DATA SHEET
CURRENT SENSOR - LOW TCR
AUTOMOTIVE GRADE
PA series
5%, 1%, 0.5%
sizes 0201/0402/0603/0805/1206/2010
Product specification – May 15, 2020 V.0
RoHS compliant & Halogen free
Chip Resistor Surface Mount
SCOPE
This specification describes
PA0201/0402/0603/0805/1206/2010
series current sensor - low TCR
with lead-free terminations metal
substrate.
FEATURES
AEC-Q200 qualified
Halogen-free Epoxy
RoHS compliant
Reduce environmentally
hazardous wastes
High component and equipment
reliability
Non-forbidden materials used in
products/production
Low resistances applied to
current sensing
Moisture sensitivity level: MSL 1
2
11
ORDERING INFORMATION - GLOBAL PART NUMBER
Global part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
GLOBAL PART NUMBER
PA XXXX X X X XX XXXX X
(1)
APPLICATIONS
Smart Phone
Batteries
Computer
Telecom / Datacom
Industrial / Power supply
Car electronics
SERIES
PA
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
(2) TOLERANCE
D = ± 0.5% ( for 5mΩ ~ 20mΩ)
F = ± 1%
J = ± 5%
(3) PACKAGING TYPE
R = Paper taping reel (PA0201~PA1206)
K = Embossed taping reel (PA2010)
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
E = ± 50ppm/°C
M = ± 75ppm/°C
F = ± 100ppm/°C
L = ± 150ppm/°C
G = ± 200ppm/°C
(5) TAPING REEL
07 / 7W / 7T / 47 / 57 / 87 inch dia. Reel and specific rated power
Detailed power rating are shown in the Table 2.
(6) RESISTANCE VALUE
1 mΩ to 20 mΩ
(7) DEFAULT CODE
Letter L / Z is the system default code for ordering only. (Note)
L is for 0201/0402/0603/0805
Z is for only 1206/2010
Resistance rule of global part
number
Resistance code rule
Example
0RXXX
(1 to 20 mΩ)
0R001 = 1 mΩ
0R02 = 20 mΩ
ORDERING EXAMPLE
The ordering code for a PA0805
0.125W chip resistor,TC50 value 0.01Ω
(10mR) with ±1% tolerance, supplied in
7-inch tape reel with 5Kpcs quantify is:
PA0805FRE070R01L.
NOTE
1. All our RChip products are RoHS compliant. "LFP" of the internal 2D reel label mentions
"Lead-Free Process"
www.yageo.com
May. 15, 2020 V0
PA
SERIES
3
11
MARKING
Fig. 1
Value = 10 mΩ
No Marking
CONSTRUCTION
The resistors are constructed using outstanding TCR level material, which makes Yageo PA resistors excellent
for current sensing application in battery charger circuit & DC -DC converter.
The composition of the resistive material is adjusted to give the app roximate required resistance. Finally, the
three external terminations (Cu / Ni / matte Tin) are added, as shown in Fig. 2.
Outlines
L
W
H
I1
I1
Fig. 2 Chip resistor outlines
www.yageo.com
May. 15, 2020 V0
PA
SERIES
4
11
DIMENSION
Table 1 For outlines, please refer to Fig. 2
TYPE
RESISTANCE RANGE
L (mm)
W (mm)
H (mm)
I1 (mm)
PA0201
5mΩ ≤ R ≤ 20mΩ
0.60± 0.03
0.31± 0.04
Max. 0.30
0.15± 0.06
PA0402
2mΩ ≤ R ≤ 20mΩ
1.00± 0.10
0.55± 0.10
Max. 0.40
0.25± 0.10
1 mΩ
1.60± 0.20
0.80± 0.20
0.55± 0.15
0.38± 0.12
2mΩ ≤ R ≤ 20mΩ
1.60± 0.20
0.80± 0.20
0.45± 0.15
0.38± 0.12
1mΩ
2.03± 0.20
1.27± 0.20
0.55± 0.15
0.60± 0.15
1.5/ 2mΩ
2.03± 0.20
1.27± 0.20
0.45± 0.15
0.50± 0.15
2.5mΩ ≤ R ≤ 20mΩ
2.03± 0.20
1.27± 0.20
0.30± 0.15
0.35± 0.20
1mΩ
3.20± 0.25
1.60± 0.25
0.65± 0.25
0.51± 0.25
2mΩ
3.20± 0.25
1.60± 0.25
0.55± 0.25
0.60± 0.25
2.5/ 3mΩ
3.20± 0.25
1.60± 0.25
0.40± 0.25
0.80± 0.30
4mΩ ≤ R ≤ 20mΩ
3.20± 0.25
1.60± 0.25
0.40± 0.25
0.60± 0.30
1mΩ ≤ R ≤ 3mΩ
5.08± 0.25
2.54± 0.25
0.50± 0.25
1.40± 0.25
4mΩ ≤ R ≤ 20mΩ
5.08± 0.25
2.54± 0.25
0.40± 0.25
0.70± 0.25
PA0603
PA0805
PA1206
PA2010
Note:
1. For relevant physical dimensions, please refer to construction outlines.
2. Please contact with sales offices, distributors and representatives in your region before ordering.
ELECTRICAL CHARACTERISTICS
Table 2
POWER RATING (1)
SIZE
TOLERANCE RESISTANCE RANGE
07
7W
7T
0201 1/20W 1/10W 3/20W
Fig. 4 Chip resistor outlines
0402 1/16W 1/8W 1/6W
47
57
87
1/4W
1/4W
1/3W
0603
1/10W
1/5W
1/3W
2/5W
1/2W
0805
1/8W
1/4W
1/2W
1W
1/4W
1/2W
1W
1206
0.5W
1W
1.5W
0.5W
1W
1.5W
2W
2010
± 1%
± 5%
5mΩ ≤ R ≤ 20mΩ
± 150 ppm/°C
2mΩ ≤ R ≤ 20mΩ
± 150 ppm/°C
1mΩ ≤ R ≤ 20mΩ
± 0.5%
10mΩ
± 1%
± 5%
1mΩ≤ R ≤ 20mΩ
± 0.5%
5mΩ ≤ R ≤ 20mΩ
± 1%
± 5%
1mΩ ≤ R ≤ 20mΩ
± 1%
± 5%
RESISTANCE
1mΩ
2/ 2.5mΩ
3mΩ ≤ R ≤ 10mΩ
± 200 ppm/°C
± 150 ppm/°C
± 50 ppm/°C, ± 75 ppm/°C
1/ 1.5mΩ
2mΩ ≤ R ≤ 20mΩ
± 150 ppm/°C
± 50 ppm/°C
1/ 2mΩ
3mΩ ≤ R ≤ 20mΩ
± 100 ppm/°C
± 50 ppm/°C
1mΩ ≤ R ≤ 20mΩ
± 50 ppm/°C
1mΩ ≤ R ≤ 10mΩ
Note: Please contact with sales offices, distributors and representatives in your region before ordering.
www.yageo.com
May. 15, 2020 V0
SERIES
PA
FUNCTIONAL DESCRIPTION
OPERATING TEMPERATURE RANGE
MLB206_14
PA0201/ 0402 Range: –55°C to +125°C
PA0603/ 0805 Range: –55°C to +155°C
PA1206/ 2010 Range: –55°C to +170°C
70
Standard rated power at 70°C: For detail power
value, please refer to Table 2.
Rated Power (%)
100
POWER RATING
80
1206/ 2010
60
0603/ 0805
40
0201/ 0402
RATED VOLTAGE
-55
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V=
5
11
-40
-20
60
80
100
155
125
170
120 140
160
180
Ambient Temperature
Fig. 3 Maximum dissipation (P max ) in percentage of rated power
as a function of the operating ambient temperature (T amb)
(PxR )
Where
V = Continuous rated DC or
AC (rms) working voltage (V)
P = Rated power (W)
R = Resistance value (Ω)
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PACKING STYLE
REEL
DIMENSION
PA0201
PA0402
PA0603
PA0805
PA1206
PA2010
Paper Taping Reel (R)
7" (178 mm)
10,000
10,000
5,000
5,000
4,000
Embossed Taping Reel (K)
7" (178 mm)
4,000
PAPER TAPE
P0
T
D0
P2
E
F
cover tape
W
B0
Fig. 4 Paper Tape
A0
P1
MBG251
www.yageo.com
May. 15, 2020 V0
SERIES
PA
6
11
EMBOSSED TAPE
P0
D0
P2
E
F
cover tape
W
B0
MBG516_b
A0
D1
T
P1
direction of unreeling
Fig. 5 Embossed Tape
Table 4 Dimensions of paper tape for relevant chip resistors size
SIZE
SYMBOL
Unit: mm
A0
B0
W
E
F
P0
P1
P2
ΦD0
T
PA0201
0.39± 0.10
0.70± 0.10
8.0± 0.30
1.75± 0.10
3.50± 0.10
4.00± 0.10
2.00± 0.10
2.00± 0.10
1.55± 0.05
0.43± 0.10
PA0402
0.59± 0.10
1.10± 0.10
8.0± 0.30
1.75± 0.10
3.50± 0.10
4.00± 0.10
2.00± 0.10
2.00± 0.10
1.55± 0.05
0.53± 0.10
PA0603
1.08± 0.10
1.90± 0.10
8.0± 0.30
1.75± 0.10
3.50± 0.10
4.00± 0.10
4.00± 0.10
2.00± 0.10
1.55± 0.05
0.60± 0.10
1.60± 0.10
2.35± 0.10
8.0± 0.30
1.75± 0.10
3.50± 0.10
4.00± 0.10
4.00± 0.10
2.00± 0.10
1.55± 0.05
0.60± 0.10*
1.60± 0.10
2.35± 0.10
8.0± 0.30
1.75± 0.10
3.50± 0.10
4.00± 0.10
4.00± 0.10
2.00± 0.10
1.55± 0.05 0.53± 0.10**
1.90± 0.10
3.50± 0.10
8.0± 0.30
1.75± 0.10
3.50± 0.10
4.00± 0.10
4.00± 0.10
2.00± 0.10
1.55± 0.05
PA0805
PA1206
0.85± 0.15
Note:
* 1~2mΩ
** 2.5~20mΩ
Table 5 Dimensions of embossed tape for relevant chip resistors size
SIZE
PA2010
SYMBOL
Unit: mm
A0
B0
W
E
F
P0
P1
P2
ΦD0
T
3.40± 0.15
6.70± 0.15
12.0± 0.30
1.75± 0.10
5.50± 0.10
4.00± 0.10
4.00± 0.10
2.00± 0.10
1.55± 0.10
0.85± 0.15
www.yageo.com
May. 15, 2020 V0
PA
SERIES
7
11
REEL SPECIFICATION
W2
D
C
Fig. 6 Reel
N
A
HBK039_a
W1
Table 6 Dimensions of reel specification for relevant chip resistors size
SIZE
QUANTITY
PER REEL
PA0201
10,000
PA0402
10,000
PA0603
5,000
PA0805
5,000
PA1206
4,000
PA2010
4,000
REEL SIZE
8mm
TAPE WIDE
7"
(Φ178mm)
7"
(Φ178mm)
7"
(Φ178mm)
7"
(Φ178mm)
7"
(Φ178mm)
REEL SIZE
12mm
TAPE WIDE
SYMBOL
Unit: mm
A
N
C
D
W1
W2 MAX.
178.0± 1.0
60.0+1/-0
13.50± 0.5
21.0± 0.8
9.0± 0.5
12.0± 0.2
178.0± 1.0
60.0+1/-0
13.50± 0.5
21.0± 0.8
9.0± 0.5
12.0± 0.2
178.0± 1.0
60.0+1/-0
13.50± 0.5
21.0± 0.8
9.0± 0.5
12.0± 0.2
178.0± 1.0
60.0+1/-0
13.50± 0.5
21.0± 0.8
9.0± 0.5
12.0± 0.2
178.0± 1.0
60.0+1/-0
13.50± 0.5
21.0± 0.8
9.0± 0.5
12.0± 0.2
7"
(Φ178mm)
178.0± 1.0
60.0+1/-0
13.50± 0.5
21.0± 0.8
13.6± 0.5
16.5± 0.5
www.yageo.com
May. 15, 2020 V0
SERIES
PA
8
11
LEADER/TRAILER TAPE SPECIFICATION
leader end
empty compartments
with cover tape
(min. 240 mm)
trailer end
cover tape only
trailer (max. 260 mm)
Fig. 7 Leader/Trailer Tape
CCB325
FOOTPRINT AND SOLDERING PROFILES
For recommended soldering profiles, please refer to data sheet “Chip resistors mounting”.
FOOTPRINT
Fig. 8 Single resistor chips recommended dimensions of footprints
Table 7 Footprint dimensions
Unit: mm
TYPE
RESISTANCE RANGE
A
B
C
D
PA0201
5mΩ ≤ R ≤ 20mΩ
1.00
0.30
0.35
0.40
PA0402
2mΩ ≤ R ≤ 20mΩ
2.00
0.40
0.80
0.60
1mΩ
2.20
0.50
0.70
0.90
1mΩ < R ≤ 20mΩ
2.20
0.80
0.70
0.90
1mΩ
4.10
0.50
1.80
2.18
1.5mΩ ≤ R ≤ 20mΩ
4.60
1.00
1.80
2.18
1mΩ / 2mΩ
4.20
1.00
1.60
1.84
2.5mΩ / 3mΩ
4.80
1.00
1.90
1.84
4mΩ ≤ R ≤ 20mΩ
4.80
1.20
1.80
1.84
1mΩ ≤ R ≤ 3mΩ
6.00
1.40
2.30
3.00
4mΩ ≤ R ≤ 20mΩ
6.00
3.50
1.25
3.00
PA0603
PA0805
PA1206
PA2010
www.yageo.com
May. 15, 2020 V0
PA
SERIES
9
11
TESTS AND REQUIREMENTS
Table 8 Test condition, procedure and requirements
TEST
PROCEDURE
REQUIREMENT
Short time
overload
TEST METHOD
IEC60115-1 4.13
5 times of rated power for 5 seconds at room
temperature
± (1.0%+0.0005Ω)
High Temperature
Exposure/
Endurance at
Upper Category
Temperature
MIL-STD-202G-Method 108A
1,000 hours at maximum operating
temperature depending on specification,
unpowered
± (1.0%+0.0005Ω)
No visible damage
No direct impingement of forced air to the
par ts Tolerances:
0201/0402: 125± 3ºC
0603/0805: 155± 3ºC
1206/2010: 170± 3ºC
Temperature
Cycling
JESD22-A104C
1,000 cycles, -55/+125ºC for 1 cycle per hour
± (1.0%+0.0005Ω)
Moisture
Resistance
MIL-STD-202G-Method 106F
Each temperature / humidity cycle is defined at
8 hours (method 106F), 3 cycles / 24 hours for
10d with 25ºC / 65ºC 95% R.H, without steps
7a & 7b, unpowered
± (0.5%+0.0005Ω)
Biased
Humidity
MIL-STD-202 Method 103
1,000 hours; 85ºC / 85% RH
± (1.0%+0.0005Ω)
Operational Life/
Endurance
IEC 60115-1 4.25.1
10% of operating power
1,000 hours at 125± 3ºC, de-rated power
applied for 1.5 hours on, 0.5 hour off, still-air
required
± (1.0%+0.0005Ω)
1,000 hours at 70± 2ºC applied rated power
1.5 hours on, 0.5 hour off, still air required
± (1.0%+0.0005Ω)
Resistance to
Solvents
MIL-STD-202 Method 215
Immerse in isopropyl alcohol for 5 min with
ultrasonic at room temperature
No visible damage
Mechanical Shock
MIL-STD-202 Method 213
Three shocks in each direction shall be applied
along the three mutually perpendicular axes of
the test specimen.
Peak value: 100 g’s
Duration: 6 ms
Velocity change: 12.3 ft/s
Waveform: Half sine
± (0.5%+0.0005Ω)
Vibration
MIL-STD-202 Method 204
5 g’s for 20 min., 12 cycles each of 3
orientations
Test from 10-2000 Hz.
± (0.5%+0.0005Ω)
Resistance to
Soldering Heat
MIL-STD-202G-method 210F
Condition B, no pre-heat of samples
Leadfree solder, 260ºC, 10 seconds immersion
time Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
± (0.5%+0.0005Ω)
No visible damage
www.yageo.com
May. 15, 2020 V0
TEST
Thermal Shock
Electrostatic
Discharge
TEST METHOD
MIL-STD-202 Method 107
AEC-Q200-002
SERIES
PA
PROCEDURE
REQUIREMENT
-55/+125ºC, Number of cycles is 300.
Maximum transfer time is 20 seconds.
Dwell time is 15 minutes. Air -Air
± (1.0%+0.0005Ω)
Human Body Model, 1 pos + 1 neg.
0805/ 1206/ 2010 : 2KV
± (1.0%+0.0005Ω)
0402/ 0603 : 1KV
10
11
No visible damage
No visible damage
0201: 500V
Solderability
- Wetting
J-STD-002
(a) Method B, aging 4 hours at 155ºC dr y heat,
dipping at 235± 3ºC for 5± 0.5 seconds.
Well tinned (>95%
covered)
(b) Method B, steam aging 8 hours, dipping at
215± 3ºC for 5± 0.5 seconds.
No visible damage
(c) Method D, steam aging 8 hours, dipping at
260± 3 ºC for 30± 0.5 seconds.
Flammability
UL94
Tr y to inflame a specimen by a needle flame
No ignition of
specimen; V-0
Board Flex /
Bending
AEC-Q200-005
Chips mounted on a 90mm glass epoxy resin
PCB (FR4), Bending for
± (1.0%+0.0005Ω)
0201: 3mm
0402 and above: 2mm
Holding time: Min.60 seconds
Terminal
Strength (SMD)
AEC-Q200-006
Applied
± (1.0%+0.0005Ω)
0201: 3N
No visible damage
0402: 5N
0603/ 0805/ 1206/ 2010: 17.7N
for 60± 1 seconds.
Flame Retardance
Temperature
Coefficient of
Resistance
(T.C.R.)
AEC-Q200-001
IEC 60115-1 4.8
Apply voltage from 9V to 32V to increase the
surface temp to 350ºC
No flame,
At +25/+125ºC
Refer to table 2
no explosion
Formula:
R2–R1
6
T.C.R= ------------------------- × 10 (ppm/ºC)
R1(t2–t1)
Where
t1 =+25ºC or specified room temperature
t2 =+125ºC test temperature
R1=resistance at reference temperature in
ohms
R2=resistance at test temperature in ohms
www.yageo.com
May. 15, 2020 V0
PA
SERIES
11
11
REVISION HISTORY
REVISION
DATE
Version 0TYPE May 07, 2020
CHANGE NOTIFICATION
POWER
DESCRIPTION
RESISTANCE
RANGE
- New datasheet
for automotive
grade current sensor –
TOLERANCE
OF RESISTANCE
PA0201/0402/0603/0805/1206/2010 series.
0603
0805
1206
1/10W, 1/5W, 3/10W, 2/5W, 1/2W
5 mΩ≦ R < 100 mΩ
1/8W, 1/4W, 1/3W, 1/2W
4 mΩ ≦ R < 100 mΩ
1/4W, 1/2W
3 mΩ ≦ R < 100 mΩ
1/2W, 1W
PF
material, which makes Yageo PF
resistors excellent for current
charger circuit & DC-DC
converter.
2010 material is adjusted to give the
approximate required resistance
and is covered with a protective
coating, which printed with the
resistance value.
Finally, the three external
terminations (Ni / matte Tin) are
added, as shown in Fig. 4.
2512
4527
± 1%
± 2%
5 mΩ ≦ R < 100 mΩ
±75 ppm/°C
± 5%
1W, 2W
1 mΩ ≦ R < 100 mΩ
3W
1 mΩ ≦ R ≦ 50 mΩ
2W, 3W, 5W
6 mΩ ≦ R < 1Ω
NOTE: 1. PLEASE CONTACT WITH SALES OFFICES, DISTRIBUTORS AND REPRESENTATIVES IN YOUR REGION BEFORE ORDERING
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any
product change will be announced by PCN.”
www.yageo.com
May. 15, 2020 V0
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Yageo:
PA0805JR-470RL PA1206FRF470R025L PA1206FRF470R006L PA1206FRF070R001L PA1206FRE470R005L
PA1206FRE470R004L PA1206FRF7W0R033L PA1206FRM7W0R05L PA1206FRF7W0R03L PA1206FRF070R006L
PA1206FRF470R05L PA1206FRF470R007L PA1206DRE7W0R01L PA1206FRF7W0R05L PA1206FRE470R003L
PA1206FRM470R001L PA0805FRL471U5L PA1206FRM7W0R025L PA1206FRM470R004L PA1206FRE7W0R004L
PA1206FRF470R01L PA1206FRF470R03L PA1206FRF470R004L PA1206FRF070R008L PA1206JRF070R005L
PA1206FRE7W0R006L
YAGEO:
PA0805FRF470R008L
