SELC3F5V2U
SELC3F5V2U
    ELECSUPER(静芯微)
    DFN1006-3L
    ESD保护 0.6pF DFN1006-3L Pppk=80W VC=25V Ipp=4A VRWM=5V
SELC3F5V2U 数据手册
SELC3F5V2U Rev-2021-1 www.elecsuper.com SuperESD – SELC3F5V2U 1. Description The SELC3F5V2U is a low capacitance TVS designed to protect high speed data interface. It has been specifically designed to protect sensitive electronic components which are connected to data and transmission lines from over-stress caused by ESD. The SELC3F5V2U incorporates one pair of steering diodes of low capacitance plus a TVS diode. 2. Features  IEC 61000-4-2 Level 4 ESD Protection  Working voltage: 5V - ±15kV Contact Discharge  Low leakage current - ±10kV Air Discharge  RoHS compliant  80W Peak pulse Power (8/20us)  Protecting two Uni-directional lines  Low clamping voltage  Junction capacitance: 0.6pF Typ. 3. Applications  USB 2.0 and USB 3.0  PCI Express  SATA and eSATA  Notebooks  DVI  HDMI 1.3 and HDMI 1.4  IEEE 1394 4. Ordering Information Part Number Package Marking Material Packing SELC3F5V2U DFN1006 -3L |L05 Halogen free Tape & Reel Table-1 Copyright© ElecSuper Incorporated Quantity per reel 10,000 PCS Flammability Rating Reel Size UL 94V-0 7 inches Ordering information Contact Us 1 / 7 SELC3F5V2U Rev-2021-1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description Outline 1 IO Connect to IO L05 Circuit Diagram 1 2 IO Connect to IO 3 3 2 3 GND Connect to GND Table-2 1 2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 80 W Peak pulse current (tp=8/20us)@25℃ IPP 4 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±15 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±10 kV TJ - 125 ℃ Operating temperature TOP -40 85 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 SELC3F5V2U Rev-2021-1 www.elecsuper.com 6.2. Electrical Characteristics At TA = 25℃ unless otherwise noted Parameter Symbol Conditions Reverse Stand-off Voltage Reverse Breakdown Voltage Min. Typ. VRWM Max. Units 5 V VBR IT=1mA 6.0 V Reverse Leakage Current IR VRWM=5V Clamping Voltage VC IPP=1A; tp=8/20us 10 V Clamping Voltage VC IPP=4A; tp=8/20us 25 V Junction Capacitance CJ I/O to GND; VR=0V; f=1MHz 0.6 pF 1 uA Table-4 Electrical Characteristics Symbol VRWM IR VBR Parameters Peak Reverse Working Voltage Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP IF Forward Current VF Forward Voltage @ IF Copyright© ElecSuper Incorporated Contact Us 3 / 7 SELC3F5V2U Rev-2021-1 www.elecsuper.com 7. Typical Characteristic 8. Typical Application Typical Interface Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 SELC3F5V2U Rev-2021-1 www.elecsuper.com 9. Dimension DFN1006-3L Units in millimeters SYMBOL A B B1 B2 D E e L1 L2 L3 L4 MIN 0.40 0.00 0.10 0.45 0.90 0.50 0.20 0.20 0.25 Table-6 Copyright© ElecSuper Incorporated NOM 0.45 0.02 0.15 0.50 1.00 0.60 0.35 BSC 0.25 0.25 0.39 BSC 0.30 MAX 0.50 0.05 0.20 0.55 1.05 0.65 0.30 0.30 0.35 product dimensions Contact Us 5 / 7 SELC3F5V2U Rev-2021-1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 6 / 7 SELC3F5V2U Rev-2021-1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application, (2) designing, validating and testing your application (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products Copyright© ElecSuper Incorporated Contact Us 7 / 7
SELC3F5V2U 价格&库存
很抱歉,暂时无法提供与“SELC3F5V2U”相匹配的价格&库存,您可以联系我们找货
