XD74LS04
XD74LS04
    XINLUDA(信路达)
    DIP-14
    这些器件包含六个独立的反相器。
XD74LS04 数据手册
XL74LS04 SOP14/XD74LS04/DIP14 XD54LS04 DIP14 XL74LS04 XD74LS04 XD54LS04 (TOP VIEW) 1 14 2 13 3 12 4 11 5 10 6 9 7 8 VCC 6A 6Y 5A 5Y 4A 4Y 2A NC 2Y NC 3A XD54LS04 . . . W PACKAGE (TOP VIEW) 1 14 2 13 3 12 VCC 3A 3Y 4A 4 11 5 10 6 9 7 8 1Y 6A 6Y GND 5Y 5A 4Y 4 3 2 1 20 19 18 5 17 6 16 7 15 8 14 9 10 11 12 13 6Y NC 5A NC 5Y 3Y GND NC 4Y 4A 1A 2Y 2A XD54LS04 . . . FK PACKAGE (TOP VIEW) 1Y 1A NC VCC 6A 1A 1Y 2A 2Y 3A 3Y GND NC − No internal connection ORDERING INFORMATION PACKAGE† TA ORDERABLE PART NUMBER TOP-SIDE MARKING Tube PDIP − N Tube XD74LS04 XD74LS04 Tube Tube 7404 Tape and reel Tube 0°C 0 C to 70 70°C C SOIC − D Tape and reel XL74LS04 LS04 Tube S04 Tape and reel Tape and reel SOP − NS Tape and reel SSOP − DB SN7404 Tape and reel Tape and reel 74LS04 XL74LS04NS 74S04 LS04 Tube Tube Tube CDIP − J Tube Tube Tube −55°C −55 C to 125 125°C C Tube CFP − W Tube Tube Tube LCCC − FK Tube 1 XL74LS04 SOP14/XD74LS04/DIP14 XD54LS04 DIP14 FUNCTION TABLE (each inverter) INPUT A OUTPUT Y H L L H logic diagram (positive logic) 1A 1Y 2A 2Y 3A 3Y 4A 4Y 5A 5Y 6A 6Y Y=A 2 XL74LS04 SOP14/XD74LS04/DIP14 XD54LS04 DIP14 schematics (each gate) ’04 VCC 4 kΩ 130 Ω 1.6 kΩ Input A Output Y 1 kΩ GND ’LS04 ’S04 VCC 20 kΩ 120 Ω 8 kΩ Input A VCC 4 kΩ 2.8 kΩ Output Y 50 Ω 900 Ω Input A 3.5 kΩ Output Y 12 kΩ 500 Ω 250 Ω 3 kΩ 1.5 kΩ GND GND Resistor values shown are nominal. 3 XL74LS04 SOP14/XD74LS04/DIP14 XD54LS04 DIP14 absolute maximum ratings over operating free-air temperature range (unless otherwise noted)† Supply voltage, VCC (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 V Input voltage, VI: ’04, ’S04 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.5 V ’LS04 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 V Package thermal impedance, θJA (see Note 2): D package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86°C/W DB package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 96°C/W N package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80°C/W NS package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 76°C/W Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −65°C to 150°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. This are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTES: 1. Voltage values are with respect to network ground terminal. 2. The package thermal impedance is calculated in accordance with JESD 51-7. recommended operating conditions (see Note 3) XD54LS04 VCC VIH Supply voltage VIL IOH Low-level input voltage IOL TA Low-level output current High-level input voltage XL74LS04 MIN NOM MAX MIN NOM MAX 4.5 5 5.5 4.75 5 5.25 2 2 High-level output current −55 V V 0.8 0.8 V −0.4 −0.4 mA 16 mA 70 °C 16 Operating free-air temperature UNIT 125 0 NOTE 3: All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Implications of Slow or Floating CMOS Inputs, literature number SCBA004. electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) TEST CONDITIONS‡ PARAMETER VIK VOH VCC = MIN, VCC = MIN, II = − 12 mA VIL = 0.8 V, VOL II VCC = MIN, VCC = MAX, VIH = 2 V, VI = 5.5 V IIH IIL VCC = MAX, VCC = MAX, VI = 2.4 V VI = 0.4 V IOS¶ ICCH VCC = MAX ICCL VCC = MAX, VCC = MAX, MIN XD54LS04 TYP§ MAX XL74LS04 TYP§ MAX −1.5 IOH = −0.4 mA IOL = 16 mA 2.4 3.4 0.2 −1.5 2.4 0.4 3.4 0.2 1 −20 VI = 0 V VI = 4.5 V MIN UNIT V V 0.4 1 V mA 40 40 µA −1.6 −1.6 mA −55 mA −55 −18 6 12 6 12 mA 18 33 18 33 mA ‡ For conditions shown as MIN or MAX, use the appropriate value specified under recommended operating conditions. § All typical values are at VCC = 5 V, TA = 25°C. ¶ Not more than one output should be shorted at a time. 4 XL74LS04 SOP14/XD74LS04/DIP14 XD54LS04 DIP14 switching characteristics, VCC = 5 V, TA = 25°C (see Figure 1) PARAMETER tPLH tPHL FROM (INPUT) TO (OUTPUT) A Y XD54LS04 XL74LS04 TEST CONDITIONS MIN RL = 400 Ω, CL = 15 pF UNIT TYP MAX 12 22 8 15 ns recommended operating conditions (see Note 3) XD54LS04 SN54LS04 VCC VIH Supply voltage VIL IOH Low-level input voltage IOL TA Low-level output current High-level input voltage XL74LS04 MIN NOM MAX MIN NOM MAX 4.5 5 5.5 4.75 5 5.25 2 2 High-level output current −55 V V 0.7 0.8 V −0.4 −0.4 mA 8 mA 70 °C 4 Operating free-air temperature UNIT 125 0 NOTE 3: All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Implications of Slow or Floating CMOS Inputs, literature number SCBA004. electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) XD54LS04 TYP‡ MAX TEST CONDITIONS† PARAMETER MIN XL74LS04 TYP‡ MAX MIN −1.5 VIK VOH VCC = MIN, VCC = MIN, II = − 18 mA VIL = MAX, VOL VCC = MIN, VIH = 2 V II IIH VCC = MAX, VCC = MAX, VI = 7 V VI = 2.7 V 0.1 0.1 20 20 µA IIL IOS§ VCC = MAX, VCC = MAX VI = 0.4 V −0.4 −0.4 mA −100 mA ICCH ICCL VCC = MAX, VCC = MAX, VI = 0 V VI = 4.5 V IOH = −0.4 mA IOL = 4 mA 2.5 3.4 0.25 −1.5 UNIT 2.7 3.4 0.4 0.25 −20 −100 V 0.4 IOL = 8 mA −20 V 0.5 V mA 1.2 2.4 1.2 2.4 mA 3.6 6.6 3.6 6.6 mA † For conditions shown as MIN or MAX, use the appropriate value specified under recommended operating conditions. ‡ All typical values are at VCC = 5 V, TA = 25°C. § Not more than one output should be shorted at a time, and the duration of the short-circuit should not exceed one second. switching characteristics, VCC = 5 V, TA = 25°C (see Figure 2) PARAMETER tPLH tPHL 5 FROM (INPUT) TO (OUTPUT) A Y TEST CONDITIONS XD54LS04 XL74LS04 MIN RL = 2 kΩ, CL = 15 pF UNIT TYP MAX 9 15 10 15 ns XL74LS04 SOP14/XD74LS04/DIP14 XD54LS04 DIP14 recommended operating conditions (see Note 3) XD54LS04 MIN NOM 4.5 MAX MIN 5.5 4.75 Supply voltage VIL IOH Low-level input voltage 0.8 0.8 V High-level output current −1 −1 mA IOL TA Low-level output current 20 mA 70 °C 2 5 2 −55 125 V V 20 Operating free-air temperature 5.25 UNIT VCC VIH High-level input voltage 5 XL74LS04 NOM MAX 0 NOTE 3: All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Implications of Slow or Floating CMOS Inputs, literature number SCBA004. electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) TEST CONDITIONS† PARAMETER VIK VOH VCC = MIN, VCC = MIN, II = − 18 mA VIL = 0.8 V, VOL II VCC = MIN, VCC = MAX, VIH = 2 V, VI = 5.5 V IIH IIL VCC = MAX, VCC = MAX, VI = 2.7 V VI = 0.5 V IOS§ ICCH VCC = MAX ICCL MIN XD54LS04 TYP‡ MAX XL74LS04 TYP‡ MAX −1.2 IOH = −1 mA IOL = 20 mA 2.5 3.4 −40 VCC = MAX, VCC = MAX, MIN VI = 0 V VI = 4.5 V −1.2 2.7 3.4 UNIT V V 0.5 0.5 1 1 V mA 50 50 µA −2 −2 mA −100 mA −100 −40 15 24 15 24 mA 30 54 30 54 mA † For conditions shown as MIN or MAX, use the appropriate value specified under recommended operating conditions. ‡ All typical values are at VCC = 5 V, TA = 25°C. § Not more than one output should be shorted at a time, and the duration of the short-circuit should not exceed one second. switching characteristics, VCC = 5 V, TA = 25°C (see Figure 1) FROM (INPUT) TO (OUTPUT) tPLH tPHL A Y RL = 280 Ω, CL = 15 pF tPLH tPHL A Y RL = 280 Ω, CL = 50 pF PARAMETER XD54LS04 XL74LS04 TEST CONDITIONS MIN UNIT TYP MAX 3 4.5 3 5 4.5 5 ns ns PARAMETER MEASUREMENT INFORMATION SERIES 54/74 AND 54S/74S DEVICES VCC RL From Output Under Test CL (see Note A) Test Point LOAD CIRCUIT FOR OPEN-COLLECTOR OUTPUTS 6 XL74LS04 SOP14/XD74LS04/DIP14 XD54LS04 DIP14 PARAMETER MEASUREMENT INFORMATION SERIES 54LS/74LS DEVICES VCC Test Point VCC RL From Output Under Test CL (see Note A) CL (see Note A) LOAD CIRCUIT FOR 2-STATE TOTEM-POLE OUTPUTS High-Level Pulse 1.3 V 5 kΩ Test Point S2 LOAD CIRCUIT FOR OPEN-COLLECTOR OUTPUTS LOAD CIRCUIT FOR 3-STATE OUTPUTS 3V Timing Input 1.3 V S1 (see Note B) CL (see Note A) RL (see Note B) RL From Output Under Test VCC From Output Under Test Test Point 1.3 V 0V tw Low-Level Pulse 1.3 V tsu Data Input 1.3 V VOLTAGE WAVEFORMS PULSE DURATIONS 1.3 V 1.3 V Output Control (low-level enabling) 0V tPLH In-Phase Output (see Note D) 1.3 V 0V 3V 1.3 V 1.3 V 0V tPZL tPLZ tPHL VOH 1.3 V 1.3 V Waveform 1 (see Notes C and D) VOL tPZH tPLH VOH 1.3 V 1.3 V VOL VOLTAGE WAVEFORMS PROPAGATION DELAY TIMES Waveform 2 (see Notes C and D) ≈1.5 V 1.3 V VOL tPHL Out-of-Phase Output (see Note D) 3V 1.3 V VOLTAGE WAVEFORMS SETUP AND HOLD TIMES 3V Input th VOL + 0.5 V tPHZ VOH 1.3 V VOH − 0.5 V ≈1.5 V VOLTAGE WAVEFORMS ENABLE AND DISABLE TIMES, 3-STATE OUTPUTS NOTES: A. CL includes probe and jig capacitance. B. All diodes are 1N3064 or equivalent. C. Waveform 1 is for an output with internal conditions such that the output is low, except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high, except when disabled by the output control. D. S1 and S2 are closed for tPLH, tPHL, tPHZ, and tPLZ; S1 is open and S2 is closed for tPZH; S1 is closed and S2 is open for tPZL. E. Phase relationships between inputs and outputs have been chosen arbitrarily for these examples. F. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO ≈ 50 Ω, tr ≤ 1.5 ns, tf ≤ 2.6 ns. G. The outputs are measured one at a time, with one input transition per measurement. Figure 2. Load Circuits and Voltage Waveforms 8 XL74LS04 SOP14/XD74LS04/DIP14 XD54LS04 DIP14 9 XL74LS04 SOP14/XD74LS04/DIP14 XD54LS04 DIP14 10
XD74LS04 价格&库存
很抱歉,暂时无法提供与“XD74LS04”相匹配的价格&库存,您可以联系我们找货
