XB431-TL
XB431-TL
    XINLUDA(信路达)
    SOT-23
    电压基准 SOT23-3 1.24~6V 1%
XB431-TL 数据手册
XB431-TL SOT23-3 1 Features 2 Applications • • • • • • • • 1 • • • • • • Low-Voltage Operation, VREF = 1.24 V Adjustable Output Voltage, VO = VREF to 6 V Reference Voltage Tolerances at 25°C – 0.5% for XB431-TL – 1% for XB431-TL – 1.5% for XB431-TL Typical Temperature Drift – 4 mV (0°C to 70°C) – 6 mV (–40°C to 85°C) – 11 mV (–40°C to 125°C) Low Operational Cathode Current, 80 µA Typ 0.25-Ω Typical Output Impedance Ultra-Small SC-70 Package Offers 40% Smaller Footprint Than SOT-23-3 See XB431-TL for: – Wider VKA (1.24 V to 18 V) and IK (80 mA) – Additional SOT-89 Package – Multiple Pinouts for SOT-23-3 and SOT-89 Packages On Products Compliant to MIL-PRF-38535, All Parameters Are Tested Unless Otherwise Noted. On All Other Products, Production Processing Does Not Necessarily Include Testing of All Parameters. Adjustable Voltage and Current Referencing Secondary Side Regulation in Flyback SMPSs Zener Replacement Voltage Monitoring Comparator with Integrated Reference 3 Description The XB431 device is a low-voltage 3-terminaladjustable voltage reference withspecified thermalstability over applicable industrialand commercialtemperature ranges. Output voltagecan be set to anyvalue between VREF (1.24 V)and 6 V with twoexternal resistors (see Figure20). These devicesoperate from a lower voltage(1.24 V) than the widelyused XB431 shunt-regulator references. When used with an optocoupler, the XB431 device is an ideal voltage reference in isolated feedback circuits for 3-V to 3.3-V switching-mode power supplies. These devices have a typical output impedance of 0.25 Ω. Active output circuitry provides a very sharp turn-on characteristic, making them excellent replacements for low-voltage Zener diodes in many applications, including on-board regulation and adjustable power supplies. 4 Device Information(1) PART NUMBER XB431x PACKAGE (PIN) BODY SIZE (NOM) SOT-23 (3) 2.90 mm x 1.30 mm SOT-23 (5) 2.90 mm x 1.60 mm SC70 (6) 2.00 mm x 1.25 mm TO-92 (3) 4.30 mm × 4.30 mm SOIC (8) 4.90 mm x 3.90 mm (1) For all available packages, see the orderable addendum at the end of the data sheet. 4 Simplified Schematic VO Input IK VREF 1 XB431-TL SOT23-3 6 Pin Configuration and Functions DBV (SOT-23-5) PACKAGE (TOP VIEW) D (SOIC) PACKAGE (TOP VIEW) CATHODE ANODE ANODE NC 1 8 2 7 3 6 4 5 REF ANODE ANODE NC NC 1 ∗ 2 CATHODE 3 ANODE ANODE 4 REF REF 1 CATHODE 2 3 DCK (SC-70) PACKAGE (TOP VIEW) CATHODE CATHODE NC REF ANODE 2 5 1 6 2 5 3 4 LP (TO-92/TO-226) PACKAGE (TOP VIEW) ANODE NC NC CATHODE ANODE REF REF 1 ANODE NC − No internal connection ∗ For XB431: NC − No internal connection ∗ For XB431: Pin 2 is attached to Substrate and must be connected to ANODE or left open. PK (SOT-89) PACKAGE (TOP VIEW) 3 DBZ (SOT-23-3) PACKAGE (TOP VIEW) NC − No internal connection Pin Functions PIN NAME TYPE DESCRIPTION DBZ DBV PK D LP DCK CATHODE 2 3 3 1 1 1 I/O REF 1 4 1 8 3 3 I Threshold relative to common anode ANODE 3 5 2 2, 3, 6, 7 2 6 O Common pin, normally connected to ground NC — 1 — 4, 5 — 2, 4, 5 I No Internal Connection * — 2 — — — — I Substrate Connection 2 Shunt Current/Voltage input XB431-TL SOT23-3 7 Specifications 7.1 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) MIN VKA Cathode voltage (2) IK Continuous cathode current range Iref Reference current range (1) (2) Storage temperature range UNIT 7 V –20 20 mA –0.05 3 mA 150 °C 150 °C Operating virtual junction temperature Tstg MAX –65 Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Voltage values are with respect to the anode terminal, unless otherwise noted. 7.2 ESD Ratings PARAMETER V(ESD) (1) (2) Electrostatic discharge DEFINITION VALUE Human body model (HBM), per ANSI/ESDA/JEDEC JS-001, all pins (1) ±2000 Charged device model (CDM), per JEDEC specification JESD22-C101, all pins (2) ±1000 UNIT V JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. 7.3 Thermal Information XB431x THERMAL METRIC (1) DCK D PK DBV DBZ LP 6 PINS 8 PINS 3 PINS 5 PINS 3 PINS 3 PINS RθJA Junction-to-ambient thermal resistance 87 97 52 206 206 140 RθJC(top) Junction-to-case (top) thermal resistance 259 39 9 131 76 55 (1) UNIT °C/W For more information about traditional and new thermal metrics, see the IC Package Thermal Metrics application report (SPRA953). 7.4 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) MIN MAX VKA Cathode voltage VREF 6 V IK Cathode current 0.1 15 mA TA Operating free-air temperature range –40 125 °C XB431 3 UNIT XB431-TL SOT23-3 7.5 Electrical Characteristics for XB431 at 25°C free-air temperature (unless otherwise noted) PARAMETER XB431 TEST CONDITIONS TA = 25°C VREF VKA = VREF, IK = 10 mA Reference voltage TA = full range (1) (see Figure 19) XB431 MIN TYP MAX 1.222 1.24 1.258 1.21 1.27 1.202 1.278 1.194 VREF(dev) DVREF VREF deviation over full temperature range (2) VKA = VREF, IK = 10 mA (1) (see Figure 19) XB431 UNIT V 1.286 4 12 6 20 11 31 mV Ratio of VREF change in cathode voltage change VKA = VREF to 6 V, IK = 10 mA (see Figure 20) –1.5 –2.7 mV/V Iref Reference terminal current IK = 10 mA, R1 = 10 kΩ, R2 = open (see Figure 20) 0.15 0.5 µA 0.3 Iref deviation over full temperature range (2) IK = 10 mA, R1 = 10 kΩ, R2 = open (1) (see Figure 20) 0.05 Iref(dev) XB431 0.1 0.4 0.15 0.5 XB431 DVKA IK(min) Minimum cathode current for regulation VKA = VREF (see Figure 19) IK(off) Off-state cathode current VREF = 0, VKA = 6 V (see Figure 21) |zKA| Dynamic impedance (3) VKA = VREF, f ≤ 1 kHz, IK = 0.1 mA to 15 mA (see Figure 19) (1) (2) 55 80 55 100 0.001 0.1 µA 0.25 0.4 Ω µA Full temperature ranges are –40°C to 125°C for XB431 –40°C to 85°C for XB431 and 0°C to 70°C for XB431 The deviation parameters VREF(dev) and Iref(dev) are defined as the differences between the maximum and minimum values obtained over the rated temperature range. The average full-range temperature coefficient of the reference input voltage, αVREF, is defined as: VREF(dev ) æ ö 6 ç ÷ ´ 10 ppm ö è VREF (TA = 25°C ) ø æ aVREF ç ÷= DTA è °C ø where ΔTA is the rated operating free-air temperature range of the device. αVREF can be positive or negative, depending on whether minimum VREF or maximum VREF, respectively, occurs at the lower temperature. (3) µA DVKA The dynamic impedance is defined as zka = DIK spacer When the device is operating with two external resistors (see Figure 20), the total dynamic impedance of the circuit is defined as: z ka ¢= DV DI » z ka æ è ´ ç1 + R1 ö ÷ R2 ø 4 XB431-TL SOT23-3 7.6 Electrical Characteristics for XB431 at 25°C free-air temperature (unless otherwise noted) PARAMETER XB431 TEST CONDITIONS TA = 25°C VREF VKA = VREF, IK = 10 mA Reference voltage TA = full range (1) (see Figure 19) XB431 MIN TYP MAX 1.228 1.24 1.252 1.221 1.259 1.215 1.265 1.209 VREF(dev) DVREF VREF deviation over full temperature range (2) VKA = VREF, IK = 10 mA (1) (see Figure 19) XB431 UNIT V 1.271 4 12 6 20 11 31 mV Ratio of VREF change in cathode voltage change VKA = VREF to 6 V, IK = 10 mA (see Figure 20) –1.5 –2.7 mV/V Iref Reference terminal current IK = 10 mA, R1 = 10 kΩ, R2 = open (see Figure 20) 0.15 0.5 µA 0.05 0.3 Iref(dev) Iref deviation over full temperature IK = 10 mA, R1 = 10 kΩ, range (2) R2 = open (1) (see Figure 20) 0.1 0.4 0.15 0.5 DVKA XB431 IK(min) Minimum cathode current for regulation VKA = VREF (see Figure 19) IK(off) Off-state cathode current VREF = 0, VKA = 6 V (see Figure 21) |zKA| Dynamic impedance (3) VKA = VREF, f ≤ 1 kHz, IK = 0.1 mA to 15 mA (see Figure 19) (1) (2) XB431 55 80 55 100 0.001 0.1 µA 0.25 0.4 Ω µA Full temperature ranges are –40°C to 125°C for XB431–40°C to 85°C for XB431 and 0°C to 70°C for XB431. The deviation parameters VREF(dev) and Iref(dev) are defined as the differences between the maximum and minimum values obtained over the rated temperature range. The average full-range temperature coefficient of the reference input voltage, αVREF, is defined as: VREF(dev ) æ ö 6 ç ÷ ´ 10 ppm ö è VREF (TA = 25°C ) ø æ aVREF ç ÷= DTA è °C ø where ΔTA is the rated operating free-air temperature range of the device. αVREF can be positive or negative, depending on whether minimum VREF or maximum VREF, respectively, occurs at the lower temperature. (3) µA DVKA The dynamic impedance is defined as zka = DIK spacer When the device is operating with two external resistors (see Figure 20), the total dynamic impedance of the circuit is defined as: z ka ¢= DV DI » z ka æ è ´ ç1 + R1 ö ÷ R2 ø 5 XB431-TL SOT23-3 7.7 Electrical Characteristics for XB431 at 25°C free-air temperature (unless otherwise noted) PARAMETER XB431 TEST CONDITIONS TA = 25°C VREF VKA = VREF, IK = 10 mA Reference voltage TA = full range (1) (see Figure 19) XB431 MIN TYP MAX 1.234 1.24 1.246 1.227 1.253 1.224 1.259 1.221 VREF(dev) DVREF VREF deviation over full temperature range (2) VKA = VREF , IK = 10 mA (1) (see Figure 19) Ratio of VREF change in cathode voltage change VKA = VREF to 6 V, IK = 10 mA (see Figure 20) Iref Reference terminal current IK = 10 mA, R1 = 10 kΩ, R2 = open (see Figure 20) Iref(dev) Iref deviation over full temperature range (2) IK = 10 mA, R1 = 10 kΩ, R2 = open (3) (see Figure 20) DVKA XB431 XB431 IK(min) Minimum cathode current for regulation VKA = VREF (see Figure 19) IK(off) Off-state cathode current VREF = 0, VKA = 6 V (see Figure 21) |zKA| Dynamic impedance (4) VKA = VREF, f ≤ 1 kHz, IK = 0.1 mA to 15 mA (see Figure 19) (1) (2) (3) (4) UNIT V 1.265 4 12 6 20 11 31 –1.5 –2.7 mV/V 0.1 0.5 µA 0.05 0.3 0.1 0.4 0.15 0.5 55 100 µA 0.001 0.1 µA 0.25 0.4 Ω mV µA Full temperature ranges are –40°C to 125°C for XB431, –40°C to 85°C for XB431, and 0°C to 70°C for XB431. The deviation parameters VREF(dev) and Iref(dev) are defined as the differences between the maximum and minimum values obtained over the rated temperature range. The average full-range temperature coefficient of the reference input voltage, αVREF, is defined as: VREF(dev ) æ ö 6 ç ÷ ´ 10 ppm ö è VREF (TA = 25°C ) ø æ aVREF ç ÷= DTA è °C ø where ΔTA is the rated operating free-air temperature range of the device. αVREF can be positive or negative, depending on whether minimum VREF or maximum VREF, respectively, occurs at the lower temperature. Full temperature ranges are –40°C to 125°C for XB431, –40°C to 85°C for XB431, and 0°C to 70°C for XB431. DVKA The dynamic impedance is defined as zka = DIK spacer When the device is operating with two external resistors (see Figure 20), the total dynamic impedance of the circuit is defined as: z ka ¢= DV DI » z ka æ è ´ ç1 + R1 ö ÷ R2 ø 6 XB431-TL SOT23-3 7.8 Typical Characteristics Operation of the device at these or any other conditions beyond those indicated in the Recommended Operating Conditions table are not implied. 250 1.254 IK = 10 mA R1 = 10 kΩ R2 = Open IK = 10 mA I ref − Reference Input Current − nA V ref − Reference Voltage − V 1.252 1.250 1.248 1.246 1.244 1.242 1.240 1.238 − 50 − 25 0 25 50 75 100 125 200 150 100 50 − 50 150 TJ − Junction Temperature − °C 0 25 50 75 100 125 TJ − Junction Temperature − °C 150 Figure 2. Reference Input Current vs Junction Temperature (for XB431) Figure 1. Reference Voltage vs Junction Temperature 15 250 VKA = VREF TA = 25°C IK = 10 mA R1 = 10 kΩ R2 = Open 230 210 10 I K − Cathode Current − mA I ref − Reference Input Current − nA − 25 190 170 150 130 110 90 5 0 −5 −10 70 50 −50 −25 0 25 50 75 100 125 −15 −1 150 TJ − Junction Temperature − °C 250 200 1.5 VKA = VREF TA = 25°C 150 I K − Cathode Current − µ A Ik(min) 0 0.5 1 VKA − Cathode Voltage − V Figure 4. Cathode Current vs Cathode Voltage Figure 3. Reference Input Current vs Junction Temperature (for XB431) 120 115 110 105 100 95 90 85 80 75 70 65 60 55 -40 −0.5 100 50 0 −50 − 100 − 150 − 200 -20 0 20 40 60 80 Temperature (qC) 100 120 140 − 250 −1 Figure 5. Minimum Cathode Current vs Temperature − 0.5 0 0.5 1 VKA − Cathode Voltage − V Figure 6. Cathode Current vs Cathode Voltage 7 1.5 XB431-TL SOT23-3 Typical Characteristics (continued) Operation of the device at these or any other conditions beyond those indicated in the Recommended Operating Conditions table are not implied. 3000 VKA = 5 V VREF = 0 I K(off) − Off-State Cathode Current − nA I K(off) − Off-State Cathode Current − nA 40 30 20 10 0 − 50 −25 0 25 50 75 100 125 VKA = 6 V VREF = 0 2500 2000 1500 1000 500 0 −50 150 −25 Figure 7. Off-State Cathode Current vs Junction Temperature (for XB431) ∆V ref/ ∆V KA − Ratio of Delta Reference Voltage to Delta Cathode Voltage − mV/V ∆V ref/ ∆V KA − Ratio of Delta Reference Voltage to Delta Cathode Voltage − mV/V 50 75 100 125 150 0.0 0 − 0.1 − 0.2 − 0.3 − 0.4 − 0.5 − 0.6 − 0.8 − 50 25 Figure 8. Off-State Cathode Current vs Junction Temperature (for XB431) 0 − 0.7 0 TJ − Junction Temperature − °C TJ − Junction Temperature − °C IK = 10 mA ∆VKA = VREF to 6 V − 25 0 25 50 75 100 125 150 TJ − Junction Temperature − °C −0.1 IK = 10 mA ∆VKA = VREF to 6 V −0.2 −0.3 −0.4 −0.5 −0.6 −0.7 −0.8 −0.9 −1 −1.0 −50 −25 0 25 50 75 100 125 150 TJ − Junction Temperature − °C Figure 9. Ratio of Delta Reference Voltage to Delta Cathode Voltage vs Junction Temperature (for XB431) Figure 10. Ratio of Delta Reference Voltage to Delta Cathode Voltage vs Junction Temperature (for XB431) 8 XB431-TL SOT23-3 Typical Characteristics (continued) Operation of the device at these or any other conditions beyond those indicated in the Recommended Operating Conditions table are not implied. 0.025 V ref − % Percentage Change in Vref IK = 1 mA % Change (avg) −0.025 % Change (3δ ) −0.05 −0.075 −0.1 % Change (−3δ) −0.125 0 10 20 30 40 50 60 Operating Life at 55°C − kh‡ ‡ Extrapolated from life-test data taken at 125°C; the activation energy assumed is 0.7 eV. Figure 11. Percentage Change in VREF vs Operating Life at 55°C Vn − Equivalent Input Noise Voltage − nV/ Hz 3V VKA = VREF IK = 1 mA TA = 25°C 1 kΩ 300 + 750 Ω 470 µF 2200 µF + 250 XB431 TLE2027 + _ TP 820 Ω 160 kΩ 160 Ω 200 TEST CIRCUIT FOR EQUIVALENT INPUT NOISE VOLTAGE 150 10 100 1k 10k 100k f − Frequency − Hz Figure 12. Equivalent Input Noise Voltage 9 XB431-TL SOT23-3 Typical Characteristics (continued) Operation of the device at these or any other conditions beyond those indicated in the Recommended Operating Conditions table are not implied. EQUIVALENT INPUT NOISE VOLTAGE OVER A 10-s PERIOD Vn − Equivalent Input Noise Voltage − µ V 10 f = 0.1 Hz to 10 Hz IK = 1 mA TA = 25°C 8 6 4 2 0 −2 −4 −6 −8 −10 0 2 4 6 8 10 t − Time − s 3V 1 kΩ + 470 µF 750 Ω 0.47 µF 2200 µF + 820 Ω TLV431 XB431 TLE2027 10 kΩ + _ 10 kΩ TLE2027 + _ 2.2 µF + 1 µF 160 kΩ CRO 1 MΩ 33 kΩ 16 Ω 0.1 µF 33 kΩ TEST CIRCUIT FOR 0.1-Hz TO 10-Hz EQUIVALENT NOISE VOLTAGE Figure 13. Equivalent Noise Voltage over a 10s Period 10 TP XB431-TL SOT23-3 Typical Characteristics (continued) Operation of the device at these or any other conditions beyond those indicated in the Recommended Operating Conditions table are not implied. 80 0° IK = 10 mA TA = 25°C 70 36° 60 72° 50 108° 40 144° 30 180° Phase Shift A V − Small-Signal Voltage Gain/Phase Margin − dB SMALL-SIGNAL VOLTAGE GAIN/PHASE MARGIN vs FREQUENCY µF Output IK 6.8 kΩ 180 Ω 10 5V 4.3 kΩ 20 10 GND 0 −10 −20 100 TEST CIRCUIT FOR VOLTAGE GAIN AND PHASE MARGIN 1k 10k 100k 1M f − Frequency − Hz Figure 14. Voltage Gain and Phase Margin REFERENCE IMPEDANCE vs FREQUENCY 100 |z ka | − Reference Impedance − Ω IK = 0.1 mA to 15 mA TA = 25°C 100 Ω Output 10 IK 100 Ω 1 − + GND 0.1 TEST CIRCUIT FOR REFERENCE IMPEDANCE 0.01 1k 10k 100k 1M 10M f − Frequency − Hz Figure 15. Reference Impedance vs Frequency 11 XB431-TL SOT23-3 Typical Characteristics (continued) Operation of the device at these or any other conditions beyond those indicated in the Recommended Operating Conditions table are not implied. PULSE RESPONSE 1 3.5 3 Input and Output Voltage − V R = 18 kΩ TA = 25°C Input 18 kΩ Output 2.5 Ik 2 1.5 Pulse Generator f = 100 kHz Output 50 Ω 1 GND 0.5 0 TEST CIRCUIT FOR PULSE RESPONSE 1 − 0.5 0 1 2 3 4 5 6 7 8 t − Time − µs Figure 16. Pulse Response 1 PULSE RESPONSE 2 3.5 3 Input and Output Voltage − V R = 1.8 kΩ TA = 25°C Input 1.8 kΩ Output 2.5 IK 2 1.5 Pulse Generator f = 100 kHz Output 50 Ω 1 GND 0.5 0 TEST CIRCUIT FOR PULSE RESPONSE 2 − 0.5 0 1 2 3 4 5 6 7 8 t − Time − µs Figure 17. Pulse Response 2 12 XB431-TL SOT23-3 Typical Characteristics (continued) Operation of the device at these or any other conditions beyond those indicated in the Recommended Operating Conditions table are not implied. STABILITY BOUNDARY CONDITION ‡ (forXB431) STABILITY BOUNDARY CONDITION ‡ (forXB431) 15 15 TA = 25°C IK = 15 mA Max VKA = VREF 12 9 Stable Stable VKA = 2 V 6 VKA = 3 V 3 0.1 1 TA = 25°C IK = 15 mA MAX For VKA = VREF , Stable for CL = 1 pF to 10k nF 0 0.001 10 CL − Load Capacitance − µF 0.01 0.1 1 CL − Load Capacitance − µF 150 Ω 150 Ω IK IK + CL Unstable 6 VKA = 3 V 0.01 VKA = 2 V 9 3 0 0.001 Stable Stable I K − Cathode Current − mA I K − Cathode Current − mA 12 − R1 = 10 kΩ CL Vbat R2 + − Vbat TEST CIRCUIT FOR VKA = 2 V, 3 V TEST CIRCUIT FOR VKA = VREF ‡ The areas under the curves represent conditions that may cause the device to oscillate. For VKA = 2-V and 3-V curves, R2 and Vbat were adjusted to establish the initial VKA and IK conditions with CL = 0. Vbat and CL then were adjusted to determine the ranges of stability. Figure 18. Stability Boundary Conditions 13 10 XB431-TL SOT23-3 8 Parameter Measurement Information VO Input IK VREF Figure 19. Test Circuit for VKA = VREF, VO = VKA = VREF xxx xxx xxx Input VO IK R1 R2 Iref VREF Figure 20. Test Circuit for VKA > VREF, VO = VKA = VREF × (1 + R1/R2) + Iref × R1 xxx xxx xxx Input VO IK(off) Figure 21. Test Circuit for IK(off) 14 XB431-TL SOT23-3 9 Detailed Description 9.1 Overview XB431 is a low power counterpart to XB431, having lower reference voltage (1.24 V vs 2.5 V) for lower voltage adjustability and lower minimum cathode current (Ik(min)=100 µA vs 1 mA). Like XB431, XB431 is used in conjunction with it's key components to behave as a single voltage reference, error amplifier, voltage clamp or comparator with integrated reference. XB431 can be operated and adjusted to cathode voltages from 1.24V to 6V, making this part optimum for a wide range of end equipments in industrial, auto, telecom & computing. In order for this device to behave as a shunt regulator or error amplifier, > 100 µA (Imin(max)) must be supplied in to the cathode pin. Under this condition, feedback can be applied from the Cathode and Ref pins to create a replica of the internal reference voltage. Various reference voltage options can be purchased with initial tolerances (at 25°C) of 0.5%, 1%, and 1.5%. These reference options are denoted by B (0.5%), A (1.0%) and blank (1.5%) after the XB431. The XB431 devices are characterized for operation from 0°C to 70°C, the XB431 devices are characterized for operation from –40°C to 85°C, and the XB431 devices are characterized for operation from –40°C to 125°C. 9.2 Functional Block Diagram CATHODE + REF _ Vref ANODE 9.3 Feature Description XB431 consists of an internal reference and amplifier that outputs a sink current base on the difference between the reference pin and the virtual internal pin. The sink current is produced by an internal darlington pair. When operated with enough voltage headroom (≥ 1.24 V) and cathode current (Ika), XB431 forces the reference pin to 1.24 V. However, the reference pin can not be left floating, as it needs Iref ≥ 0.5 µA (please see the Functional Block Diagram). This is because the reference pin is driven into an npn, which needs base current in order operate properly. When feedback is applied from the Cathode and Reference pins, XB431 behaves as a Zener diode, regulating to a constant voltage dependent on current being supplied into the cathode. This is due to the internal amplifier and reference entering the proper operating regions. The same amount of current needed in the above feedback situation must be applied to this device in open loop, servo or error amplifying implementations in order for it to be in the proper linear region giving XB431 enough gain. Unlike many linear regulators, XB431 is internally compensated to be stable without an output capacitor between the cathode and anode. However, if it is desired to use an output capacitor Figure 18 can be used as a guide to assist in choosing the correct capacitor to maintain stability. 15 XB431-TL SOT23-3 9.4 Device Functional Modes 9.4.1 Open Loop (Comparator) When the cathode/output voltage or current of XB431 is not being fed back to the reference/input pin in any form, this device is operating in open loop. With proper cathode current (Ika) applied to this device, XB431 will have the characteristics shown in Figure 6. With such high gain in this configuration, XB431 is typically used as a comparator. With the reference integrated makes XB431 the preferred choice when users are trying to monitor a certain level of a single signal. 9.4.2 Closed Loop When the cathode/output voltage or current of XB431 is being fed back to the reference/input pin in any form, this device is operating in closed loop. The majority of applications involving XB431 use it in this manner to regulate a fixed voltage or current. The feedback enables this device to behave as an error amplifier, computing a portion of the output voltage and adjusting it to maintain the desired regulation. This is done by relating the output voltage back to the reference pin in a manner to make it equal to the internal reference voltage, which can be accomplished via resistive or direct feedback. 16 XB431-TL SOT23-3 10 Applications and Implementation 10.1 Application Information Figure 22 shows the XB431 used in a 3.3-V isolated flyback supply. Output voltage VO can be as low as reference voltage VREF (1.24 V ± 1%). The output of the regulator, plus the forward voltage drop of the optocoupler LED (1.24 + 1.4 = 2.64 V), determine the minimum voltage that can be regulated in an isolated supply configuration. Regulated voltage as low as 2.7 Vdc is possible in the topology shown in Figure 22. The 431 family of devices are prevalent in these applications, being designers go to choice for secondary side regulation. Due to this prevalence, this section will further go on to explain operation and design in both states of XB431 that this application will see, open loop (Comparator + Vref) & closed loop (Shunt Regulator). Further information about system stability and using a XB431 device for compensation can be found in the application note Compensation Design With XB431 for UCC28600, SLUA671. ~ VI 120 V − + P ~ VO 3.3 V P P Gate Drive VCC Controller VFB XB431 Current Sense GND P P P P Figure 22. Flyback With Isolation Using XB431 as Voltage Reference and Error Amplifier 17 XB431-TL SOT23-3 10.2 Typical Applications 10.2.1 Comparator with Integrated Reference (Open Loop) Vsup Rsup Vout CATHODE R1 VIN RIN REF VL + R2 1.24 V ANODE Figure 23. Comparator Application Schematic 10.2.1.1 Design Requirements For this design example, use the parameters listed in Table 1 as the input parameters. Table 1. Design Parameters DESIGN PARAMETER EXAMPLE VALUE Input Voltage Range 0 V to 5 V Input Resistance 10 kΩ Supply Voltage 5V Cathode Current (Ik) 500 µA Output Voltage Level ~1 V - Vsup Logic Input Thresholds VIH/VIL VL 10.2.1.2 Detailed Design Procedure When using XB431 as a comparator with reference, determine the following: • Input voltage range • Reference voltage accuracy • Output logic input high and low level thresholds • Current source resistance 10.2.1.2.1 Basic Operation In the configuration shown in Figure 23 XB431 will behave as a comparator, comparing the Vref pin voltage to the internal virtual reference voltage. When provided a proper cathode current (Ik), XB431 will have enough open loop gain to provide a quick response. With the XB431 max Operating Current (Imin) being 100 uA and up to 150 uA over temperature, operation below that could result in low gain, leading to a slow response. 18 XB431-TL SOT23-3 10.2.1.2.2 Overdrive Slow or inaccurate responses can also occur when the reference pin is not provided enough overdrive voltage. This is the amount of voltage that is higher than the internal virtual reference. The internal virtual reference voltage will be within the range of 1.24V ±(0.5%, 1.0% or 1.5%) depending on which version is being used. The more overdrive voltage provided, the faster the XB431 will respond. This can be seen in figures Figure 24 and Figure 25, where it displays the output responses to various input voltages. For applications where XB431 is being used as a comparator, it is best to set the trip point to greater than the positive expected error (i.e. +1.0% for the A version). For fast response, setting the trip point to > 10% of the internal Vref should suffice. For minimal voltage drop or difference from Vin to the ref pin, it is recommended to use an input resistor < 10 kΩ to provide Iref. 10.2.1.2.3 Output Voltage and Logic Input Level In order for XB431 to properly be used as a comparator, the logic output must be readable by the recieving logic device. This is accomplished by knowing the input high and low level threshold voltage levels, typically denoted by VIH & VIL. As seen in Figure 24, XB431 output low level voltage in open-loop/comparator mode is ~1 V, which is sufficient for some 3.3V supplied logic. However, would not work for 2.5 V and 1.8 V supplied logic. In order to accommodate this a resistive divider can be tied to the output to attenuate the output voltage to a voltage legible to the receiving low voltage logic device. XB431 output high voltage is approximately Vsup due to TLV431 being open-collector. If Vsup is much higher than the receiving logic's maximum input voltage tolerance, the output must be attenuated to accommodate the outgoing logic's reliability. When using a resistive divider on the output, be sure to make the sum of the resistive divider (R1 & R2 in Figure 23) is much greater than Rsup in order to not interfere with XB431 ability to pull close to Vsup when turning off. 10.2.1.2.3.1 Input Resistance XB431 requires an input resistance in this application in order to source the reference current (Iref) needed from this device to be in the proper operating regions while turning on. The actual voltage seen at the ref pin will be Vref=Vin-Iref*Rin. Since Iref can be as high as 0.5 µA it is recommended to use a resistance small enough that will mitigate the error that Iref creates from Vin. 12 11 10 9 8 7 6 5 4 3 2 1 0 -1 -2 -0.4 10 Vin~1.24V (+/-5%) Vo(Vin=1.18V) Vo(Vin=1.24V) Vo(Vin=1.30V) 9 Vo(Vin=5.0V) Vin=5.0V 8 7 6 Voltage (V) Voltage (V) 10.2.1.3 Application Curves 5 4 3 2 1 0 -1 -0.2 0 0.2 0.4 Time (ms) 0.6 -2 -0.4 0.8 D001 Figure 24. Output Response with Small Overdrive Voltages 19 -0.2 0 0.2 0.4 Time (ms) 0.6 0.8 D001 Figure 25. Output Response with Large Overdrive Voltage XB431-TL SOT23-3 10.2.2 Shunt Regulator/Reference VSUP RSUP VO = ( 1 + R1 0.1% CATHODE REF Vr ef R1 ) Vref R2 R2 0.1% XB431 TL431 ANODE CL Figure 26. Shunt Regulator Schematic 10.2.2.1 Design Requirements For this design example, use the parameters listed in Table 2 as the input parameters. Table 2. Design Parameters DESIGN PARAMETER EXAMPLE VALUE Reference Initial Accuracy 1.0% Supply Voltage 6V Cathode Current (Ik) 1 mA Output Voltage Level 1.24 V - 6 V Load Capacitance 100 nF Feedback Resistor Values and Accuracy (R1 & R2) 10 kΩ 10.2.2.2 Detailed Design Procedure When using XB431 as a Shunt Regulator, determine the following: • Input voltage range • Temperature range • Total accuracy • Cathode current • Reference initial accuracy • Output capacitance 10.2.2.2.1 Programming Output/Cathode Voltage In order to program the cathode voltage to a regulated voltage a resistive bridge must be shunted between the cathode and anode pins with the mid point tied to the reference pin. This can be seen in Figure 26, with R1 & R2 being the resistive bridge. The cathode/output voltage in the shunt regulator configuration can be approximated by the equation shown in Figure 26. The cathode voltage can be more accuratel determined by taking in to account the cathode current: VO=(1+R1/R2)*Vref–Iref*R1 In order for this equation to be valid, XB431 must be fully biased so that it has enough open loop gain to mitigate any gain error. This can be done by meeting the Imin spec denoted in Recommended Operating Conditions table. 20 XB431-TL SOT23-3 10.2.2.2.2 Total Accuracy When programming the output above unity gain (Vka=Vref), XB431 is susceptible to other errors that may effect the overall accuracy beyond Vref. These errors include: • • • • R1 and R2 accuracies VI(dev) - Change in reference voltage over temperature ΔVref / ΔVKA - Change in reference voltage to the change in cathode voltage |zKA| - Dynamic impedance, causing a change in cathode voltage with cathode current Worst case cathode voltage can be determined taking all of the variables in to account. Application note SLVA445 assists designers in setting the shunt voltage to achieve optimum accuracy for this device. 10.2.2.2.3 Stability Though XB431 is stable with no capacitive load, the device that receives the shunt regulator's output voltage could present a capacitive load that is within the XB431 region of stability, shown in Figure 18. Also, designers may use capacitive loads to improve the transient response or for power supply decoupling. Voltage (V) 10.2.2.3 Application Curves 6.5 6 5.5 5 4.5 4 3.5 3 2.5 2 1.5 1 0.5 0 -0.5 -1 Vsup Vka=Vref R1=10k: & R2=10k: 0 1 2 3 4 5 Time (Ps) 6 7 Figure 27. XB431 Start-up Response 21 8 9 D001 XB431-TL SOT23-3 11 Power Supply Recommendations When using XB431 as a Linear Regulator to supply a load, designers will typically use a bypass capacitor on the output/cathode pin. When doing this, be sure that the capacitance is within the stability criteria shown in Figure 18. In order to not exceed the maximum cathode current, be sure that the supply voltage is current limited. Also, be sure to limit the current being driven into the Ref pin, as not to exceed it's absolute maximum rating. For applications shunting high currents, pay attention to the cathode and anode trace lengths, adjusting the width of the traces to have the proper current density. 12 Layout 12.1 Layout Guidelines Place decoupling capacitors as close to the device as possible. Use appropriate widths for traces when shunting high currents to avoid excessive voltage drops. 12.2 Layout Example DBZ (TOP VIEW) Rref Vin REF 1 Rsup Vsup ANODE 3 CATHODE 2 CL GND Figure 28. DBZ Layout Example 22 GND XB431-TL SOT23-3 23 22
XB431-TL 价格&库存
很抱歉,暂时无法提供与“XB431-TL”相匹配的价格&库存,您可以联系我们找货
XB431-TL
  • 1+5.63500
库存:115
XB431-TL
    • 10+0.32957
    库存:60
