内电极
Inner electrode
外电极
Substrate electrode
镍层
Nickel Layer
锡层
Tin Layer
共
14 页
三、型号规格表示方法
0805
HOW TO ORDER
CG
101
J
500
N
T
②
③
④
⑤
⑥
⑦
①
※说明 NOTES:
①尺寸 DIMENSIONS
尺寸规格
1005 0201 0402
SizeCode
长×宽
0.01
0.02
0.04
(L×W)
inch
0.005
0.01
0.02
长×宽
0.40
0.60
1.00
(L×W)
mm
0.20
0.30
0.50
单位(unit)
:inch/ mm
0603
0805
1206
1210
1808
1812
2220
2225
3035
0.06
0.08
0.12
0.12
0.18
0.18
0.22
0.22
0.30
0.03
0.05
0.06
0.10
0.08
0.12
0.20
0.25
0.35
1.60
2.00
3.20
3.20
4.50
4.50
5.70
5.70
7.60
0.80
1.25
1.60
2.50
2.00
3.20
5.00
6.30
9.00
② 介质种类 DIELECTRIC STYLE
介质种类
(Dielectric
CG
CH
HG
LG
PH
RH
SH
TH
UJ
SL
B
X
BS
DS
E
F
COG
COH
HG
LG
PH
RH
SH
TH
UJ
SL
X7R
X5R
X7S
X6S
Z5U
Y5V
Code)
介质材料
(Dielectric)
③ 标称容量 NOMINAL CAPACITANCE
表示方式
实际值
(Express Method)
(Actual Value)
0R5
0.5
1R0
1.0
102
10×10
224
22×10
单位(unit):pF
注:头两位数字为有效数字,第三位数字为 0
的个数;R 为小数点。
Note: the first two digits are significant; third digit
denotes number of zeros; R=decimal point.
2
4
④ 容量误差 CAPACITANCE TOLERANCE
代码
(Code)
误差
(Tolera
nce)
A
B
C
D
F
G
J
0.05pF
0.10pF
0.25pF
0.5pF
1.0%
2.0%
5.0%
K
±10%
L
M
S
Z
±15%
±20%
+50%
-20%
+80%
-20%
备注:A、B、C、D 级误差适用于容量≤10pF 的产品。
Note:These capacitance tolerance A,B, C, D are just applicable the capacitance that equals to or less than
10pF。
第 4 页
共
14 页
⑤ 额定电压 RATED VOLTAGE
单位(unit):V
表示方式
实际值
(Express Method)
(Actual Value)
6R3
6.3
500
50×10
201
20×10
102
10×10
注:头两位数字为有效数字,第三位数字为 0 的个数;
R 为小数点。
1
2
⑥ 端头材料 TERMINAL MATERIAL STYLES
端头类别 (Termination Styles)
纯银端头
表示方式 (Express Method)
(Silver Solderable Termination)
S
纯铜端头 (Copper Solderable Termination)
C
三层电镀端头 (Nickel Barrier Termination)
N
⑦ 包装方式 PACKAGE STYLES
B
T
散包装(Bulk Bag)
编带包装(Taping Package)
四、温度系数/特性 Temperature Coefficient /Characteristics
介质种类
参考温度点
标称温度系数
Dielectric Reference Temperature Point Temperature Coefficient
工作温度范围
Operation Temperature Range
COG
20C
030 ppm/℃
-55℃~125℃
COH
20C
060 ppm/℃
-55℃~125℃
HG
20C
-3330 ppm/℃
-25℃~85℃
LG
20C
-7530 ppm/℃
-25℃~85℃
PH
20C
-150 60 ppm/℃
-25℃~85℃
RH
20C
-220 60 ppm/℃
-25℃~85℃
SH
20C
-330 60 ppm/℃
-25℃~85℃
TH
20C
-470 60 ppm/℃
-25℃~85℃
UJ
20C
-750 120 ppm/℃
-25℃~85℃
SL
20C
-1000~+140 ppm/℃
-25℃~85℃
X7R
20C
15%
-55℃~125℃
X5R
20C
15%
-55℃~85℃
X7S
20C
22%
-55℃~125℃
X6S
20C
22%
-55℃~105℃
Z5U
20C
-56%~+22%
10℃~85℃
Y5V
20C
-80%~+30%
-25℃~85℃
备注:Ⅰ类电容器标称温度系数和允许偏差是采用温度在 20C 和 85C 之间的电容量变化来确定的,而
Ⅱ类电容器标称温度系数是按照工作范围之间的电容量相对 20C 的电容量变化来确定的。
Note:Nominal temperature coefficient and allowed tolerance of class Ⅰare decided by the changing of the
capacitance between 20C and 85C. Nominal temperature coefficient of class Ⅱare decided by the
temperature of 20C。
第
5 页
共
14 页
五、容量范围及其电压
Capacitance Range and Operating Voltage
单位/unit:pF
容量范围 Capacitance
尺寸规格
额定电压
Size Code
Rated Voltage
COG(NPO)(PF)
Y5V (Z5U)(PF)
4V
6.3V
10V
0.1~220
16V
0.1~100
25V
0.1~100
50V
4V
6.3V
10,000~100,000
10V
16V
10,000
25V
0.1~1,000
50V
0.1~220
4V
6.3V
0.1~4,700
1,000~1,000,000
10V
0.1~2,700
1,000~1,000,000
16V
0.1~2,700
1,000~220,000
25V
0.1~1,200
1,000~220,000
50V
0.1~1,000
1,000~100,000
4V
6.3V
1,000~10,000,000
10V
0.1~22,000
1,000~10,000,000
16V
0.1~10,000
1,000~2,200,000
25V
0.1~6,800
1,000~2,200,000
50V
0.1~6,800
1,000~1,000,000
4V
6.3V
1,000~22,000,000
10V
0.1~100,000
1,000~22,000,000
16V
0.1~33,000
1,000~10,000,000
25V
0.1~27,000
1,000~4,700,000
50V
0.1~22,000
1,000~2,200,000
1005
0201
0402
0603
0805
第 6 页
共
14 页
尺寸规格
额定电压
Size Code
Rated Voltage
COG(NPO)(PF)
Y5V (Z5U)(PF)
4V
6.3V
1,000~47,000,000
10V
1,000~22,000,000
16V
1,000~22,000,000
25V
1,000~10,000,000
50V
0.3~100,000
1,000~4,700,000
6.3V
4,700~100,000,000
10V
4,700~47,000,000
16V
4,700~22,000,000
25V
4,700~10,000,000
50V
10~100,000
4,700~4,700,000
6.3V
10V
16V
25V
50V
10~100,000
6.3V
10,000~100,000,000
10V
10,000~100,000,000
16V
10,000~22,000,000
25V
10,000~10,000,000
50V
10~100,000
10,000~10,000,000
1206
1210
1808
1812
容量范围 Capacitance
第 7 页
共
14 页
尺寸规格
Size Code Rated Voltage
1005
0201
0402
0603
0805
容量范围 Capacitance
额定电压
X7R (PF)
X7S(PF)
X5R(uF)
X6S(uF)
4V
0.015uF~0.1uF
6.3V
0.015uF~0.1uF
10V
100~1,000
0.015uF~0.01uF
16V
100~1,000
0.015uF~0.01uF
25V
50V
4V
10,000~1,000,000
0.015uF~1uF
0.015uF~1uF
6.3V
10,000~220,000
0.015uF~1uF
0.015uF~1uF
10V
100~22,000
10,000~220,000
0.015uF~1uF
0.015uF~0.22uF
16V
100~22,000
0.015uF~0.22uF
0.015uF~0.1uF
25V
100~10,000
0.015uF~0.1uF
0.015uF~0.1uF
50V
100~1,000
0.0047uF~0.01uF
4V
0.1uF~10uF
0.1uF~4.7 uF
6.3V
100~470,000
100,000~470,000
0.1uF~10uF
0.1uF~4.7 uF
10V
100~470,000
100,000~470,000
0.1uF~4.7uF
0.1uF~2.2 uF
16V
100~220,000
47,000~220,000
0.1uF~2.2 uF
0.1uF~2.2 uF
25V
100~220,000
22,000~100,000
0.1uF~2.2 uF
0.1uF~1 uF
50V
100~100,000
4,700~100,000
0.047uF~1uF
4V
0.47uF~22uF
0.1uF~22 uF
6.3V
150~4,700,000
470,000~2,200,000
0.47uF~22uF
0.1uF~22 uF
10V
150~2,200,000
470,000~2,200,000
0.47uF~22uF
0.1uF~10 uF
16V
150~2,200,000
470,000~1,000,000
0.47uF~10uF
0.1uF~10 uF
25V
150~1,000,000
470,000~1,000,000
0.47uF~10uF
0.1uF~4.7 uF
50V
150~1,000,000
0.47uF~2.2uF
4V
1uF~47uF
0.1uF~47 uF
6.3V
150~10,000,000 1,000,000~10,000,000
1uF~47uF
0.1uF~22 uF
10V
1uF~22uF
0.1uF~22 uF
16V
150~10,000,000
1,000,000~4,700,000
1uF~22uF
0.1uF~10 uF
25V
150~4,700,000
1,000,000~4,700,000
1uF~22uF
0.1uF~10 uF
50V
150~2,200,000
1uF~4.7uF
第 8 页
共
14 页
尺寸规格
额定电压
容量范围 Capacitance
Size Code
Rated Voltage
X7R (PF)
X7S (PF)
X5R(uF)
X6S(uF)
4V
2,200,000~47,000,000
2.2uF ~150uF
0.1uf ~100 uF
6.3V
200~22,000,000
2,200,000~22,000,000
2.2uF~100uF
0.1uF~100 uF
10V
200~22,000,000
2.2uF~47uF
0.1uF~22 uF
16V
200~10,000,000
2,200,000~10,000,000
2.2uF~22uF
0.1uF ~22 uF
25V
200~10,000,000
1,500,000~10,000,000
2.2uF~22uF
0.1uF ~10 uF
50V
200~4,700,000
1,000,000~4,700,000
2.2uF~10uF
4V
47uF~330uF
0.1uF~330 uF
6.3V
220~47,000,000
3,300,00~100,000,000
47uF~330uF
0.1uF~100 uF
10V
220~47,000,000
4.7uF~100uF
0.1uF~100 uF
16V
220~22,000,000
3,300,000~22,000,000
4.7uF~100uF
0.1uF~47 uF
25V
220~22,000,000
4.7uF~47uF
0.1uF~22 uF
50V
220~10,000,000
4.7uF~10uF
6.3V
220~4,700,000
4.7uF~100uF
10V
220~4,700,000
4.7uF~47uF
16V
220~4,700,000
4.7uF~22uF
25V
220~4,700,000
4.7uF~10uF
50V
220~4,700,000
6.3V
10uF~100uF
10V
10uF~47uF
16V
470~6,800,000
4.7uF~22uF
25V
470~6,800,000
4.7uF~10uF
50V
470~4,700,000
1206
1210
1808
1812
Note:We can design according to customer special requirements.
第 9 页
共
14 页
六、可靠性测试
Reliability Test
项目
技术规格
测 试 方 法
Item
Technical Specification
Test Method and Remarks
应符合指定的误差级别
Ⅰ类
测试频率
标称容量
测试电压
Measuring
Capacitance
ClassⅠ
tolerance.
Measuring Voltage
Frequency
Should be within the specified
≤1000pF
1MHz±10%
>1000 pF
1KHz±10%
1.0±0.2Vrms
测试温度: 25℃±3℃
Test Temprature: 25℃±3℃
C≤10µF:测试频率: 1KHz±10%
测试电压: 1.0±0.2Vrms
容量
Test Frequency: 1KHz±10%
Capacitance
Test Voltage: 1.0±0.2Vrms
应符合指定的误差级别
Ⅱ类
Class Ⅱ
C>10µF X7R、X5R、X7S、X6S、Y5V
测试频率: 120±24 Hz
tolerance.
测试电压:0.5±0.1Vrms
Test Frequency: 120±24 Hz
Test Voltage: 0.5±0.1Vrms
Z5U:测试频率:1±0.1KHz
测试电压:0.5±0.05Vrms
Test Frequency: 1±0.1KHz
Test Voltage: 0.5±0.05Vrms
标称容量
DF
测试频率
测试电压
Measuring
Measuring
Frequency
Voltage
Capacitance
损耗角正切
(DF, tanδ)
Ⅰ类
≤0.56%
Cr<5 pF
1MHz±10%
Dissipation
ClassⅠ
1.5[(150/Cr)+7]×10-4
5pF≤Cr<50 pF
1MHz±10%
Factor
≤0.15%
1.0±0.2Vrms
50pF≤Cr≤1000
1MHz±10%
pF
≤0.15%
第 10 页
>1000 pF
1KHz±10%
共
14 页
项目
Item
技术规格
≥50V
6.3V
≤3.5%
≤5.0%
≤5.0%
C≤10µF
测试频率: 1KHz±10%
( C < ( C < ( C < ( C < 测试电压: 1.0±0.2Vrms
Test Frequency: 1KHz ±
0.47µF) 0.47µF) 0.15µF) 0.15µF)
10%
≤10.0% ≤10.0% ≤10.0% ≤10.0%
(C ≥ ( C ≥ ( C ≥ ( C ≥
≤2.5%
0402)
Factor
10V
≤3.5%
Dissipation
16V
X5R
X6S
(DF, tanδ)
25V
X7R/
X7S/
损耗角正切
测 试 方 法
0.47µF) 0.47µF) 0.15µF) 0.15µF) C>10µF X7R、X5R、X7S、
X7R/
≤5.0%
≤7.5%
≤7.5%
X6S、Y5V
Ⅱ类
X5R
( C < ( C < ( C < 测试频率: 120±24 Hz
Class Ⅱ
X7S/
0.047µF) 0.047µF) 0.047µF) 测试电压:0.5±0.1Vrms
≤3.5% ≤5.0%
≤ 10% ≤ 10% ≤ 10% Test Frequency: 120±24 Hz
X6S
( C ≥ ( C ≥ ( C ≥ Test Voltage: 0.5±0.1Vrms
0402)
Z5U:测试频率:1±0.1KHz
≥25V
16V
10V
6.3V
测试电压:0.5±0.05Vrms
Y5V
Z5U
≤7.0%
(C<1.0µF)
≤9.0%
≤15%
≤15%
≤15%
(C≥1.0µF)
Ⅰ类
C≤10 nF, Ri≥50000MΩ
ClassⅠ
C>10 nF, Ri• CR≥500S
绝缘电阻
(IR)
Insulation
Resistance
X7R/X5R/
C≤25 nF, Ri≥10000MΩ
X7S/X6S
C>25 nF, Ri• CR>100S
Y5V
C≤25 nF, Ri≥4000MΩ
Z5U
Ⅱ类
Class Ⅱ
介质耐电强度
(DWV)
不应有介质被击穿或损伤
Dielectric
No breakdown or damage.
Withstanding
Voltage
第
11 页
测试电压:额定电压
测试时间: 60±5 秒
测试湿度:≤75%
测试温度: 25℃±3℃
测试充放电电流:≤50mA
Measuring Voltage: Rated Voltage
Duration: 60±5s
Test Humidity: ≤75%
Test Temperature: 25℃±3℃
Test Current: ≤50mA
测量电压:
Ⅰ类:300%额定电压 Ⅱ类:250%
额定电压
时间: 1~5 秒 充/放电电流:不应
超过 50mA
(这部分说明不包括中高压 MLCC)
Measuring Voltage:
ClassⅠ:300% Rated voltage
ClassⅡ:250% Rated voltage
Duration: 1~5s
Charge/ Discharge Current: 50mA max.
(This method excludes high-voltage
MLCC)
共
14 页
项目
技术规格
测 试 方 法
Item
可焊性
Solderability
耐焊接热
Resistance to
Soldering Heat
抗弯曲强度
上锡率应大于 95%
外观:无可见损伤.
At least 95% of the terminal electrode is
covered by new solder.
Visual Appearance: No visible damage.
将电容在 80~120℃的温度下预热 10~30 秒.
Preheating conditions:80 to 120℃; 10~30s.
有铅焊料:
(Sn/Pb:63/37)
无铅焊料:
浸锡温度: 235±5℃
浸锡温度: 245±5℃
浸锡时间: 2±0.5s
浸锡时间: 2±0.5s
Solder Temperature: 235±5℃ Solder Temperature: 245±5℃
Duration: 2±0.5s
Duration: 2±0.5s
将电容在 100~200℃的温度下预热 10±2 分钟.
项目 NPO 至 SL X7R/X5R
Y5V Z5U 浸锡温度: 265±5℃
Item
NPO to SL /X7S/X6S
浸锡时间: 10±1s
ΔC/C ≤±0.5% -5~+10%
-10~+20%
然后取出溶剂清洗干净,在10 倍以上的显微镜底下观察.
同初始标准
放置时间:24±2 小时
放置条件:室温
DF
Same to initial value.
Preheating conditions: 100 to 200℃; 10±2min.
同初始标准
Solder Temperature: 265±5℃
IR
Duration: 10±1s
外观:无可见损伤 上锡率: ≥95%
Clean the capacitor with solvent and examine it with a
Appearance:No visible damage.At least 10X(min.) microscope.
95% of the terminal electrode is covered Recovery Time: 24±2h
by new solder.
Recovery condition: Room temperature
试验基板:Al2O3 或 PCB
外观: 无可见损伤.
弯曲深度:1mm
施压速度:0.5mm/sec.
单位:mm
应在弯曲状态下进行测量。
T=10
Resistance
to Flexure
of Substrate
(Bending
1mm
ΔC/C
≤±10%
45±2
45±2
Test Board: Al2O3 or PCB
Warp: 1mm
Speed: 0.5mm/sec.
Unit: mm
The measurement should be made with the board in
Strength)
the bending position.
端头结合强度
Termination
Adhesion
外观无可见损伤
施加的力:5N
时间:10±1S
No visible damage.
Applied Force: 5N
Duration: 10±1S
第 12 页
共
14 页
项目
Item
技术规格
ΔC/C:
Ⅰ类:≤±1%或±1pF ,
取两者中最大者
Ⅱ类: B,X,BS,DS: ≤±10%
E,F: ≤±20%
测 试 方 法
预处理 (2 类)
:上限类别温度,1 小时
恢复:24±1h
初始测量
循环次数:5 次,一个循环分以下 4 步:
阶段
温度(℃)
时间(分钟)
下限温度
第1步
30
NPO/X7R/X7S/X6S/X5R:-55
( Y5V:-25 Z5U:+10
第2步
温度循环
Temperature
Cycle
ClassⅠ: ≤±1% or ±1pF,
whichever is larger.
ClassⅡ:
B,X,BS,DS: ≤±10%
E,F: ≤±20%
常温
(+20)
上限温度
第3步
第4步
NPO/X7R/X7S: +125
Y5V/Z5U/X5R:+85 X6S:+105
常温
(+20)
2~3
30
2~3
试验后放置(恢复)时间:24±2h
Preheating conditions: up-category temperature, 1h
Recovery time: 24±1h
Initial Measurement
Cycling Times: 5 times, 1 cycle, 4 steps:
Step
Temperature(℃)
Time (min.)
1
Low- category temp.
30
(NPO/X7R/X7S/X6S/X5R:-55
Y5V:-25 Z5U:+10
2
3
Normal temp. (+20)
Up- category temp.
2~3
30
+125
(NPO/X7R/X7S:
Y5V/Z5U/X5R:+85 X6S:+105)
4
Normal temp. (+20)
Recovery time after test: 24±2h
潮湿试验
Moisture
Resistance
Ⅰ类: ≤±2%或±1pF,
取两者之中较大者
Δ
E,F: ≤±30%
C/C ClassⅠ: ≤±2% or ±1pF,
ClassⅡ: B,X,BS,DS: ≤±10%
E,F: ≤±30%
≤2 倍初始标准
DF
Not more than twice of initial
value.
Ⅰ类:Ri≥2500MΩ或 Ri• CR≥
25S 取两者之中较小者.
ClassⅠ: Ri≥2500MΩ或 Ri• CR
≥25S whichever is smaller.
IR
Ⅱ类:Ri≥1000MΩ或 Ri• CR≥
25S 取两者之中较小者.
ClassⅡ: Ri≥1000MΩ或 Ri• CR
外观:无损伤
第 13 页
2~3
温度:40±2℃
湿度:90~95%RH
时间:500 小时
放置条件:室温
放置时间:24 小时(Ⅰ类);48 小时(Ⅱ类)
Temperature: 40±2℃
Humidity: 90~95%RH
Duration: 500h
Recovery conditions: Room temperature
Recovery Time: 24h (Class1) or 48h (Class2)
共
14 页
项目
Item
技术规格
Ⅰ类:≤±2%或±1pF
取两者之中较大者
Ⅱ类:B,X,BS,DS: ≤±20%
E,F: ≤±30%
ΔC/C
ClassⅠ:≤±2% or ±1pF,
ClassⅡ: B,X,BS,DS: ≤±20%
E,F: ≤±30%
≤2 倍初始标准
DF
value.
Ⅰ类:Ri≥4000MΩ或 Ri• CR≥
40S 取两者之中较小者.
ClassⅠ: Ri≥4000MΩ或 Ri• CR
≥40S whichever is smaller.
IR
Ⅱ类:Ri≥2000MΩ或 Ri• CR≥
50S 取两者之中较小者.
ClassⅡ: Ri≥2000MΩ或 Ri• CR
≥50S whichever is smaller.
外观:无损伤
寿命试验
Life Test
测 试 方 法
低压产品(<100V)
电压:1.5 倍额定工作电压
时间:1000 小时
温度:125℃(NPO、X7R、X7S) 85℃(Y5V、
X5R)105℃(X6S)
充电电流:不应超过 50mA
放置条件:室温
放置时间:24 小时(Ⅰ类)
,或 48 小时(Ⅱ类)
Low-voltange(<100V)
Applied Voltage: 1.5 ×Rated Voltage
Duration: 1000h
Temperature:125℃(NPO、X7R、X7S) 85℃
(Y5V、X5R)105℃(X6S)
Recovery Conditions: Room Temperature
Recovery Time: 24h (Class 1), or 48h (Class2)
注解:
专门预处理 (仅对 2 类电容器)
将电容器放在上限类别温度或按详细规范中可能规定的更高温度下经 1h 后,接着在试验的标准大气条件下恢
复 24±1h。
Note:Pretreatment (only for class2 capacitor)
Pretreatment (only for class2 capacitor) is a method to treat the capacitor before measurement. First, place the
capacitor in the up-category temperature or other specified higher temperature environment for 1hour. Then recovery
the capacitor at standard pressure conditions for 24±1hours。
※以最新版本的内容为准
第 14 页
共
14 页
