TPESD0504C6
4-line Ultra Low Capacitance TVS Diode Array
www.sot23.com.tw
Features
Mechanical Characteristics
Package:SOT363
Lead Finish :Matte Tin
UL Flammability Classification Rating 94V-0
ESD Protect for 4 high-speed I/O channels
Provide ESD protection for each channel to
IEC 61000-4-2 (ESD) ±18kV (air), ±14kV (contact)
IEC 61000-4-4 (EFT) (5/50ns) Level-3, 20A for I/O,
80A for Power
IEC 61000-4-5 (Lightning) 6.5A (8/20µs)
For below 5V operating voltage
Low capacitance : 1.3pF typical
Fast turn-on and Low clamping voltage
Array of surge rated diodes with internal
equivalent TVS diode
Small package saves board space
Solid-state silicon-avalanche and active circuit
triggering technology
Green part available
Applications
3000
Reel Size
PU
Qty per Reel
7”
CH
TPE05L4C6
TPESD0504C6
Dimensions and Pin Configuration
TE
Part Number
BL
Ordering Information
IC
USB2.0 Power and Data lines protection
Notebook and PC Computers
Monitors and Flat Panel Displays
IEEE 1394 Firewire Ports
Video Graphics Cards
SIM ports
Pin Configuration
WWW.TECHPUBLIC.COM.TW
TPESD0504C6
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
PARAMETER
PARAMETER
RATING
UNITS
IPP
6.5
A
VDC
VESD
V
kV
TSOL
6
18
14
30
30
260 (10 sec.)
TOP
-55 to +85
o
o
Peak Pulse Current (tp =8/20µs)
Operating Supply Voltage (VDD-GND)
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
ESD per IEC 61000-4-2(Air)(VDD-GND)
ESD per IEC 61000-4-2(Contact) (VDD-GND)
Lead Soldering Temperature
Operating Temperature
VESD_VDD
kV
o
C
C
TSTO
-55 to +150
DC Voltage at any I/O pin
VIO
(GND – 0.5) to (VDD + 0.5)
IC
Storage Temperature
C
V
Electrical Characteristics (TA=25°C unless otherwise specified)
SYMBOL
VRWM
Channel Leakage
Current
Reverse
Breakdown
Voltage
Forward Voltage
ICH_Leak
Clamping Voltage
VCL
ESD Clamping
Voltage –VDD
ESD Dynamic
Turn-on
Resistance –I/O
ESD Dynamic
Turn-on
Resistance –VDD
Channel Input
Capacitance
Channel to
Channel Input
Capacitance
Variation of
Channel Input
Capacitance
PU
CH
VBV
VPin 5 = 5V, VPin 2 = 0V, T=25 oC,
VCH = 0 ~ 5V
IBV = 1mA, T=25 oC
Pin 5 to Pin 2
IF = 15mA, T=25 oC
Pin 2 to Pin 5
IPP=5A, tp=8/20µs, T=25 oC
Any Channel pin to Ground
IEC 61000-4-2 +6kV, T=25 oC,
Contact mode, Any Channel pin to
Ground
Contact mode, VDD pin to Ground
IEC 61000-4-2 0~+6kV, T=25 oC,
Ground
TE
ESD Clamping
Voltage –I/O
Vclamp_io
Vclamp_VDD
Rdynamic_io
Rdynamic_VDD
CIN
CCROSS
△CIN
MIN
TYP
MAX
5
UNITS
V
5
µA
1
µA
9
V
0.8
1
V
8.1
9
V
VRWM = 5V, T=25 oC, Pin 5 to pin 2
ILeak
VF
CONDITIONS
Pin 5 to pin 2, T=25 oC
BL
PARAMETER
Reverse Stand-Off
Voltage
Reverse Leakage
Current
Vpin5 = 5V, Vpin2 = 0V, VIN = 2.5V, f =
1MHz, T=25 oC, Any Channel pin
to Ground
1MHz, T=25 oC , Between
Channel pins
1MHz, T=25 oC , Channel_x pin to
Ground - Channel_y pin to Ground
6
12.5
V
9
V
0.35
Ω
0.2
Ω
1.3
1.6
pF
0.12
0.14
pF
0.05
0.07
pF
TPESD0504C6
www.sot23.com.tw
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
80
60
40
td=t IPP/2
10
15
30
Time (ns)
30ns
60ns
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
tr = 0.7~1ns
PU
t - Time ( s)
Fig3.
10%
BL
90%
IC
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
50
75
100
125
150
Ambient Temperature –TA (ºC)
TPESD0504C6
www.sot23.com.tw
Outline Drawing - SOT363
DIM
D
e1
A
A1
A2
b
c
D
E1
E
e
e1
L
L1
N
01
aaa
bbb
ccc
N
E/2
E1
1
ccc C
2X N/2 TIPS
E
2
e
B
D
A2
A
SEATING
PLANE
bxN
bbb
1.10
0.00
0.10
0.70 0.90 1.00
0.15
0.30
0.08
0.22
1.80 2.00 2.20
1.15 1.25 1.35
2.10 BSC
0.65 BSC
1.30 BSC
0.26 0.36 0.46
(0.42)
6
0°
8°
0.10
0.10
0.30
H
A1
C
.043
.000
.004
.028 .035 .039
.012
.006
.003
.009
.071 .079 .087
.045 .049 .053
.083 BSC
.026 BSC
.051
.010 .014 .018
(.017)
6
8°
0°
.004
.004
.012
BL
aaa C
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
IC
A
C A-B D
GAGE
PLANE
PU
0.15
SEE DETAIL
01
(L1)
DETAIL
A
A
CH
SIDE VIEW
L
c
TE
Land Pattern -SOT363
X
DIM
C
G
Y
Z
C
G
P
X
Y
Z
DIMENSIONS
INCHES
MILLIMETERS
(.073)
.039
.026
.016
.033
.106
(1.85)
1.00
0.65
0.40
0.85
2.70
P
很抱歉,暂时无法提供与“TPESD0504C6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.41753
- 100+0.33459
- 300+0.29312
- 3000+0.24992
- 6000+0.22508
- 9000+0.21255
- 国内价格
- 10+0.38273
- 100+0.30670
- 600+0.26869
- 1200+0.26466
- 3000+0.22909
- 国内价格
- 1+0.61490
- 200+0.42460
- 1500+0.38610
- 3000+0.36080
