OZ Type
2.0 x 1.6 mm SMD Crystal Oscillator
Actual Size
FEATURE
- Typical 2.05 x 1.65 x 0.75 mm ceramic SMD package.
- Tight symmetry (45 to 55%) available.
- Operation voltage: 1.8V, 2.5V, 3.3V
- Tri-state enable/disable
TYPICAL APPLICATION
- WLAN/WiMax
- Mobile Phone
- DSC,Set-top Box,HDTV
RoHS Compliant
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ B O T T O M V IE W ]
[ TO P VIEW ]
0.1 μF
1.27±0.10
#4
#2
#2
0.47±0.10
1.65±0.10
#1
#1
0.97
#3
#3
0.97±0.10
#4
0.60
2.05±0.10
0.57±0.10
0.75±0.10
[ S ID E V IE W ]
1.27
Pin#
Function
Tri-state
GND
Output
VDD
1
2
3
4
0.75
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
Pameter
Min.
Supply Voltage Variation (V DD )
Frequency Range
3.3V
Max.
Min.
VDD+10%
VDD-10%
VDD+10%
VDD-10%
Max.
VDD+10%
1.5
50
1.5
50
1.5
50
45
15
55
45
10
55
45
7
55
Duty Cycle
Output Level (CMOS)
Output High (Logic"1")
Output Low(Logic"0")
Transition Time:Rise/Fall Time +
1.5 MHz ≦ Fo < 20 MHz
2.97
0.33
2.25
0.25
1.62
0.18
20 MHz ≦ Fo ≦ 50 MHz
4
3
2
4
3
2
5
4
2
Start Time
Tri-State(Input to Pin 1)
Enable (High voltage or floating)
Disable (Low voltage or GND)
2.31
0.99
1.75
0.75
1.26
0.54
Period Jitter(pk-pk)
RMS Phase Jitter (Integrated 12 KHz~20 MHz)
Standby Current
Aging (@ 25 oC 1st year)
Duty Cycle
Storage Temp. Range
-55
40
1
10
±3
125
-55
24,26
Max.
40
1
10
±3
125
Min.
1.8V
VDD-10%
Standard Frequency
Supply Current
2.5V
-55
Unit
V
MHz
mA
V
nSec
mSec
40
1
10
±3
125
V
pSec
pSec
μA
ppm
o
C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position
+ Transition times are measured between 10% and 90% of VDD, with an output load of 15 pF.
FREQ. STABILITY vs. TEMP. RANGE
ppm
Temp(o C)
-10 ~ +60
-20 ~ +70
-40 ~ +85
±20
±25
±50
*O: Available △: Conditional X: Not available
*Inclusive of calibration @ 25 oC ,operating temperature rrange,input
Voltage variation,load variation,aging (1st year),shock,and vibration
-40 ~ +125
Note: not all combination of options are available. Other specifications may be available upon request.
24
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(6)04/2019
很抱歉,暂时无法提供与“OZETELJANF--25MHZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.44375
- 30+3.32500
- 100+3.08750
- 500+2.85000
- 1000+2.73125
