SENC5D15V1UA
SENC5D15V1UA
    ELECSUPER(静芯微)
    SOD-523(SC-79)
    SENC5Dxx1UA是一种瞬态电压抑制器,用于保护连接到数据和传输线的部件免受静电放电(ESD)、电快速瞬态(EFT)和雷电的影响。
SENC5D15V1UA 数据手册
SENC5Dxx1UA Rev-2021-1 www.elecsuper.com SuperESD – SENC5Dxx1UA 1. Description The SENC5Dxx1UA is a Transient Voltage Suppressor that designed to protect components which are connected to data and transmission lines against electrostatic discharge (ESD), electrical fast Transients (EFT), and lightning. All pins are rated to withstand 30kV ESD pulses using the IEC610004-2 air discharge methods. 2. Features  IEC 61000-4-2 Level 4 ESD Protection  Unidirectional configuration - ±30kV Contact Discharge  Low clamping voltage - ±30kV Air Discharge  Low leakage current  Protects one power or I/O  250W Peak pulse Power (8/20us)  RoHS compliance 3. Applications  Portable electronics  Set-top box  Control & monitoring systems  Communication systems  Servers, notebooks, and desktop PCs  Digital cameras 4. Ordering Information Part Number Package Material Packing Quantity per reel Flammability Rating Reel Size SENC5Dxx1UA SOD523 Halogen Tape & Reel 3000 PCS UL 94V-0 7 inches Marking for the SEHC3Fxx1U series VRWM 3.3V 5V 7V 12V 15V 24V Marking ||||N1 |KE Z.H.8 ||||N3 ||||N4 ||||N5 Table-1 Copyright© ElecSuper Incorporated Ordering information Contact Us 1 / 6 SENC5Dxx1UA Rev-2021-1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description 1 IO Connect to IO Outline 1 2 GND Marking Circuit Diagram 2 1 2 Connect to GND Table-2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 250 W Peak pulse current (tp=8/20us)@25℃ IPP - ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±30 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±30 kV TJ - 125 ℃ Operating temperature TOP -40 85 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Refer to Table-5 A Absolute Maximum rating Contact Us 2 / 6 SENC5Dxx1UA Rev-2021-1 www.elecsuper.com 6.2. Electrical Characteristics Symbol Description VRWM Rated reverse stand-off voltage VBR Minimum breakdown voltage @IT = 1mA VCL Typical Clamping voltage IPP Maximum peak pulse current IR Reverse leakage current @VRWM CO Typical line capacitance (VIO=0V, VP-P = 30mV, f = 1MHz) Table-4 Parameters Description At TA = 25℃ unless otherwise noted VRWM VBR VCL@I=1A IPP VCL@I=IPP IR CO (V) (V) (V) (A) (V) (uA) (pF) SENC5D3V1UA 3.3 4.5 8.5 16.0 18.0 1.0 200 SENC5D5V1UA 5.0 6.5 9.5 15.0 20.0 1.0 180 SENC5D7V1UA 7.0 7.5 11.0 12.0 22.0 1.0 140 SENC5D12V1UA 12.0 13.3 20.0 8.0 35.0 1.0 100 SENC5D15V1UA 15.0 16.5 25.0 6.0 45.0 1.0 60 SENC5D24V1UA 24.0 26.0 40.0 4.0 55.0 1.0 40 Part Number Table-5 Copyright© ElecSuper Incorporated Electrical Characteristics for All Series Contact Us 3 / 6 SENC5Dxx1UA Rev-2021-1 www.elecsuper.com 7. Typical Characteristic 8. Typical Application Pic-3 Copyright© ElecSuper Incorporated Typical Internet 1G Interface Application Contact Us 4 / 6 SENC5Dxx1UA Rev-2021-1 www.elecsuper.com 9. Dimension SOD-523 Units: Millimeters Unit Max. Min. A 0.77 0.51 A1 0.70 0.50 b 0.35 0.25 c 0.15 0.08 Table-6 D 0.85 0.75 E 1.30 1.10 E1 1.70 1.50 E2 0.20 REF. L 0.07 0.01 θ 7° REF. product dimensions 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 5 / 6 SENC5Dxx1UA Rev-2021-1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application, (2) designing, validating and testing your application (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products Copyright© ElecSuper Incorporated Contact Us 6 / 6
SENC5D15V1UA 价格&库存
很抱歉,暂时无法提供与“SENC5D15V1UA”相匹配的价格&库存,您可以联系我们找货
