SENC23T12V2U
SENC23T12V2U
    ELECSUPER(静芯微)
    SOT-23
    TVS 阵列 100pF SOT23 Ppk=350W VC=28V Ipp=15A VRWM=12V
SENC23T12V2U 数据手册
SENC23Txx2U Rev-2021-1 www.elecsuper.com SuperESD - SENC23Txx2U 1. Description The SENC23Txx2U is a Transient Voltage Suppressor Arrays that designed to protect components which are connected to data and transmission lines against electrostatic discharge (ESD), electrical fast Transients (EFT), and lightning. All pins are rated to withstand 30kV ESD pulses using the IEC61000-4-2 are discharge method. 2. Features  IEC 61000-4-2 Level 4 ESD Protection - ±30kV Contact Discharge - ±30kV Air Discharge Protects one bidirectional or two  Unidirectional lines  Low leakage current  450W Peak pulse Power (8/20us)  ESD protection > 15kV  Low clamping voltage  RoHS compliant 3. Applications  Portable electronic  Set-top box  Control & monitoring systems  Communications systems  Servers, notebooks, and desktop PCs 4. Ordering Information Part Number Package Material Packing SENC23Txx2U SOT-23 Halogen free Tape & Reel Quantity per reel 3,000 PCS Flammability Rating Reel Size UL 94V-0 7 inches Marking for the SENC23Txx2U series VRWM 3.3V 5V 7V 12V 15V 24V 36V Marking M03 M05 M07 M12 M15 M24 M36 Table-1 Copyright© ElecSuper Incorporated Ordering information Contact Us 1 / 7 SENC23Txx2U Rev-2021-1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description Outline 1 IO Connect to IO 2 IO Connect to IO 3 GND Connect to GND Circuit Diagram 3 3 Marking 1 Table-2 2 1 2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 450 W Peak pulse current (tp=8/20us)@25℃ IPP Refer to Table-5 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±30 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±30 kV TJ - 125 ℃ Operating temperature TOP -40 85 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 SENC23Txx2U Rev-2021-1 www.elecsuper.com 6.2. Electrical Characteristics Symbol Description VRWM Rated reverse stand-off voltage VBR Minimum breakdown voltage @IT = 1mA VCL Clamping voltage IPP Maximum peak pulse current IR Reverse leakage current @VRWM CO Typical line capacitance (VIO=0V, VP-P = 30mV, f = 1MHz) Table-4 Parameters Description At TA = 25℃ unless otherwise noted VRWM VBR VCL@I=1A IPP VCL@I=IPP IR CO (V) (V) (V) (A) (V) (uA) (pF) SENC23T3V2U 3.3 4.5 9 32 18 1.0 300 SENC23T5V2U 5 6 9 30 18 1.0 220 SENC23T7V2U 7 7.5 9 25 20 1.0 180 SENC23T12V2U 12 13.5 18 15 28 1.0 100 SENC23T15V2U 15 16.5 22 11 33 1.0 80 SENC23T24V2U 24 26.5 33 6 48 1.0 60 SENC23T36V2U 36 40 55 3 65 1.0 50 Part Number Table-5 Copyright© ElecSuper Incorporated Electrical Characteristics for All Series Contact Us 3 / 7 SENC23Txx2U Rev-2021-1 www.elecsuper.com 7. Typical Characteristic 8. Typical Application Typical Interface Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 SENC23Txx2U Rev-2021-1 www.elecsuper.com 9. Dimension SOT-23 Symbol A A1 b C D E E1 e Dimensions in Millimeters Max. Symbol 1.15 e1 0.10 L 0.50 L1 θ 0.15 3.00 1.40 2.55 Min. 0.9 0.00 0.30 0.08 2.80 1.20 2.25 Min. 1.80 Max. 2.00 0.55REF 0.30 0° 0.50 8° 0.95TYP Table-5 Copyright© ElecSuper Incorporated Product dimensions Contact Us 5 / 7 SENC23Txx2U Rev-2021-1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 6 / 7 SENC23Txx2U Rev-2021-1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application, (2) designing, validating and testing your application (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products Copyright© ElecSuper Incorporated Contact Us 7 / 7
SENC23T12V2U
1. 物料型号:SENC23Txx2U,是瞬态电压抑制二极管阵列,用于保护数据和传输线上的元件免受静电放电(ESD)、电气快速瞬变(EFT)和雷击。
2. 器件简介:符合IEC 61000-4-2标准,提供4级ESD保护,可保护双向或两条单向线路,具有低漏电流、450W峰值脉冲功率、低钳位电压和符合RoHS标准。
3. 引脚分配:共有3个引脚,1和2引脚连接到IO,3引脚连接到GND。
4. 参数特性:包括额定反向电压(VRWM)、最小击穿电压(VBR)、钳位电压(VcL)、最大峰值脉冲电流(lpp)、反向漏电流(IR)和典型线路电容(Co)。
5. 功能详解:提供了详细的电气特性表,包括不同型号的VRWM、VBR、VcL、lpp、IR和Co参数。
6. 应用信息:适用于便携式电子设备、机顶盒、控制与监控系统、通信系统、服务器、笔记本电脑和台式电脑。
7. 封装信息:采用SOT-23封装,提供无卤素选项,每卷3000个元件,UL 94V-0阻燃等级,卷径7英寸。
8. 典型应用:展示了一个典型的接口应用电路图。
9. 尺寸信息:提供了SOT-23封装的详细尺寸表。
10. 推荐焊盘图案:提供了推荐的焊盘布局图。
11. 免责声明:ElecSuper提供技术和可靠性数据、设计资源、应用或其他设计建议、安全信息等资源,但不提供任何明示或暗示的保证。
SENC23T12V2U 价格&库存
很抱歉,暂时无法提供与“SENC23T12V2U”相匹配的价格&库存,您可以联系我们找货
