SELC143T5V2UA
SELC143T5V2UA
    ELECSUPER(静芯微)
    SOT-143
    超低电容双轨对轨静电放电(ESD)保护二极管SOT143 Ppk=75W VC=18V Ipp=8A VRWM=5V CJ=1.2pF
SELC143T5V2UA 数据手册
SELC143T5V2UA Rev-2021-1 www.Elecsuper.com SuperESD - SELC143T5V2UA 1. Description The SELC143T5V2UA is Ultra low capacitance double rail-to-rail Electro Static Discharge (ESD) protection diode in a small SOT143 Surface Mounted Device (SMD) plastic package designed to protect two Hi-Speed data lines or high frequency signal lines from the damage caused by ESD and other transients. 2. Features  IEC 61000-4-2 Level 4 ESD Protection  Protect two I/O lines - ±15kV Contact Discharge  Low operating and clamping voltage - ±15kV Air Discharge  Low leakage current  Solid-state silicon technology  IEC61000-4-4 (EFT) 40A (5/50ns)  IEC61000-4-5 (Surge) 5A (8/20μs) 3. Applications  USB 2.0  Digital cameras  DVI and HDMI interfaces  PCs, notebooks, printers and other PC  Mobile and cordless phones  Personal Digital Assistants (PDA) peripherals 4. Ordering Information Part Number Package Marking SELC143T5V2UA SOT-143 R05 Flammability per reel Rating Packing Halogen Tape & 3,000 free Reel PCS Table-1 Copyright© ElecSuper Incorporated Quantity Material UL 94V-0 Reel Size 7 inches Ordering information Contact Us 1 / 7 SELC143T5V2UA Rev-2021-1 www.Elecsuper.com 5. Pin Configuration and Functions Pin Name Description Outline 1 GND Connect to GND 2 IO Connect to IO 3 IO Connect to IO 4 Vcc Connect to Vcc 4 Circuit Diagram 3 4 3 1 2 R05 1 Table-2 2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 75 W Peak pulse current (tp=8/20us)@25℃ IPP 5 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±15 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±15 kV TJ - 125 ℃ Operating temperature TOP -40 85 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 SELC143T5V2UA Rev-2021-1 www.Elecsuper.com 6.2. Electrical Characteristics At TA = 25℃ unless otherwise noted Parameter Symbol Reverse Stand-off Voltage VRWM Reverse Breakdown Voltage VBR IT=1mA Reverse Leakage Current IR VRWM=5V Clamping Voltage VC IPP=1A; tp=8/20us 10 V Clamping Voltage VC IPP=5A; tp=8/20us 15 V Junction Capacitance CJ 0.6 pF Junction Capacitance CJ 1.2 pF Table-4 Conditions VR=0V; f=1MHz I/O pin to I/O pin VR=0V; f=1MHz I/O pin to GND Typ. Max. Units 5 V 6 V 1 uA Electrical Characteristics Symbol Parameters VRWM Peak Reverse Working Voltage IR Reverse Leakage Current @ VRWM VBR Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP IF Forward Current VF Forward Voltage @ IF Copyright© ElecSuper Incorporated Min. Contact Us 3 / 7 SELC143T5V2UA Rev-2021-1 www.Elecsuper.com 7. Typical Characteristic 8. Typical Application Typical Interface Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 SELC143T5V2UA Rev-2021-1 www.Elecsuper.com 9. Dimension SOT-143 All dimension in millimeters Symbol A B C D E F G H J K Min 2.70 1.10 0.90 0.78 1.80 0.37 1.59 0.02 0.05 2.20 Max 3.10 1.50 1.10 0.88 2.00 0.43 1.79 0.10 0.15 2.60 Table-5 Copyright© ElecSuper Incorporated Product dimensions Contact Us 5 / 7 SELC143T5V2UA Rev-2021-1 www.Elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 6 / 7 SELC143T5V2UA Rev-2021-1 www.Elecsuper.com DISCLAIMER ELECSUPER SUPERESD PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper SuperESD products. You are solely responsible for (1) selecting the appropriate ElecSuper SuperESD products for your application, (2) designing, validating and testing your application (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper SuperESD grants you permission to use these resources only for development of an application that uses the ElecSuper SuperESD products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper SuperESD intellectual property right or to any third party intellectual property right. ElecSuper SuperESD disclaims responsibility for, and you will fully indemnify ElecSuper SuperESD and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper SuperESD’s products are provided subject to ElecSuper SuperESD’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper SuperESD products. ElecSuper SuperESD’s provision of these resources does not expand or otherwise alter ElecSuper SuperESD’s applicable warranties or warranty disclaimers for ElecSuper SuperESD products Copyright© ElecSuper Incorporated Contact Us 7 / 7
SELC143T5V2UA 价格&库存
很抱歉,暂时无法提供与“SELC143T5V2UA”相匹配的价格&库存,您可以联系我们找货
