SELC363T5V4UA
SELC363T5V4UA
    ELECSUPER(静芯微)
    SOT363
    反向关断电压(典型值):5V(Max) 击穿电压(最小值):6V 箝位电压:8.5V 峰值脉冲电流:4A (8/20us) 极性:Unidirectional
SELC363T5V4UA 数据手册
SELC363T5V4UA Rev-2021-1 www.elecsuper.com SuperESD - SELC363T5V4UA 1. Description The SELC363T5V4UA is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. 2. Features  IEC 61000-4-2 Level 4 ESD Protection  Working voltage: 5V - ±12kV Contact Discharge  Low leakage current - ±17kV Air Discharge  RoHS compliant  60W Peak pulse Power (8/20us)  Protecting 4 unidirectional lines  Low clamping voltage  Capacitance: 0.8pF Typ. 3. Applications  Cellular Handsets and Accessories  Notebooks & Handhelds  Cordless Phones  Digital Cameras  Personal Digital Assistants (PDA’s)  Portable Instrumentation 4. Ordering Information Part Number SELC363T5V4UA Package Marking SOT363 .B54 Material Packing Halogen free Tape & Reel Table-1 Copyright© ElecSuper Incorporated Quantity per reel 3,000 PCS Flammability Rating Reel Size UL 94V-0 7 inches Ordering information Contact Us 1 / 7 SELC363T5V4UA Rev-2021-1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description 1 IO1 2 GND 3 IO2 Connect to I/O 4 IO3 Connect to I/O 5 Vcc Connect to Vcc 6 IO5 Connect to I/O Outline Circuit Diagram Connect to I/O Connect to GND 5 6 4 5 B54 1 Table-2 2 6 1 3 4 2 3 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 60 W Peak pulse current (tp=8/20us)@25℃ IPP 4 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±17 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±12 kV TJ - 125 ℃ Operating temperature TOP -40 85 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 SELC363T5V4UA Rev-2021-1 www.elecsuper.com 6.2. Electrical Characteristics At TA = 25℃ unless otherwise noted Parameter Symbol Conditions Reverse Stand-off Voltage Reverse Breakdown Voltage Min. Typ. VRWM Max. Units 5 V VBR IT=1mA Reverse Leakage Current IR VRWM=5V Clamping Voltage VC IPP=1A; tp=8/20us 10 V Clamping Voltage VC IPP=4A; tp=8/20us 15 V I/O to GND; VR=0V; f=1MHz 0.8 pF Between I/O; VR=0V; f=1MHz 0.4 pF Junction Capacitance CJ Table-4 Symbol VRWM IR VBR 6 V 1 uA Electrical Characteristics Parameters Peak Reverse Working Voltage Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP IF Forward Current VF Forward Voltage @ IF Copyright© ElecSuper Incorporated Contact Us 3 / 7 SELC363T5V4UA Rev-2021-1 www.elecsuper.com 7. Typical Characteristic 8. Typical Application Typical Interface Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 SELC363T5V4UA Rev-2021-1 www.elecsuper.com 9. Dimension SOT-363 Unit: mm Symbol Min Spec Max Symbol Min Spec Max A 0.900 1.100 E 1.150 1.350 A1 0.000 0.100 E1 2.150 2.450 Table-5 Copyright© ElecSuper Incorporated A2 0.900 1.000 e 0.650 REF b 0.150 0.350 e1 1.200 1.400 c 0.080 0.150 L 0.525 REF D 2.000 2.200 L1 0.2600 0.4600 θ 0° 8° - Product dimensions in millimeter Contact Us 5 / 7 SELC363T5V4UA Rev-2021-1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 6 / 7 SELC363T5V4UA Rev-2021-1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application, (2) designing, validating and testing your application (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products Copyright© ElecSuper Incorporated Contact Us 7 / 7
SELC363T5V4UA 价格&库存
很抱歉,暂时无法提供与“SELC363T5V4UA”相匹配的价格&库存,您可以联系我们找货
