附件 7
版本号:FH-2016-003
一、概述
●电容器及介质种类:
※高频类: 此类介质材料的电容器为Ⅰ类电容器,包括通用型高频 COG、COH 电容器和温度补偿型高频
HG、LG、PH、RH、SH、TH、UJ、SL 电容器。其中 COG、COH 电容器电性能最稳定,几乎不随温度、
电压和时间的变化而变化,适用于低损耗,稳定性要求高的高频电路,HG、LG、PH、RH、SH、TH、UJ、
SL 电容器容量随温度变化而相应变化,适用于低损耗、温度补偿型电路中。
※ X7R、X5R、X7S、X6S:此类介质材料的电容器为Ⅱ类电容器,具有较高的介电常数,容量比Ⅰ类电容
器高,具有较稳定的温度特性,适用于容量范围广,稳定性要求不高的电路中,如隔直、耦合、旁路、鉴频
等电路中。
※Y5V:此类介质材料的电容器为Ⅱ类电容器,是所有电容器中介电常数最大的电容器,但其容量稳定性较
差,对温度、电压等条件较敏感,适用于要求大容量,温度变化不大的电路中。
※Z5U:此类介质材料的电容器为Ⅱ类电容器,其温度特性介于 X7R 和 Y5V 之间,容量稳定性较差,对温
度、电压等条件较敏感,适用于要求大容量,使用温度范围接近于室温的旁路,耦合等,低直流偏压的电路
中。
SUMMARY
●Types of Dielectric Material and Capacitor
※HIGH FREQUENCY TYPE: The capacitor of this kind dielectric material is considered as ClassⅠcapacitor,
including
high frequency COG、COH capacitor and temperature compensating capacitor such as HG, LG, PH,
RH,SH, TH, UJ, SL. The electrical properties of COG、COH capacitor are the most stable one and change invariablly
with temperature, voltage and time. They are suited for applications where low-losses and high-stability are required,
HG,
LG,
PH,RH,
SH,
TH,
UJ,
SL capacitor’s capacitance changes with temperature.They are suited for applications
where low-losses and temperature compensating circuits.
※X7R、
X5R、
X7S、
X6S:
X7R、
X5R、X7S、
X6S material is a kind of material has high dielectric constant. The capacitor
made of this kind material is considered as Class Ⅱ capacitor whose capacitance is higher than that of class Ⅰ.
These capacitors are classified as having a semi-stable temperature characteristic and used over a wide temperature
range, such in these kinds of circuits, DC-blocking, decoupling, bypassing, frequency discriminating etc.
※Y5V:The capacitor made of this kind of material is the highest dielectric constant of all ceramic capacitors. They are
used over a moderate temperature range in application where high capacitance is required because of its unstable
temperature coefficient, but where moderate losses and capacitance changes can be tolerated. Its capacitance and
dissipation factors are sensible to measuring conditions, such as temperature and voltage, etc.
※Z5U:The capacitor made of this kind of material is considered as ClassⅡ capacitor, whose temperature characteristic
is between that of X7R and Y5V. The capacitance of this kind of capacitor is unstable and sensible to temperature and
voltage. Ideally suited for bypassing and decoupling application circuits operating with low DC bias in the
environment approaches to room temperature.
第
1
页
共 27
页
二、尺寸及结构
DIMENSIONS AND STRUCTURE
※ 尺寸 DIMENSIONS
L
L
W
T
WB
WB
型号 Type
英制表示
公制表示
British expression
Metric expression
0201
0603
0402
1005
0603
1608
尺寸
Dimensions
(mm)
L
W
T
WB
0.6±0.03
1.00±0.05
1.60±0.10
0.3±0.03
0.50±0.05
0.80±0.10
0.3±0.03
0.50±0.05
0.80±0.10
≤0.55
0.80±0.20
1.00±0.20
1.25±0.20
0.80±0.20
1.00±0.20
1.25±0.20
1.60±0.30
≤2.80
≤2.20
≤3.50
≤3.50
≤6.20
≤8.10
≤8.10
0.15±0.10
0.25±0.10
0.30±0.10
0805
2012
2.00±0.20
1.25±0.20
1206
3216
3.20±0.30
1.60±0.30
1210
1808
1812
2220
2225
3012
3035
3225
4520
4532
5750
5763
7632
7690
3.20±0.30
4.50±0.40
4.50±0.40
5.70±0.40
5.70±0.50
7.60±0.50
7.60±0.50
2.50±0.30
2.00±0.20
3.20±0.30
5.00±0.40
6.30±0.50
3.20±0.30
9.00±0.50
备注:可根据客户的特殊要求设计符合客户需求的产品。
Note:We can design according to customer special requirements
序号
NO
※ 结构 STRUCTURE
W
L
①
②
T
③
①
②
③
④
④
⑤
⑤
第
2
页
名称
Name
陶瓷介质
Ceramic dielectric
内电极
Inner electrode
外电极
Substrate electrode
镍层
Nickel Layer
锡层
Tin Layer
共 27
页
0.50±0.20
0.60±0.30
0.60±0.30
0.60±0.30
0.60±0.30
0.60±0.30
0.60±0.30
0.60±0.30
0.60±0.30
三、型号规格表示方法
HOW TO ORDER
0805
CG
101
J
500
N
T
①
②
③
④
⑤
⑥
⑦
0805
1206
1210
1808
1812
2220
2225
3035
0.08×0.05
0.12×0.06
0.12×0.10
0.18×0.08
0.18×0.12
0.22×0.20
0.22×0.25
0.30×0.35
2.00×1.25
3.20×1.60
3.20×2.50
4.50×2.00
4.50×3.20
5.70×5.00
5.70×6.30
7.60×9.00
※说明 NOTES:
①尺寸 DIMENSIONS
尺寸规格
0201
0402
0603
SizeCode
长×宽
(L×W) 0.02×0.01 0.04×0.02 0.06×0.03
inch
长×宽
(L×W) 0.60×0.30 1.00×0.50 1.60×0.80
mm
.② 介质种类 DIELECTRIC STYLE
介质种类
(Dielectric Code)
介质材料
(Dielectric)
CG CH
CO
CO
G
H
HG
LG
PH
RH
SH
TH
UJ
SL
HG
LG
PH
RH
SH
TH
UJ
SL
X
B
BS
DS
E
F
X5
X7
X7
X6
Z5
Y5
R
R
S
S
U
V
③ 标称容量 NOMINAL CAPACITANCE
单位(unit):pF
表示方式
实际值
(Express Method)
(Actual Value)
0R5
0.5
1R0
1.0
102
10×102
224
22×104
注:头两位数字为有效数字,第三位数字为 0
的个数;R 为小数点。
Note: the first two digits are significant; third digit
denotes number of zeros; R=decimal point.
④ 容量误差 CAPACITANCE TOLERANCE
代码 (Code)
A
B
C
D
F
G
J
误差
(Tolerance)
0.05pF
0.10pF
0.25pF
0.5pF
1.0%
2.0%
5.0%
K
±10%
M
±20%
S
Z
+50%
-20%
+80%
-20%
备注:A、B、C、D 级误差适用于容量≤10pF 的产品。
Note:These capacitance tolerance A,B, C, D are just applicable the capacitance that equals to or less than 10pF。
第 3
页
共 27
页
⑤ 额定电压 RATED VOLTAGE
表示方式
实际值
(Express Method)
(Actual Value)
6R3
6.3
500
50×100
201
20×101
102
10×102
单位(unit):V
注:头两位数字为有效数字,第三位数字为 0 的个数;
R 为小数点。
⑥ 端头材料 TERMINAL MATERIAL STYLES
端头类别 (Termination Styles)
纯银端头
表示方式 (Express Method)
(Silver Solderable Termination)
S
纯铜端头 (Copper Solderable Termination)
C
三层电镀端头 (Nickel Barrier Termination)
N
⑦ 包装方式 PACKAGE STYLES
B
T
散包装(Bulk Bag)
编带包装(Taping Package)
四、温度系数/特性 Temperature Coefficient /Characteristics
介质种类
Dielectric
参考温度点
Reference Temperature Point
标称温度系数
工作温度范围
Operation Temperature Range
COG
COH
HG
LG
PH
RH
SH
TH
UJ
SL
X7R
X5R
X7S
X6S
Z5U
Y5V
20°C
20°C
20°C
20°C
20°C
20°C
20°C
20°C
20°C
20°C
20°C
20°C
20°C
20°C
20°C
20°C
0±30 ppm/℃
0±60 ppm/℃
-33±30 ppm/℃
-75±30 ppm/℃
-150± 60 ppm/℃
-220± 60 ppm/℃
-330± 60 ppm/℃
-470± 60 ppm/℃
-750± 120 ppm/℃
-1000~+140 ppm/℃
±15%
±15%
±22%
±22%
-56%~+22%
-80%~+30%
-55℃~125℃
-55℃~125℃
-25℃~85℃
-25℃~85℃
-25℃~85℃
-25℃~85℃
-25℃~85℃
-25℃~85℃
-25℃~85℃
-25℃~85℃
-55℃~125℃
-55℃~85℃
-55℃~125℃
-55℃~105℃
10℃~85℃
-25℃~85℃
备注:Ⅰ类电容器标称温度系数和允许偏差是采用温度在 20°C 和 85°C 之间的电容量变化来确定的,而Ⅱ类
电容器标称温度系数是按照工作范围之间的电容量相对 20°C 的电容量变化来确定的。
Note:Nominal temperature coefficient and allowed tolerance of class Ⅰare decided by the changing of the
capacitance between 20°C and 85°C. Nominal temperature coefficient of class Ⅱare decided by the
temperature of 20°C.
第 4
页
共 27
页
五、容量范围及其电压
Capacitance Range and Operating Voltage
尺寸规格
额定电压
Size Code
Rated Voltage
COG(NPO)(PF)
Y5V (Z5U)(PF)
4V
6.3V
10,000~100,000
10V
16V
10,000
25V
50V
0.5~100
4V
6.3V
1,000~1,000,000
10V
1,000~1,000,000
16V
1,000~220,000
25V
1,000~220,000
50V
0.1~1,000
1,000~100,000
4V
6.3V
1,000~10,000,000
10V
1,000~10,000,000
16V
1,000~2,200,000
25V
1,000~2,200,000
50V
0.1~6,800
1,000~1,000,000
4V
6.3V
1,000~22,000,000
10V
1,000~22,000,000
16V
1,000~10,000,000
25V
1,000~4,700,000
50V
0.3~22,000
1,000~2,200,000
容量范围 Capacitance
0201
0402
0603
0805
第 5
页
共 27
页
容量范围 Capacitance
尺寸规格
额定电压
Size Code
Rated Voltage
COG(NPO)(PF)
Y5V (Z5U)(PF)
4V
6.3V
1,000~47,000,000
10V
1,000~22,000,000
16V
1,000~22,000,000
25V
1,000~10,000,000
50V
0.3~100,000
1,000~4,700,000
6.3V
4,700~100,000,000
10V
4,700~47,000,000
16V
4,700~22,000,000
25V
4,700~10,000,000
50V
10~100,000
4,700~4,700,000
6.3V
10V
16V
25V
50V
10~100,000
6.3V
10,000~100,000,000
10V
10,000~100,000,000
16V
10,000~22,000,000
25V
10,000~10,000,000
50V
10~100,000
10,000~10,000,000
1206
1210
1808
1812
第 6
页
共 27
页
尺寸规格
Size Code
额定电压
容量范围 Capacitance
Rated Voltage
X7R (PF)
X7S(PF)
X5R(uF)
X6S(uF)
4V
0.015 uF~1uF
6.3V
0.015 uF~1uF
10V
100~10,000
0.015 uF~0.1 uF
16V
100~10,000
25V
100~10,000
50V
4V
0.1uF~10uF
0.1~2.2 uF
6.3V
100~470,000
100,000~470,000
0.1uF~4.7uF
0.1~2.2 uF
10V
100~470,000
100,000~470,000
0.1uF~4.7uF
0.1~1 uF
16V
100~220,000
47,000~220,000
0.1uF~2.2 uF
25V
100~100,000
22,000~100,000
0.1uF~2.2 uF
50V
100~100,000
4,700~100,000
0.047uF~0.1 uF
4V
0.47uF~22uF
0.1~10 uF
6.3V
150~2,200,000
470,000~2,200,000
0.47uF~22uF
0.1~10 uF
10V
150~2,200,000
470,000~2,200,000
0.47uF~10uF
0.1~10 uF
16V
150~1,000,000
470,000~1,000,000
0.47uF~10uF
0.1~4.7 uF
25V
150~1,000,000
470,000~1,000,000
0.47uF~10uF
0.1~4.7 uF
50V
150~470,000
0.47uF~1uF
4V
1uF~47uF
0.1~47 uF
6.3V
150~10,000,000
1,000,000~10,000,000
1uF~47uF
0.1~22 uF
10V
150~10,000,000
1uF~22uF
0.1~10 uF
16V
150~4,700,000
1,000,000~4,700,000
1uF~22uF
0.1~10 uF
25V
150~4,700,000
1,000,000~4,700,000
1uF~10uF
0.1~10 uF
50V
150~1,000,000
0201
0402
0603
0805
第 7
页
共 27
页
尺寸规格
额定电压
Size Code
Rated Voltage
X7R (PF)
X7S (PF)
X5R(uF)
X6S(uF)
4V
2.2uF ~100uF
6.3V
200~22,000,000
2,200,000~22,000,000
2.2uF~100uF
0.1~100 uF
10V
200~22,000,000
2.2uF~47uF
0.1~22 uF
16V
200~10,000,000
2,200,000~10,000,000
2.2uF~22uF
0.1~22 uF
25V
200~10,000,000
1,500,000~10,000,000
2.2uF~22uF
0.1~10 uF
50V
200~4,700,000
1,000,000~4,700,000
2.2uF~10uF
6.3V
220~47,000,000
47uF~100uF
0.1~100 uF
10V
220~47,000,000
4.7uF~100uF
0.1~47 uF
16V
220~22,000,000
3,300,000~22,000,000
4.7uF~47uF
0.1~22 uF
25V
220~22,000,000
4.7uF~22uF
0.1~22 uF
50V
220~10,000,000
6.3V
220~4,700,000
4.7uF~100uF
10V
220~4,700,000
4.7uF~47uF
16V
220~4,700,000
4.7uF~22uF
25V
220~4,700,000
4.7uF~10uF
50V
220~4,700,000
6.3V
10uF~100uF
10V
10uF~47uF
16V
470~6,800,000
4.7uF~22uF
25V
470~6,800,000
4.7uF~10uF
50V
470~4,700,000
容量范围 Capacitance
1206
1210
1808
1812
Note:We can design according to customer special requirements.
第 8
页
共
27
页
六、高 Q 值 COG 电容器
Hi-Q COG MLCC
※ 应用:
适合于射频 RF 电路及要求 Hi-Q、低 ESR、高频率响应的微波电路中。
●CQ、CG 电容器说明:
※下述 Q 值标准是相对通用客户而制定的,对要求更高 Q 值产品的客户,可专门设计和生产。
※使用频率在 1MHz~2.4GHz 之间,对要求更高频率产品的客户,可根据客户的要求另外专门设计。
※CQ 比 CG 相对可应用频率略高,请客户依需选定。
※ Application:
Hi-Q COG capacitors are ideally suited for RF and microwave application requiring high Q, low ESR, and high
resonant frequency。
●Note for CQ and CG:
※The following Q value is just confirmed by general customer. If there is a higher requirement for Q value
requirements, we can design and produce according to the special requirements。
※For the customer whose requirements for frequency is between 1MHz and 2.4GHz or higher frequency, we can
design it according to their requirements。
※The frequency of CQ is a little higher than that of CG. Please choose them according to your requirements。
※ CQ 电容器的容量值及其 Q 值 CQ Capacitance value and Q value
容量
300MHz 时的Q 值
容量
300MHz 时的Q 值
容量
300MHz 时的Q 值
Capacitance
Q value at 300MHz
Capacitance
Q value at 300MHz
Capacitance
Q value at 300MHz
(pF)
0805
0603
(pF)
0805
0603
(pF)
0805
0603
4.7
≥1000
≥800
12
≥400
≥320
30
≥150
≥120
5.2
≥900
≥720
13
≥375
≥300
33
≥140
≥112
5.6
≥850
≥680
14
≥350
≥280
36
≥130
≥104
6.2
≥800
≥640
15
≥325
≥260
39
≥120
≥96
6.8
≥700
≥560
16
≥300
≥240
43
≥110
≥88
7.5
≥650
≥520
18
≥250
≥200
47
≥100
≥80
8.2
≥575
≥460
≥225
≥180
56
≥80
≥80
9.1
≥525
≥420
22
≥215
≥172
62
≥80
≥80
10
≥500
≥400
24
≥200
≥160
68
≥80
≥80
11
≥450
≥360
27
≥175
≥140
82
≥80
≥80
第 9
页
共 27
页
七、中高压电容器
HIGH VOLTAGE MLCC
中高压多层片状陶瓷电容器是在多层片状陶瓷电容器的工艺技术、设备基础上,通过采用特殊工艺制
作的一种具有良好高压可靠性的产品,该产品适合于表面贴装,适合于多种直流高压线路,可以有效的改
善电子线路的性能。
●应用范围
※模拟或数字调制解调器 。
※局域网/广域网接口界面。
※日光灯启动辉器照明电路。
※倍压电器。
※直流变送器。
※背光源驱动电路。
Middle & high voltage MLCC is a kind of special design 、special technology MLCC that bases on the
technology of general MLCC. This kind of MLCC has stable high voltage reliability and suitable to SMT.
Middle & high MLCC is widely applicable for many direct high voltage circuits in which it can improve the
performance of the circuit.
●APPLICATIONS
※Analog & Digital Modems
※LAN/WAN Interface
※Lighting Ballast Circuits
※Voltage Multipliers
※DC-DC Converters
※Back-lighting Inverters
容量范围及其电压
单位/unit: pF
尺寸规格
工作电压
Size Code
Rated Voltage
NPO
X7R
Y5V
100V
0.5~1,000
150~100,000
200V
0.5~470
150~10,000
2,200~100,000
250V
0.5~470
150~10,000
100V
0.5~3,300
150~100,000
10,000~100,000
200V
0.1~1,500
150~22,000
10,000~47,000
250V
0.1~1,500
150~22,000
10,000~47,000
500V
0.1~470
150~10,000
630V
0.1~470
150~10,000
1000V
0.1~100
100V
0.5~3,300
150~1,000,000
15,000~470,000
200V
0.1~2,700
150~220,000
10,000~220,000
250V
0.1~2,700
150~220,000
10,000~220,000
500V
0.1~1,500
150~33,000
630V
0.1~1,500
150~33,000
1000V
0.1~1,000
150~10,000
2000V
0.1~270
150~2,700
0603
0805
1206
第 10
页
容量范围 Capacitance
共 27
页
容量范围及其电压
尺寸规格
Size Code
1210
1808
1812
1825
单位/unit: pF
容量范围 Capacitance
X7R
工作电压
Rated Voltage
NPO
100V
1.0~6,800
150~2,200,000
15,000~1,000,000
200V
1.0~3,300
150~220,000
15,000~470,000
250V
500V
1.0~3,300
1.0~2,200
150~220,000
150~68,000
15,000~470,000
630V
1000V
1.0~2,200
1.0~1,000
150~68,000
150~22,000
2000V
3000V
4000V
100V
200V
1.0~470
2.0~4,700
2.0~3,900
150~10,000
150~680
150~680
220~2,200,000
220~220,000
150,000~1,000,000
10,000~390,000
250V
500V
630V
2.0~3,900
2.0~2,700
2.0~2,700
220~220,000
220~68,000
220~68,000
10,000~390,000
1000V
2000V
3000V
4000V
5000V
100V
200V
2.0~1,000
2.0~470
2.0~330
2.0~33
2.0~33
3.0~10,000
3.0~6,800
150~22,000
150~10,000
150~4,700
150~2,200
270~1,000,000
270~560,000
150,000~2,200,000
100,000~470,000
250V
500V
630V
1000V
2000V
3000V
4000V
5000V
100V
200V
250V
500V
630V
1000V
2000V
3000V
4000V
5000V
3.0~6,800
3.0~4,700
3.0~4,700
3.0~1,200
3.0~1,000
3.0~560
3.0~220
3.0~68
3.0~22,000
3.0~8,200
3.0~8,200
3.0~5,600
3.0~5,600
3.0~1,800
3.0~1,000
3.0~680
3.0~470
3.0~82
270~560,000
270~150,000
270~150,000
270~56,000
270~12,000
270~4,700
270~3,300
12,000~1,200,000
12,000~1,000,000
12,000~1,000,000
1,000~470,000
1,000~470,000
1,000~100,000
1,000~22,000
1,000~10,000
1,000~6,800
100,000~470,000
150,000~2,200,000
100,000~470,000
100,000~470,000
第 11
页
共
Y5V
27
页
尺寸规格
Size Code
2220
2225
3012
3035
容量范围 Capacitance
工作电压
Rated Voltage
NPO
X7R
Y5V
100V
5.0~27,000
22,000~1,200,000
150,000~1,500,000
200V
250V
5.0~12,000
5.0~12,000
22,000~1,000,000
22,000~1,000,000
100,000~1,000,000
100,000~1,000,000
500V
5.0~6,800
1,500~470,000
630V
5.0~6,800
1,500~470,000
1000V
5.0~3,900
1,500~100,000
2000V
5.0~1,000
1,500~33,000
3000V
5.0~680
1,500~10,000
4000V
5.0~560
1,500~6,800
5000V
5.0~120
100V
200V
5.0~27,000
5.0~12,000
2,200~2,200,000
2,200~2,200,000
250,000~3,300,000
220,000~2,200,000
250V
5.0~12,000
2,200~2,200,000
220,000~2,200,000
500V
630V
5.0~6,800
5.0~6,800
2,200~470,000
2,200~470,000
1000V
5.0~3,900
2,200~100,000
2000V
5.0~1,000
2,200~47,000
3000V
5.0~680
2,200~15,000
4000V
5.0~560
2,200~6,800
5000V
5.0~120
100V
5.0~27,000
150~3,300,000
15,000~1,500,000
200V
5.0~12,000
150~2,200,000
15,000~1,000,000
250V
500V
5.0~12,000
5.0~6,800
150~1,200,000
150~220,000
630V
5.0~6,800
150~150,000
1000V
2000V
5.0~3,900
5.0~1,000
150~47,000
150~33,000
3000V
5.0~1,000
150~10,000
4000V
5.0~1,000
150~8,200
100V
5.0~27,000
47,000~4,700,000
10,000~2,200,000
200V
5.0~12,000
47,000~2,200,000
10,000~2,200,000
250V
500V
5.0~12,000
5.0~6,800
47,000~2,200,000
5,600~1,000,000
10,000~2,200,000
630V
5.0~6,800
5,600~470,000
1000V
2000V
5.0~3,900
5.0~1,000
5,600~56,000
5,600~47,000
第 12
页
共
27
页
中高压电容器介质耐电强度的测试方法:
Measurement method of dielectric withstanding voltage for high voltage MLCC
额定电压范围
Rated voltage range
100V≤Vr<500V
500V≤Vr≤1000V
1000V<Vr≤2000V
2000V<Vr≤5000V
八、可靠性测试
项目
Item
容量
Capacitance
损耗角正切
(DF, tanδ)
Dissipation
Factor
耐电性能的测试方法
Measuring Method
施加额定电压的 200%, 5 秒, 最大电流不超过 50mA
Force 200%Rated voltage for 5 second. Max..current should not exceed 50 mA.
施加额定电压的 150%, 5 秒, 最大电流不超过 50mA
Force 150%Rated voltage for 5 second. Max..current should not exceed 50 mA.
施加额定电压的 120%, 5 秒, 最大电流不超过 50mA
Force 120%Rated voltage for 5 seconds. Max..current should not exceed 50 mA.
施加额定电压的 120%, 5 秒, 最大电流不超过 10mA
Force 120%Rated voltage for 5 seconds. Max..current should not exceed 10 mA.
Reliability Test
技术规格
Technical Specification
测 试 方 法
Test Method and Remarks
测试频率
测试电压
标称容量
Measuring
Measuring
应符合指定的误差级别
Capacitance
Ⅰ类
Frequency
Voltage
Should be within the
ClassⅠ
specified tolerance.
≤1000pF
1MHZ±10%
1.0±0.2Vrms
>1000 pF
1KHZ±10%
测试温度: 25℃±3℃
Test Temperature: 25℃±3℃
C≤10µF:测试频率: 1KHZ±10%
测试电压: 1.0±0.2Vrms
Test Frequency: 1KHZ±10%
Test Voltage: 1.0±0.2Vrms
C>10µF
应符合指定的误差级别
Ⅱ类
X7R、X5R、X7S、X6S、Y5V:
测试频率: 120±24 HZ
Class Ⅱ
测试电压:0.5±0.1Vrms
Test Frequency: 120±24 HZ
Test Voltage: 0.5±0.1Vrms
Z5U:测试频率:1±0.1KHZ
测试电压:0.5±0.05Vrms
Test Frequency: 1±0.1KHZ
Test Voltage: 0.5±0.05Vrms
测试频率
测试电压
标称容量
Measuring
Measuring
DF
Capacitance
Frequency
Voltage
Ⅰ类
Cr<5 pF
1MHZ±10%
≤0.56%
ClassⅠ
-4
5pF≤Cr<50 pF
1MHZ±10%
1.5[(150/Cr)+7]×10
1.0±0.2Vrms
50pF≤Cr≤1000 pF
1MHZ±10%
≤0.15%
≤0.15%
第 13
页
>1000 pF
1KHZ±10%
共
27
页
项目
Item
损耗角正
切(DF, tan
δ)
Dissipation
Factor
Ⅱ类
Class
Ⅱ
技术规格
25V
16V
X7R/ 50V
X5R
≤3.5% ≤3.5%
X7S/
(C < (C <
X6S ≤
0.47µF) 0.47µF)
(≥ 2.5% ≤10.0% ≤10.0%
0402)
(C ≥ (C ≥
0.47µF) 0.47µF)
25V
16V
X7R/ 50V
X5R
≤5.0%
X7S/
(C <
X6S ≤
0.047µF)
≤5.0%
(< 3.5%
≤10%
0402)
(C >
0.047µF)
≥25V
16V
≤7.0%
Y5V
(C<1.0µF)
Z5U
≤15%
≤9.0%
(C≥1.0µF)
Ⅰ类 C≤10 nF, Ri≥50000MΩ
ClassⅠ C>10 nF, Ri• CR≥500S
绝缘电阻
(IR)
Insulation
Resistance
介质耐电强
度(DWV)
Dielectric
Withstanding
Voltage
Ⅱ类
Class
Ⅱ
X7R/
X5R/
X7S/
X6S
C≤25 nF, Ri≥10000MΩ
C>25 nF, Ri• CR>100S
Y5V
Z5U
C≤25 nF, Ri≥4000MΩ
不应有介质被击穿或损伤
No breakdown or damage.
第 14
页
测 试 方 法
10V
6.3V
≤5.0%
(C <
0.15µF)
≤10.0%
(C ≥
0.15µF)
≤5.0%
(C <
0.15µF)
≤10.0%
(C ≥
0.15µF)
10V
6.3V
≤7.5%
(C <
0.047µF)
≤10%
(C >
0.047µF)
10V
≤7.5%
(C <
0.047µF)
≤10%
(C >
0.047µF)
6.3V
≤15%
C≤10µF
测试频率: 1KHZ±10%
测试电压: 1.0±0.2Vrms
C>10µF X7R、X5R、X7S、X6S、Y5V
测试频率: 120±24 HZ
测试电压:0.5±0.1Vrms
Test Voltage: 0.5±0.1Vrms Z5U:测试频
率:1±0.1KHZ
测试电压:0.5±0.05Vrms
≤15%
测试电压:额定电压(最高 500V)
测试时间: 60±5 秒
测试湿度:≤75%
测试温度: 25℃±3℃
测试充放电电流:≤50mA
Measuring Voltage: Rated Voltage(Max
500V)
Duration: 60±5s
Test Humidity: ≤75%
Test Current: ≤50mA
测量电压:
Ⅰ类:300%额定电压
Ⅱ类:250%额定
电压
时间:1~5 秒 充/放电电流:不应超过
50mA
(这部分说明不包括中高压 MLCC)
Measuring Voltage:
ClassⅠ:300% Rated voltage
ClassⅡ:250% Rated voltage
Duration: 1~5s
Charge/ Discharge Current: 50mA max.
(This method excludes high-voltage
MLCC)
共 27
页
项目
Item
可焊性
Solderability
技术规格
上锡率应大于 95%
外观:无可见损伤.
At least 95% of the terminal electrode is
covered by new solder.
Visual Appearance: No visible damage.
项目
Item
耐焊接热
Resistance to
Soldering Heat
测 试 方 法
将电容在 80~120℃的温度下预热 10~30 秒.
Preheating conditions:80 to 120℃; 10~30s.
有铅焊料:
(Sn/Pb:63/37) 无铅焊料:
浸锡温度: 235±5℃
浸锡温度: 245±5℃
浸锡时间: 2±0.5s
浸锡时间: 2±0.5s
Solder Temperature: 235±5℃ Solder Temperature: 245±5℃
Duration: 2±0.5s
Duration: 2±0.5s
Y5V、 将电容在 100~200℃的温度下预热 10±2 分钟.
Z5U 浸锡温度: 265±5℃
≤ ± 0.5% 或 ±
浸锡时间: 10±1s
-10~+2 然后取出溶剂清洗干净,在 10 倍以上的显微镜底
0.5PF,取较大值
-5~+10%
ΔC/C
0%
≤±0.5% or ±0.5PF,
下观察.
whichever is larger
放置时间:24±2 小时 放置条件:室温
Preheating conditions: 100 to 200℃; 10±2min.
同初始标准
DF
Solder Temperature: 265±5℃
Same to initial value.
Duration: 10±1s
同初始标准
IR
Clean the capacitor with solvent and examine it with
a 10X(min.) microscope.
外观:无可见损伤 上锡率:≥95%
Appearance:No visible damage.At least 95% of Recovery Time: 24±2h
the terminal electrode is covered by new solder. Recovery condition: Room temperature
NPO至 SL
NPO to SL
X7R/X5R/
X7S/X6S
抗弯曲强度
外观:无可见损伤.
Resistance
试验基板:Al2O3 或 PCB
弯曲深度:1mm
施压速度:0.5mm/sec.
单位:mm
应在弯曲状态下进行测量。
T=10
to Flexure
of Substrate
45±2
45±2
Test Board: Al2O3 or PCB
(Bending
Strength)
Warp: 1mm
Speed: 0.5mm/sec.
Unit: mm
ΔC/C
≤±10%
The measurement should be made with the board in
the bending position.
第 15 页
共 27
页
项目
Item
端头结合强度
Termination
Adhesion
技术规格
外观无可见损伤
No visible damage.
测 试 方 法
施加的力:5N
Applied Force: 5N
时间:10±1S
Duration: 10±1S
温度循环
Temperature
Cycle
潮湿试验
Moisture
Resistance
ΔC/C:
Ⅰ类:≤±1%或±1pF ,
取两者中最大者
Ⅱ类:
B,X,BS,DS: ≤±10%
E,F: ≤±20%
ClassⅠ: ≤±1% or ±1pF,
whichever is larger.
ClassⅡ:
B,X,BS,DS: ≤±10%
E,F: ≤±20%
Ⅰ类: ≤±2%或±1pF,
取两者之中较大者
Ⅱ类: B,X,BS,DS:≤±10%
Δ
E,F: ≤±30%
C/C ClassⅠ: ≤±2% or ±1pF,
ClassⅡ: B,X,BS,DS:≤±10%
E,F: ≤±30%
≤2 倍初始标准
DF
Not more than twice of initial value.
Ⅰ类:Ri≥2500MΩ或 Ri• CR≥25S
取两者之中较小者.
ClassⅠ: Ri≥2500MΩ或 Ri• CR≥
25S whichever is smaller.
IR
Ⅱ类:Ri≥1000MΩ或 Ri• CR≥25S
取两者之中较小者.
ClassⅡ: Ri≥1000MΩ或 Ri• CR≥
外观:无损伤
第 16
页
预处理 (2类)
:上限类别温度,1小时 恢复:24±1h
初始测量
循环次数:5 次,一个循环分以下 4 步:
阶段
温度(℃)
时间(分钟)
NPO/X7R/X7S/X6S/X5R:-55
第 1 步 下限温度( Y5V:-25
30
Z5U:+10)
第2步
常温
第3步
上限温度(
(+20)
NPO/X7R/X7S:
Y5V/Z5U/X5R:+85
2~3
+125
X6S:+105
30
第4步
常温
(+20)
2~3
试验后放置(恢复)时间:24±2h
Preheating conditions: up-category temperature, 1h
Recovery time: 24±1h
Initial Measurement
Cycling Times: 5 times, 1 cycle, 4 steps:
Time
Step
Temperature(℃)
(min.)
1
Low- category temp. (NPO/X7R/X7S/X6S/X5R:-55
30
Y5V:-25
Z5U:+10
2
Normal temp. (+20)
2~3
NPO/X7R/X7S:
+125
3
Up- category temp. (Y5V/Z5U/X5R:+85 X6S:+105)
30
4
Normal temp. (+20)
2~3
Recovery time after test: 24±2h
温度:40±2℃
湿度:90~95%RH
时间:500 小时
放置条件:室温
放置时间:24 小时(Ⅰ类);48 小时(Ⅱ类)
Temperature:40±2℃
Humidity:90~95%RH
Duration:500h
Recovery conditions:Room temperature
Recovery Time:24h (Class1) or 48h (Class2)
共 27
页
项目
Item
寿命试验
Life Test
中高压产品
寿命试验
Middle
&high
voltage
Life Test
技术规格
Ⅰ类:≤±2%或±1pF
取两者之中较大者
Ⅱ类:B,X,BS,DS: ≤±20%
Δ
E,F: ≤±30%
C/C ClassⅠ:≤±2% or ±1pF,
ClassⅡ: B,X,BS,DS: ≤±20%
E,F: ≤±30%
≤2 倍初始标准
DF
Ⅰ类:Ri≥4000MΩ或 Ri• CR≥40S
取两者之中较小者.
ClassⅠ: Ri≥4000MΩ或 Ri• CR ≥
40S whichever is smaller.
IR
Ⅱ类:Ri≥2000MΩ或 Ri• CR≥50S
取两者之中较小者.
ClassⅡ: Ri≥2000MΩ或 Ri• CR ≥
50S whichever is smaller.
外观:无损伤
Ⅰ类:≤±2%或±1pF
取两者之中较大者
Ⅱ类:B,X,BS,DS: ≤±20%
Δ
E,F: ≤±30%
E,F: ≤±30%
≤2 倍初始标准
DF
取两者之中较小者.
ClassⅠ: Ri≥4000MΩ或 Ri• CR≥
IR
取两者之中较小者.
ClassⅡ: Ri≥2000MΩ或 Ri• CR≥
外观:无损伤
测 试 方 法
低压产品(≤100V)
电压:1.5 倍额定工作电压
时间:1000 小时
温度:125℃(NPO、X7R、X7S) 85℃(X5R、Y5V)
105℃(X6S)
充电电流:不应超过 50mA
放置条件:室温
放置时间:24 小时(Ⅰ类)
,或 48 小时(Ⅱ类)
Low-Voltage(≤100V)
Applied Voltage: 1.5 × Rated Voltage
Duration: 1000h
Temperature:125℃(NPO、X7R、X7S) 85℃(X5R、
Y5V)105℃(X6S)
Recovery Conditions: Room Temperature
Recovery Time: 24h (Class 1), or 48h (Class2)
中高压产品:
100V≤额定电压<500V:2 倍工作电压
500V≤额定电压≤1000V:1.5 倍工作电压
额定电压>1000V:1.2 倍工作电压
时间:1000 小时
充电电流:不应超过 50mA
温度:125℃(NPO X7R、X7S);85℃(X5R、Y5V)
105℃(X6S)
放置条件:室温
放置时间:24 小时(Ⅰ类),或 48小时(Ⅱ类)
Applied Voltage:
100V≤Rated Voltage<500V:2 Multiple
500V≤Rated Voltage≤1000V:1.5 Multiple
>1000V Rated Voltage:1.2 Multiple
Duration: 1000h
Temperature:125℃(NPO X7R、X7S)
;85℃(X5R、
Y5V)105℃(X6S)
注解:
专门预处理 (仅对 2 类电容器)
将电容器放在上限类别温度或按详细规范中可能规定的更高温度下经 1h 后,接着在试验的标准大气条件下恢复 24
±1h。
Note:Pretreatment (only for class2 capacitor)
Pretreatment (only for class2 capacitor) is a method to treat the capacitor before measurement. First, place the capacitor in
the up-category temperature or other specified higher temperature environment for 1hour. Then recovery the capacitor at
standard pressure conditions for 24±1hours。
第 17
页
共 27
页
九、包装
PACKAGE
※ 纸带卷盘结构
PAPER TAPING
Top cover tape 面胶
Carrier tape(paper)传送带
Chip hole(Pocket) 芯片孔
Polystyrene reel 胶盘
Bottom tape 底胶
※ 0201、0402 纸带编带尺寸大小
Dimensions of paper taping for 0402 type
代号
W1
L1
D
C
B
P1
P2
P0
d
t
0.37±
0.10
0.67±
0.10
8.00±
0.10
3.50±
0.05
1.75±
0.10
2.00±
0.05
2.00±
0.05
4.00±
0.10
1.50
-0/+0.10
0.80
Below
0.65±
1.15±
8.00±
3.50±
1.75±
2.00±
2.00±
4.00±
1.50
0.80
0.10
0.10
0.10
0.05
0.10
0.05
※适合‘0603,0805,1206’常规尺寸产品的纸带尺寸
Dimensions of paper taping for 0603,0805,1206 types.
0.05
0.10
-0/+0.10
Below
Code
0201
0402
第 18
页
共
27
页
送带孔 Feeding hole
芯片方穴 Chip pocket
J
E
A
D
B
T
H
Chip cap
G
F
C
Tape running direction
纸带运行方向
Unit:mm
代号Code
纸带规格
paper size
A
B
C
D*
1.10
1.90
8.00
3.50
± 0.10
± 0.10
± 0.10
± 0.05
1.45
2.30
8.0
3.50
0805
± 0.15
± 0.15
± 0.15
± 0.05
1.80
3.40
8.00
3.50
1206
± 0.20
± 0.20
± 0.20
± 0.05
注意:*表示此处对尺寸的要求非常精确。
0603
E
F
G*
H
J
T
1.75
± 0.10
1.75
± 0.10
1.75
± 0.10
4.00
± 0.10
4.00
± 0.10
4.00
± 0.10
2.00
± 0.10
2.00
± 0.10
2.00
± 0.10
4.00
± 0.10
4.00
± 0.10
4.00
± 0.10
1.50
-0/+0.10
1.50
-0/+0.10
1.50
-0/+0.10
1.10
Max
1.10
Max
1.10
Max
Note: The place with “*” means where needs exactly dimensions.
●塑胶卷盘结构
EMBOSSED TAPING
Top cover tape 面胶
Chip hole(Pocket)芯片孔
Polystyrene reel 胶盘
※ 塑胶带尺寸结构(适合‘0805~1812’型产品)
Dimensions of embossed taping for 0805~1812 type
第 19
页
共 27
页
送带孔 Feeding hole
芯片方穴 Chip pocket
J
E
A
D
B
H
T
G
C
F
Chip cap
塑胶带传送方向
代号
Code
规格
Tape size
0805
1206
1210
1808
1812
A
B
C
D*
E
F
G*
H
J
T
1.55
2.35
8.00
3.50
1.75
4.00
2.00
4.00
1.50
1.50
± 0.20
± 0.20
± 0.20
± 0.05
± 0.10
± 0.10
± 0.10
± 0.10
-0/+0.10
Max
1.95
3.60
8.00
3.50
1.75
4.00
2.00
4.00
1.50
1.85
± 0.20
± 0.20
± 0.20
± 0.05
± 0.10
± 0.10
± 0.10
± 0.1
-0/+0.10
Max
2.70
3.42
8.00
3.50
1.75
4.00
2.00
4.00
1.55
3.2
± 0.10
± 0.10
± 0.10
± 0.05
± 0.10
± 0.10
± 0.05
± 0.10
-0/+0.10
Max
2.20
4.95
12.00
5.50
1.75
4.00
2.00
4.00
1.50
3.0
± 0.10
± 0.10
± 0.10
± 0.05
± 0.10
± 0.10
± 0.05
± 0.10
-0/+0.10
Max
3.66
4.95
12.00
5.50
1.75
8.00
2.00
4.00
1.55
4.0
± 0.10
± 0.10
± 0.10
± 0.05
± 0.10
± 0.10
± 0.05
± 0.10
-0/+0.10
Max
备注:*表示此处对尺寸的要求非常精确。
Note:The place with “*” means where needs exactly dimensions.
●传送带的前后结构
Structure of leader part and end part of the carrier paper
尾部(空带)
芯片传送
End (Vacant position)
Chip carrier
大于 150 mm
over 150mm
第 20
空带
Vacant position
大于 150 mm
over 150mm
页
带头(面胶面)
Leader part(cover) tape)
大于 150 mm /Over 150 mm
传送方向/ Moving Direction
共 27
页
※ 卷盘尺寸 Reel Dimensions
(unit: mm)
※ 尺寸代码(CODE)
卷盘型号
A
B
C
D
7 REEL
φ178±2.0
3.0
φ13±0.5
φ21±0.8
13′REEL
φ330±2.0
3.0
φ13±0.5
φ21±0.8
E
φ50或更大
φ50 or more
φ50或更大
φ50 or more
F
G
10.0±1.5
12max
10.0±1.5
12max
Taping specification
● 关于卷带的说明
※面胶剥离强度 Top tape peeling strength
(a)纸带
Paper Taping
Cover tape peeling direction 面胶剥离方向
Cover tape
面胶
0~15°
Carrier tape 传送带
(b) 塑料胶盘 Embossed Taping
Cover tape 面胶
0~15°
Carrier tape 传送带
标准:0.1N
