SENC23Txx2U
Rev-2021-1
www.elecsuper.com
SuperESD - SENC23Txx2U
1. Description
The SENC23Txx2U is a Transient Voltage Suppressor Arrays that designed to protect components
which are connected to data and transmission lines against electrostatic discharge (ESD), electrical
fast Transients (EFT), and lightning. All pins are rated to withstand 30kV ESD pulses using the
IEC61000-4-2 are discharge method.
2. Features
IEC 61000-4-2 Level 4 ESD Protection
±30kV Contact Discharge
±30kV Air Discharge
Protects one bidirectional or two
Unidirectional lines
Low leakage current
450W Peak pulse Power (8/20us)
ESD protection > 15kV
Low clamping voltage
RoHS compliant
3. Applications
Portable electronic
Set-top box
Control & monitoring systems
Communications systems
Servers, notebooks, and desktop PCs
4. Ordering Information
Part Number
Package
Material
Packing
SENC23Txx2U
SOT-23
Halogen
free
Tape &
Reel
Quantity
per reel
3,000
PCS
Flammability
Rating
Reel
Size
UL 94V-0
7 inches
Marking for the SENC23Txx2U series
VRWM
3.3V
5V
7V
12V
15V
24V
36V
Marking
M03
M05
M07
M12
M15
M24
M36
Table-1
Copyright© ElecSuper Incorporated
Ordering information
Contact Us
1 / 7
SENC23Txx2U
Rev-2021-1
www.elecsuper.com
5. Pin Configuration and Functions
Pin
Name
Description
Outline
1
IO
Connect to IO
2
IO
Connect to IO
3
GND
Connect to GND
Circuit Diagram
3
3
Marking
1
Table-2
2
1
2
Pin configuration
6. Specification
6.1. Absolute Maximum rating
Over operating free-air temperature range (unless otherwise noted)
Parameters
Symbol
Min.
Max.
Unit
Peak pulse power (tp=8/20us)@25℃
Ppk
450
W
Peak pulse current (tp=8/20us)@25℃
IPP
Refer to
Table-5
A
ESD (IEC61000-4-2 air discharge) @25℃
VESD
±30
kV
ESD (IEC61000-4-2 contact discharge) @25℃
VESD
±30
kV
TJ
125
Operating temperature
TOP
-40
85
Storage temperature
TSTG
-55
150
TL
260
Junction temperature
Lead temperature
Table-3
Contact Us
2 / 7
SENC23Txx2U
Rev-2021-1
www.elecsuper.com
6.2. Electrical Characteristics
Symbol
Description
VRWM
Rated reverse stand-off voltage
VBR
Minimum breakdown voltage @IT = 1mA
VCL
Clamping voltage
IPP
Maximum peak pulse current
IR
Reverse leakage current @VRWM
CO
Typical line capacitance (VIO=0V, VP-P = 30mV, f = 1MHz)
Table-4
Parameters Description
At TA = 25℃ unless otherwise noted
VRWM
VBR
VCL@I=1A
IPP
VCL@I=IPP
IR
CO
(V)
(V)
(V)
(A)
(V)
(uA)
(pF)
SENC23T3V2U
3.3
4.5
9
32
18
1.0
300
SENC23T5V2U
5
6
9
30
18
1.0
220
SENC23T7V2U
7
7.5
9
25
180
SENC23T12V2U
12
13.5
18
15
28
1.0
100
SENC23T15V2U
15
16.5
22
11
33
1.0
80
SENC23T24V2U
24
26.5
33
6
48
1.0
60
SENC23T36V2U
36
40
55
3
65
1.0
50
Part Number
Table-5
Electrical Characteristics for All Series
Contact Us
3 / 7
SENC23Txx2U
Rev-2021-1
www.elecsuper.com
7. Typical Characteristic
8. Typical Application
Typical Interface Application
Contact Us
4 / 7
SENC23Txx2U
Rev-2021-1
www.elecsuper.com
9. Dimension
SOT-23
Symbol
A
A1
b
C
D
E
E1
e
Dimensions in Millimeters
Max.
Symbol
1.15
e1
0.10
L
0.50
L1
θ
0.15
3.00
1.40
2.55
Min.
0.9
0.00
0.30
0.08
2.80
1.20
2.25
Min.
1.80
Max.
2.00
0.55REF
0.30
0°
0.50
8°
0.95TYP
Table-5
Product dimensions
Contact Us
5 / 7
SENC23Txx2U
Rev-2021-1
www.elecsuper.com
10. Recommended Land Pattern
Note:
1. Controlling dimension: in millimeters
2. General tolerance: ±0.05mm
3. The pad layout is for reference only
Contact Us
6 / 7
SENC23Txx2U
Rev-2021-1
www.elecsuper.com
DISCLAIMER
ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES
(INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER
RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING
WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE
OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS.
These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for
(1) selecting the appropriate ElecSuper products for your application,
(2) designing, validating and testing your application
(3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources
are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an
application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are
prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right.
ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims,
damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to
ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such
ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable
warranties or warranty disclaimers for ElecSuper products
Contact Us
7 / 7
很抱歉,暂时无法提供与“SENC23T5V2U”相匹配的价格&库存,您可以联系我们找货
