SENC23T5V2UC
SENC23T5V2UC
    ELECSUPER(静芯微)
    SOT-23
    TVS阵列 120pF SOT23 Ppk=350W VC=20V Ipp=16A VRWM=5V
SENC23T5V2UC 数据手册
SENC23T5V2UC Rev-2021-1 www.elecsuper.com SuperESD - SENC23T5V2UC 1. Description The SENC23T5V2UC is a Transient Voltage Suppressor Arrays that designed to protect components which are connected to data and transmission lines against electrostatic discharge (ESD), electrical fast Transients (EFT), and lightning. All pins are rated to withstand 30kV ESD pulses using the IEC61000-4-2 air discharge method. 2. Features  IEC 61000-4-2 Level 4 ESD Protection  Low leakage current - ±30kV Contact Discharge  ESD Protection > 15kV - ±30kV Air Discharge  RoHS compliant  Protecting one bidirectional or two  350W Peak pulse Power (8/20us)  Low clamping voltage  Working voltage: 5V unidirectional lines 3. Applications  Portable electronics  Set-top box  Control & monitoring systems  Communication systems  Servers, notebooks, and desktop PCs 4. Ordering Information Part Number SENC23T5V2UC Package Marking Material Packing SOT-23 Halogen free Tape & Reel M05 Table-1 Copyright© ElecSuper Incorporated Quantity per reel 3,000 PCS Flammability Rating Reel Size UL 94V-0 7 inches Ordering information Contact Us 1 / 7 SENC23T5V2UC Rev-2021-1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description 1 IO Connect to IO 2 IO Connect to IO 3 GND Outline Circuit Diagram 3 1 M05 1 Connect to GND Table-2 3 2 2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 350 W Peak pulse current (tp=8/20us)@25℃ IPP 16 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±30 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±30 kV TJ - 125 ℃ Operating temperature TOP -40 85 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 SENC23T5V2UC Rev-2021-1 www.elecsuper.com 6.2. Electrical Characteristics At TA = 25℃ unless otherwise noted Parameter Symbol Reverse Stand-off Voltage Conditions Min. VRWM Reverse Breakdown Voltage VBR IT=1mA 6 Typ. Max. Units 5 V 9.5 V Reverse Leakage Current IR VRWM=5V 1 uA Clamping Voltage VC IPP=1A; tp=8/20us 9 V Clamping Voltage VC IPP=16A; tp=8/20us 20 V Junction Capacitance CJ VR=0V; f=1MHz 120 pF Table-4 Electrical Characteristics Symbol VRWM IR VBR Parameters Peak Reverse Working Voltage Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP IF Forward Current VF Forward Voltage @ IF Copyright© ElecSuper Incorporated Contact Us 3 / 7 SENC23T5V2UC Rev-2021-1 www.elecsuper.com 7. Typical Characteristic 8. Typical Application Typical Interface Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 SENC23T5V2UC Rev-2021-1 www.elecsuper.com 9. Dimension SOT-23 Symbol A A1 b C D E E1 e Dimensions in Millimeters Max. Symbol 1.15 e1 0.10 L 0.50 L1 θ 0.15 3.00 1.40 2.55 Min. 0.9 0.00 0.30 0.08 2.80 1.20 2.25 Min. 1.80 Max. 2.00 0.55REF 0.30 0° 0.50 8° 0.95TYP Table-5 Copyright© ElecSuper Incorporated Product dimensions Contact Us 5 / 7 SENC23T5V2UC Rev-2021-1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 6 / 7 SENC23T5V2UC Rev-2021-1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application, (2) designing, validating and testing your application (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products Copyright© ElecSuper Incorporated Contact Us 7 / 7
SENC23T5V2UC 价格&库存
很抱歉,暂时无法提供与“SENC23T5V2UC”相匹配的价格&库存,您可以联系我们找货
