SELC23T5V2U
SELC23T5V2U
    ELECSUPER(静芯微)
    SOT-23
    TVS阵列 0.6pF SOT23 Ppk=60W VC=15V Ipp=4A VRWM=5V
SELC23T5V2U 数据手册
SELC23T5V2U Rev-2021-1 www.elecsuper.com SuperESD - SELC23T5V2U 1. Description The SELC23T5V2U is an ultra-low capacitance TVS (Transient Voltage Suppressor) array designed to protect high speed data interfaces. It has been specifically designed to protect sensitive electronic components which are connected to data and transmission lines from over-stress caused by ESD (Electrostatic Discharge). 2. Features ⚫ IEC 61000-4-2 Level 4 ESD Protection ⚫ Working voltage: 5V - ±15kV Contact Discharge ⚫ RoHS compliant - ±10kV Air Discharge ⚫ Protecting two unidirectional lines ⚫ Low clamping voltage ⚫ 30W Peak pulse Power (8/20us) ⚫ Low leakage current 3. Applications ⚫ Portable electronics ⚫ DVI ⚫ USB 2.0 and USB 3.0 ⚫ IEEE 1394 ⚫ HDMI 1.3 and HDMI 1.4 ⚫ PCI Express ⚫ SATA and eSATA ⚫ Notebooks 4. Ordering Information Part Number SELC23T5V2U Package Marking Material Packing Quantity per reel Flammability Rating Reel Size SOT-23 Halogen free Tape & Reel 3,000 PCS UL 94V-0 7 inches R22 Table-1 Copyright© ElecSuper Incorporated Ordering information Contact Us 1 / 7 SELC23T5V2U Rev-2021-1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description Outline 1 IO Connect to IO 2 IO Connect to IO 3 GND Connect to GND Circuit Diagram 2 3 R22 1 3 2 1 Table-2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 30 W Peak pulse current (tp=8/20us)@25℃ IPP 3 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±15 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±10 kV TJ - 125 ℃ Operating temperature TOP -40 85 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 SELC23T5V2U Rev-2021-1 www.elecsuper.com 6.2. Electrical Characteristics At TA = 25℃ unless otherwise noted Parameter Symbol Reverse Stand-off Voltage Conditions Min. Typ. VRWM Reverse Breakdown Voltage Max. Units 5 V VBR IT=1mA Reverse Leakage Current IR VRWM=5V Clamping Voltage VC IPP=1A; tp=8/20us 10 V Clamping Voltage VC IPP=3A; tp=8/20us 15 V Junction Capacitance CJ VR=0V; f=1MHz 0.6 pF Table-4 Electrical Characteristics Symbol VRWM IR VBR 6 V 1 uA Parameters Peak Reverse Working Voltage Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP IF Forward Current VF Forward Voltage @ IF Copyright© ElecSuper Incorporated Contact Us 3 / 7 SELC23T5V2U Rev-2021-1 www.elecsuper.com 7. Typical Characteristic 8. Typical Application Typical Interface Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 SELC23T5V2U Rev-2021-1 www.elecsuper.com 9. Dimension SOT-23 Symbol A A1 b C D E E1 e Dimensions in Millimeters Max. Symbol 1.15 e1 0.10 L 0.50 L1 θ 0.15 3.00 1.40 2.55 Min. 0.9 0.00 0.30 0.08 2.80 1.20 2.25 Min. 1.80 Max. 2.00 0.55REF 0.30 0° 0.50 8° 0.95TYP Table-5 Copyright© ElecSuper Incorporated Product dimensions Contact Us 5 / 7 SELC23T5V2U Rev-2021-1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 6 / 7 SELC23T5V2U Rev-2021-1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application, (2) designing, validating and testing your application (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products Copyright© ElecSuper Incorporated Contact Us 7 / 7
SELC23T5V2U 价格&库存
很抱歉,暂时无法提供与“SELC23T5V2U”相匹配的价格&库存,您可以联系我们找货
