SENC23T3V2B
SENC23T3V2B
    ELECSUPER(静芯微)
    SOT-23
    反向关断电压(典型值):3.3V(Max) 击穿电压(最小值):4.5V 箝位电压:8.5V 峰值脉冲电流:24A (8/20us) 极性:Bidirectional
SENC23T3V2B 数据手册
SENC23Txx2B Rev-2021-1 www.elecsuper.com SuperESD - SENC23Txx2B 1. Description The SENC23Txx2B is a Transient Voltage Suppressor Arrays that designed to protect components which are connected to data and transmission lines against electrostatic discharge (ESD), electrical fast Transients (EFT), and lightning. All pins are rated to withstand 15kV ESD pulses using the IEC61000-4-2 are discharge method. 2. Features  IEC 61000-4-2 Level 4 ESD Protection - ±15kV Contact Discharge - ±15kV Air Discharge Protects two bidirectional or two  Unidirectional lines  450W Peak pulse Power (8/20us)  Low clamping voltage  Low leakage current  RoHS compliant 3. Applications  Portable electronic  Set-top box  Control & monitoring systems  Communications systems  Servers, notebooks, and desktop PCs  Cellular handsets and accessories 4. Ordering Information Part Number Package Material Packing Quantity per reel Flammability Rating Reel Size SENC23Txx2B SOT-23 Halogen free Tape & Reel 3,000 PCS UL 94V-0 7 inches Marking for the SENC23Txx2U series VRWM 3.3V 5V 8V 12V 15V 18V 24V 36V Marking C03 C05 C08 C12 C15 C18 C24 C36 Table-1 Copyright© ElecSuper Incorporated Ordering information Contact Us 1 / 7 SENC23Txx2B Rev-2021-1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description Outline 1 IO Connect to IO 2 IO Connect to IO 3 GND Connect to GND Circuit Diagram 3 3 Marking 1 Table-2 2 1 2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 450 W Peak pulse current (tp=8/20us)@25℃ IPP Refer to Table-5 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±15 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±15 kV TJ - 125 ℃ Operating temperature TOP -40 85 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 SENC23Txx2B Rev-2021-1 www.elecsuper.com 6.2. Electrical Characteristics Symbol Description VRWM Rated reverse stand-off voltage VBR Minimum breakdown voltage @IT = 1mA VCL Typical Clamping voltage IPP Maximum peak pulse current IR Reverse leakage current @VRWM CO Typical line capacitance (VIO=0V, VP-P = 30mV, f = 1MHz) Table-4 Parameters Description At TA = 25℃ unless otherwise noted VRWM VBR VCL@I=1A IPP VCL@I=IPP IR CO (V) (V) (V) (A) (V) (uA) (pF) SENC23T3V2B 3.3 4.5 8.5 24 22.0 1.0 120 SENC23T5V2B 5 6.5 9.5 20 22.0 1.0 120 SENC23T8V2B 8 8.5 11.0 15 28.0 1.0 110 SENC23T12V2B 12 13.3 20.0 12 37.0 1.0 70 SENC23T15V2B 15 16.5 25.0 9.0 55.0 1.0 40 SENC23T18V2B 18 19.5 30.0 7.0 56.0 1.0 35 SENC23T24V2B 24 26.0 40.0 6.0 63.0 1.0 30 SENC23T36V2B 36 38 55.0 4.0 72.0 1.0 25 Part Number Table-5 Copyright© ElecSuper Incorporated Electrical Characteristics for All Series Contact Us 3 / 7 SENC23Txx2B Rev-2021-1 www.elecsuper.com 7. Typical Characteristic 8. Typical Application Typical Interface Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 SENC23Txx2B Rev-2021-1 www.elecsuper.com 9. Dimension SOT-23 Symbol A A1 b C D E E1 e Dimensions in Millimeters Max. Symbol 1.15 e1 0.10 L 0.50 L1 θ 0.15 3.00 1.40 2.55 Min. 0.9 0.00 0.30 0.08 2.80 1.20 2.25 Min. 1.80 Max. 2.00 0.55REF 0.30 0° 0.50 8° 0.95TYP Table-5 Copyright© ElecSuper Incorporated Product dimensions Contact Us 5 / 7 SENC23Txx2B Rev-2021-1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 6 / 7 SENC23Txx2B Rev-2021-1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application, (2) designing, validating and testing your application (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products Copyright© ElecSuper Incorporated Contact Us 7 / 7
SENC23T3V2B 价格&库存
很抱歉,暂时无法提供与“SENC23T3V2B”相匹配的价格&库存,您可以联系我们找货
