SENC5D5V1BA
SENC5D5V1BA
    ELECSUPER(静芯微)
    SOD-523(SC-79)
    SENC5D5V1BA旨在保护电压敏感元件免受ESD造成的损坏或闭锁。优秀的箝位能力、低泄漏和快速响应时间为暴露于ESD的设计提供了最佳的板级保护。
SENC5D5V1BA 数据手册
SENC5D5V1BA Rev-2021-1 www.elecsuper.com SuperESD - SENC5D5V1BA 1. Description The SENC5D5V1BA is designed to protect voltage sensitive components from damage or latch-up due to ESD. Excellent clamping capability, low leakage, and fast response time provide best in class protection on designs that are exposed to ESD for board level. Because of its small size and bidirectional design, it is ideal for use in cellular phones, MP3 players, and portable applications that require audio line protection. 2. Features  IEC 61000-4-2 Level 4 ESD Protection  Working voltage: 5V - ±25kV Contact Discharge  Low leakage current - ±25kV Air Discharge  RoHS compliant  80W Peak pulse Power (8/20us)  Protecting one bi-directional lines  Low clamping voltage  Junction capacitance: 15pF Typ. 3. Applications  Cellular handsets and accessories  Digital cameras  Portable digital assistants  MP3 players  Notebooks & handhelds  Peripherals 4. Ordering Information Part Number Package Marking Material Packing SENC5D5V1BA SOD-523 DT Halogen free Tape & Reel Table-1 Copyright© ElecSuper Incorporated Quantity per reel 3,000 PCS Flammability Rating Reel Size UL 94V-0 7 inches Ordering information Contact Us 1 / 7 SENC5D5V1BA Rev-2021-1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description Outline 1 IO1 Connect to IO 1 2 IO2 Connect to IO Table-2 DT Circuit Diagram 2 1 2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 80 W Peak pulse current (tp=8/20us)@25℃ IPP 8 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±25 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±25 kV TJ - 125 ℃ Operating temperature TOP -40 85 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 SENC5D5V1BA Rev-2021-1 www.elecsuper.com 6.2. Electrical Characteristics At TA = 25℃ unless otherwise noted Parameter Symbol Conditions Reverse Stand-off Voltage Reverse Breakdown Voltage Min. Typ. VRWM Max. Units 5 V VBR IT=1mA 5.8 V Reverse Leakage Current IR VRWM=5V Clamping Voltage VC IPP=1A; tp=8/20us 6 V Clamping Voltage VC IPP=8A; tp=8/20us 10 V Junction Capacitance CJ I/O to GND; VR=0V; f=1MHz 15 pF 1 uA Table-4 Electrical Characteristics Symbol VRWM IR VBR Parameters Peak Reverse Working Voltage Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP IF Forward Current VF Forward Voltage @ IF Copyright© ElecSuper Incorporated Contact Us 3 / 7 SENC5D5V1BA Rev-2021-1 www.elecsuper.com 7. Typical Characteristic 8. Typical Application Typical Interface Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 SENC5D5V1BA Rev-2021-1 www.elecsuper.com 9. Dimension SOD-523 Unit A A1 b c D E E1 E2 L θ Max. 0.77 0.70 0.35 0.15 0.85 1.30 1.70 0.20 0.07 7° Min. 0.51 0.50 0.25 0.08 0.75 1.10 1.50 REF. 0.01 REF. Table-5 Copyright© ElecSuper Incorporated Product dimensions in millimeter Contact Us 5 / 7 SENC5D5V1BA Rev-2021-1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only 4. Unit: mm Copyright© ElecSuper Incorporated Contact Us 6 / 7 SENC5D5V1BA Rev-2021-1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application, (2) designing, validating and testing your application (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products Copyright© ElecSuper Incorporated Contact Us 7 / 7
SENC5D5V1BA 价格&库存
很抱歉,暂时无法提供与“SENC5D5V1BA”相匹配的价格&库存,您可以联系我们找货
SENC5D5V1BA
  • 20+0.13803
  • 200+0.10887
  • 600+0.09267
  • 3000+0.08295
  • 9000+0.07452
  • 21000+0.06999
库存:30705
