SDMM0806H-2-900T
SDMM0806H-2-900T
    SUNLORD(顺络)
    共模滤波器 0806 90Ω@100MHz 100mA 4Ω
SDMM0806H-2-900T 数据手册
Multilayer Chip Common Mode Filter– SDMM Series Operating Temp. : -40℃~+85℃ FEATURES     Effective for suppressing common mode noise at high frequency Excellent solderability characteristics Small size & low profile (0.85*0.65*0.40 mm) Multilayer type SMD component based on LTCC technology APPLICATIONS  Common mode noise suppression of high speed differential signal lines, such as MIPI, MHL in mobile phone, tablet PC etc. PRODUCT IDENTIFICATION 0806 SDMM ② ① ① H -2 900 T ③ ④ ⑤ ⑥ ③ ② External Dimensions (L×W) (mm) 0806 0.85×0.65 Type Multilayer Chip Common Mode Filter SDMM Feature Type For High-Speed Differential Signal Lines For Ultra high speed Differential Signal Lines H U ⑤ Common Mode Impedance (Ω) ④ Example Nominal Value 350 900 35 90 Number of Lines 2 Lines 2 ⑥ Packing T Tape & Reel SHAPE, DIMENSIONS AND LAND-PATTERN Type: SDMM0806 Land Pattern SL B (2) SW (3) (1) (1) A (4) D T (4) (3) (2) (2) C Unit: mm P W L Land A B C D 0.9 0.8 0.3 0.3 Unit: mm [inch] Type L W T SL SW P SDMM0806 0.85±0.05 [.033±.002] 0.65±0.05 [.026±.002] 0.40±0.05 [.016±.002] 0.20+0.05/-0.10 [.008+.002/-.004] 0.27±0.05 [.011±.002] 0.50±0.05 [.020±.002] Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2019/03/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com EQUIVALENT CIRCUIT (3) (1) (4) (2) SPECIFICATIONS SDMM0806H-2-_T Series Part Number Common Mode Impedance @ 100MHz Units Symbol SDMM0806H-2-120T SDMM0806H-2-350T SDMM0806H-2-470T SDMM0806H-2-900T Ω Z 12±5 35±20% 47±20% 90±20% Max. DC Max. Rated Resistance Current Ω DCR 2.5 3.0 3.5 4.0 mA Ir 130 100 100 100 Max. DC Max. Rated Resistance Current Ω DCR 3.5 4.5 mA Ir 100 100 Rated Voltage Withstand Voltage Min. Insulation Resistance Volts VDC 5 5 5 5 Volts VP 12.5 12.5 12.5 12.5 MΩ IR 100 100 100 100 SDMM0806U-2-_T Series Part Number Common Mode Impedance @ 100MHz Units Symbol SDMM0806U-2-350TB01 SDMM0806U-2-900TB01 Ω Z 35±20% 90±20% Rated Voltage Volts VDC 5 5 Min. Cutoff Insulation Frequency (typ.) Resistance MΩ IR 100 100 GHz f0 >6 3.5 ELECTRICAL CHARACTERISTICS SDMM0806H-2-_T Series Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2019/03/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com ELECTRICAL CHARACTERISTICS SDMM0806U-2-_T Series Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2019/03/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
SDMM0806H-2-900T
1. 物料型号:通常指的是电容器的具体型号,例如SDMM系列中的某个具体型号。
2. 器件简介:介绍电容器的基本信息,如其用途、主要功能等。
3. 引脚分配:描述电容器的引脚布局,包括正负极性。
4. 参数特性:包括电容器的电容值、耐压值、温度范围、等效串联电阻(ESR)和等效串联电感(ESL)等。
5. 功能详解:详细说明电容器在电路中的作用,如滤波、去耦、储能等。
6. 应用信息:介绍电容器在哪些领域或产品中有应用,如电源、通信设备、汽车电子等。
7. 封装信息:描述电容器的物理尺寸、形状和封装类型,这对于PCB设计和组装非常重要。
SDMM0806H-2-900T 价格&库存
很抱歉,暂时无法提供与“SDMM0806H-2-900T”相匹配的价格&库存,您可以联系我们找货
SDMM0806H-2-900T
  • 20+0.19044
  • 1000+0.13369
  • 4000+0.12153
库存:2100
SDMM0806H-2-900T
  • 1+0.48730
  • 500+0.16280
  • 5000+0.10824
  • 10000+0.08877
库存:19708
SDMM0806H-2-900T
  • 20+0.20690
  • 200+0.16680
  • 600+0.14450
  • 2000+0.13130
  • 10000+0.11990
  • 20000+0.11390
库存:687
