SEUC10F3V4U
SEUC10F3V4U
    ELECSUPER(静芯微)
    DFN2510-10
    SEUC10F3V4U设计用于保护电压敏感元件免受ESD和瞬态电压事件的影响。
SEUC10F3V4U 数据手册
SEUC10F3V4U Rev-2021-1 www.elecsuper.com SuperESD - SEUC10F3V4U 1.Description The SEUC10F3V4U is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability. Low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. 2.Features    IEC 61000-4-2 Level 4 ESD Protection  RoHS compliance - ±12kV Contact Discharge  Protecting four I/O line - ±17kV Air Discharge  Ultra-low Capacitance:0.6pF (Typical) IEC 61000-4-4 EFT Protection  Low clamping voltage - 40A (5/50ns)  Low leakage current IEC 61000-4-5 Surge  Solid-state silicon technology - 4.5A (8/20us) 3.Applications  HDMI/USB2.0  Notebook computers  Monitors and flat panel displays  SIM ports  10/100/1000 ethernet  ATM interface 4.Ordering Information Part Number Package Marking SEUC10F3V4U DFN2510-10L .3324P Table-1 Copyright© ElecSuper Incorporated Material Packing Halogen Tape & free Reel Quantity Flammability per reel Rating 3K PCS UL 94V-0 Reel Size 7 inches Ordering information Contact Us 1 / 7 SEUC10F3V4U Rev-2021-1 www.elecsuper.com 5.Pin Configuration and Functions Pin Name Description Outline 1 IO Connect to IO 2 IO Connect to IO 3 GND Connect to GND 4 IO Connect to IO 5 IO Connect to IO 6 NC NO Connection 7 NC NO Connection 8 GND Connect to GND 9 NC NO Connection 10 NC NO Connection Circuit Diagram 3324P 1 2 4 5 3, 8 Table-2 Pin configuration 6.Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 60 W Peak pulse current (tp=8/20us)@25℃ IPP 4.5 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±17 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±12 kV TJ - 125 ℃ Operating temperature TOP -40 85 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 SEUC10F3V4U Rev-2021-1 www.elecsuper.com 6.2. Eletrical Characteristics At TA = 25℃ unless otherwise noted Parameters Symbol conditions Min. Typ. Reverse stand-off voltage VRWM Reverse Breakdown Voltage VBR IT= 1mA Reverse Leakage Current IR VRWM=3.3V Clamping Voltage VCL IPP=1A; TP=8/20us 8.5 Clamping Voltage VCL IPP=4.5A; TP=8/20us 12 Max. Unit 3.3 V 4.0 V 1 uA V I/O pins to ground; VR=0V; f = 1MHz Junction capacitance 0.6 pF CJ Between I/O pins; VR=0V; f = 1MHz Table-4 Symbol VRWM IR VBR 0.3 Electrical Characteristics Parameters Peak Reverse Working Voltage Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP IF Forward Current VF Forward Voltage @ IF Copyright© ElecSuper Incorporated Contact Us 3 / 7 SEUC10F3V4U Rev-2021-1 www.elecsuper.com 7.Typical Characteristic 8.Typical Application Typical HDMI Interface Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 SEUC10F3V4U Rev-2021-1 www.elecsuper.com 9.Dimension DNF2510-10L Symbol A A1 A2 b b1 b2 L1 φ Min. 0.500 0.00 0.122 0.150 0.200 0.350 0.150 Nom. 0.550 / 0.152 0.200 0.250 0.400 0.075 0.200 Dimensions in Millimeter Max. Symbol 0.600 D 0.05 E 0.200 e 0.250 h 0.300 k 0.450 L L2 0.250 Table-5 Copyright© ElecSuper Incorporated Min. 2.450 0.950 0.450 0.080 0.150 0.350 Nom. 2.500 1.00 0.500 0.120 0.200 0.400 0.05 Max. 2.550 1.050 0.550 0.150 0.250 0.450 Product dimensions Contact Us 5 / 7 SEUC10F3V4U Rev-2021-1 www.elecsuper.com 10.Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 6 / 7 SEUC10F3V4U Rev-2021-1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application, (2) designing, validating and testing your application (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
SEUC10F3V4U 价格&库存
很抱歉,暂时无法提供与“SEUC10F3V4U”相匹配的价格&库存,您可以联系我们找货
