XA213-G4J SOT363 (SC-76-6)
Applications
l
Pin Out
GND
L ow insertion loss (0.4 dB @ 2.4 GHz)
Isolation 22 dB @ 2.4 GHz
l Low DC power consumption
l PHEMT process
l Operates with 1.8 V control voltage
5
Features
6
CBL
2
J3
1
T /R switch in WLANs, BluetoothÒ and medium-power
telecommunication applications
V2
CBL
J1
l
CBL
4
3
J2
l
V1
bl
bl
DC blocking capacitors (C ) must be supplied externally for positive voltage operation.
C = 100 pF for operation >500 MHz.
Description
The XA213-G4J is a medium-power IC FET SPDT switch in a lowcost miniature SC-70 6-lead plastic package. The AS213-92
features low insertion loss and positive voltage operation with
very low DC power consumption. This general-purpose switch
can be used in a variety of telecommunications applications.
Electrical Specifications at 25 °C (0, 3 V)
Parameter(1)
loss(2)
Frequency
Min. Typ.
Max.
Unit
0.5
0.6
0.7
dB
dB
dB
0.1–1.0 GHz
1.0–2.0 GHz
2.0–3.0 GHz
0.3
0.4
0.5
Isolation
0.1–1.0 GHz
1.0–2.0 GHz
2.0–3.0 GHz
27
23
19
VSWR(3)
0.1–1.0 GHz
1.0–3.0 GHz
24
1.3:1
1.4:1
dB
dB
dB
Insertion
1. All measurements made in a 50 W system, unless otherwise specified.
2. Insertion loss changes by 0.003 dB/°C.
3. Insertion loss state.
1
XA213-G4J SOT363(SC-76-6)
Operating Characteristics at 25 °C (0, 3 V)
Parameter
Condition
Frequency
Min. Typ.
Max.
Switching characteristics
Rise, fall
On, off
Video feedthru
10/90% or 90/10% RF
50% CTL to 90/10% RF
TRISE = 1 ns, BW = 500 MHz
Input power for 1 dB compression
0/1.8 V
0/3 V
Intermodulation intercept point (IP3)
For two-tone input power 5 dBm
0/3 V
0.5–3 GHz
40
0.5–3 GHz
0.5–3 GHz
Thermal resistance
V
V
high
low
Control voltages
Unit
10
ns
ns
mV
dBm
dBm
25
dBm
°C/W
= 0 to 0.2 V @ 20 µA max.
= 1.8 V @ 100 µA max. to 5 V @ 200 mA max.
-0.25
-15
-0.50
-20
Isolation (dB)
Insertion Loss (dB)
Simulated Performance Data (0, 3 V)
-0.75
-1.00
-1.25
-1.75
-45
-50
0.5
1.0
1.5
2.0
2.5
3.0
1.0
1.5
2.0
2.5
Insertion Loss vs. Frequency
Isolation vs. Frequency
1.3
VSWR
0.5
Frequency (GHz)
1.4
1.2
1.1
1.0
Frequency (GHz)
1.5
0.5
1.0
1.5
2.0
Frequency (GHz)
VSWR vs. Frequency
-35
-40
-1.50
-2.00
2
-25
2.5
3.0
3.0
Absolute Maximum Ratings
Value
V1
V2
J1–J2
J1–J3
2 W max. for f > 500 MHz
500 mW for f < 500 MHz
VCTL = 0/8 V
Vhigh
Isolation
Insertion loss
Insertion loss
Isolation
Supply voltage
8V
Control voltage
-0.2 V, +8 V
Operating temperature
-40 °C to +85 °C
Storage temperature
-65 °C to +150 °C
V
high
Characteristic
RF input power
Any state other than described in the truth table will put the device in an undefined state.
An undefined state will not damage the device.
V
= 1.8 to 5 V.
high
Truth Table
Performance is guaranteed only under the conditions listed in the specifications table and is
not guaranteed under the full range(s) described by the Absolute Maximum specifications.
Exceeding any of the absolute maximum/minimum specifications may result in permanent
damage to the device and will void the warranty.
CAUTION: A lthough this device is designed to be as robust as
possible, ESD (Electrostatic Discharge) can damage
this device. This device must be protected at all
times from ESD. Static charges may easily produce
potentials of several kilovolts on the human body or
equipment, which can discharge without detection.
Industry-standard ESD precautions must be employed
at all times.
3
很抱歉,暂时无法提供与“XA213-G4J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.89748
- 50+0.70676
- 150+0.61139
- 500+0.53979
