MM3Z2V0~MM3Z75
Silicon Planar Zener Diodes
PINNING
Features
• Total power dissipation : max. 300 mW
PIN
DESCRIPTION
1
Cathode
2
Anode
• Small plastic package suitable for
2
1
surface mounted design
• Tolerance approximately ± 5%
Top View
Simplified outline SC-76 and symbol
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Power Dissipation
Junction Temperature
Storage Temperature Range
Symbol
Value
Unit
Ptot
300
mW
Tj
150
O
Tstg
- 55 to + 150
O
Symbol
Max.
RθJA
417
VF
0.9
C
C
Characteristics at Ta = 25 OC
Parameter
Thermal Resistance Junction to Ambient Air
Forward Voltage
at IF = 10 mA
Unit
C/W
O
V
SEMTECH ELECTRONICS LTD.
Dated: 16/03/2015 Rev: 01
MM3Z2V0~MM3Z75
Marking
Code
Type
MM3Z2V0
B0
Zener Voltage Range 1)
Dynamic Impedance
Vznom
VZT
at IZT
(V)
2.0
(V)
1.8...2.15
(mA)
5
ZZT
Max. ( Ω)
100
at IZT
(mA)
5
Reverse Leakage Current
IR
at VR
Max. (μA)
120
(V)
0.5
MM3Z2V2
C0
2.2
2.08...2.33
5
100
5
120
0.7
MM3Z2V4
1C
2.4
2.28...2.56
5
100
5
120
1
MM3Z2V7
1D
2.7
2.5...2.9
5
110
5
120
1
MM3Z3V0
1E
3.0
2.8...3.2
5
120
5
50
1
MM3Z3V3
1F
3.3
3.1...3.5
5
130
5
MM3Z3V6
1H
3.6
3.4...3.8
5
130
5
10
1
MM3Z3V9
1J
3.9
3.7...4.1
5
130
5
5
1
MM3Z4V3
1K
4.3
4...4.6
5
130
5
5
1
MM3Z4V7
1M
4.7
4.4...5
5
130
5
2
1
MM3Z5V1
1N
5.1
4.8...5.4
5
130
5
2
1.5
MM3Z5V6
1P
5.6
5.2...6
5
80
5
1
2.5
MM3Z6V2
1R
6.2
5.8...6.6
5
50
5
1
3
MM3Z6V8
1X
6.8
6.4...7.2
5
30
5
0.5
3.5
MM3Z7V5
1Y
7.5
7...7.9
5
30
5
0.5
4
MM3Z8V2
1Z
8.2
7.7...8.7
5
30
5
0.5
5
MM3Z9V1
2A
9.1
8.5...9.6
5
30
5
0.5
6
MM3Z10
2B
10
9.4...10.6
5
30
5
0.1
7
MM3Z11
2C
11
10.4...11.6
5
30
5
0.1
8
MM3Z12
2D
12
11.4...12.7
5
35
5
0.1
9
MM3Z13
2E
13
12.4...14.1
5
35
5
0.1
10
MM3Z15
2F
15
13.8...15.6
5
40
5
0.1
11
MM3Z16
2H
16
15.3...17.1
5
40
5
0.1
12
MM3Z18
2J
18
16.8...19.1
5
45
5
0.1
13
MM3Z20
2K
5
50
5
0.1
15
MM3Z22
2M
22
20.8...23.3
5
55
5
0.1
17
MM3Z24
2N
24
22.8...25.6
5
60
5
0.1
19
MM3Z27
2P
27
25.1...28.9
2
70
2
0.1
21
MM3Z30
2R
30
28...32
2
80
2
0.1
23
MM3Z33
2X
33
31...35
2
80
2
0.1
25
MM3Z36
2Y
36
34...38
2
90
2
0.1
27
MM3Z39
2Z
39
37...41
2
100
2
0.1
30
MM3Z43
3A
43
40...46
2
130
2
0.1
33
MM3Z47
3B
47
44...50
2
150
2
0.1
36
MM3Z51
3C
51
48...54
2
180
2
0.1
39
MM3Z56
3D
56
52...60
2
200
2
0.1
43
MM3Z62
3E
62
58...66
2
215
2
0.1
47
MM3Z68
3F
68
MM3Z75
3H
75
1)
VZT is tested with pulses (20 ms).
64...72
2
240
2
0.1
52
70...79
2
265
2
0.1
56
MM3Z2V0~MM3Z75
Breakdown characteristics
Tj = constant (pulsed)
mA
50
Iz
Tj=25o C
3V9
2V7
6V8
4V7
3V3
40
8V2
5V6
30
Test current Iz
5mA
10
2
3
4
5
6
8
7
9
10 V
Vz
mA
30
Tj=25 oC
10
12
Iz
15
22
27
Test current Iz
5mA
10
33
40 V
Vz
Power Dissipation: Ptot (mW)
300
200
100
150
100
Ambient Temperature: Ta ( C)
O
Derating Curve
MM3Z2V0~MM3Z75
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SC-76
A
c
HE
A
D
E
bp
UNIT
A
mm
1.10
0.80
bp
0.40
0.25
C
0.15
0.10
D
1.80
1.60
E
HE
1.35
1.15
2.80
2.30
很抱歉,暂时无法提供与“MM3Z24”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12751
- 300+0.10187
- 1200+0.10034
- 3000+0.08326
- 国内价格
- 20+0.20240
- 100+0.12070
- 800+0.08450
- 3000+0.06040
- 6000+0.05740
- 30000+0.05310
- 国内价格
- 50+0.13911
- 500+0.11114
- 3000+0.09083
- 国内价格
- 1+0.27720
- 200+0.09218
- 1500+0.05764
- 3000+0.04576
